Key morphing -2
Username: Nydas
Post Number: 3684
Till yesterday there was key morphing on the first number of Key 00 and of Key 01.
Since yesterday the key morphing has changed ot the second number.
The logic applied is the same.
Real_2nd_number = autorolled_2nd_number XOR 43H
I will publish the table in my second post for those who want to work from a table.
It is great to be able to use a table if you can't access the internet or the sites are busy.
Username: Nydas
Post Number: 3685
The DN ECM has changed only slightly in concept..
If you have new BIN since yesterday install it and it will correct the problem
If you do not have a new BIN, let the new keys roll in under the old BIN
and then turn autoroll off and change the second number of Key 00 and 2nd number of Key 01.
You can either use new key posted and do a manual change.
Or if you know hex arithmetic, do a XOR o\with 43 of the 2nd numbers as stated
Or use the table below on the second numbers.
Basically, the attention of the ECM has shifted from the first number in each key to the second number of each key
1st Digit ''' 2nd Digit --------- 1st Digit ''' 2nd Digit
0 = 4 .'''' 0 = 3 ---------------- 8 = C '''. 8 = B
1 = 5 .'''' 1 = 2 ---------------- 9 = D '''. 9 = A
2 = 6 .'''' 2 = 1 ---------------- A= E '''. A = 9
3 = 7 .'''' 3 = 0 ---------------- B = F '''. B = 8
4 = 0 .'''' 4 = 7 ---------------- C = 8 '''. C = F
5 = 1 .'''' 5 = 6 ---------------- D = 9 '''. D = E
6 = 2 .'''' 6 = 5 ---------------- E = A '''. E = D
7 = 3 .'''' 7 = 4 ---------------- F = B '''. F = E
Username: Flu_guy
Hi Nalin
I have been using the XOR 43 method ever since you first told us about it, it's generally faster than looking for the keys on the internet and I use windows calculator, in scientific mode, to do the arithnetic.
With regard to your new post above, I think what you are saying is that the second pair of Hex digits, in each key, is what is being morphed now instead of the first pair as before. Am I correct?
Username: Nydas
Post Number: 3703
htiek. Your are right. Ever since 17th August I had to take back my old Pansat 2500 clone back from a close relative and her use my Sonicview. I have been using the XOR 43H ever since. It was on the first byte (number) of each key and now they have shifted the attention to the second byte ornumber.
Username: Nydas
Post Number: 3704
Technical:
A XOR (exclusive OR)in binary arithmetic in Software is equivalent to the inverter logic of hardware.
0 XOR 0 is 0
0 XOR 1 is 1
1 XOR 0 is 1
1 XOR 1 IS 0
Currently we are using 43H against the unknow number. 43H is 0100 0011
Wherever in the binary representation of 43H there is a 1, that is the bit that will be inverted.
Any unknown binary number XORed with binary 1, gets inverted.
Username: Flu_guy
Thanks, it's so easy and fast, I am surprised that it hasn't caught on. I am still using 286T in my FLU and it works fine.
Username: Nydas
Post Number: 3711
There was this big talk about MAP 57 calls several months ago. So far what I have noticed is that after the keys come into your receiver from God (as opposed to entering them manually), a Map 57 call is made to alter some bits in the keys.
The people who are revising the BINs are trying to figure out an answer to the specific change made at a particular time. There should and would be a method of looking at the general way in which the alteration is taking place (usually a XOR operation) and devise a software patch inside the flash that looks at the Map call in operation, figures out what it is doing and act accordingly.
Anyway, I am going to try out the older BINs again and see in what way they behave under the current minor ECM. I am pretty certain that all the older BINs sin 281T would be valid now except for the same minor but identical defect. However, without testing I would not categorically say so.
Username: La_estrella
This is interesting, I was using 293T on my pansat 2500a clone, then I found a table to replace the first digit on the key. So I never upgraded the bin.
But know is two digits so the third and four digit of the key are changing, but also I thing first digit is still changing for my pansat.
So last time I second couple of digits where 96 and I changed by 53.
Looking to this table 9 is D and 6 is 5 ??
I will try this table tonight
Thanks
Username: Flu_guy
Post Number: 7
Hello Estrella & Nalin
What if the BIN in use already has some sort of anti-morphing correction built in, (like 294 and possibly 293), will not the keys it shows you, after rolling, be already altered, according to the method used when the BIN was made. Now that the rules have changed, with the second byte morphed instead of the first, at the receiver, both the first and the second byte could end up wrong because of this.
I am still using 286T which does not try to fix the keys and is therefore unaffected.
What do you think, does this make sense?
As you suggested, Nalin, some kind of adaptive BIN that could automatically adapt to these changes would be the best.
Ok I made the change to the last key 01 active
With my bin 293T the key came complete but the two second digits where wrong wich I changed to FE
I did not take note of the digits I replaced, So I could not compare with the XOR conversion.
With the adaptive thing I don't know, but remember that Ngv 2 is a scrambling system and very complicated.
But once you know the digits to replace the thing will be to enter this formula or replacement table to to be taken automatic once the key enters.
Unfortunatelly maybe this will require more memory that my poor pansat 2500a has. :-(
Username: Nydas
Post Number: 3718
From another site where I posted this, I found out that with the 293 BIN the first number is altered - bits 6 and 7 are inverted or XOR with C0 to get the correct.
With BIN 293 the second number is also altered but I do not have enough data to find the logical operation. If somebody is still using 293 or 293T, and I get the data re what came in and what it should have been and the positions in both the keys, I don't think it would be difficult to formulate a temporary rule.
Username: Amex
Post Number: 621
C&P
Nalin Nyda
Username: Nydas
Post Number: 3716
Posted on Wednesday, September 12, 2007 - 02:22 pm:
And it would be pointless to have TV if you did not have football.
Week 1
THU, SEP 6 HI PASSING HI RUSHING HI RECEIVING
Indianapolis 41, New Orleans 10 Manning 288 Addai 118 Wayne 115
SUN, SEP 9 HI PASSING HI RUSHING HI RECEIVING
Green Bay 16, Philadelphia 13 Favre 206 Westbrook 85 Driver 66
Houston 20, Kansas City 3 Schaub 225 Green 73 Johnson 142
Denver 15, Buffalo 14 Cutler 304 Henry 139 Walker 119
Pittsburgh 34, Cleveland 7 Anderson 184 Parker 109 Winslow 83
Carolina 27, St. Louis 13 Delhomme 201 Foster 94 Smith 118
Minnesota 24, Atlanta 3 Harrington 199 Peterson 103 Peterson 60
New England 38, NY Jets 14 Brady 297 Maroney 72 Moss 183
Washington 16, Miami 13 Campbell 222 Portis 98 Randle El 162
Tennessee 13, Jacksonville 10 Garrard 204 Brown 175 Northcutt 57
San Diego 14, Chicago 3 Rivers 190 Benson 42 Gates 107
Seattle 20, Tampa Bay 6 Hasselbeck 222 Alexander 105 Galloway 72
Detroit 36, Oakland 21 McCown 313 Bell 87 Curry 133
Dallas 45, NY Giants 35 Romo 345 Ward 89 Burress 144
MON, SEP 10 HI PASSING HI RUSHING HI RECEIVING
Cincinnati 27, Baltimore 20 McNair 203 McGahee 77 Johnson 95
San Francisco 20, Arizona 17 Smith 126 James 92 Battle 60
Week 2
SUN, SEP 16 TIME (ET) TV RESOURCES LOCATION
Buffalo at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field
Houston at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium
Atlanta at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium
New Orleans at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium
Green Bay at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium
San Francisco at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome
Cincinnati at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium
Indianapolis at Tennessee 1:00 PM CBS Tickets | Travel LP Field
Minnesota at Detroit 4:05 PM Fox Tickets | Travel Ford Field
Dallas at Miami 4:05 PM Fox Tickets | Travel Dolphin Stadium
Seattle at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium
NY Jets at Baltimore 4:15 PM CBS Tickets | Travel M&T Bank Stadium
Oakland at Denver 4:15 PM CBS Tickets | Travel Invesco Field
Kansas City at Chicago 4:15 PM CBS Tickets | Travel Soldier Field
San Diego at New England 8:15 PM NBC Tickets | Travel Gillette Stadium
MON, SEP 17 TIME (ET) TV RESOURCES LOCATION
Washington at Philadelphia 8:30 PM ESPN Tickets | Travel Lincoln Financial Field
Week 3
SUN, SEP 23 TIME (ET) TV RESOURCES LOCATION
Detroit at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field
Miami at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium
Buffalo at New England 1:00 PM CBS Tickets | Travel Gillette Stadium
Arizona at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium
St. Louis at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium
San Francisco at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field
Indianapolis at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium
San Diego at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field
Minnesota at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium
Cleveland at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum
Jacksonville at Denver 4:05 PM CBS Tickets | Travel Invesco Field
Cincinnati at Seattle 4:05 PM CBS Tickets | Travel Qwest Field
NY Giants at Washington 4:15 PM Fox Tickets | Travel FedEx Field
Carolina at Atlanta 4:15 PM Fox Tickets | Travel Georgia Dome
Dallas at Chicago 8:15 PM NBC Tickets | Travel Soldier Field
MON, SEP 24 TIME (ET) TV RESOURCES LOCATION
Tennessee at New Orleans 8:30 PM ESPN Tickets | Travel Superdome
Week 4
SUN, SEP 30 TIME (ET) TV RESOURCES LOCATION
Green Bay at Minnesota 1:00 PM Fox Tickets | Travel Metrodome
Oakland at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium
NY Jets at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium
Houston at Atlanta 1:00 PM CBS Tickets | Travel Georgia Dome
Chicago at Detroit 1:00 PM Fox Tickets | Travel Ford Field
Baltimore at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium
St. Louis at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium
Tampa Bay at Carolina 4:05 PM Fox Tickets | Travel Bank of America Stadium
Seattle at San Francisco 4:05 PM Fox Tickets | Travel Monster Park
Kansas City at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium
Pittsburgh at Arizona 4:15 PM CBS Tickets | Travel Cardinals Stadium
Denver at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome
Philadelphia at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium
MON, OCT 1 TIME (ET) TV RESOURCES LOCATION
New England at Cincinnati 8:30 PM ESPN Tickets | Travel Paul Brown Stadium
i½ Bye: Tennessee, New Orleans, Washington, Jacksonville
Week 5
SUN, OCT 7 TIME (ET) TV RESOURCES LOCATION
Miami at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium
Atlanta at Tennessee 1:00 PM Fox Tickets | Travel LP Field
Jacksonville at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium
NY Jets at NY Giants 1:00 PM CBS Tickets | Travel Giants Stadium
Carolina at New Orleans 1:00 PM Fox Tickets | Travel Superdome
Arizona at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome
Cleveland at New England 1:00 PM CBS Tickets | Travel Gillette Stadium
Seattle at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field
Detroit at Washington 1:00 PM Fox Tickets | Travel FedEx Field
Tampa Bay at Indianapolis 4:05 PM Fox Tickets | Travel RCA Dome
San Diego at Denver 4:15 PM CBS Tickets | Travel Invesco Field
Baltimore at San Francisco 4:15 PM CBS Tickets | Travel Monster Park
Chicago at Green Bay 8:15 PM NBC Tickets | Travel Lambeau Field
MON, OCT 8 TIME (ET) TV RESOURCES LOCATION
Dallas at Buffalo 8:30 PM ESPN Tickets | Travel Ralph Wilson Stadium
i½ Bye: Cincinnati, Oakland, Minnesota, Philadelphia
Week 6
SUN, OCT 14 TIME (ET) TV RESOURCES LOCATION
Minnesota at Chicago 1:00 PM Fox Tickets | Travel Soldier Field
Miami at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium
Washington at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field
Cincinnati at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium
Tennessee at Tampa Bay 1:00 PM CBS Tickets | Travel Raymond James Stadium
St. Louis at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium
Houston at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium
Philadelphia at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium
Carolina at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium
Oakland at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium
New England at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium
New Orleans at Seattle 8:15 PM NBC Tickets | Travel Qwest Field
MON, OCT 15 TIME (ET) TV RESOURCES LOCATION
NY Giants at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome
i½ Bye: Buffalo, Denver, Detroit, Indianapolis, Pittsburgh, San Francisco
Week 7
SUN, OCT 21 TIME (ET) TV RESOURCES LOCATION
Tennessee at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium
Baltimore at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium
Minnesota at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium
Tampa Bay at Detroit 1:00 PM Fox Tickets | Travel Ford Field
Arizona at Washington 1:00 PM Fox Tickets | Travel FedEx Field
San Francisco at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium
Atlanta at New Orleans 1:00 PM Fox Tickets | Travel Superdome
New England at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium
Kansas City at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum
NY Jets at Cincinnati 4:05 PM CBS Tickets | Travel Paul Brown Stadium
Chicago at Philadelphia 4:15 PM Fox Tickets | Travel Lincoln Financial Field
St. Louis at Seattle 4:15 PM Fox Tickets | Travel Qwest Field
Pittsburgh at Denver 8:15 PM NBC Tickets | Travel Invesco Field
MON, OCT 22 TIME (ET) TV RESOURCES LOCATION
Indianapolis at Jacksonville 8:30 PM ESPN Tickets | Travel ALLTEL Stadium
i½ Bye: Cleveland, Green Bay, San Diego, Carolina
Week 8
SUN, OCT 28 TIME (ET) TV RESOURCES LOCATION
Indianapolis at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium
Cleveland at St. Louis 1:00 PM CBS Tickets | Travel Edward Jones Dome
NY Giants at Miami 1:00 PM Fox Tickets | Travel
Philadelphia at Minnesota 1:00 PM Fox Tickets | Travel Metrodome
Pittsburgh at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium
Detroit at Chicago 1:00 PM Fox Tickets | Travel Soldier Field
Oakland at Tennessee 1:00 PM CBS Tickets | Travel LP Field
Buffalo at NY Jets 4:05 PM CBS Tickets | Travel Giants Stadium
Jacksonville at Tampa Bay 4:05 PM CBS Tickets | Travel Raymond James Stadium
Houston at San Diego 4:05 PM CBS Tickets | Travel Qualcomm Stadium
New Orleans at San Francisco 4:15 PM Fox Tickets | Travel Monster Park
Washington at New England 4:15 PM Fox Tickets | Travel Gillette Stadium
MON, OCT 29 TIME (ET) TV RESOURCES LOCATION
Green Bay at Denver 8:30 PM ESPN Tickets | Travel Invesco Field
i½ Bye: Atlanta, Dallas, Kansas City, Arizona, Seattle, Baltimore
Week 9
SUN, NOV 4 TIME (ET) TV RESOURCES LOCATION
Denver at Detroit 1:00 PM CBS Tickets | Travel Ford Field
San Francisco at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome
Cincinnati at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium
Carolina at Tennessee 1:00 PM Fox Tickets | Travel LP Field
Green Bay at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium
San Diego at Minnesota 1:00 PM CBS Tickets | Travel Metrodome
Jacksonville at New Orleans 1:00 PM CBS Tickets | Travel Superdome
Washington at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium
Arizona at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium
Seattle at Cleveland 4:05 PM Fox Tickets | Travel Cleveland Browns Stadium
New England at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome
Houston at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum
Dallas at Philadelphia 8:15 PM NBC Tickets | Travel Lincoln Financial Field
MON, NOV 5 TIME (ET) TV RESOURCES LOCATION
Baltimore at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field
i½ Bye: Chicago, St. Louis, Miami, NY Giants
Week 10
SUN, NOV 11 TIME (ET) TV RESOURCES LOCATION
Cleveland at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field
Philadelphia at Washington 1:00 PM Fox Tickets | Travel FedEx Field
Atlanta at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium
St. Louis at New Orleans 1:00 PM Fox Tickets | Travel Superdome
Buffalo at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium
Denver at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium
Jacksonville at Tennessee 1:00 PM CBS Tickets | Travel LP Field
Minnesota at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field
Cincinnati at Baltimore 4:05 PM CBS Tickets | Travel M&T Bank Stadium
Dallas at NY Giants 4:15 PM Fox Tickets | Travel Giants Stadium
Detroit at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium
Chicago at Oakland 4:15 PM Fox Tickets | Travel McAfee Coliseum
Indianapolis at San Diego 8:15 PM NBC Tickets | Travel Qualcomm Stadium
MON, NOV 12 TIME (ET) TV RESOURCES LOCATION
San Francisco at Seattle 8:30 PM ESPN Tickets | Travel Qwest Field
i½ Bye: New England, NY Jets, Tampa Bay, Houston
Week 11
SUN, NOV 18 TIME (ET) TV RESOURCES LOCATION
Cleveland at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium
San Diego at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium
Miami at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field
Pittsburgh at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium
Oakland at Minnesota 1:00 PM CBS Tickets | Travel Metrodome
Kansas City at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome
Carolina at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field
Washington at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium
Tampa Bay at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome
New Orleans at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium
New England at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium
Arizona at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium
NY Giants at Detroit 4:15 PM Fox Tickets | Travel Ford Field
St. Louis at San Francisco 4:15 PM Fox Tickets | Travel Monster Park
Chicago at Seattle 8:15 PM NBC Tickets | Travel Qwest Field
MON, NOV 19 TIME (ET) TV RESOURCES LOCATION
Tennessee at Denver 8:30 PM ESPN Tickets | Travel Invesco Field
Week 12
THU, NOV 22 TIME (ET) TV RESOURCES LOCATION
Green Bay at Detroit 12:30 PM Fox Tickets | Travel Ford Field
NY Jets at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium
Indianapolis at Atlanta 8:15 PM NFL Tickets | Travel Georgia Dome
SUN, NOV 25 TIME (ET) TV RESOURCES LOCATION
Seattle at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome
Minnesota at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium
Buffalo at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium
New Orleans at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium
Washington at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium
Houston at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium
Tennessee at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium
Denver at Chicago 1:00 PM CBS Tickets | Travel Soldier Field
Oakland at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium
San Francisco at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium
Baltimore at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium
Philadelphia at New England 8:15 PM NBC Tickets | Travel Gillette Stadium
MON, NOV 26 TIME (ET) TV RESOURCES LOCATION
Miami at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field
Week 13
THU, NOV 29 TIME (ET) TV RESOURCES LOCATION
Green Bay at Dallas 8:15 PM NFL Tickets | Travel Texas Stadium
SUN, DEC 2 TIME (ET) TV RESOURCES LOCATION
San Diego at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium
Houston at Tennessee 1:00 PM CBS Tickets | Travel LP Field
Jacksonville at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome
Buffalo at Washington 1:00 PM CBS Tickets | Travel FedEx Field
San Francisco at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium
Detroit at Minnesota 1:00 PM Fox Tickets | Travel Metrodome
NY Jets at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium
Atlanta at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome
Seattle at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field
Tampa Bay at New Orleans 1:00 PM Fox Tickets | Travel Superdome
Cleveland at Arizona 4:05 PM CBS Tickets | Travel Cardinals Stadium
Denver at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum
NY Giants at Chicago 4:15 PM Fox Tickets | Travel Soldier Field
Cincinnati at Pittsburgh 8:15 PM NBC Tickets | Travel Heinz Field
MON, DEC 3 TIME (ET) TV RESOURCES LOCATION
New England at Baltimore 8:30 PM ESPN Tickets | Travel M&T Bank Stadium
Week 14
THU, DEC 6 TIME (ET) TV RESOURCES LOCATION
Chicago at Washington 8:15 PM NFL Tickets | Travel FedEx Field
SUN, DEC 9 TIME (ET) TV RESOURCES LOCATION
Carolina at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium
NY Giants at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field
Pittsburgh at New England 1:00 PM CBS Tickets | Travel Gillette Stadium
St. Louis at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium
Tampa Bay at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium
Miami at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium
Oakland at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field
Dallas at Detroit 1:00 PM Fox Tickets | Travel Ford Field
San Diego at Tennessee 1:00 PM CBS Tickets | Travel LP Field
Minnesota at San Francisco 4:05 PM Fox Tickets | Travel Monster Park
Arizona at Seattle 4:05 PM Fox Tickets | Travel Qwest Field
Cleveland at NY Jets 4:15 PM CBS Tickets | Travel Giants Stadium
Kansas City at Denver 4:15 PM CBS Tickets | Travel Invesco Field
Indianapolis at Baltimore 8:15 PM NBC Tickets | Travel M&T Bank Stadium
MON, DEC 10 TIME (ET) TV RESOURCES LOCATION
New Orleans at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome
Week 15
THU, DEC 13 TIME (ET) TV RESOURCES LOCATION
Denver at Houston 8:15 PM NFL Tickets | Travel Reliant Stadium
SAT, DEC 15 TIME (ET) TV RESOURCES LOCATION
Cincinnati at San Francisco 8:15 PM NFL Tickets | Travel Monster Park
SUN, DEC 16 TIME (ET) TV RESOURCES LOCATION
Jacksonville at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field
Atlanta at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium
Seattle at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium
Green Bay at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome
Baltimore at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium
NY Jets at New England 1:00 PM CBS Tickets | Travel Gillette Stadium
Arizona at New Orleans 1:00 PM Fox Tickets | Travel Superdome
Buffalo at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium
Tennessee at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium
Indianapolis at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum
Detroit at San Diego 4:15 PM Fox Tickets | Travel Qualcomm Stadium
Philadelphia at Dallas 4:15 PM Fox Tickets | Travel Texas Stadium
Washington at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium
MON, DEC 17 TIME (ET) TV RESOURCES LOCATION
Chicago at Minnesota 8:30 PM ESPN Tickets | Travel Metrodome
Week 16
THU, DEC 20 TIME (ET) TV RESOURCES LOCATION
Pittsburgh at St. Louis 8:15 PM NFL Tickets | Travel Edward Jones Dome
SAT, DEC 22 TIME (ET) TV RESOURCES LOCATION
Dallas at Carolina 8:15 PM NFL Tickets | Travel Bank of America Stadium
SUN, DEC 23 TIME (ET) TV RESOURCES LOCATION
Oakland at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium
Washington at Minnesota 1:00 PM Fox Tickets | Travel Metrodome
Miami at New England 1:00 PM CBS Tickets | Travel Gillette Stadium
Philadelphia at New Orleans 1:00 PM Fox Tickets | Travel Superdome
Kansas City at Detroit 1:00 PM CBS Tickets | Travel Ford Field
Cleveland at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium
Green Bay at Chicago 1:00 PM Fox Tickets | Travel Soldier Field
NY Giants at Buffalo 1:00 PM Fox Tickets | Travel Ralph Wilson Stadium
Houston at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome
Atlanta at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium
Baltimore at Seattle 4:15 PM CBS Tickets | Travel Qwest Field
NY Jets at Tennessee 4:15 PM CBS Tickets | Travel LP Field
Tampa Bay at San Francisco 8:15 PM NBC Tickets | Travel Monster Park
MON, DEC 24 TIME (ET) TV RESOURCES LOCATION
Denver at San Diego 8:00 PM ESPN Tickets | Travel Qualcomm Stadium
Week 17
SAT, DEC 29 TIME (ET) TV RESOURCES LOCATION
New England at NY Giants 8:15 PM NFL Tickets | Travel Giants Stadium
SUN, DEC 30 TIME (ET) TV RESOURCES LOCATION
Buffalo at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field
Cincinnati at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium
Pittsburgh at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium
Dallas at Washington 1:00 PM Fox Tickets | Travel FedEx Field
Carolina at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium
Tennessee at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome
New Orleans at Chicago 1:00 PM Fox Tickets | Travel Soldier Field
Jacksonville at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium
Seattle at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome
Detroit at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field
San Francisco at Cleveland 1:00 PM Fox Tickets | Travel Cleveland Browns Stadium
Minnesota at Denver 4:15 PM Fox Tickets | Travel Invesco Field
San Diego at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum
St. Louis at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium
if not go to http://sports.espn.go.com/nfl/schedule?campaign=PSGeneral
Kansas City at NY Jets 8:15 PM NBC Tickets | Travel Giants Stadium
Username: Amex
Post Number: 622
Oops! I got it posted in the wrong place!
Username: Amex
Post Number: 623
C&P
Nalin Nyda
Username: Nydas
Post Number: 3716
Week 1
Week 2
Week 3
Week 4
Week 5
Week 6
Week 7
Week 8
Week 9
Week 10
Week 11
Week 12
Week 13
Week 14
Week 15
Week 16
Week 17
Username: Amex
Post Number: 624
Oops! I got it posted in the wrong place again!
Damn!
Username: Dimwitt
Post Number: 112
FCUKING GENIUS.
Username: Amex
Post Number: 625
. Upload
Nalin
I am using the 293T, today was 12:30 NOON east time
86: XX 1A XX ... I replaced by DF
96: XX 0F XX ... I replaced by CA
Regards
Username: Amex
Post Number: 626
C&P
Nalin Nyda
Username: Nydas
Post Number: 3716
Week 1
Week 2
Week 3
Week 4
Week 5
Week 6
Week 7
Week 8
Week 9
Week 10
Week 11
Week 12
Week 13
Week 14
Week 15
Week 16
Week 17
Username: Amex
Post Number: 627
maybe somethin' wrong with damn keyboard......
Username: Nydas
Post Number: 3721
Estrella :
293T BIN.
2nd number is being XORed with C5 hex.
Inverting bits 0,2,6 and 7
I am told that the first number is being XORed with C0
Today 6pm eastern time I confirmed that XORed number for my 293T is C5.
86: came as 29 26 XX .... 64 XORed 26 with C5 and everybody is watching now!
Thanks guys for this very instructional post! WOW!
Just change 26 by E3 and you are done!
Regards
Username: Flu_guy
Post Number: 8
Estrella & Nalin
FYI
The keys just changed on DN about 1/2hr ago and I can confirm that for good ole 286T, only the second byte in each key is altered and that the magic number for the XOR is still unchanged at 43H
Post Number: 7
Yes htiek,
you confirm 2 things:
1st --> XOR system works
2nd --> for each ben there is a different
comparison number: 286T -- 43H
293T -- C5H
any one with another bin???
Regards
Username: Flu_guy
Post Number: 9
Estrella
Yes, I agree
I think that most of the older bins should work with 43H because the Key Morphing thing did not start till fairly recently.
Perhaps someone else can confirm this?
Username: Nydas
Post Number: 3722
Estrella and htiek: Thanks for the input.
Don't forget it is 2nd byte on key 00 and key 01 when you use 294T - XOR with 43H. Same on 286T Bin.
What is the status of 1st byte with 293 BIN. Is it XORed with C0 or is left unaltered? On 294 and I presume on 286 the first byte is now unaltered, only the second byte affected.
Username: Flu_guy
Post Number: 10
Hi Nalin
On 286T it is just the second byte that is altered, at the moment.
Username: Flu_guy
Post Number: 11
Hi Nalin
Why am I seeing these funny characters between "1st digit" and "2nd digit" in your charts? see below:
0 = 4 .'''' 0 = 3
etc.
Are you aware of this?
Username: Nydas
Post Number: 3723
Ecoustics software does not allow more than one space, so to create a distance for a reasonably good looking table I had to put in ......
Post Number: 8
6am eastern time
Bin 293T status
only second couple changes, still XORing C5
Regards
Username: Flu_guy
Post Number: 12
Estrella
I guess that would be the 1AM EDT key change and as with you, no changes, still 43H with 286T
Username: Flu_guy
Post Number: 13
Hi Nalin
For your table, did you try disabling the HTML code in the message? I bet that's it!
Username: Nydas
Post Number: 3724
Tried disabling HTML, but did not work. Strange - it should have worked.
For users of Pansat 2500, clones and FLU
May also apply to other receivers not upgraded in last 3-4 days.
Let key roll in first with autoroll on or off
Turn autoroll off and change 2nd number in Key 00 and Key 01
If using BIN 294, 294T, 286, 286T
XOR 2nd number (byte) with 43 Hex or use this table.
1st Digit-------------2nd digit
0 < --- > 4''.0 < --- > 3
1 < --- > 5''.1 < --- > 2
2 < --- > 6''.2 < --- > 1
3 < --- > 7''.4 < --- > 7
8 < --- > C''5 < --- > 6
9 < --- > D'....6 < --- > 5
A < -- > E'.....8 < --- >B
B < -- > F'.'9 < --- >A
E < -- > A''C < --- >F
F < -- > B''D < -- > E
If using BIN 293 and 293T
XOR 2nd number (byte) with C5 Hex or use this table
1st Digit-----------2nd digit
0 < --- > C''.0 < --- > 5
1 < --- > D''.1 < --- > 4
2 < --- > E''.2 < --- > 7
3 < --- > F''.3 < --- > 6
4 < --- > 8''.8 < --- > D
5 < --- > 9''.9 < --- > C
6 < -- > A'.....A < --- > F
7 < -- > B'..'B < --- > E
Post Number: 9
This is fun, no need to wait for bins or keys!!!
Thanks again Nalin and Htiek good job!
Regards
Post Number: 10
Just a TIP
I found that Windows Calculator can be put in scientific mode
wich allows to calculate XOR easily!!!
I'am doing it with my Sony Clie scientific calculator!.
Regards
Username: Packet_storm
Post Number: 44
Idea for you !
Create a image and upload it to your posts.
Post Number: 45
Or even better yet use the systems Non-Breaking Space command.
Username: Flu_guy
Post Number: 14
Hi all
The table is good because you can print it out and keep it by the TV and it is strange that turning of HTML did not work, non breaking space should work though.
I have a HEX calculator too, an HP100LX, very old but still works perfectly.
Username: Nydas
Post Number: 3734
Packet Storm : Thanks for the tip. However, I tried the &nbsp; in my own work I had done several years ago using Arachnophilia, and with html enabled it still does not work.
I just tried the standard "Previous Top Next" html message that I have used a thousand times and it did not convert to html.
the center /center html command works.
I will experiment again when I have time.
Thanks again
Username: Flu_guy
Post Number: 15
Estrella
Yes it's marvellous isn't it, always faster than looking for the keys on the internet, (although we must be grateful that there are people out there that put them up for us). My wife and I used to have a little race to see who could get them faster, but she'e mostly given up now.
Thank you Nalin for sharing this technique with us.
Post Number: 47
1         2        3       4
4         3        2       1
It will work
Username: Flu_guy
Post Number: 16
Nalin's table looks good in Courier
see below:
1st Digit | ------- | 2nd digit
0 <---> 4 | ------- | 0 <---> 3
1 <---> 5 | ------- | 1 <---> 2
2 <---> 6 | ------- | 2 <---> 1
3 <---> 7 | ------- | 4 <---> 7
8 <---> C | ------- | 5 <---> 6
9 <---> D | ------- | 6 <---> 5
A <---> E | ------- | 8 <---> B
B <---> F | ------- | 9 <---> A
E <---> A | ------- | C <---> F
F <---> B | ------- | D <---> E
0 <---> C | ------- | 0 <---> 5
1 <---> D | ------- | 1 <---> 4
2 <---> E | ------- | 2 <---> 7
3 <---> F | ------- | 3 <---> 6
4 <---> 8 | ------- | 8 <---> D
5 <---> 9 | ------- | 9 <---> C
6 <---> A | ------- | A <---> F
7 <---> B | ------- | B <---> E
Username: Flatulant_kitty
Post Number: 367
Nice chart.
Verified for 293t.
Verified 289t same as 294t
Username: Annej
Thank you for the key code table. It works perfect. Although, I have a small problem. It takes around 10 minutes to see the new keys once the picture is lost. Can you please advise?
Post Number: 368
10 min isn't bad.
DEAL WITH IT.
3 min is good and 1 is better but 10 ain't bad and is normal.
Post Number: 11
Could take longer looking over the internet
Regards
Username: Flu_guy
Post Number: 18
Josh: I haven't really timed it but my FLU with 286T seems to take 5-10 mins usually, (it varies). By the way, does anybody know what the percent readout really means? mine will usually finish at anywhere from 250 to 560%
Username: Nydas
Post Number: 3735
On a Pansat clone it goes to 200-350%. At times I felt that by hurriedly turning the autoroll on, it comes in a bit faster. Then I go in, turn autoroll off and do the two XORed entries.
I know it does not take more than 3 minutes, because I remember a few days ago, somebody was just about to start a song, I missed it as the keys rolled in and when the picture was finally up, the judges were about to start pronouncing on his performance.
Username: Nydas
Post Number: 3738
XORind 2nd byte with 43H works so far with BIN 294T autorolls.
Post Number: 370
Ditto 293T
Username: Dolybell
Hi, I'm new as a member, but I've been watching the posts here several days ago and the tables posted works in my 2500 clone with 293. I know about hex and XOR, but I want someone to explain me the XOR with C5. Please.
Username: Zahirahmad
since last 3 days i need to put new keys after every few hours. is it with all or only with me?
i have viewsat extreme 2000.
and what r the new keyd?
Username: Flu_guy
Post Number: 19
Zahir:
Yes the keys are changing quite frequently right now on DN so this is normal.
I am not that familiar with the viewsat situation at the moment, however, I see that they introduced a new bin on the 11th September, so its possible it may solve your problem. You can get it here:
http://www.totalfta.com/
There is a thread in this forum specifcally for posting new keys and you can find it here:
https://www.ecoustics.com/electronics/forum/home-video/259083.html
Username: Flu_guy
Post Number: 20
Dolybel:
XOR with C5 means that bits 7,6,2 and 0 of the byte are inverted.
Instead of using the table, you can use the windows calculator, in scientific mode to do this operation. You can also switch modes back and forth between hex and binary to see how it all works out.
Hope this helps.
Username: Nydas
Post Number: 3740
You can use the table I have given or use the XOR formula
0 XOR 0 is 0
0 XOR 1 is 1
1 XOR 0 is 1
1 XOR 1 IS 0
On 286,289,294 BINs, the keys came in as
Key 00: EB 29 21 '' 2nd byte should be 6A
Key 01: 95 FE F5 '' 2nd byte should be BD
Hex Binary|'.........|Hex Binary
29 =0010 1001''|FE =1111 1110
43 =0100 0011''|43 =0100 0011 XOR byte is 43H
______________________________.
6A =0110 1010''|BD =1011 1101 Resulting Real values
On 293 BIN, the keys came in as
Key 00: EB AF 21 '' 2nd byte should be 6A
Key 01: 95 78 F5 '' 2nd byte should be BD
Hex Binary|'.......'|Hex Binary
AF =1010 1111''|78 =0111 1000
C5 =1100 0101''|C5 =1100 0101 XOR byte is C5H
Username: Nydas
Post Number: 3743
Estrella has suggested above the use of Windows Calculator. It is available from Start/Programs/accessories/calculator.
Choose Scientific calculator, and then choose HEX in the scientific calculator. Doing Hex arithmetic becomes very easy.
Username: Amex
Post Number: 652
THIS VERY IMPORTANT INFO
POSTED BY POCKET SPERM...........
Packet Storm
Post Number: 33
Posted on Thursday, September 13, 2007 - 01:05 pm:
Week 1
Week 2
Week 3
Week 4
&#65533; Bye: Tennessee, New Orleans, Washington, Jacksonville
Week 5
&#65533; Bye: Cincinnati, Oakland, Minnesota, Philadelphia
Week 6
&#65533; Bye: Buffalo, Denver, Detroit, Indianapolis, Pittsburgh, San Francisco
Week 7
&#65533; Bye: Cleveland, Green Bay, San Diego, Carolina
Week 8
&#65533; Bye: Atlanta, Dallas, Kansas City, Arizona, Seattle, Baltimore
Week 9
&#65533; Bye: Chicago, St. Louis, Miami, NY Giants
Week 10
&#65533; Bye: New England, NY Jets, Tampa Bay, Houston
Week 11
Week 12
Week 13
Week 14
Week 15
Week 16
Week 17
Username: Amex
Post Number: 653
IF YOU DIDNT HAVE A CHANCE TO READ IT THE FIRST TIME,
HERE IT IS AGAIN..........
Packet Storm
Post Number: 33
Week 1
Week 2
Week 3
Week 4
Week 5
Week 6
Week 7
Week 8
Week 9
Week 10
Week 11
Week 12
Week 13
Week 14
Week 15
Week 16
Week 17
Username: Lklives
Post Number: 12024
Oooops!...lmao
Username: Bill038
Post Number: 116
I missed the info the first 5 or 6 times it was posted, could you please post the nfl schedule again?
Username: Amex
Post Number: 654
MAYBE IF YOU ASK'IM, HE CAN POST IT AGAIN......
BUT RIGHT NOW HE'S KINDA BUSY..........
Username: Giantstretch
I have been out of satellite service for at least 4 years ... card is gone and I have a direct tv system .... what does the discussion about "keys" refer to? THanks,
Username: Nydas
Post Number: 3747
https://www.ecoustics.com/electronics/forum/home-video/350855.html
Bill Vickers Silver Member
Username: Bill038
Post Number: 116 Registered: Sep-06
The information you are looking for is posted in the following threads.
https://www.ecoustics.com/electronics/forum/home-video/386528.html
https://www.ecoustics.com/electronics/forum/home-video/387222.html
https://www.ecoustics.com/electronics/forum/home-video/388036.html
Username: Nydas
Post Number: 3754
0 XOR 0 is 0
0 XOR 1 is 1
1 XOR 0 is 1
1 XOR 1 IS 0
Username: Nydas
Post Number: 3755
Username: Amex
Post Number: 659
LATEST MLB SCHEDULE
JUST MOMENTS AGO...!!
( C&P )
Sunday, September 16, 2007
Away Home Result Winning Pitcher Losing Pitcher MLB.TV Audio
Royals Indians KC 4, CLE 3 Buckner (1-1) Laffey (3-2)
Orioles Blue Jays BAL 8, TOR 6 Bell (4-3) Frasor (1-5)
Phillies Mets PHI 10, NYM 6 Geary (3-2) Mota (2-2)
Braves Nationals ATL 3, WSH 0 Hudson (16-8) Hill (4-4)
Angels White Sox CWS 9, LAA 7 MacDougal (2-5) Moseley (4-3)
Reds Brewers MIL 5, CIN 2 Villanueva (8-4) Belisle (8-9)
Pirates Astros HOU 15, PIT 3 Backe (1-1) Maholm (10-15)
Tigers Twins DET 6, MIN 4 Jurrjens (3-1) Baker (9-8)
Cubs Cardinals CHC 4, STL 2 Marquis (12-8) Mulder (0-3)
Marlins Rockies COL 13, FLA 0
Giants Padres SD 5, SF 1 Peavy (18-6) Lincecum (7-5)
Devil Rays Mariners TB 9, SEA 2 Sonnanstine (5-9) Washburn (9-14)
Away Home Time (ET) Away Probable Home Probable MLB.TV Tickets
Rangers Athletics In progress Padilla (6-9) DiNardo (8-9)
D-Backs Dodgers In progress Gonzalez (7-2) Loaiza (2-1)
Yankees Red Sox 8:05 p.m. Clemens (6-6) Schilling (8-7)
Monday, September 17, 2007
Orioles Yankees 7:05 p.m. Cabrera (9-16) Hughes (3-3) Buy
Tigers Indians 7:05 p.m. Rogers (3-2) Byrd (15-6) Buy
Marlins Braves 7:05 p.m. Kim (9-6) Smoltz (13-7) Buy
Mets Nationals 7:05 p.m. Lawrence (1-2) Redding (3-5) Buy
Red Sox Blue Jays 7:07 p.m. Wakefield (16-10) McGowan (10-9) Buy
Reds Cubs 8:05 p.m. Arroyo (9-14) Hill (9-8) Buy
Brewers Astros 8:05 p.m. Gallardo (8-4) Albers (4-8) Buy
White Sox Royals 8:10 p.m. Vazquez (12-8) Davies (6-13) Buy
Phillies Cardinals 8:10 p.m. Kendrick (8-4) TBD Buy
Rangers Twins 8:10 p.m. Volquez (2-1) Slowey (3-0) Buy
Giants D-Backs 9:40 p.m. Correia (4-6) Webb (16-10) Buy
Pirates Padres 10:05 p.m. Van Benschoten (0-5) Cassel (0-0) Buy
Mariners Athletics 10:05 p.m. Batista (13-11) Haren (14-7) Buy
Devil Rays Angels 10:05 p.m. Jackson (4-14) Escobar (17-7) Buy
Tuesday, September 18, 2007
Dodgers Rockies GM 1: 3:05 p.m. Billingsley (11-4) Francis (15-8) Buy
Orioles Yankees 7:05 p.m. Leicester (2-1) TBD Buy
Tigers Indians 7:05 p.m. Verlander (17-5) Westbrook (5-9) Buy
Mets Nationals 7:05 p.m. Maine (14-9) Hanrahan (4-3) Buy
Red Sox Blue Jays 7:07 p.m. Lester (4-0) Burnett (8-7) Buy
Marlins Braves 7:35 p.m. Seddon (0-0) Reyes (0-2) Buy
Reds Cubs 8:05 p.m. Harang (15-4) Zambrano (16-12) Buy
Brewers Astros 8:05 p.m. Sheets (12-5) Paulino (0-0) Buy
White Sox Royals 8:10 p.m. Floyd (1-3) Meche (8-12) Buy
Phillies Cardinals 8:10 p.m. Hamels (14-5) TBD Buy
Rangers Twins 8:10 p.m. Millwood (9-12) Silva (11-14) Buy
Dodgers Rockies GM 2: 8:35 p.m. Wells (8-8) Redman (1-4) Buy
Giants D-Backs 9:40 p.m. Sanchez (1-4) Owings (6-8) Buy
Pirates Padres 10:05 p.m. Gorzelanny (14-7) Maddux (12-10) Buy
Mariners Athletics 10:05 p.m. Weaver (6-12) Gaudin (11-11) Buy
Devil Rays Angels 10:05 p.m. Hammel (2-4) Lackey (16-9) Buy
Username: Amex
Post Number: 660
PLAY BALL.....!!
LATEST MLB SCHEDULE
( C&P )
Username: Lklives
Post Number: 12038
Buy a new receiver (Sonicview 4000) for $150 or a Captiveworks premium for $99, and input the latest bin/file which will autoroll the keys ....so U do NOTHING, but WATCH TV...
This is barbaric ans primitive, this BS about figuring out the keys math....old school thinking there...its 2007 , not 1918.....
Post Number: 66
hexadecimal in 1918 ROLLING on the floor OH boy this guy LK to much. How can one be so clueless and make it through life.
Free-tvers rot and waste away sitting in front of a TV like yourself Warthog.
Testers work at it. Thats the fun.
Username: Nbn
Post Number: 209
who said anything about hex in 1918 ? besides the ignorant brown pieces of sh*t muslim denying paki storm
Post Number: 70
Learn to read first! Comprehension comes later.
in making reference to the years above on is comparing what is now and what was then.
Fish barrels oh what fun!
Username: Amex
Post Number: 666
WHAT A PATHETIC DOG.........
SOMEBODY SHOULD TAKE HIM FOR A "WALK".....
Username: Nydas
Post Number: 3778
0 XOR 0 is 0
0 XOR 1 is 1
1 XOR 0 is 1
1 XOR 1 IS 0
Username: Nydas
Post Number: 3779
