CD Players
Shanling Unveils SCD3.3 SACD Player With 2nd-Gen R2R DAC and Tube Output
Shanling’s SCD3.3 treats SACD like it never died—true DSD output, a 212-resistor R2R DAC, tube stage, and enough engineering muscle to shame most “modern” players.
Shanling SCD3.3 SACD Player
Is SACD quietly staging a comeback? Shanling seems to think so. Hot on the heels of the ONIX Zenith XST20 SACD/CD Transport released earlier this year, the company has unveiled the $3,990 Shanling SCD3.3 SACD player, a full-featured deck built around SACD playback, a 2nd-generation R2R DAC, and a classic tube output stage.
What Is SACD and Why Does It Still Matter in 2025?
Let’s be honest: outside the audiophile world, most people who still have a CD player—or are thinking of buying one—are staring at the SACD logo like it’s hieroglyphics. A little context goes a long way.
SACD (Super Audio CD) landed in 1999 as Sony and Philips’ big swing at next-generation physical media. Instead of the 16-bit/44.1 kHz PCM used on CDs, SACD relied on DSD, a 1-bit stream sampled at 2.8 MHz. The goal was simple: capture more nuance, extend the frequency response, and get closer to the master tape without the digital glare that defined early CD playback. The format could also deliver 5.1 surround mixes, which made it catnip for classical labels and early home-theater enthusiasts.
So why didn’t SACD take over the world? Timing. It arrived just as downloads and streaming were gaining momentum, while DVD—and later Blu-ray—stole the spotlight for home entertainment. Consumers moved on before SACD ever had a chance to hit critical mass.
Yet here we are in 2025, and SACD refuses to die. Audiophiles still swear by the format’s sound quality, collectors chase down rare pressings, and labels like Acoustic Sounds keep the flame alive with meticulous reissues. It’s niche, sure—but it’s a niche with staying power. And with transports like the ONIX XST20 and players like Shanling’s new SCD3.3, the format’s “legacy” looks a lot less like a eulogy and more like a second life.
shanling-scd-3-3-top-open-angle
Shanling SCD3.3: What This Player Actually Offers
Shanling’s new SCD3.3 isn’t another nostalgia-driven disc spinner—it’s a purpose-built SACD machine with modern engineering, a full-blown R2R DAC, and a tube output stage baked in. At 10kg, it’s a serious component, and the feature set reads like Shanling decided to make a “do everything, do it right” statement piece.
The transport is entirely in-house and uses a proprietary disc system built around the HD850 laser. It’s a top-loading design with a dedicated CD puck, and more importantly, it extracts true DSD data from SACDs. That DSD stream feeds both the internal R2R DAC and the digital outputs (I2S and Coaxial), so you’re not getting PCM-converted SACD playback. This is the real deal.
The DAC section is where things get interesting. Shanling is using its second-generation R2R DAC module, a resistor ladder built with 212 ultra-precise 0.01% resistors. R2R continues its resurgence for a reason: it delivers a tonal density and texture that delta-sigma designs rarely match, and Shanling doubles down by offering both solid-state and a classic 12AT7 tube output stage. Whether you want clean, fast R2R playback or something warmer and more forgiving, you get both paths.
shanling-scd-3-3-front
shanling-scd-3-3-rear
On the output side, the SCD3.3 offers RCA and XLR, along with a switchable line-out or preamp mode, so it can run directly into a power amplifier if needed. The I2S output is FPGA-assisted and includes 10 selectable pinout modes, making it compatible with a wide array of external DACs—something many transports still fail at.
Inside, the power supply is unusually serious for a disc player: dual 66W transformers plus a dedicated 15W module, feeding isolated digital and analog sections. It’s one of the reasons the chassis weighs a full 10kg, along with the thick aluminum construction.
On the usability side, Shanling didn’t phone it in. You get a 5-inch LG touchscreen, a remote, hardware buttons, and a companion app. Beyond discs, it supports USB drive playback, a USB DAC mode, and a Bluetooth 5.0 receiver with LDAC, aptX HD, and aptX support. For a disc player, it’s surprisingly flexible.
SCD3.3 Specifications
Dimensions & Build
  • Size: 430 × 319 × 91 mm
  • Weight: ~10 kg
  • Chassis: Thick aluminum build for vibration control and transport stability
Processor & Interface
  • Main Processor: Ingenic X2000
  • Display: 5.0″ LG touchscreen (854 × 358)
  • Controls: Touchscreen, remote, hardware buttons, companion app
Power Architecture
  • Transformers: Dual 66W transformers
  • Additional Power Module: Independent 15W supply
  • Design Goal: Isolated digital/analog sections for lower noise and better channel stability
Supported Playback & Connectivity
  • Discs: SACD / CD
  • USB DAC: PCM up to 768kHz/32-bit, DSD512
  • SPDIF Inputs: Coaxial
  • USB Drive Support:
    • PCM up to 768kHz/32-bit
    • DSD512 (.iso/.dsf/.dff; DST not supported)
    • Formats: WAV, FLAC, AIFF, APE, ALAC, MP3, AAC, OGG, M4A, AC3, OPUS, and more
  • Bluetooth: BT 5.0 receiver
    • Codecs: LDAC, aptX HD, aptX, AAC, SBC
Digital Output Options
  • I2S:
    • PCM up to 768kHz
    • Native DSD up to DSD512
    • FPGA-assisted with 10 selectable pinout modes
  • USB Audio Out:
    • PCM 768kHz, DSD512
    • (SACD not supported over USB)
  • Coaxial SPDIF Out:
    • PCM up to 192kHz
    • DoP DSD64 (SACD-supported)
Analog Output Performance
RCA Output
  • Level: 2.45 Vrms
  • Frequency Response: 20Hz–40kHz (–0.3dB)
  • THD+N: 0.15%
  • Crosstalk: 110dB
  • Dynamic Range / SNR: 117dB
XLR Output
  • Level: 4.9 Vrms
  • THD+N: 0.15%
  • Channel Separation: 110dB
shanling-scd-3-3-front-back-angle
The Bottom Line
The Shanling SCD3.3 isn’t just another SACD player dusted off for nostalgia points—it’s one of the few modern machines treating disc playback like it still matters. True DSD from SACD, a fully discrete 2nd-gen R2R ladder DAC, a selectable 12AT7 tube output stage, and an FPGA-driven I2S system with 10 pinout modes make it a rare hybrid: a high-end transport, DAC, and analog stage all living under one roof without compromise.
Most players force you to pick a lane. The SCD3.3 doesn’t. It gives you native DSD output if you want to run it as a pure transport, a resistor ladder DAC if you want fully in-house digital conversion, and a tube stage if you want tone without losing resolution. Add in dual 66W transformers, a true top-loading mechanism, and a 10kg chassis built to keep noise and vibration out of the equation, and you’re looking at one of the most complete SACD-focused components available in 2025.
If you’re the kind of listener who still values physical media—and you want a player that treats SACD and CD with the same seriousness you do—the SCD3.3 stands out because it isn’t trying to be everything to everyone. It’s built for people who actually care about sound and are willing to pay close to $4,000 for that level of performance.
Where to buy: $3,990 at shanling.com
4 Comments
4 Comments
  1. Soundboy
    November 28, 2025 at 5:36 am
    Your article make it seems like true DSD wasn’t available before. What does the Shanling do that is any different than any other SACD player aside from its I2S output and tube output? You didn’t mention the Shanling’s lack of multichannel capability (yes, I know almost all dedicated SACD players are just 2 channel models).
    By the way, SACD is not making a comeback. There will be around 500 new SACD releases worldwide in 2025, which represented a declined when compared to 2024. In fact, the number of new SACD releases worldwide have been on a relatively stable level for the past decade. Also, all of the major music companies (i.e. Sony Music, Universal Music, and Warner Records) are involved in the release of music on SACD. However, in the US, they rather license their music to reissue labels such as Mobile Fidelity and Analogue Productions for release on SACD.
    • Ian White
      November 28, 2025 at 10:50 am
      Considering the niche that SACD represents, 500 new SACD releases at this point is a lot. I think one has to look at the Shanling for what it offers, as opposed to what it doesn’t offer. Let’s totally take a dump on manufacturers who are spending R&D money on physical media at a time when it only represents 10% of all music sales.
      IW
    • Mark Garmaise
      November 29, 2025 at 11:54 am
      I would have considered it if if were front loading. Many of us don’t have the space to top load as the tv takes up the top shelf.
      I’ll probably go with the Denon 3000NE.
  2. Jim Dukey
    November 29, 2025 at 4:49 pm
    Hi,
    This quote is from Darko .com
    Is it stated in the manual which method is used?
    I would certainly prefer Pure DSD!
    I’m also considering 2 Marantz SACD Players,
    the 30n and an SA-KI-Ruby, which is still available from Audio Classics.
    Will the Shanling upsample CDs to DSD?
    Thanks,
    Jim Dukey Oakland Ca
    “As for the internal processing (handled by an Ingenic X2000 processor and an FPGA), Shanling doesn’t say whether the DSD extracted from an SACD is converted to PCM before reaching the R2R DAC – though given that R2R architectures are inherently multibit (and not DSD’s stream of single bits), conversion seems likely.”
2026 Samsung The Frame Pro vs. The Frame 4K Art TVs
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle
Soundboks Mix delivers 72-watts Class D amplification, Bluetooth, and pro-level SKAA wireless with volume that goes to 11. Is it the right party speaker...
Shanling SM90 adds HDMI ARC, dual AKM DACs, and Android streaming under $1,000, but can it stand out in a crowded streamer market?
CD Players
At $4,000, the Michi Prestige Q430 CD Player targets compact disc fans with ESS DAC and balanced outputs, but was omitting SACD playback a...
Luxman's CENTENNIAL series D-100 SACD/CD player and L-100 Class A Integrated Amplifier aim to end your desire to upgrade.
ONIX’s XMT20 streamer transport pairs a new Linux platform with Roon Ready, TIDAL and Qobuz Connect, plus high-end digital outputs and CD ripping support.
CD Players
Mission completes its 778 Series with the 778CDT CD transport, a practical, affordable addition that reflects the quiet return of CD playback in modern...
CD Players
Shanling’s $999 CT90 CD transport targets modern CD collectors with digital-only outputs and Bluetooth, but skips SACD, analog outs, and compact rack-friendly design.
Is the FiiO K11 R2R the most musically engaging DAC/headphone amp under $200, blending R2R texture with real-world balance at $175?
