Pantec to 2700
Username: South2
Post Number: 32
Hi guys,
Questions:
Is this true there won't be any further files for pantec(clone of pansat 2500)?
Can pantec being a clone be converted into 2700 or is it just the original pansat that can be converted?
Will the remote for pantec work for the converted 2700?
Finally, I did some reading about conversion on different sites, but I'm getting confusing and inconsistent information. I would really appreciate if you guys can send me following info:
what cable to use,
what loader,
what files and in what sequence.
Thanks guys.
Username: Asharfi
Post Number: 1096
Yes, it's true that there will be NO files for PANSAT 2500 CLONES, such as FLUs, Pantecs, etc. From what I know, Pantecs are Pansat 2500 CLONES, am I right? If yes, then you can use my FLU-Pansat 2700 Converting Procedure and convert your unit to Pansat 2700. The remote should work!
Username: Rtap
FL
Post Number: 786
or you can use vortex files
Username: South2
Post Number: 33
Hi AV,
Thanks for quick response. Pantecs are pansat 2500 clones. Where can I find your files for conversion?
I hope it doesn't involve j-tagging as I'm comfortable in loading files but no j-tagging experience. Again if you could kindly provide the following info:
what cable to use,
what loader,
Thanks very much.
Username: Asharfi
Post Number: 1107
Here's the link to my thread : https://www.ecoustics.com/electronics/forum/home-video/389206.html
Read the first post by me
