Cambridge Audio’s MXW70 is So Compact It Might Just Start a Class D Rebellion in Your Sock Drawer: The Cabin Audiophiler
The MXW70 shoves 70-watts of Class D power into a half-width amplifier. No screen, no ego, just clean sound for folks who know gear isn’t the story, the music is.
Cambridge Audio MXW70 Amplifier atop MXN10 Streamer Lifestyle
At some point, even die-hard full-rack separatists like me have to admit the obvious: space isn’t what it used to be. When your life gets split between a Zook A-Frame ADU cabin on the Shore, a ranch on Florida’s Treasure Coast, and another dwelling in the Garden State—each charming, each compact—the hi-fi rig needs to evolve. The combined square footage of all three is nearly identical to my old home, but thirty years of high-end system purchases didn’t get the memo. That’s where the rebellion begins. Meet the Cambridge Audio MXW70.
Cambridge Audio just joined the half-width uprising—and they didn’t come bearing peace offerings. The new MXW70 power amp is a Class D sniper, aimed directly at WiiM, NAD, Bluesound, Marantz, and SMSL. If you thought the compact amp game was settled, Cambridge just kicked the tea table over.
Cambridge Audio MXW70, DacMagic 200M, and MXN10 Streamer
Designed to lock arms with the MXN10 streamer—which quietly gained digital preamp functionality while the rest of the hi-fi world argued over filters and DAC topology—the MXW70 doesn’t care about your bookshelf aesthetic. It’s not here to look cute. It’s here to do the job. Half-width, full control via the StreamMagic app, and enough Class D muscle to make legacy gear feel bloated. It doesn’t need to prove anything. It just works—tight, focused, and very British in its refusal to over-explain.
I’m sure there are still a few holdouts clutching their toroidal transformers and bemoaning the rise of Class D (none of us care), but based on the overwhelmingly positive response to our recent features on the evolution of Class D—from $130 desktop amps to $50,000 reference monoblocks—it’s clear most of you can see the proverbial forest for the trees. You get it: a compact amp like the MXW70, one that won’t be pampered in a ventilated rack, needed to be this way.
It’ll stay relatively cool—because the notion that Class D can’t sound musical unless it’s wrapped in a $10,000 billet aluminum enclosure is tired. Cambridge knows this. So they kept it simple. Smart topology, good parts, tuned by people who actually listen. The result? An amp that behaves like it belongs in the big leagues but fits on a bookshelf without setting off a smoke alarm.
Cambridge Audio MXW70 Amplifier angle
Cambridge Audio MXW70: Compact Class D Muscle With No Patience for Your Full-Size Excuses
Cambridge Audio didn’t build the MXW70 to win beauty contests. This half-width power amp was designed for tight spaces and tighter tolerances—where ventilation is limited, shelf space is rationed, and sound quality still matters. At just 215mm wide, it looks polite. It isn’t.
You get 70 watts per channel into 8 ohms, 100 into 6, and if you throw it into bridged mono mode, it delivers 250 clean watts into 8 ohms. That’s not theoretical output measured on a cold Canadian morning—it’s actual, usable power thanks to Hypex NCORE Class D modules and Cambridge’s no-BS tuning.
Some Class D amps still sound like lab experiments in progress. This doesn’t. The MXW70 brings clarity, grip, and composure without crossing into sterile territory. It’s neutral without being boring, efficient without sounding dry. And most importantly, it doesn’t flinch when asked to drive real loudspeakers in real rooms.
There are no dials, no glowing tubes, and no vintage cosplay to distract you. Just a steel box that does the work and keeps its mouth shut.
System Building: The Half-Width Path to Glory (and a Few Caveats)
Cambridge Audio MXW70 Rear
Connectivity? You’re covered. RCA and studio-grade XLR inputs mean the MXW70 doesn’t throw a tantrum when paired with non-Cambridge gear. Whether you’re building a straightforward stereo setup or integrating it into something more complex, it plays nice. Standard 4mm banana plugs make speaker hookup idiot-proof, and there’s even a 12V trigger with pass-through—plus a USB auto-on/off cable that syncs with the MXN10 via the StreamMagic app. Translation: fire up your streamer, and the amp wakes up without demanding your attention like a neglected housecat.
Stack it with the DacMagic 200M and you’ve got a sleek little tower of British engineering—high-res capable, compact, and finished in Lunar Grey aluminum that looks more boutique than budget. You get a proper volume knob (hallelujah), headphone output, and every digital input you could ask for. Just don’t come looking for analog inputs—because none of these units (MXN10, CXN100, or the DacMagic 200M) give you one. So if you’ve got a turntable with a built-in phono stage, tough luck unless you get creative with a Bluetooth transmitter.
Enter Cambridge’s own Alva ST or TT V2 turntables with Bluetooth aptX (with the TT V2)—they’ll play nicely with the DacMagic 200M wirelessly, which isn’t purist-approved but still better than doing nothing. Or, if you want to stay under budget and still add analog sources, the WiiM Ultra has analog outs, a solid interface, and real preamp functionality. Not exactly a gentleman’s solution, but neither was trench warfare—and look how that turned out.
Bottom line: you can build a real system here. Just don’t expect it to accommodate your 2023 Luxman phono stage without a little strategic thinking.
Speaker Matching: Choose Your Fighter
Let’s be honest: no one’s buying the Cambridge Audio MXW70 to drive a $10K speaker system in a purpose-built listening room with oxygen-free feng shui. This amp is for those of us building something smarter—more modest, maybe, but designed to last.
If you’re spending $2,000 to $3,000 on a system—including speakers, source, and cables—you want it to work. You want to enjoy music, not chase your own tail upgrading every six months because something “lacks slam.” That’s who this amplifier is for. Set it up, forget about it, and let it disappear into your day—precisely what Cambridge Audio wants. No sonic fireworks. Just solid performance, long-term satisfaction, and none of the nervosa.
Q Acoustics 3020c Stand-mount loudspeaker pair in pin oak
Q Acoustics 3020c Stand-mount loudspeakers in Pin Oak
With the Q Acoustics 3020c, it’s a lovely balance—easy to drive, sonically composed, and tonally even. A small-space killer. Add a decent streamer or DAC, and you’re well into hi-fi without triggering a midlife crisis.
The Wharfedale EVO 5.1 and Denton 85 step things up a notch in terms of body and warmth. The MXW70 holds its own, but let’s not pretend it’s swinging Thor’s hammer here. At sane volumes, these pairings sound lush, natural, and just resolving enough to make you smile during your fifth spin of Kind of Blue—not because you “heard something new,” but because it sounds right.
The Cambridge SX50 is a logical house pairing—think of it as the “same pub, different drink” match. Tonally balanced, easygoing, and compact enough to work on shelves or desktops without any complaints. The combo doesn’t thrill, but it doesn’t disappoint either. It just works. And for many people, that’s the win.
DALI Spektor 2 Bookshelf Speaker in Walnut
The DALI Spektor 2 injects a little more sparkle—Danish enthusiasm meets English discipline. They’re efficient, quick on their feet, and the MXW70 reins them in just enough to avoid treble fatigue. This is the surprise combo that’s more fun than it has any right to be.
Now, for those dreaming of expansion, the CXN100 opens the door to future-proofing. Want to run dual MXW70s as balanced monoblocks? Cambridge isn’t stopping you. You can squeeze more headroom and control out of the setup if you ever upgrade to harder-to-drive speakers. But let’s keep expectations grounded—this isn’t your Maggie driver. Don’t even look at a pair of MartinLogan ESLs. This is precision hardware for realistic systems.
A single MXW70 paired with the MXN10 streamer will run you around $1,100—nearly $700 less than the all-in-one Cambridge Evo 75, which tosses in a full-color screen, subwoofer output, HDMI eARC, and an analog input. On paper, that looks like more value in one box—and for many users, it is. But if you’re building a more modular system with room to grow, the separates approach has its own logic.
Step up to two MXW70s in monoblock configuration and the CXN100 streamer, and you’re looking at $2,300 total—still $1,000 less than the Evo 150, which technically offers less power but adds a phono stage, HDMI, and a wider array of inputs. The trade-off? Flexibility and upgradeability. With the separates, you get Cambridge’s better streamer, more power, and the option to scale. With the Evo series, you get slicker integration. Pick your path—just don’t pretend one kills the other.
Bottom line? This amp wasn’t designed to make headlines—it was designed to disappear into your lifestyle and just work. That’s what makes it smart. And that’s what might make it worth owning.
More to come with this one in late-July.
Available soon for $599 at Cambridge Audio.
16 Comments
16 Comments
  1. Catherine Lugg
    July 8, 2025 at 1:14 pm
    Ian, Thanks for this detailed overview of Cambridge’s entries into more affordable gear using Class D typology. I also appreciate the discussion of how well they pair with various speakers (!). It really is the Golden Age of audio, especially for those of us who are NOT blessed with gobs of cash to burn. I did have the Cambridge Dac Magic 200M, but!! Headphones just make the tinnitus scream. So, I gave that with the Focal headphones to someone who would happily use both. That said, it’s an exciting time to see what amps arise for those of us of modest means and modest backs.
    • Ian White
      July 8, 2025 at 9:25 pm
      Catherine,
      Finally home. Europe was…interesting.
      Products like the CA amplifier offer those of us who don’t have a lot of physical space a real alternative that isn’t overpriced.
      I’m likely to spring for two of them as I’m hoping to build a system with the Super Denton for my master bedroom and the tonal match might be perfect and they thrive with more power. Just figuring out the preamp as I have 3 sources.
      IW
  2. John
    July 10, 2025 at 7:16 pm
    Hi Ian
    A dilemma, 2 of these at £1000, or an Edge A ( refurbed direct from Cambridge) for £2500.
    Any thoughts
    John
    • Ian White
      July 10, 2025 at 7:25 pm
      John,
      Depends on the rest of the system. I’ve owned an Edge A since it was introduced and it is the best piece of kit that I own.
      What will you be using the amplifiers with and that also includes sources.
      The Edge A can drive very difficult loads and that includes large planar speakers and electrostatic models.
      The £2500 price is less than 1/2 of what I paid, so that’s a helluva good deal.
      IW
      • Ian White
        July 10, 2025 at 9:35 pm
        And as a follow-up…
        If you go with the two smaller class D amplifiers, what would they be connected to?
        I have an MXN10 and CXN100. The “balanced” mono block route is very appealing, but that still leaves me without any analog inputs — and that doesn’t work for me long-term if I want to add a turntable/phono preamp.
        Cambridge should have designed a similarly sized preamp with a DAC and multiple analog inputs and subwoofer output.
        IW
  3. John
    July 10, 2025 at 10:18 pm
    Hi Ian
    We’ve communicated before.
    Oracle Delphi / FR 64 ( black ) Denon 103 ( Le Son modified – amazing ) Tisbury Audio Domino, WiiM Ultra as preamp / streamer, Quad 405-2 into PSB Image T54 ( can’t believe how good these are )
    The 405-2 is now 42 years old, refurbed by Quad last year and working nicely but time for an upgrade ?
    Think it’s got to be Edge A or maybe Edge W ( £1500 refurbed ) with Ultra as preamp as it is now.
    John
    • Ian White
      July 10, 2025 at 10:37 pm
      John,
      The WiiM/Edge W could certainly work as long as you think there are enough inputs for your sources.
      I’ve owned a few pairs of PSB over the years, so I’m familiar with the tonal balance.
      They will benefit from more power and control in the low end.
      My only caveat is that the WiiM will sound thinner and cooler than the Edge A or Edge W. I have an Ultra as well running into the Edge A and NAD 316BEE V2 and it’s more analytical sounding than my two Cambridge network players.
      I did use the Edge A with the PSB Synchrony B600 and it worked well.
      IW
  4. John
    July 12, 2025 at 12:31 pm
    Hi Ian
    Thank you for sound advice.
    Will probably go for Edge A with WiiM Pro Plus ( which i already have ) for Streaming.
    Regards
    John
    • Ian White
      July 13, 2025 at 1:12 pm
      John,
      Sounds like a good plan. I also forgot that you can use the Edge A as a pre-amplifier.
      IW
  5. MadMex
    July 12, 2025 at 10:22 pm
    Parasound has been in the half-width game for a long long time, and still are with an amp, preamp and phono preamp. All 3 units for $1000 and still quite the Swiss army knife. Use to you could choose silver or black. Today only black. They scrapped the CD player long long ago.
    • Ian White
      July 13, 2025 at 1:13 pm
      MM,
      They have and we have reached out multiple times to get review samples. Crickets. Management change and not very good at communication.
      IW
  6. Frank B.
    July 13, 2025 at 4:07 am
    Didn’t Marantz do a series like this in the early 90s. Music Link series I think? Similar style,nicer (imo), all small desktop friendly units. But they had monoblocks, CD player, phono eq, Dac (digital audio controller), and the very hard to come by DPS-1 (Digital power supply) all which had the dedicated rack for all the units to sit on. It would be cool if Cambridge went a similar way with more units like that.
    • Ian White
      July 13, 2025 at 1:14 pm
      Frank,
      Marantz should definitely revisit that. Especially with the popularity of the M1 Streaming Amplifier. They could add a dedicated phono stage and headphone amplifier and design a rack for it. I like the idea.
      IW
  7. Michael
    December 8, 2025 at 6:02 pm
    Thanks for the informative review Ian. Well written and funny too! I have the 200M, the MXN10 and two cheaper 48V mono blocks. Cheap, but powerful and clean. A pair of those MXW70’s look tempting…
    • Ian White
      December 8, 2025 at 10:06 pm
      Michael,
      Glad you enjoyed it. They are good with the MXN10, but I will say that you definitely need the warmth/coloration of the MXN10 to make it work. A tad dry. Quick, detailed, but sorta dry.
      IW
      • Michael
        December 10, 2025 at 7:58 am
        That warmth and character is exactly why I was drawn to the 200M (I don’t use the DAC inside the MXN10). It’s not a just an analytical bit crusher, its presentation is pleasantly musical with good detail and soundstage. I can listen to it for hours. I think the engineers did an excellent job.
        It certainly is a step up from most cheaper Pre/DAC’s which might measure perfectly, but sound like a machine and a bit lifeless. A lot of the sound coloring comes from the preamp stage of course. And the 200N preamp is good.
        Since I only use the MXN10 as a transport, I have no idea how its build-in DAC sounds. All I know is that these Cambridge Audio streamers silently and reliably do their job. And the app is very good too.
        That’s the beauty of Cambridge Audio stuff. Not much marketing fluff or hyping the latest and greatest. Just solidly performing audio components for an honest price. Not cheap, but you do get what you pay for.
        That ‘dryness’ you hear, is probably just the class D sound signature. I think class D sounds quick, tight, a bit leaner than for instance Class A/B, but with enough power to push and control power hungry woofers.
        I think I might testdrive a single MXW70 in stereo to get an idea of the sound and how it compares to my current power amps.
Which compact speaker sounds best on a desk? DALI, Q Acoustics, and Acoustic Energy go head-to-head.
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
Podcasts
On this live stream podcast, the eCoustics team discusses the very best of what we saw and heard at CES 2026 in Las Vegas.
Cambridge Audio unveils its L/R Active Speaker Series at CES 2026—bold design, serious power, StreamMagic streaming, and a clear shot at KEF’s LS dominance.
Hi-Fi Components
Cambridge Audio names Fidelity Imports as its exclusive U.S. distributor, promising better service, wider retail access, and overdue visibility at hi-fi shows. About time.
From Q Acoustics and Wharfedale to DALI, Vera-Fi, and ATC, these bookshelf speakers prove design and voicing matter. Five radically different paths to great...
In 2025, the best-in-class streamers from Cambridge, Bluesound and WiiM set the pace as new challengers from FiiO, Topping, and Eversolo loom for 2026.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
