First revealed as a concept in 2009 and hitting the market in 2011, the KEF Blade has been the brand’s unapologetically bold flagship loudspeaker ever since — part sculpture, part sonic weapon. Now refreshed with the latest color finishes, the Blade continues to flaunt KEF’s cutting-edge 12th-generation Uni-Q driver array with Metamaterial Absorption Technology (MAT), proving that even after more than a decade, this British icon still knows how to make a statement — both visually and sonically.
Offered in two forms — the KEF Blade One Meta and Blade Two Meta — the design remains every bit the flagship it was meant to be. The Blade Two Meta trims the dimensions slightly, making it a bit more room-friendly, but both models stand tall as floor-standing monuments to KEF’s “no compromise” engineering ethos. Same DNA, same attitude — just different footprints.
KEF Blade Meta Series Introduces Striking New Color Options for 2025
For 2025, KEF decided it was time to give the Blade lineup a fresh coat of paint — literally. Both the Blade One Meta and Blade Two Meta now come in three new finishes designed to match the latest 2025/26 interior trends:
- Grigio – a sleek light-to-medium gloss metallic silver with a matching Uni-Q driver array.
- Garnet – a deep, wine-red gloss metallic finish that looks every bit as bold as it sounds.
- Sapphire – a rich gloss metallic blue that’s pure audiophile eye candy.
These new options join the existing Piano Black/Copper, Piano Black/Grey, Racing Red/Grey, and Arctic White/Champagne finishes — while KEF quietly retires Frosted Blue/Blue, Frosted Blue/Bronze, Charcoal Grey/Red, and Charcoal Grey/Bronze to the archives.
Available across North and South America, these updated colorways prove that even when your speaker design is already iconic, a little wardrobe update never hurts.
KEF Blade Meta Comparison
For anyone new to the KEF Blade Meta lineup, here’s the quick rundown: both models look identical at first glance, but size and scale set them apart. The Blade One Meta is the full-size statement piece, while the Blade Two Meta trims things down slightly for easier room integration — without watering down the flagship DNA. Below is a side-by-side look at their shared features and key specifications.
| Blade One Meta | Blade Two Meta | |
| Product Type | Floorstanding Speaker | Floorstanding Speaker |
| Price (pair) | $34,999.98 | $27,999.98 |
| Design | Three-way bass reflex Single apparent source | Three-way bass reflex Single apparent source |
| Drive units | Uni-Q driver array: HF: 25 mm (1 in.) aluminium dome with MAT MF: 125 mm (5 in.) aluminium cone Bass Units (LF): 4 x 225 mm (9 in.) aluminium cone,force cancelling | Uni-Q driver array: HF: 25 mm (1 in.) aluminium dome with MAT MF: 125 mm (5 in.) aluminium cone Bass Units (LF): 4 x 165 mm (6.5 in.) aluminium cone,force cancelling |
| Frequency Range Free Field (-6dB) | 27Hz – 45kHz | 30Hz – 45kHz |
| Frequency Range Typical in Room Bass Response (-6 dB) | 20Hz | 25Hz |
| Frequency response (±3dB) | 35Hz – 35kHz | 33Hz – 35kHz |
| Crossover frequency | 350Hz, 2kHz | 450Hz, 2.2kHz |
| Amplifier Requirements | 50-400W | 50-400W |
| Sensitivity (2.83V/1m) | 88dB | 86dB |
| Harmonic distortion 2nd and 3rd harmonics (90dB, 1m) | <0.5% 40Hz – 100kHz <0.2% 200Hz – 2kHz <0.1% 2kHz – 20kHz | <0.5% 40Hz – 100kHz <0.2% 200Hz – 2kHz <0.1% 2kHz – 20kHz |
| Maximum output (SPL)(peak sound pressure level at 1m with pink noise) | 117dB | 116dB |
| Impedance | 4 Ω (min. 2.8 Ω) | 4 Ω (min. 3.2 Ω) |
| Dimensions – with plinth (HWD) | 1590 x 363 x 540 mm 62.5 x 14.3 x 21.2 in. | 1461 x 338 x 475 mm 57.5 x 13.3 x 18.7 in. |
| Weight | 57.2 kg (126 lbs.) | 35.5kg (77.8 lbs.) |
| Standard Finishes | Piano Black/Copper Piano Black/Grey Racing Red/Grey Arctic White/Champagne | Piano Black/Copper Piano Black/Grey Racing Red/Grey Arctic White/Champagne |
| New Finish Offerings (2025) | Grigio/Light/medium gloss metallic silver Garnet/Deep wine red, gloss metallic Sapphire/Gloss metallic blue | Grigio/Light/medium gloss metallic silver Garnet/Deep wine red, gloss metallic Sapphire/Gloss metallic blue |
| Dropped Finish Offerings (2025) | Frosted Blue/Blue Frosted Blue/Bronze Charcoal Grey/Red Charcoal Grey/Bronze | Frosted Blue/Blue Frosted Blue/Bronze Charcoal Grey/Red Charcoal Grey/Bronze |
The Bottom Line
At the end of the day, this move isn’t about reinventing the wheel — it’s about polishing the rims. KEF’s decision to refresh the Blade Series with new finishes follows a familiar pattern seen across the industry: change the color, keep the core. We’ve already watched KEF pull this trick with the LSX II, LS60 Wireless, and KC62 subwoofer, and now REL, Astell&Kern, and even McIntosh have joined the paint party. Sure, it’s fun to have options — Garnet, Grigio, Sapphire, or whatever shade your audiophile soul craves — but the real magic is still under the hood. A new finish might catch your eye, but it’s the sound that keeps you listening.
Price & Availability
- KEF Blade One Meta – $34,999.98 at KEF
- KEF Blade Two Meta – $27,999.98 at KEF
Related Reading
- KEF’s Q Series META Loudspeakers Featuring MAT Technology Have the Potential to Dominate Below $2,000
- KEF R Meta Series Loudspeakers Featuring MAT Technology Unveiled
- KEF Speakers Make Strange Bedfellows in Savoir’s $115,000 Bed
- KEF’s KC92 and Kube MIE Subwoofers Pack A Huge Punch In A Rather Small Package
Steve Carlos Kirk
October 25, 2025 at 6:16 am
KEF I don’t understand. I’ve pulled KEF apart and they’re the most basic contractor grade trash I’d never spec. This is all marketing BS – no one would ever mix an album on these, why would we listen to one on them?
