I said it on our 100th podcast: the biggest trend in headphones over the last four years isnβt just for travelersβitβs wireless with active noise cancellation (ANC) for everyone. Bluetooth, batteries, DSPβthese things have all gotten better, and todayβs wireless headphones deliver sound quality that, not long ago, would have seemed impossible. Even the dongle market, once red-hot when we started this podcast, has cooled. People have decided the convenience of wireless outweighs whatever tiny edge wired models might offer. After all, most of us donβt listen in some quiet, idealized audiophile cave. Weβre at work, on the train, stuck in the house with screaming kids, or in the den.
However, the wireless headphone market has matured fast, and the landscape in 2025 is very different from 2022, when the Focal Bathys racked up nearly every award a wireless headphone can win. Advances in Bluetooth, power management, and ANC processing mean older modelsβno matter how celebratedβstruggle to keep pace with todayβs top performers. Among the newer contenders are the Sony WH-1000XM6, the Bowers & Wilkins Px7 S3, and the Noble Fokus Apollo, all of which deliver excellent sound and features in their own right.
Not one to shy away from a challenge, Focal introduced the Bathys MG on May 26th, 2025. Anyone familiar with Focalβs lineup will recognize the MG badge from the Clear MG wired headphones, and for good reason: the Bathys MG shares the same M-shaped magnesium dome diaphragm first seen in the Clear MG, as well as the same chestnut-and-dark-copper colorway.
The new Bathys MG doesnβt replace the original Bathysβit carves out a new spot above it, both in performance and price. The Bathys will continue serving the mid-tier wireless crowd, while this new model, retailing at $1,499, takes aim squarely at high-end competitors like the Mark Levinson No. 5909 and DALI IO-12. Focal isnβt subtle about it: this is a statement headphone, and they expect it to be judged as such.
Focal Bathys MG Wireless Headphones: Comfort, Craftsmanship, and Durability
Externally, the Bathys MG closely resembles the original Bathys, aside from the copper-accented colorway, with familiar design language and controls in expected locations. Construction combines aluminum, magnesium, and leather, and with the mid-sized cups and redesigned headband and pads, weight is well distributed, resulting in very good comfort.
As with its predecessor, the Focal logo on the cup faces is backlit, illuminating on power-up and fully controllable via the companion app. Controls are minimal but functional: the left cup houses only the ANC button, positioned just below the rear gimbal attachment. The right cup is busier, featuring a three-way button beneath the rear gimbal (the center button also doubles as the pairing control), a three-position switch for off/DAC/on, a voice assistant button, a USB-C port, and a 3.5mm auxiliary input.
The included kit is straightforward and practical, consisting of a color-matched hard case, a USB-C cable, and a 3.5mm auxiliary cable.
Technology and Internals: Drivers, ANC, and Bluetooth Performance
Internally, the Bathys MG features upgraded electronics, including Bluetooth 5.2, improved ANC, and extended battery life. Bluetooth supports multi-point connectivity for use with multiple sources and is compatible with SBC, AAC, aptX Adaptive, and the step-down aptX codecs. While I would have liked to see Bluetooth LE, AptX Adaptive still delivers very good performance.
Battery life varies depending on usage. Focal advertises 30 hours in Bluetooth ANC mode, 35 hours in 3.5mm wired mode, and 42 hours in USB-DAC mode which aligns with our experience. Note that while DAC mode draws less power, the headphones do not charge and play simultaneously. Quick charge is supported, delivering roughly 5 hours of listening time from a 15-minute charge.
DAC mode also allows bypassing some of Bluetoothβs inherent limits, supporting 24-bit/192kHz lossless audio for listeners who want to extract the absolute maximum from the drivers.
The Bathys MG employs Focalβs legendary 40mm M-shaped magnesium dome drivers, with a frequency response of 10Hzβ22kHz and a THD of <0.2% at 1kHz. This driver design has been a cornerstone of Focalβs headphones and tweeters for years and has been continually refined. The magnesium version used here slots between the aluminum/magnesium hybrid driver of the original Bathys and the Beryllium driver found in the Utopia.
Those familiar with Focalβs Clear series will recall the Clear MG, which upgraded from an Al/Mg hybrid to a pure magnesium driver, delivering a substantial sound improvementβsetting high expectations for similar performance gains in the Bathys MG.
Volume control has also been improved, now moving in 3dB increments rather than the 5dB steps of the original Bathys. On the original, I occasionally found myself just a hair off the perfect level, so the narrower increments here are a welcome, precise adjustment.
Control App
The Focal app extends the Bathys MGβs controls, offering EQ and sound personalization, as well as sidetone adjustment for calls. Overall, the app is simpler than some of the more feature-rich options, like Sennheiserβs, but I appreciate the combination of presets and custom tuning via the EQ and sound personalization.
That said, I do wish it offered a true parametric EQ. It never failsβif I want to lift 1.5kHz, the app only gives me 1kHz and 4kHz bands, which either cover too wide a range or leave the target frequency at the edge of the band. To reach the desired level, I often have to crank the bandβs center to absurd levels. A small frustration, but one that doesnβt negate the appβs usefulness.
Focal Bathys MG Wireless Headphones ANC Performance
Focal has always been upfront about ANC on the original Bathys: the goal was never miracles, just enough noise reduction to make listening more pleasant without compromising sound quality. The Bathys MG follows the same philosophyβfirst, βdo no harm,β and then reduce noise.
Having experienced the original Bathys, I expected more of the sameβbut the MG pleasantly surprised me with noticeably improved ANC. There are three modes: Transparent, Soft, and Silent. Importantly, there is no true off setting; the headphones must remain powered because the signal always passes through the DSP, regardless of input path. USB or 3.5mm modes donβt amplify outside sounds like Transparent, but they still require power to operate. Transparent lifts voices from the environment clearly, making it easy to hear conversations when music isnβt playingβmuch more effective than passive isolation alone.
Soft mode attenuates low-frequency noise well but struggles as sounds move into the mids. Predictable noises, like a steady whistle, are handled nicely, but unpredictable soundsβlike a baby cryingβstill cut through with some regularity. Silent mode performs similarly, more effectively removing top and bottom frequencies than mids. In busy environments with multiple conversations, some noise will still get through. Itβs reduced, yes, but compared to top ANC models, itβs a step back.
If your goal is the maximum possible noise reduction, Sony and Bose still leadβbut donβt expect them to match the sound quality of the original Bathys or the MG. For anyone who prioritizes keeping noise manageable while preserving the best audio fidelity, the Bathys series remains a top choice.
Focal Bathys MG Wireless Headphones Listening Notes
Many readers know I usually cover ANC after discussing the sound signatureβor during the listening notesβbecause switching ANC modes often alters how headphones sound. That isnβt the case here. With the Bathys MG, changing ANC modes made no discernible difference to the audio. Thatβs a rare achievement in wireless headphones and something Focal deserves real credit for.
Another positive: if the default tuning isnβt to your taste, the app offers some flexibility. The Dynamic preset closely mirrors the Harman target, while the built-in 5-band EQ allows you to fine-tune things to land somewhere between the preset curves. Itβs not the deepest customization, but itβs enough to adapt the signature without sacrificing Focalβs core sound.
Sub-bass presence is improved over the original Bathys, though texture below about 30Hz still leaves a little to be desired. Above that mark, things tighten up considerablyβtextures become more convincing, definition improves, and the Bathys MG delivers a low-end that feels deliberate and well curated. Detail is strong, rumble shows up when called for without overstaying its welcome, and the driverβs speed keeps even the heaviest hits from turning sloppy.
The mid-bass is where the Bathys MG really shines. Kick drums carry satisfying slam without smearing, while string bass retains a natural, believable tone. Either of these is difficult to pull offβdrums demand snap and agility, bass lines demand weight and fluidityβbut the Bathys MG manages both in the same driver. That balance alone speaks to the refinement of the design.
The lower mids continue the tonal balance established in the mid-bass, carrying good weight and timbre with just a touch of warmth that adds to the musicality. Strings sound fluid and natural, while guitar growl has the grit and bite it should.
Moving upward, the Bathys MG proves versatile across genres. Strings retain energy without tipping into stridency, vocals come through clean and well-weighted without drifting nasal, and piano tone lands convincingly realistic. There is a slight lift in the upper midsβthese arenβt ruler-flat monitorsβso purists may grumble about the coloration. But in practice, I found the deviation from neutral enhanced rather than detracted from the experience.
I pushed the Bathys MG with tracks as varied as Haydnβs Opus 76 No. 1, Van Halenβs βEruption,β and Beth Hartβs “Damn Your Eyes,” and the mids held their ground every time. No weaknesses surfaced, and the presentation felt consistently engaging.
The lift in the upper mids carries into the lower treble, and this is the first part of the Bathys MGβs signature where the praise becomes a bit more measured. The fluidity present in the lower ranges gives way to a more assertive, occasionally sharp character. Itβs not that the Bathys MG is inherently bright or harshβmost of the time it isnβtβbut every so often Hyde slips through Jekyll. On tracks mastered hot, the MG leans in, and fatigue can set in.
Percussion benefits here, with snare hits carrying excellent snap, but cymbals are more hit-or-missβsome recordings sound crisp and well defined, others come off too hot. Thatβs likely not the headphoneβs fault so much as a mirror reflecting questionable mastering choices. Still, for treble-shy listeners or those with a library full of bright recordings, the Bathys MG may occasionally push into uncomfortable territory.
The Bathys MG presents a soundstage that feels natural in scale, with slightly more width than depth and a convincing sense of height. On my go-to test track, βSo Lonelyβ by the Cowboy Junkies, echoes landed at the right anglesβaccurate if not reaching into the cavernous depths an HD800 can conjure.
Orchestral seating showed no gaps or odd placements, and instrument separation proved excellent, as expected at this level. Imaging is also precise, with movements easy to follow and positions locked firmly in space. While it doesnβt push into exaggerated expansiveness, the Bathys MG delivers a well-proportioned, realistic stage that keeps the music engaging and immersive.
The Bottom Line
The Focal Bathys MG is a complicated beastβin the best way. Sonically, itβs outstanding, with clear improvements in sound quality and ANC that fully justify its premium asking price. While the absence of Bluetooth LE or LDAC feels like a missed opportunity, the supplied codecs deliver more than enough fidelity to satisfy serious listeners.
The real complication lies in the branding. By calling it βBathys,β Focal has set expectations for it to be a direct, twice-the-price upgrade over the original. That comparison doesnβt always do the MG justice, as it arguably deserves its own identity. Add to that the polarizing βDynamicβ EQ option, and youβve got a headphone that will spark debate depending on which camp youβre in.
All that aside, the Focal Bathys MG is, simply put, the best-sounding wireless headphone available today. If you have the budget, itβs worth every consideration. Just approach it on its own terms, not as a sibling to the original Bathysβand youβll hear exactly why it commands the crown.
Pros:
- Redesigned headband and pads improve long-term comfort
- Detailed, fluid sound with excellent imaging and separation
- Choice of sound signatures, including the βDynamicβ EQ option
- Effective ANC that preserves the headphoneβs core sound quality
- Premium build and sonic performance that justify its high-end status
Cons:
- Expensive, with a price nearly double the original Bathys
- Limited app functionality and basic EQ controls
- No Bluetooth LE or LDAC support, restricting wireless codec options
- Branding as βBathysβ sets unfair expectations against its predecessor
Where to buy:
Related Reading:
- Podcast: Best Wireless Headphones & Earbuds Of 2025
- Bowers & Wilkins Px7 S3 Headphones: Better Sound, Better Noise Cancellation, But At What Cost?
- Sony WH-1000XM6 Wireless Noise Cancelling Headphones β The New High Bar?
- Mark Levinson No. 5909 Wireless Headphones: Review
Zoltan Andrusecz
February 15, 2026 at 1:24 pm
Spot on article.
I sat in Richer Sounds’ quiet listening room for 2.5 hours trying out all their headsets without looking up their price or reviews first to not prejudice my decision.
I choose based on purely my listening experience, tried lots of wired and wireless options (I used a USB cable with these for best sounds quality). I walked out with the Focal Bathys MG as that was the best with all really wide range of the different genres I listen to.
All this with the default tuning! No EQ was used for my testing.
Their default tuning is very close to the Harman target curve. But so was the Sennheiser HDB630 which all the reviewers are raving about yet it sounded very underwhelming to me. Yes you can EQ all headsets but they’ll never sound like the Bathys MG out of the box, their sound signature is like magic.
It beat the wired competition as well. Tried it with Bluetooth and I must say it’s veeery close to the wired DAC mode so you get the benefit of wireless as well AND it has ANC which is a nice bonus.
All this before I discovered that you can use their app to run a hearing test to create a personalised profile that took the sound next level for me π€―
Oh yeah and these Focal Bathys MGs look gorgeous π
