TEAC’s AP-507 Power Amplifier Features Next Generation Hypex NCOREx Class D Technology
At $2,199, the TEAC AP-507 power amplifier can be configured for two channel stereo, bi-amp, or bridged.
TEAC AP-507 Power Amplifier
Compact and efficient desktop amplifiers are becoming extremely popular in 2025 as more consumers look to build out systems that can drive both high-end headphones and bookshelf speakers and it looks like TEAC has a new power amplifier utilising the latest in Class D technology. Following the releases of the HA-507 Headphone Amp/Preamp and UD-507 DAC/Preamp/Headphone Amp in 2024, TEAC has announced another addition to the 500 reference component series, the AP-507 Power Amplifier.
Introduction
The TEAC AP-507 is primarily designed to be a companion to the above-mentioned previously released components, but can also elevate the performance of almost any audio system.
The AP-507 is a step up from the AP-505 that was released in 2019, but with an updated amplifier module and higher power output along with much lower levels of distortion.
TEAC AP-507 Black Rear
Amplifier Section
The AP-507 features TEAC’s custom-tuned new generation ‘NCOREx’ power amplifier module. Tuned by TEAC’s R&D team, the AP-507 is designed to achieve exceptional audio performance. At the heart of the AP-507 is TEAC’s in-house designed dual-mono buffer amplifier. Featuring ultra-linear performance, low distortion, and high efficiency, the fully balanced design allows the AP-507 to reproduce music with the best possible quality.
The AP-507 supports flexible operation including Stereo, Bi-AMP, and BTL mono modes. It can deliver a high power output of 170 watts per channel at 4 ohms and up to 350 watts at 8 ohms in BTL mode. This flexibility makes it an excellent choice for enhancing AV surround sound systems.
To provide full support for the needs of the amplifier section, the AP-507 includes a High-Capacity Power Supply with a large toroidal transformer and 18,800 μF capacitors per channel.
Compact Size
The AP-507 has a small footprint. While the amplifier is designed for audiophiles looking for precision, clarity, and dynamic performance, it is also designed to be able to fit attractively and seamlessly into modern living spaces. TEAC claims that the AP-507 is small enough to be used in a desktop audio system.
TEAC AP-507 VU Meters
Exterior Design
The AP-507 features an aluminum and steel chassis with a 2.8mm thick semi-floating aluminum top plate and a 3-point stress-less isolation foot system. This design minimizes vibrations, creating a more open and natural listening experience. The AP-507 also runs fairly cool and has a fanless design for minimal noise.
Like its predecessor, the AP-507 also provides Dual Point VU meters with a 4-step dimmer and 2-step sensitivity switch. This makes it easy to keep track of the AP -507’s operational status.
Comparison
TEAC AP-507 (L) and AP-505 (R) 2-Channel Power Amplifiers
ModelAP-507 (2025)AP-505 (2019)
Price$2,199$1,499
Amplifier TypeHypex “NCOREx”  new generation amplifier module custom-modified to TEAC’s specifications.Hypex Ncore power amplifier module
Amplifier Drive Modes (Selectable)Stereo, Bi-Amp, and BTLStereo, Bi-Amp, and BTL
Amplifier Power Output (Maximum Effective – 1 kHz)Stereo or Bi-Amp: 170W + 170W(4 Ω), 95W + 95W(8 Ω)
BTL: 350W(8 Ω)
Stereo or Bi-Amp: 130W + 130W (4Ω), 90W + 90W (8Ω)
BTL: 250W (8Ω)
Amplifier Power Output (Rated Output – 1% THD, 1kHz)Stereo or Bi-Amp: 125W + 125W(4 Ω) , 70W + 70W(8 Ω)
BTL: 230W(8 Ω)
Stereo or Bi-Amp: 115W + 115W (4Ω), 70W + 70W (8Ω)
BTL: 220W (8Ω)
Speaker Output Impedance Stereo or Bi-Amp: 4 Ω to 16 Ω
BTL: 8 Ω to 16 Ω
BTL: 8 Ω to 16 Ω
THD (Total Harmonic Distortion)0.0015% 8 Ω, 1kHz, 12.5W) 0.0015% (8Ω, 1kHz, 12.5W)
SNR (Signal to Noise Ratio)113 dB (8 Ω, 1kHz)113 dB (8Ω, 1kHz)
Frequency Response (8Ω、1kHz、1W)10 to 50kHz(+0dB, −5dB)10Hz to 50,000Hz (+0dB, –5dB)
Damping Factor Not Indicated370 or higher (20Hz to 20kHz, Output  impedance: 22mΩ, 8Ω loaded)
Inputs1  x XLR
1 x  RCA Inputs
1  x XLR
1 x  RCA Inputs
Outputs1 x Large Screw-Type Speaker Binding Posts1 x Large Screw-Type Speaker Binding Posts
Input Sensitivity ( 8 Ω, 1% THD output)RCA 0.66V, XLR 1.3VRCA 0.66V, XLR 1.3V
Input Impedance (RCA/XLR)10k Ω or more10k Ω or higher
ControlFront Panel Controls
1 x Trigger In
1 x Trigger  Through
(Triggers not provided)
Power SupplyAC 220–230 V, 50/60 Hz (Europe) AC 120 V, 60 Hz (USA/Canada) AC 220–240 V, 50/60 Hz (Europe) AC 120 V, 60 Hz (USA/Canada)
Power Consumption58W 106W
Standby PowerNot Indicated0.1W or less (at Auto power-saving mode)
FinishSilver or BackSilver or Back
Dimensions (WHD, including protrusions)290 x 84.5 x 271mm
11 1/2 × 3 3/8 × 10 ¾ inches
290 × 84.5 × 271 mm
11.4 × 3.3 × 10.7 inches
Weight 4.4kg (9 3/4 lb)4.4kg (9.7 lbs)
Included AccessoriesPower cord × 1, Rubber pads × 3, Owner’s ManualPower cord, Owner’s Manual (incl. Warranty card)
TEAC AP-507 SGM-10
The Bottom Line
With each new generation of products, class D technology continues to improve; one of the advantages of the updated Hypex NCOREx modules is that there is a lot less heat dissipation. The module will run in a much lower idle current when it can and will only switch to a higher idle current when performance is needed. The output impedance has also improved and the levels of measured distortion have also been reduced even further — these are extraoridnalry quiet amplifiers that run rather cool.
However, keep that the AP-507 is a power amp, you need to budget for a preamp (such as HA-507 and UD-507) to supply input switching and any processing that may be needed before sending those signals to the AP-507 to power the speakers.
That being said, on paper the specs for the AP-507 look good and for its price point, it might be a great power amp solution for a two-channel audio system, as a bi-amp or bridged amplifier for a portion of a home theater audio system.
Price & Availability
The AP-507 will be available to purchase in Spring 2025 from TEACUSA.com  and select dealers. The MSRP is $2199 (USA) / €1899 (EU) / £1899 (UK).
2 Comments
2 Comments
  1. ORT
    February 13, 2025 at 2:23 am
    Style is back in style! Vu Meters 4Ever!
    ORT
    • Ian White
      February 13, 2025 at 11:31 am
      ORT,
      Looks like they all got the message. I agree that Vu meters are definitely back.
      IW
QUAD ESL 2912X Electrostatic Speaker System at AXPONA 2026
Quad ESL 2912X electrostatic speakers at AXPONA 2026 from MoFi Distribution prove big panels can deliver clarity, scale, and real emotional connection without excess.
Amphion Stereo System AXPONA 2026 Amphion Stereo System AXPONA 2026
Amphion Argon7LX arrives at AXPONA 2026 with Finnish precision, clean power, and zero drama. No hype, just sound that quietly outperforms.
ATC EL50 Anniversary Active Speakers at AXPONA 2026 ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Geshelli TORC DAC at AXPONA 2026 Geshelli TORC DAC at AXPONA 2026
Geshelli's TORC DAC makes its case at AXPONA 2026 with a modular design, swappable DAC boards, and a real upgrade path that will not...
2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood 2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood
Dynaudio Legend bookshelf speakers hit AXPONA 2026 with Esotar 3 tweeter, real bass, and Danish build that proves the internet got this one wrong.
2026 Grado Phono Cartridges 2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Can a Bluetooth turntable make vinyl practical for wireless headphone users? TEAC’s TN 400BT X/TB bets that convenience matters more than purism.
Is the Aavik M-880 pure excess, or a serious rethink of Class A amplification delivering 400 watts at $115,000 per channel?
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Unison Research’s Unico PRE v2 and DM v2 introduce a modern design, substantially more power, and an $18,498 system price—no streamer, no Bluetooth, just...
Esoteric’s N-05XE and S-05XE combine flagship DAC, streaming, balanced preamp, serious headphone amp, and Class A power—but at $26,500, is this the most future-proof...
ARCAM’s new Radia home theater lineup adds Dirac Live ART, higher channel counts, and new audio video amps and processors, priced from $4,500 to...
Can Roksan’s $4,500 Caspian 4G Streaming Preamp and $3,750 Power Amp compete with NAD and Naim in this price class?
Emotiva introduces an affordable line of fully balanced hi-fi separates for a discounted package price of $2,599.
