Questyle Unveils Flagship Sigma Portable DAC/Amps with Support for Bluetooth LE
Questyle’s Sigma Pro ($899) and Sigma ($599) portable DAC with headphone amplifiers offer Current Mode Amplification, Bluetooth LE, and LDAC.
Questyle Sigma Portable DAC Headphone Amplifier
There’s no shortage of desktop and portable DAC/headphone amps these days, making it harder than ever to know which ones truly stand out. Questyle, however, has spent nearly a decade leading the charge in digital audio players, desktop headphone amplifiers, and high-performance dongle DACs.
With the introduction of the new Sigma Pro and Sigma Flagship portable DAC/headphone amplifiers, Questyle brings its current mode amplification technology full circle—combining the company’s signature precision engineering with modern features like Bluetooth LE and LDAC support for today’s demanding listeners.
Previewed at CanJam London 2025, the new Questyle Sigma and Sigma Pro portable DAC/headphone amplifiers are set to launch in late October 2025 (Sigma) and early November 2025 (Sigma Pro).
Both models feature a precision-crafted chassis made from CNC-machined aluminum, topped with transparent glass and an RF signal suppression coating—a design that reflects Questyle’s obsession with build quality and signal purity.
Questyle Sigma Pro
questyle-sigma-pro-portable-dac-headphone-amp
Questyle Sigma Pro
The Sigma Pro is engineered to deliver the power, performance, and flexibility of a desktop DAC/headphone amplifier—packed into a far more convenient and portable design.
Key features of the Sigma Pro include the following:
  • Flagship DAC: Dual ESS ES9069 DAC chips in a dual-mono configuration deliver exceptional clarity and channel separation.
  • Amplification: Features Questyle’s Current Mode Amplifier technology, offering enough power to drive everything from sensitive IEMs to 300Ω headphones.
  • Connection Versatility: Equipped with 3.5mm, 4.4mm, and 6.35mm outputs, plus both analog and digital inputsfor maximum flexibility.
  • Recording Ready: Converts digital input signals to analog for playback or recording, compatible with home audio setups, studio monitors, and headphones.
  • Hi-Res Wireless Audio: Certified for Qualcomm Snapdragon Sound and Sony LDAC for high-resolution wireless streaming.
  • Portability: Up to 12 hours of battery life with dual USB-C ports that allow simultaneous charging and playback.
questyle-sigma-pro-front
Questyle Sigma
At $599, the Questyle Sigma portable DAC/amp is a step down from the Sigma Pro, although it shares many of its flagship sibling’s features, including Current Mode Amplification, balanced and unbalanced analog outputs, Qualcomm Snapdragon Sound, LDAC support, 768kHz/32-bit PCM playback, and DSD compatibility up to DSD512. It differs in using a single AKM AK4493 DAC chip and omits digital/coaxial/analog inputs, recording functionality, and multi-device monitoring, offering a high-quality experience at a more accessible price point.
questyle-sigma-connected-headphones
Questyle Sigma
Comparison
Questyle Sigma ProSigma
Product TypeDAC & Headphone amplifierDAC & Headphone amplifier
Price$899$599
USB InputPCM: 44.1kHz-768kHz/32-Bit
DSD Native: DSD64,DSD128,DSD256,DSD512, DSD
DoP: DSD64,DSD128,DSD256
MQA: MQA Rendering and Full MQA Decoding
Support UAC 2.0
WinXP/Vista/Win7/Win8/Win10/Win11/ Linux/Android/HarmonyOS/macOS and iOS
PCM: 44.1kHz-768kHz/32-bit
Support UAC 2.0
Optical Input PCM 44.1kHz~192kHz/24-Bit No
Coaxial Input  PCM 44.1kHz~192kHz/24-Bit No
Bluetooth Input Bluetooth 5.4 Support SBC/LE Audio/aptX/aptX HD/LDAC decodingBluetooth 5.4 Support SBC/LE Audio/aptX/aptX HD/LDAC decoding
Analog Input3.5mm SE IN: Standard level 1Vrms
4.4mm BAL IN: Standard level 2Vrms
No
Outputs6.35mm/3.5mm unbalanced output
4.4mm balanced output
Recording FunctionAnalog input recording and simultaneous monitoring 48kHz/24bit fixed samplingNo
Gain ControlThree gain settings for Line and Headphone outputs: L (Low), H (High), and S (Studio)
Two gain settings for IEM output: L (Low) and H (High)
Manual Gain Option
Output Power40mW @300Ω SE
160mW @300Ω BAL
1200mW @32Ω BAL
Peak Power Output>5W
1200mW@320 Balanced
THD+N0.0002% @48kHz 24bit 1kHz sine<0.0003% @20mW, 300Ω
SNR120dB120dB
Frequency Response (±0.8dB) 20Hz~20kHz(±0.1dB) 20Hz-20kHz
Battery Capacity4300mAh 3.7V4300mAh 3.7V
Battery LifeUp to 12 hours>12h
ChargingApproximately 3 hours to full charge.
Supports 5V/2A charging
Dedicated USB-C charging port with support for simultaneous charging and listening
Approximately 3.5 hours to full charge.
USB ChipXMOS XU316No separate USB Chip
DAC ChipDual ESS9069Q AKM AK4493
Amplifier CircuitFour sets of fully discrete current-mode amplifier designsFour sets of fully discrete current-mode amplifier designs
Volume Control360-degree rotary encoder with Mute buttonTraditional +/- level buttons
Apple MFi Certification YesYes
The Sigma Pro PackageSIGMA Pro Portable DAC with Headphone Amplifier
Type-A to Type-C adapter
Type-C to Type-C cable (120cm)
Warranty Card & User Manual
SIGMA Portable DAC with Headphone Amplifier
Type-C Charging Cable
questyle-sigma-usb
Questyle Sigma
The Bottom Line
Questyle’s Sigma Pro and Sigma portable DAC/headphone amplifiers continue the company’s nearly decade-long legacy of reliability, precise sound quality, and wide format support. Both models feature Current Mode Amplification, high-resolution wireless streaming with LDAC and Snapdragon Sound, and portable designs that make them ideal for on-the-go listening.
The Sigma Pro delivers flagship-level performance with dual DACs, multi-device connectivity, and recording capabilities, while the Sigma offers much of that same core functionality at a lower price point with a single DAC and simplified inputs. With impressive portability, robust build quality, and Questyle’s proven engineering, these could be the portable DAC/headphone amps that serious listeners should prioritize.
Price & Availability
  • Sigma Pro – $899 (coming November 2025)
  • Sigma$599 at Amazon (available now)
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
HiBy W4 packs aptX Lossless, LDAC, 475mW balanced output, and a touchscreen into a $99 portable Bluetooth DAC Amplifier.
Our favorite Dongle DACs in 2025 for audiophiles include models from Questyle, Audioengine, iFi and Campfire Audio.
With the Dongle DAC market shaking itself out in 2024, the $129 Questyle 15c leapfrogged the competition.
The Burson Conductor GT4 is a $3K audio sledgehammer—insanely powerful, deadly neutral, and hot enough to fry eggs. Upgradeable, versatile, and built like a...
Cayin RU9 delivers tube warmth, solid-state detail, strong power, and rare versatility in a pocketable DAC/amp with one drawback.
The 2025 Chord Mojo 2 portable DAC/Amplifier gets a psuedo-balanced 4.4 mm socket and USB-C charging convenience, while price unchanged.
Discover the FiiO K15 DAC Headphone Amp: A powerful, affordable desktop solution offering balanced audio, Wi-Fi, and Bluetooth, all for $549. Compare with top...
Dongle DACs
Questyle’s QCC ($59) and QCC Pro ($99) finally bring aptX Adaptive and LDAC to iPhone and iPad, giving Apple users higher resolution Bluetooth audio.
