ZVOX Launches AV835 Compact Soundbar For Clear Dialogue in Smaller Rooms
ZVOX’s AV835 $269 plug-and-play soundbar brings clear dialogue and bass without the overkill—your landlord will thank you.
ZVOX AV835 Soundbar Front Lifestyle
ZVOX has unveiled the new AV835 soundbar ($269.99), a compact version of its flagship AV855 designed for TVs 32 inches and larger. Aimed at consumers who want crystal-clear dialogue and room-filling sound in smaller spaces—like bedrooms, kitchens, dorm rooms, or secondary TVs—the AV835 brings ZVOX’s renowned dialogue-enhancing technology and immersive audio performance to a more affordable and space-friendly package.
The AV835 isn’t trying to be the mothership of your home theater. It’s a compact, soundbar designed for normal people who don’t want their living room looking like Skywalker Ranch. ZVOX leans on its dialogue-clarification tech—which is still some of the best in the business—so you can actually hear what people are saying without jacking the volume every time an explosion hits.
It’s not Atmos, it’s not a surround-sound circus, but that’s the point: it’s simple, clear, and built for spaces where convenience and intelligibility matter more than bragging rights.
zvox-av835-soundbar-top-angle
ZVOX AV835 Soundbar: Affordable $269 Plug-and-Play Upgrade for TVs
Despite its smaller footprint, the ZVOX AV835 doesn’t sound like a compromise. This low-profile, single-cabinet soundbar ditches the headache of multi-speaker setups and still manages to fill a room with satisfying detail.
Like its big brother, the AV855 ($329), it offers 20 levels of voice boost: 10 levels of ZVOX’s patented AccuVoice (built on hearing-aid algorithms that pull dialogue forward without cranking the volume) and another 10 levels of SuperVoice, which strip away background clutter so you can actually hear what’s being said.
Add in Output Leveling—which evens out quiet dialogue and those “blast your eardrums” commercials—and you’ve got a soundbar designed to keep the peace. Translation: your landlord won’t be knocking on your door.
At just over 17 inches wide, the AV835 packs serious hardware for its size. Two 2.95-inch woofers handle bass with enough punch to make you forget it’s a compact bar, while two 1.46-inch front-firing drivers cover mids and highs with plenty of clarity.
zvox-av835-soundbar-front
ZVOX’s PhaseCue Virtual Surround tech expands that sound into something that actually feels cinematic, even sneaking in a virtual center channel for sharper vocals. And all of this comes from a bar that’s barely 2 inches tall and 5 inches deep.
Aesthetically, the brushed aluminum enclosure and metal grille look a lot more high-end than the price tag suggests, and its compact build slides neatly under most TVs or onto crowded consoles without hogging real estate.
Usability is equally thought out: there’s a discreet digital display that shows volume and inputs, an included IR remote with big, legible buttons, and plug-and-play setup via HDMI-ARC, optical, or 3.5mm analog. Better yet, your TV remote can handle the basics—volume, mute, power—so you don’t end up with a drawer full of redundant remotes.
zvox-av835-soundbar-rear-inputs
ZVOX AV835 Soundbar Specifications
  • Dimensions: 17.6″ W x 5″ D x 1.9″ H
  • Weight: 3.2 lbs
  • Voice Enhancement: 20 levels total
    • 10 levels of AccuVoice (dialogue lift)
    • 10 levels of SuperVoice (background noise reduction)
  • Virtual Surround: PhaseCue technology with virtual center channel
  • Inputs: HDMI-ARC, Optical, 3.5mm analog, USB
  • Output Leveling: Yes (balances loud commercials and quiet dialogue)
  • Bluetooth: No
  • Drivers:
    • Two 2.95″ built-in woofers (bass)
    • Two 1.46″ front-firing drivers (mids/highs)
  • Power Supply: 15V DC adapter
  • Amplifier: High-performance built-in amplifier
  • Included Accessories: IR remote control with large buttons, batteries, all necessary audio cables
zvox-av835-soundbar-angle
The Bottom Line
The ZVOX AV835 isn’t here to flex with Dolby Atmos logos or brag about detachable satellites—it’s here to solve a problem: lousy TV audio. For $269.99, you get a compact, no-nonsense soundbar that makes dialogue crystal clear, evens out volume swings, and adds enough bass to keep things lively without rattling the walls.
It’s ideal for bedrooms, dorms, kitchens, or anyone who just wants to hear what’s being said without decoding alphabet-soup formats. Think of it as the anti-overkill soundbar: simple, effective, affordable—and your landlord won’t be banging on the door asking why your “Fast & Furious” marathon sounds like a drag strip in the living room.
Where to buy: $269 at Amazon | ZVOX
JLab Blue XL Wireless Headphones and Speakers
Esoteric N-05XE DAC Preamplifier Streamer and S-05XE Power Amplifier Esoteric N-05XE DAC Preamplifier Streamer and S-05XE Power Amplifier
Esoteric’s N-05XE and S-05XE combine flagship DAC, streaming, balanced preamp, serious headphone amp, and Class A power—but at $26,500, is this the most future-proof...
Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front
For about a 10% price premium, customers in the EU and APAC can purchase the Bowers & Wilkins 707 Prestige Edition bookshelf speaker in...
2026 ARCAM Radia AVA 2026 ARCAM Radia AVA
ARCAM’s new Radia home theater lineup adds Dirac Live ART, higher channel counts, and new audio video amps and processors, priced from $4,500 to...
Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026 Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026
Theory Professional previews the SR-221.3 at ISE 2026, an extreme-output full-range loudspeaker. Pricing isn’t final, but it won’t be cheap.
JBL Synthesis SCL In-room Loudspeakers 2026 JBL Synthesis SCL In-room Loudspeakers 2026
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
TCL’s A65K Design Series soundbar features 3.1.2 channels, 460-watts of power and Bang & Olufsen tuning, but pricing and final specs won’t arrive until...
SVS debuts 3000 R|Evolution subwoofers, a new Atmos soundbar, and a 5.2.4 demo at CES 2026.
Most soundbars promise Dolby Atmos and deliver disappointment. These are the rare models that actually sound convincing and are worth recommending in 2025.
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
Sony's flagship soundbar system will add punch to your movie and TV viewing and music listening, but at a price.
2025 Black Friday tech deals you won't want to miss on premium hi-fi, headphones, and home theater gear this Holiday Season.
