Schiit Valhalla 3 Unleashed: Thor’s Class A OTL Tube Amp for Mortals Who Dare Drive Hard-to-Tame Headphones
Unlock the gates of Asgard with Schiit Valhalla 3 — a fully modern, OTL/OCL tube headphone amp forged for high-impedance cans and audiophiles who crave that warm, glowing Valhalla magic.
Schiit Valhalla 3 Tube Headphone Amplifier Silver
Schiit Audio just dropped the Valhalla 3—a pure triode, OTL/OCL, Class A headphone amp and preamp that’s ready to take on your hard-to-drive cans like it’s storming the gates of Asgard. Priced at $499, it’s not cheap, but for what it does, Odin himself might call it a bargain.
This isn’t just a tweak of the Valhalla 2, Schiit’s longest-serving amp. According to Jason Stoddard, Schiit’s Co-Founder and resident god of audio war, the Valhalla 3 is “completely different,” borrowing its battle-tested tech from the limited-run Folkvangr—aka the giant, tube-filled beast that made headphone nerds cry tears of joy and wallet pain.
Like Folkvangr, the Schiit Valhalla 3 operates as a OTL/OCL design—no output transformers, no capacitors in the signal path. Translation: your headphones are getting raw tube power straight from the source. No filters, no frills, no fluff—just Mjölnir to the ears.
There’s also a switchable impedance multiplier, which sounds fancy but basically means your 32-ohm, stubborn-as-hell planar headphones will finally behave. And unlike the usual high-current buffer cheats, this keeps your cans connected directly to the tubes—like the gods intended.
Valhalla 3 isn’t just a mini Folkvangr—it goes one better. It adds three gain levels, including a zero-feedback setting that unleashes the full fury for high-impedance headphones. It’s like flipping the Bifrost on your gear.
The burning rainbow bridge that spans between Midgard and Asgard, the realm of the gods — not the $800 DAC from Schiit… though, the second option might be a bit more preferable when explaining things to your home insurance company.
Protection? Oh, it’s got it. Not the kind you’re thinking of, though — this is the actual kind that keeps your gear from frying, not the “I’ll-be-back-before-midnight” kind.
Delayed startup, fast shutdown, and analog-style DC sensing keep your gear safe from Ragnarok. Add a filtered preamp output, and Valhalla 3 can anchor your entire desktop system—headphones, active speakers, the works.
A new thermal tray design not only keeps things cool, it also finally makes a Schiit amp look as badass as it sounds. And like all Schiit gear, it’s made in the USA using real metalwork, not some glorified hunk of milled aluminum that costs more to carve than it does to design.
schiit-valhalla-3-rear
Valhalla 3 Specs
  • Power Output
    • 750mW @ 32Ω (with impedance multiplier)
    • 250mW @ 300Ω (without impedance multiplier)
    • Plenty of juice for high-impedance headphones, handles most others with the multiplier engaged
  • Noise Floor
    • Dead silent on most headphones and IEMs
    • Some hiss on ultra-sensitive IEMs
  • Distortion
    • High by modern standards—because it’s a real triode tube amp
    • THD rated at 10%, and yes, it sounds damn good
  • Gain Levels
    • Low: 1.25x
    • High: 6x
    • No Feedback: 10x (pure tube rage)
  • Output Impedance
    • Low Gain: 25Ω
    • High Gain: 40Ω
    • No Feedback: 60Ω
    • Preamp Out: <200Ω
  • Topology
    • All-triode, OTL/OCL, Class A
    • DC-coupled, single-stage voltage gain, WCF output
    • No output transformers or capacitors in the signal path
  • Tube Complement
    • Input: 6N1P (rollable to 6DJ8, 6922, etc.)
    • Output: 6N6P
    • 1 of each per channel
    • Max 2.7A heater current
  • Frequency Response
    • 20Hz–20kHz, ±0.05dB
  • THD+N / IMD (at 1V RMS into 300Ω)
    • Low Gain: <0.05%
    • High Gain: <0.2%
    • IMD CCIF: <0.05% / <0.25%
  • SNR
    • Low Gain: >110dB (A-weighted)
    • High Gain: >95dB (A-weighted)
  • Crosstalk
    • <-75dB (20Hz–20kHz into 300Ω)
  • Input Impedance
    • 50kΩ
  • Protection
    • DC sensing, analog-computer-style mute
    • Delayed startup & fast shutdown
    • Full-time oversight
  • Power Supply
    • 48VA internal transformer
    • Fully linear with discrete regulated rails
    • Capacitance multipliers and servo control
  • Power Consumption
    • 27W typical
  • Thermals
    • Gets hot—tubes run hotter
    • Designed to survive its own heat for years
  • Size & Weight
    • 9” x 6” x 2” (3.25” tall with tubes)
    • 7 lbs
    • Very desk-friendly
schiit-valhalla-3-inside
But How Does All of this Norse Magic Work? (For the Head-Fi Nerds…with appreciation to our friends at Schiit)
Glad you asked. Valhalla 3 may look like something Odin would use to warm up his headphones, but inside, it’s got more tech than Thor’s hammer.
OTL/OCL Topology: That means no output transformers and no coupling capacitors in the signal path. Your headphones connect directly to the cathodes of the tubes. No middlemen. That’s a big deal in tube land, and it’s only possible thanks to DC servos and a complex, nerd-approved power supply.
Impedance Multiplier: Most tube amps suck with low-impedance headphones. This clever circuit makes the tubes think they’re driving a higher impedance, so they deliver more power without the usual meltdown.
Analog Computer-Style Protection: No microcontrollers. No BS. Just good old analog circuitry that constantly monitors DC levels so your headphones don’t go poof if something goes sideways.
How is the impedance multiplier different from a buffer?
A buffer adds a solid-state stage between the tubes and your headphones. That kills the whole “tube sound” thing. The impedance multiplier keeps the tubes directly in the path — all the gooey tube goodness, but with more muscle. Think of it as a magic hammer that makes your tubes hit harder.
When should I use the impedance multiplier?
If your low-impedance headphones sound weak or distorted, flip the switch. You won’t break anything. Odin’s honor. Call Mike to complain.
Is this just a smaller Folkvangr?
Pretty much. Folkvangr was a $1,800 10-tube beast that made your desk look like a Viking funeral. Valhalla 3 keeps the soul, loses the bulk (and half the price). But wait. What the hell was the Folkvangr?
Glad you asked.
Timing is everything. The Schiit Audio Folkvangr Headphone Amplifier was released when energy costs were at an all-time high and replacement tubes were not exactly inexpensive — not much has changed since 2022.
We liked it. A lot. Go bold or go home.
Folkvangr was Schiit’s $1,800 mic-drop moment — their most expensive headphone amp to date and a curveball from a company known for making high-end, American-made gear that doesn’t torch your bank account. Only 250 units were made, making it less a product and more a myth. Think of it as Valhalla’s big brother who shows up once, drinks all the mead, and disappears into legend.
Folkvangr wasn’t just Schiit’s most expensive headphone amp — it was a full-on tube-fueled fever dream. The first DC-coupled, output transformerless (OTL) and output capacitorless (OCL) amp from the brand, it packed ten tubes and an 8X impedance multiplier to give low-impedance headphones a fighting chance. Each one idled at 100 watts just to squeeze out a watt or so of output — pure excess, no apologies.
Folkvangr is completely bonkers,” said Jason Stoddard, Schiit’s co-founder and head of analog. “There’s no other way to put it. There’s no reason for a 10-tube amp that dissipates 100 watts at idle, to produce only about a watt or so at its best. It measures very badly, and it’s not what we’d use for any kind of IEM. But it’s the answer to a question that’s bugged me for years—what do tubes really sound like—and, at least to me, it sounds very good.”
But, like all things that are too cool for this world, it sold out faster than Loki disappearing into another timeline — never to be spoken of again. Much like that next season of Loki… which, let’s be honest, is probably never coming.
Will this drive all headphones?
Almost. Very low impedance headphones might not be ideal. It does handle most headphones just fine — especially high-impedance models. Beyerdynamic and Sennheiser users can stop grinning like little children who were just dropped at Willy Wonka’s factory — be advised children — he’s sorta creepy — in a weird uncle who wants to hang out with your teenage friends kinda way.
But what about IEMs? Low gain works for most. If your IEMs are hypersensitive divas, you might hear a hiss. Blame the tubes, not the folks at Schiit.
Do the preamp outputs go through the tubes?
Yep. Everything gets soaked in tube flavor — even your powered monitors. Volume and gain settings carry over, so if you’re looking for that warm, saturated sound without cranking cans, this gets it done. Think of it as marinating your monitors in a slow-cooked tube stew — just without the calories and annoying 2 hours of scrubbing the pot clean.
Can I turn off the headphone jack when I’m using the preamp outs?
You don’t have to. The amp handles it like a pro. Plug in headphones? Preamp outs go dark. Unplug ’em? Preamp signal flows again. No switches, no drama, no spreadsheet required.
Can I roll tubes?
Of course. It’s basically encouraged. Swap the input tube (6N1P) for the usual suspects — 6DJ8, 6922, E88CC, ECC85, 6BZ7, whatever dusty gold you’ve hoarded. Just keep the heater current under 2.7A unless you enjoy the smell of burning regret.
schiit-valhalla-3-angle-black
The Bottom Line
For $499, Valhalla 3 gives you a fully Class-A, OTL/OCL, all-triode headphone amp and preamp that can actually drive real-world headphones — not just a museum exhibit of 600-ohm relics. It’s got modern protection, clever impedance tricks, and enough tube magic to make even your cold, solid-state heart question its life choices. You want specs? They’re here. You want character? It oozes. You want measurements that beat Magni+? Keep walking. But if you want a slice of sonic Valhalla with just enough Loki mischief baked in — this is it.
For more information: schiit.com/products/valhalla-3
6 Comments
6 Comments
  1. Anton Bunderland
    May 5, 2025 at 12:22 pm
    Sold and I don’t even own high impedance headphones.
    IKEA definitely needs to hire you to rewrite their catalog.
    • Ian White
      May 5, 2025 at 1:55 pm
      IKEA can’t afford me. Unless they want to pay me in furniture and all of those delicious salmon treats.
      I’m actually buying another tube headphone amp from Schiit as I don’t think I want that much heat on my desk — 12 inches from my hands, but this does intrigue me.
      IW
  2. Jamie Ward
    November 5, 2025 at 2:53 pm
    Schiit describes their own amp Valhalla 3 this way “Distortion: abysmal by modern standards, 1000x higher than most of the stuff we make, but has very nice triode profile” Seriously? I suppose the honesty should be appreciated, but even with your review, it sure makes me hesitate a LOT. Then again, I’m just learning about this stuff and looking for an amp for my Sennheiser 800S, so maybe “abysmal” distortion isn’t such a bad thing.
    • Jamie Ward
      November 6, 2025 at 1:59 pm
      OK, I’m replying to my own comment. After doing a little more research, I’m getting this headphone amp for my Sennheiser 800S headphones that are coming today. Using the word “abysmal” to describe your own product is either crazy or genius.
      • Ian White
        November 6, 2025 at 3:03 pm
        Jamie,
        In the case of Schiit…it’s usually a little of both.
        Enjoy. They do make great Schiit.
        IW
        • Jamie Ward
          November 7, 2025 at 6:46 pm
          Thanks for the reply. My new Sennheiser 800S sound so amazing using a much lesser amp that it blows me away. It’s hard to imagine them sounding better. Can’t wait for this amp!
Fosi Audio S3 Music Streamer Front Angle Silver with Orange Knob
Can the $259 Fosi Audio S3 streamer DAC and preamp challenge WiiM and Bluesound with balanced outputs and HDMI eARC despite missing key features?
LAiV Crescendo Verse DAC headphone amplifier lifestyle with headphones and IEMs LAiV Crescendo Verse DAC headphone amplifier lifestyle with headphones and IEMs
2026 Samsung QN70H and QN80H Neo QLED 4K TVs 2026 Samsung QN70H and QN80H Neo QLED 4K TVs
Samsung M80H and M70H Mini-LED 4K TVs Angle Samsung M80H and M70H Mini-LED 4K TVs Angle
Bravia 3, II TV with BRAVIA Home Theater Bar 9 and 2 BRAVIA Theater Sub 9s. Bravia 3, II TV with BRAVIA Home Theater Bar 9 and 2 BRAVIA Theater Sub 9s.
Sony just launched two new soundbars, new rear speakers and three new subwoofers plus the ability to add a second powered sub to their...
Sony BRAVIA 3, Mark II Sony BRAVIA 3, Mark II
Sony is bringing its renowned XR video processor for TVs to a much more affordable price point.
Schiit's Lyr 5 Headphone Amplifier at $799 combines tube and MOSFET gain with up to 6W output and Forkbeard control but skips balanced inputs...
Featuring Schiit’s new Continuity A output stage, Mesh DAC architecture, and Forkbeard app control, the Asgard X brings trickle-down Mjolnir tech to a powerful...
Dongle DACs
Power, neutrality, and a very affordable price. The iFi Audio GO Link gets a second listen and we think it's even better than we...
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
Lexus is pushing its first full-electric SUV with Miles Davis on classic vinyl and a gorgeous turntable from VPI, and we're fully on board.
Daily Deals
Why bother with under-performing soundbar-based surround sound systems when you can pick up this separates-based complete home theater for under $1,200?
