REL Serie S 2025 Subwoofers Bring State-of-the-Art Bass Honoring 35 Years of Subwoofer Innovation
Priced from $3,299 to $5,999, the REL Serie S 2025 subwoofers deliver deep, articulate bass, optional wireless, and Line Array towers because your neighbors probably don’t need peace and quiet.
REL Serie S Subwoofer Family 2025
REL Acoustics has long been a powerhouse in the subwoofer world, and the newly reimagined Serie S line proves just how far they’ve come since early legacy models like the Strata III, introduced in 1998. Once considered among the best subwoofers of their time, those designs have been surpassed over the years by successive Serie S generations—2014, 2016, and 2019—earning REL a reputation for creating some of the finest subwoofers for two-channel music systems.
The 2025 Serie S lineup features four models: the S/550, S/850, Carbon Special Black Label, and 212 Black Label, each engineered for faster, deeper, and more articulate bass. As REL lead designer John Hunter explains: “Serie S is our boldest statement yet. We took everything we’ve learned over three decades and re-engineered the line from the ground up—including drivers, amplifiers, cabinetry, and even wireless connectivity.”
The Serie S Sessions: Exploring REL’s 2025 Subwoofers
To mark its 35th anniversary and the launch of the Serie S, REL hosted a two-day experience in Berkeley, California—the hub of REL’s North America operations and home to its design and development team. The event gathered a select group of journalists, creators, and hi-fi enthusiasts for exclusive first listens of the new models, intimate music experiences across the Bay Area, and a behind-the-scenes recording session. (Our invitation must have gotten lost in the mail.)
As REL lead designer John Hunter explains: “REL has always been about connecting people to the emotional truth of music and film. Serie S Sessions gave guests a chance to feel that for themselves and to see how REL’s craft translates into real-world experiences.”
Sound and Space: How REL Serie S 2025 Subwoofers Transform Music and Room Dynamics
The Serie S subwoofers are engineered not just to amplify sound—they turn it into an immersive experience. With their refined, architectural design, REL says the Serie S can seamlessly integrate into any space.
Here’s a brief overview of how each Serie S model fits into REL’s implementation strategy:
rel-s550-black
S/550
S/550 ($3,200): The “entry-level” model in the Serie S line, the S/550 is a reinvention of REL’s previous S/510. It delivers greater scale and richer dynamics, powered by a 550-watt Pure Class D amplifier, a 10-inch driver, and a 12-inch passive radiator. Its compact footprint makes it ideal for both music and home theater systems.
rel-s850-white
S/850
S/850 ($3,999): Positioned in the “sweet spot” of the Serie S lineup, the S/850 is slightly larger than the S/550 and features an 850-watt amplifier, a 12-inch driver, and a 12-inch passive radiator. Engineered for detail, speed, and impact, it excels in music, home theater, and even gaming applications.
rel-carbon-special-black-label-grille
Carbon Special Black Label Subwoofers with wood grille or black cloth ($200 extra)
Carbon Special Black Label ($4,999): This model features a 12-inch pure carbon-fiber driver and 12-inch passive radiator, delivering ultra-fast, transparent bass powered by a 900-watt amplifier. It also includes a premium wood grille, standard on this model, whereas it is optional on the other Serie S models.
rel-212-black-label
212 Black Label (comes with black cloth cover, but wood grille option available for $600 more).
212 Black Label ($5,999): The flagship of the Serie S line, the 212 Black Label features 12-inch twin active drivers and 12-inch twin passive radiators, all powered by a 1,000-watt amplifier. Designed for large rooms, it delivers commanding bass that excels in home theater and music applications alike.
rel-airship
REL Airship Direct
All four Serie S models feature faster, lighter drivers with carbon-fiber refinements, redesigned passive radiators, and amplifiers with expanded headroom and control. They are compatible with REL’s Airship Direct high-resolution wireless system, which has an excellent track record and makes it easier for integrators to add these subwoofers to home theater setups without long and costly runs of cabling. Cabinet designs are wider and lower on select models for improved presence and are available with classic cloth or optional handcrafted wood grilles, combining architectural beauty with high-performance sound.
Line Array: REL Serie S 2025 Subs for Controlled, Immersive Low-End Performance
rel-s850-white-line-array
One intriguing way to set up the Serie S subwoofers (except the 212 Black Label) is in a Line Array configuration. Up to three subs can be stacked using REL Couplers (Line Array Connectors included with each compatible Serie S subwoofer), which link lower units to upper units. The couplers are solid, milled aluminum and, combined with the substantial rails on the underside of each cabinet, form an extremely heavy, sturdy bass tower.
When set up correctly—with dealer assistance, which should be a given at this price—the benefit isn’t just more low-end output: the system delivers better-balanced bass with fewer room issues. For those willing to invest in the experience, this setup will shake more than just the room—neighbors beware.
REL Serie S Subwoofers Comparison
Rel Serie S ModelS/550S/850Carbon Special Black Label212 Black Label
Price$3,299$3,999$4,999$5,999
Product TypeSubwooferSubwooferSubwooferSubwoofer
Driver Configuration1 x Front-firing active driver
1 x  down-firing passive radiator
2 x Front-firing active drivers
1 x  rear passive radiator
Driver1 x 10 in. (250mm) long-throw, CarbonAlloy™ cone structure, die cast alloy chassis1 x 12 in. (305mm) long-throw, CarbonAlloy™ cone structure, die cast alloy chassis1 x 12 in. (305mm) long-throw, carbon fibre cone with inverted carbon fibre centre cap, die cast alloy chassis2 x 12 in. (305mm) long-throw, CarbonAlloy™ cone structure, die cast alloy chassis
Passive Radiator Size and Material1 x 12 in. (305mm), Carbon/Carbon flat cone structure, steel chassis1 x 12 in. (305mm), Carbon/Carbon flat cone structure, steel chassis1 x 12 in. (305mm) long-throw, carbon fibre cone with inverted carbon fibre centre cap, die cast alloy chassisRear: 1 x 12 in. (305mm)CarbonAlloy™ cone structure, die cast alloy chassis
Down: 1 x 12 in. (305mm) CarbonAlloy™ cone structure, die cast alloy chassis
Low Frequency Extension-6 dB at 19Hz-6 dB at 19Hz-6 dB at 19Hz-6dB at 18 Hz
InputsHigh Level: 1 x Neutrik Speakon
Low Level
2 x  RCA
1 x  LFE RCA
1 x  LFE XLR
Low Level
2 x  RCA
1 x  LFE RCA
1 x  LFE XLR
Low Level
2 x  RCA
1 x  LFE RCA
1 x  LFE XLR
Low Level
2 x  RCA
1 x  LFE RCA
1 x  LFE XLR
OutputsHigh Level: 1 x Neutrik Speakon
Low Level:
1 x RCA
1 x LFE RCA
1 x LFE XLR
Low Level:
1 x RCA
1 x LFE RCA
1 x LFE XLR
High Level: :1 x Neutrik Speakon
Low Level:
1 x RCA
1 x LFE RCA
1 x LFE XLR
High Leve:l :1 x Neutrik Speakon
Low Level:
1 x RCA
1 x LFE RCA
1 x LFE XLR
Amplifier TypeLinear Class DLinear Class DLinear Class DLinear Class D
Power Output550 watts (RMS)850 watts (RMS)900 watts (RMS)1,000 watts (RMS)
Wireless Copability REL AirShip Direct (sold separately)REL AirShip Direct (sold separately)REL AirShip Direct (sold separately)REL AirShip Direct (sold separately)
Protection SystemFully Electronic Set Safe
D.C. Fault
Output Short
D.C. Fault
Output Short
D.C. Fault
Output Short
D.C. Fault
Output Short
Mains Input Voltage220-240 volts, 110-120 volts for certain markets220-240 volts, 110-120 volts for certain markets220-240 volts, 110-120 volts for certain markets220-240 volts, 110-120 volts for certain markets
Fuses8 Amp semi delay 220 volts operation
15 Amp semi delay 120 volts operation
Supplied AccessoriesMains Lead: Yes
Neutrik Speakon: Yes (10 Meters Nominal)
Mains Lead: Yes
Mains Lead: Yes
Mains Lead: Yes
Dimensions (WHD)17.5 x 14.75 x 19.75 in.
445 x 372 x 500 mm
19.25 x 16.125 x 21.25 in
488 x 410 x 540 mm
19.25 x 16.125 x 22.25 in.
488 x 410 x 565 mm
14.25 x 33 x 20.5 in.
362 x 840 x 523.3 mm
Weight68 lbs. (31 kg)93.5 lbs. (42.5 kg)98 lbs. (44.5 kg)134 lbs. (60.8 kg)
FinishPiano Black Lacquer, Gloss White Lacquer 8 coatsPiano Black Lacquer, Gloss White Lacquer 8 coatsPiano Black Lacquer 8 coatsPiano Black Lacquer 8 coats
What’s in the boxSerie S/550 Subwoofer
Power Cord
32′ Neutrik Speakon cable
Cloth Grille
Line Array Mounting Hardware
User Manual and Warranty Information
Serie S/850 Subwoofer
6′ AC Power Cord
Cloth Grille
Subwoofer
6′ AC Power
Cord
Premium Wood Grille
User Manual & Warranty Information
212 Black Label Subwoofer
Power Cord
Standard Black Cloth Grille
rel-s-serie-subwoofer-family-black
The Bottom Line
The REL Serie S subwoofers combine state-of-the-art design, exceptional performance, and thoughtful features like premium wood grilles and hardware for Line Array setups—but they come at a premium price. While REL remains a benchmark for high-end two-channel and home theater subwoofers, the category is fiercely competitive.
Brands such as Neumann, DALI, Velodyne, and SVS also offer models capable of delivering impressive bass performance at various price points. For buyers willing to invest, the Serie S provides unmatched refinement and flexibility, but savvy shoppers should weigh alternatives before committing.
Price & Availability
Serie S is now available through authorized REL dealers around the world and via REL Website:
Since its founding in 1990, REL has elevated subwoofer performance with breakthrough engineering and craftsmanship. It’s a small but passionate Berkeley team, headed up by CEO Alex Broday and Chief Designer John Hunter. The team is not only responsible for maintaining leadership in subwoofer design that continually redefines what is possible in Low-Frequency Sound, but they also handle all U.S. customer service directly, no bots, and no outsourcing.
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
MartinLogan Grotto 12 ($2,299) & 15 ($2,799) subwoofers deliver 2kW peak power, triple hybrid woofers and precise DSP.
At $1,199, the PSB SubSeries BP7 is a compact powered subwoofer offering precise, deep bass with dual 6-inch drivers.
MartinLogan Dynamo 10 Subwoofer delivers fast, controlled bass, wireless and wired options, ARC room correction, and furniture-friendly design for $1,199.
Meet the new apex predator of home theater bass: the Hsu Research D15-Chimera SC, a modular, dual 15-inch subwoofer that just made its explosive debut...
2025 “innovation”? Forget tech — it’s pastel colors and retro vibes. Why? Because Hi-Fi might finally be getting smart about style, and appealing to...
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
The REL Classic 99 subwoofer carries on the vintage design of the previously released Classic 98 but with a larger 12-inch driver and increased...
$30,000 for a subwoofer? The Wilson Audio Submerge might play down into the lower depths but can your wallet handle the hit.
