Acoustic Energy Rolls Out AE320² Loudspeakers: Big Sound, Slim Cabinet, Proper British Swagger
Acoustic Energy’s AE320² floorstanders deliver impressive sound with innovative RSC cabinets, new paper/coconut drivers, and refined British design — a top contender for affordable mid-range speakers.
Acoustic Energy AE320-2 Floorstanding Loudspeakers in White Front Lifestyle
Acoustic Energy has officially expanded its reimagined 300 Series with the introduction of the AE320², a new floorstanding loudspeaker that draws from the company’s flagship Corinium series while staying firmly planted in the real-world price category. Known for models like the AE100 MK2 and the AE1 Active—both favorites of ours for their tonal balance and bang-for-the-buck appeal—Acoustic Energy is once again targeting budget-conscious audiophiles who want high-end sound without a five-figure invoice.
Mat Spandl, Managing Director of Acoustic Energy, commented “The development of the new 300 Series has been a journey of innovation and discovery. By leveraging the insights from our Corinium project, we have been able to push the boundaries of what is possible in loudspeaker design at this price point. Our goal was to create a speaker that not only delivers exceptional sound quality but also integrates seamlessly into modern living spaces. We believe the new AE320² achieves this and more.”
Acoustic Energy Corinium Loudspeakers in Black, White, Wood, Green
So…What the Hell Is “Corinium” and Why Should You Care?
Acoustic Energy keeps name-dropping “Corinium” like it’s some sacred British audio code, so let’s clear it up. Corinium was the Roman name for Cirencester—a charming Cotswolds town that’s been home to AE for over 25 years. Back in the day, it was the biggest Roman city outside of Londinium, and was the inspiration for AE’s most ambitious speaker to date: The Corinium.
Why does that matter? Because the trickle-down tech from AE’s flagship loudspeaker is now baked into the new AE320². That includes the upgraded cabinet, tweeter, and mid-bass driver tech—reengineered from the Corinium to perform at a far more accessible price point.
Let’s start with the tweeter. AE developed a new soft dome that’s actually lighter than carbon fiber. Translation? Faster transients, more detail, and less coloration. That same design sits behind a wide dispersion waveguide to give you a bigger sweet spot and more open, natural highs—without that grainy metallic edge you get in cheaper domes.
Acoustic Energy AE320² Loudspeakers in Walnut
The mid and bass drivers? They’re built using a super-rigid carbon fiber cone derived from AE’s 500 Series, now refined further for the Corinium with long-throw voice coils for better dynamics and slam. The new AE320² takes some of this DNA and gives it a paper/coconut-fiber twist—swapping out the carbon fiber for something smoother, but still quick on its feet. Think warmth and punch in equal measure.
Now, the cabinet. This isn’t your typical MDF box. The Corinium uses AE’s proprietary RSC (Resonance Suppression Composite) design—a hybrid of MDF and bitumen layering that damps internal vibrations and resonance. That same approach is used in the AE320², albeit slimmed down a bit. It’s a tech borrowed straight from AE’s Reference Series, and it lets the drivers breathe and perform cleanly, without boxy coloration.
For bass, the Corinium uses twin 165mm drivers in a wider cabinet, designed for speed and power—not just boom. While the AE320² isn’t quite as beefy, it still benefits from the same airflow-friendly port design and careful low-end tuning.
The bottom line? The Corinium is AE’s blueprint for high-end British loudspeaker design. And the AE320² is the budget-conscious benefactor of all that R&D—offering a real taste of flagship performance without forcing you to remortgage the cottage.
You can read more about our listening experience with the Acoustic Energy Corinium here.
Standing tall but not overbearing, the AE320² is designed for medium to large listening spaces. Available in matte walnut, black, or white with color-matched trim and upscale grille fabric, they look as good as they sound. The cabinets are finished in a durable “silk-touch” matte coating, and the solid aluminum outriggers keep things planted—even when you’re pushing them hard.
Acoustic Energy AE320² Specifications
  • Design: 3-way floorstanding loudspeaker
  • Midrange Driver: 120mm paper/coconut fibre cone
  • Bass Drivers: Dual 140mm paper/coconut fibre cones
  • Tweeter: 29mm soft dome (derived from the Corinium project)
  • Frequency Response: 30Hz – 29kHz
  • Sensitivity: 92dB (1W @ 1m)
  • Peak SPL: 118dB
  • Recommended Power Handling: Up to 200W
  • Crossover Frequencies: 240Hz / 2.8kHz
  • Nominal Impedance: 6 Ohms
  • Cabinet Technology: RSC™ (Resonance Suppression Composite), 18mm MDF/bitumen constrained layer
  • Grilles: Slim-fit magnetic cloth grilles
  • Dimensions (H x W x D): 1050 x 200 x 350mm (1070mm height including spikes)
  • Spike Thread Size: M8
  • Weight: 26kg each
  • Finish Options: Walnut veneer, ‘Silk-Touch’ Matte Black, or Matte White
Acoustic Energy AE320-2 Floorstanding Loudspeakers in Black
Acoustic Energy AE320-2 Floorstanding Loudspeakers in Walnut
The Bottom Line: An Affordable Rival to Q Acoustics, KEF, and Wharfedale
Acoustic Energy is playing the long game. By offering Reference-level build and tech under £1500, the AE320² becomes a very serious alternative to similarly priced loudspeakers from Q AcousticsKEF, and Wharfedale. While those brands dominate the conversation in mid-tier British hi-fi, Acoustic Energy keeps proving that it deserves to be in that conversation—if not leading it.
Keep an eye on Acoustic Energy later in 2025—they’re gearing up to celebrate a major milestone with a 40th Anniversary Edition of one of their most iconic loudspeakers. If you’re heading to the North West Audio Show in the UK, you might catch a sneak peek in about 10 days. We’ve already seen it—and yeah, it’s a real looker.
Pricing & Availability
The Acoustic Energy AE320² (aka AE320-2) will be available in late June 2025 from authorized retailers for about £1500. We’re still awaiting U.S. pricing.
For more information: acoustic-energy.co.uk
1 Comment
1 Comment
  1. Anton
    June 11, 2025 at 11:35 pm
    Really nice looking speakers and the price is quite reasonable
    Can you spill any more information about the 40th anniversary speaker? Price?
Grell OAE2 Open-Back Headphones Flat
Axel Grell’s OAE2 open-back headphones debut at CanJam NYC 2026 with a speaker-like soundstage concept. Can the $599 design change how we listen to...
Grado Labs Signature S550 Open-back Headphones Lifestyle Woman Grado Labs Signature S550 Open-back Headphones Lifestyle Woman
At $995, Grado's most affordable Signature Series open-back headphones feature new S2 drivers and cushion design with a Brazilian Walnut housing. Is this the...
Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black
Samsung Galaxy Buds4 Pro at $249.99 and Buds4 at $179.99 add AI live translation, enhanced ANC, and Galaxy optimized tech but are they worth...
iFi GO Link 2 Dongle DAC connected to laptops iFi GO Link 2 Dongle DAC connected to laptops
Dongle DACs
The $59 iFi GO link 2 USB-C Dongle DAC makes the case that smaller is better for hi-res audio listening, but what do you...
Q Acoustics Easyfit In-ceiling Speakers Lifestyle Q Acoustics Easyfit In-ceiling Speakers Lifestyle
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
Astell&Kern PD20 DAP Front and Back Angle Views Astell&Kern PD20 DAP Front and Back Angle Views
DAPs
Can the Astell&Kern PD20 redefine portable hi-fi with hearing based personalization and Triple AMP architecture for under $2000?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Loudspeakers
Fyne Audio is now offering bold custom colors to UK buyers. Have Scottish speakers decided beige is no longer brave enough?
Is ATC’s EL50 Anniversary the most compelling fully active 3-way tower under £50K for serious listeners seeking studio grade precision at home?
Børresen M8 Gold Signature is a $1,150,000 loudspeaker built in Denmark. Engineering breakthrough or high-end excess for the ultra wealthy?
Arendal Sound unveils the 1610 loudspeaker series bringing flagship inspired design and three way performance to a more accessible price point without cutting corners.
Which compact speaker sounds best on a desk? DALI, Q Acoustics, and Acoustic Energy go head-to-head.
ARCAM debuts the Radia Series loudspeakers at ISE 2026, returning to speakers with a premium-priced lineup for music and home cinema.
KLH Audio President David Kelley joins the podcast to discuss the company's history, loudspeaker design, today's product line and more.
JBL’s L100 Classic 80 is the L100 Classic MKII in anniversary clothing—same drivers and tuning, new finish, limited to 800 pairs worldwide.
