SOUNDBOKS Launches “Mix” Bluetooth Party Speaker With 121 dB Output and Swappable Battery
Soundboks Mix delivers 72-watts Class D amplification, Bluetooth, and pro-level SKAA wireless with volume that goes to 11. Is it the right party speaker for you?
Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle
Danish audio brand SOUNDBOKS isn’t chasing subtlety with its latest release. The Soundboks Mix is a portable Bluetooth party speaker built to hit a claimed 121 dB output, which puts it squarely in festival territory, not casual background listening. That kind of volume is less about filling a room and more about taking over a space entirely, whether that’s a backyard, a parking lot, or anywhere your neighbors haven’t already filed a complaint.
To its credit, the Mix isn’t just brute force. SOUNDBOKS is aiming to balance raw output with real-world usability, pairing high SPL performance with a portable design, swappable battery system, and rugged construction meant to survive outdoor abuse. The promise is simple: big sound without being tethered to an outlet or treated like fragile gear.
That said, a quick reality check. 121 dB isn’t a party trick you should be chasing for more than a few minutes unless hearing loss is on your bucket list. Sustained exposure at that level will do real damage, and it won’t take long. There’s also the small matter of everyone within a block radius suddenly developing strong opinions about your life choices. Use the headroom, don’t live in it.
soundboks-mix-party-speaker-front
Soundboks Mix
Amongst the inconsistent, one constant remains: everyday life requires a speaker to sound great, whatever the situation,” said Jesper Theil Thomsen. “Soundboks Mix is perfectly placed to do just that, balancing audio quality, power, battery life, durability, and portability.”
Whether indoors or outdoors, and across a wide range of listening levels, the Soundboks Mix is designed to adapt to different use cases without requiring constant adjustment. Its acoustical system is tuned to maintain clarity as output increases, rather than simply getting louder at the expense of balance. Three sound profiles and adjustable EQ settings, accessible through the Soundboks app, allow users to tailor performance based on environment and preference. The enclosure follows the brand’s established design approach, with a durable build intended to handle regular transport and outdoor use without treating it like fragile gear.
The party speaker market is one-dimensional, forcing a choice between power and portability,” said Jesper Theil Thomsen. “With Soundboks Mix, we’ve eliminated the need to choose between the two. This speaker strikes a balance without compromise, offering a level of versatility that extends beyond typical use cases. We didn’t just make this for hosting and partying—Soundboks Mix was designed to fit into everyday listening as well.”
soundboks-mix-party-speaker-carry
Soundboks Mix
Soundboks Mix Key Features
Compact and Durable Design: Rounded ball corners and an impact-resistant PC/ABS cabinet are designed to handle transport, bumps, and typical outdoor use without requiring careful handling.
Room-Filling Sound: The Mix uses dual Class D amplification to drive a 10-inch woofer and a 0.5-inch tweeter, with a claimed maximum output of 121 dB SPL. The system is tuned to maintain composure at higher volumes across indoor and outdoor environments. And yes, the volume scale going to 11 is a clear wink at This Is Spinal Tap—because subtlety was never the point.
soundboks-mix-party-speaker-controls
Custom-Developed Acoustical System: SOUNDBOKS claims the Mix is engineered for efficiency relative to its size, aiming to deliver higher output without requiring a proportionally larger enclosure.
Up to 40-Hour Battery with Swappable Design: Battery life is rated at up to 40 hours at moderate listening levels and around 8 hours at maximum output. The removable battery can be swapped in seconds, with additional packs available separately for extended use.
Single Carry Handle and Strap Mount: An integrated handle and mounting points support optional accessories like the Soundboks Backpack and Strap 2, making transport more practical for outdoor use or longer distances.
TeamUp Connectivity: Up to five compatible Soundboks speakers, including Soundboks 4 ($1,199 at Amazon), Soundboks Go (discontinued), and Soundboks Mix, can be linked using SKAA wireless technology for synchronized playback or expanded coverage.
soundboks-app-screenshots
Companion App: The SOUNDBOKS app provides control over EQ adjustments, sound profiles, and speaker locking, allowing users to manage settings directly from a mobile device.
Customizable Front Grille: The Mix supports interchangeable grille options in Metallic Grey, White, Orange, and Black, allowing users to personalize the speaker’s appearance without altering its core design.
IP65-Rated Electronics Coating: The internal components are coated for protection against dust and water exposure, meeting IP65 standards. It’s built to handle outdoor conditions and the occasional spill, but it’s not designed for full submersion or heavy rain abuse.
Soundboks Mix Bluetooth Party Speaker Specifications
Soundboks ModelSoundboks Mix
Product TypeBluetooth Party Speaker
Price$799
Amplification 2 x Texas Instruments 72-watts RMS Class-D amplifiers in PBTL (Parallel Bridge-Tied Load) mode
Driver Units1 x 10″ Woofer
1 x 1.2″ Dome tweeter
Pulse Reflex PortYes
Max SPL 121 dB
Effective frequency range40 Hz – 20 kHz
Soundboks Adaptive Bass Enhancer DSPYes
Wireless ConnectivityBluetooth 4.2
TeamUP connection (SKAA) for up to 5 SKAA-enabled speakers
Wired Connectivity1 x 3.5mm TRS stereo input
App Sound SettingsVolume adjustment
Sound Profiles optimized for different spaces and occasions
Custom EQ
True stereo roles (left/right/mono)
Advanced ControlsAdvanced TeamUp controls and settings
TeamUp Joined Volume Control
SKAA Pro Mode for reduced latency
Connection & AccessRemotely disconnect or power off
Auto-connect for Bluetooth audio
Security PIN code for app and audio connection
Mark as lost or stolen
Output (USB-C)10W USB PD, 5v 2A
MaterialsABS and polycarbonate cabinet
Silicone ball corners
Built-in reinforced top hat
Detachable steel grill
IP RatingIP65-rated electronics coating
Carry HandleYes
Mount for Add-On
Carrying StrapYes
UI PanelVolume control knob with LED indicators
TeamUP button with LED indicators
Power On/Off button
Bluetooth LED indicator
Wireless LinkSKAA TeamUP
Battery Life40 hours at mid-volume
8 hours at full volume
2 hours full recharge with The Charger
Battery Cell Type12.8V, 7.8Ah Lithium Iron Phosphate (LiFePO4) – 99.84 Wh or 7.8 Ah capacity
Charging ConditionsCharge condition: 0°C to 45°C
Discharge condition: -15°C to 55°C
Product DesignReinforced ABS casing – IPX65
5-step LED battery-life indicator
Heavy-duty DC-connector
Dirt cover over the USB connector
Carry strap available
Battery charge LED indication
Short circuit protection
Overheat protection
Carry HandleYes
Mount for Add-On
Carrying StrapYes
Dimensions (HWD)48 x 34 x 27 cm
(18.9 x 13.4 x 10.6 inches)
Weight9.7 kg
(21.4 oz)
What’s in the boxSoundboks Mix
Rechargeable Swappable Battery
Manual
Firmware & WarrantyFirmware updates via the app for sound and performance upgrades
soundboks-mix-party-speaker-back
The Bottom Line
The Soundboks Mix stands out because it is built like something meant to leave the house and come back in one piece. Beyond the claimed 121 dB output and swappable battery, the details matter: an impact-resistant PC/ABS cabinet, silicon rubber ball corners to absorb knocks, IP65-rated protection for the coated electronics against dust and water exposure, and a design meant to handle transport, bumps, drops, and outdoor use without feeling precious. That gives it a more serious, utility-driven edge than a lot of party speakers that look ready for a weekend but not necessarily built to survive one.
It is still missing a few things some buyers will expect at $799. There is no included microphone, no dedicated mic input for karaoke, no built-in light show, and accessories like the carry strap and faster charging solution cost extra. So this is not the all-in-one party circus box that does every trick.
Who is it for? People who actually need a loud portable speaker they can move around, use outdoors, and trust to keep going. Tailgaters, beach crews, backyard hosts, small event users, and anyone who values durability and battery stamina over gimmicks. For that buyer, the Soundboks Mix offers solid value because it focuses on power, runtime, and survivability. It is not trying to be cute. It is trying to outlast the party, the weather, and probably one drunk idiot who thinks dropping it is a personality trait.
Price & Availability
The Soundboks Mix is available for $799 at Amazon or direct from SOUNDBOKS.
Kaleidescape Terra Prime Movie Server
Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle
Soundboks Mix delivers 72-watts Class D amplification, Bluetooth, and pro-level SKAA wireless with volume that goes to 11. Is it the right party speaker...
Shanling SM90 Music Streamer Angle Shanling SM90 Music Streamer Angle
Shanling SM90 adds HDMI ARC, dual AKM DACs, and Android streaming under $1,000, but can it stand out in a crowded streamer market?
JBL PartyBox On-the-go 2 Plus Portable Bluetooth Speaker at Beach JBL PartyBox On-the-go 2 Plus Portable Bluetooth Speaker at Beach
JBL PartyBox On The Go 2 Plus adds AI karaoke with real time vocal removal, EasySing mics, and Auracast. Is this the future of...
Beats by Dre Powerbeats Pro 2 Nike Special Edition Wireless Earbuds Beats by Dre Powerbeats Pro 2 Nike Special Edition Wireless Earbuds
Beats and Nike team up for Powerbeats Pro 2 Special Edition with fitness features, bold design, and zero upgrades under the hood. Smart move...
At $799, the Marshall Bromley 450 packs 360-degree sound, 40+ hour battery, and mic inputs in a 27 pound portable party speaker box.
JBL Boombox 4 and PartyBox 720 are the perfect portable party speakers for 2025 with booming bass, waterproof designs and epic lightshows.
TCL’s TP200K and TP300K party speakers bring solid specs and features to challenge Sony and JBL—perfect for any gathering, from Bar Mitzvahs to dog...
Tronsmart Halo 300 crashes the 2025 party speaker scene. How does it stack up against Sony’s ULT Tower 9 and JBL's PartyBox Series?
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Ask an Expert
Waterproof vs. water resistant? Here's what the numbers really mean in those IP ratings.
Klipsch Music City Series Bluetooth Party Speakers Pay Homage to 3 American Party Cities: Vegas, Miami and New York.
