Pro-Ject’s Peanuts 75th Anniversary Turntable: Just Like Charlie Brown’s Football, It Looks Perfect—But Will It Spin Without Getting Pulled Away?
Celebrate 75 years of Peanuts with Pro-Ject’s limited edition turntable, featuring hi-fi tech, Bluetooth, and Schroeder-approved specs—finally, a reason Linus might drop the blanket.
Pro-Ject Peanuts 75th Anniversary Turntable with Charlie Brown Platter
Back on October 2, 1950, Charles M. Schulz dropped a little comic strip called Peanuts featuring the forever hopeful round-headed kid we all know as Charlie Brown. Fast forward to 2025, and Peanuts is celebrating its 75th anniversary—still going strong, thanks to a cast of unforgettable characters. Of course, Snoopy remains the undeniable star, the coolest beagle ever to grace a comic strip.
As longtime fans, Pro-Ject Audio Systems decided to mark this milestone with a special turntable release. They collaborated on a unique design featuring comic-inspired artwork tied to music themes—part of their Artist Collection that’s already given us killer editions like AC/DC, Metallica, and Sgt. Pepper, all of which flew off the shelves. This Peanuts turntable fits right into that lineup, blending nostalgia with serious style and Pro-Ject’s signature build quality.
peanuts-turntable-75-years-sticker
Charlie Brown and the Peanuts gang have stayed surprisingly popular over the decades, and part of that lasting charm comes from Vince Guaraldi—the pianist and composer whose A Charlie Brown Christmas soundtrack is nothing short of iconic. Growing up before the internet era, we often wondered what happened to Guaraldi beyond that breakthrough success and his string of late ’60s Warner Brothers albums. Sadly, he passed away in 1976, and it seemed like his official releases dried up after 1970’s A Boy Named Charlie Brown soundtrack.
Thankfully, Guaraldi’s music didn’t just vanish. After his death, there were numerous posthumous releases, including a slew of children’s read-along comic book-style story records on Charlie Brown Records in the late ’70s that featured his music. His son kept the legacy alive by releasing archival CDs in the early 2000s with previously unreleased live performances and studio sessions—definitely worth tracking down. On top of that, compilations and rarities from labels like Fantasy and Omnivore Records have surfaced over the years.
More recently, Lee Mendelson Film Productions—the creators behind the Peanuts TV specials—have been filling in the gaps with previously unreleased official soundtracks from Guaraldi’s work on various Peanuts animated shows. It’s a solid way to keep his timeless music alive for longtime fans and new listeners alike.
pro-ject-peanuts-turntable
Peanuts Turntable Limited Special Edition: Even Linus Would Drop His Blanket for This One
The Limited Edition Peanuts Turntable may have Charlie Brown’s face on it, but this thing is no blockhead. Based on Pro-Ject’s T1 BT model, it’s a legit audiophile entry-level turntable that brings real hi-fi chops to the table—just with a whole lot more personality.
It’s built around an 8.6″ premium aluminum tonearm that’s both lightweight and rigid, paired with a pre-installed Ortofon OM 10 cartridge. That’s not a throwaway stylus—it’s a legit upgrade over the usual bundled suspects and comes factory-aligned for plug-and-play use.
The drive system uses a belt connected to a custom sub-platter, which sits in a precision-machined main bearing with a hardened steel axle and brass bushing. Translation: your records spin with dead-on stability. That’s helped by a thick, zero-resonance glass platter—none of that cheap plastic or flimsy steel nonsense.
pro-ject-peanuts-turntable-outputs
And yes, it’s Bluetooth-enabled. You can stream wirelessly to your favorite Bluetooth speakers or headphones if you want the convenience without extra gear. A built-in phono preamp means you don’t need a separate phono stage—just hook it up and go.
To top it off (literally), you get a custom acrylic platter mat featuring none other than good ol’ Charlie Brown. It sits right on the glass platter—because if you’re going to spin records, you might as well do it with style and a little Schulz snark.
peanuts-tonearm
Specifications
  • Peanuts Turntable Limited Edition (Based on the Pro-Ject T1 BT platform)
  • Speeds: 33⅓ & 45 RPM (manual change)
  • Drive: Belt drive
  • Speed Variance: ±0.7% (33), ±0.6% (45)
  • Wow & Flutter: 0.25% (33), 0.23% (45)
  • Platter: 8mm heavy glass with felt mat + acrylic Charlie Brown slipmat
  • Main Bearing: Stainless steel axle with brass bushing
  • Signal-to-Noise: 65 dB
  • Tonearm: 8.6″ aluminum, 8g mass, 17.5 mN tracking force (pre-set)
  • Cartridge: Ortofon OM 10 MM (pre-mounted)
  • Outputs: RCA Line, RCA Phono (switchable), Bluetooth 5.0
  • Accessories: Dust cover, felt mat, RCA cable, external power supply
  • Power: 110–240V (15V DC, 800mA), 3W max
  • Dimensions: 16.3″ x 3.9″ x 13.2″ (W x H x D)
  • Weight: 8.4 lbs (3.8 kg)
“As big fans of Peanuts at Pro-Ject Audio Systems, we wanted to celebrate this anniversary with a very special turntable,” said Heinz Lichtenegger, CEO and founder of Pro-Ject Audio Systems. “We teamed up and designed the turntable artwork with music-related comic snippets and a special Charlie Brown acrylic record plate.”
The Pro-Ject Peanuts Turntable just landed in June through authorized Pro-Ject dealers, priced at £579 / €599 in the UK and EU via Henley Audio. U.S. pricing and availability are still to be confirmed, but expect it to show up soon—likely with Snoopy riding shotgun.
pro-ject-peanuts-turntable-detail
The Bottom Line
The Pro-Ject Peanuts Turntable isn’t just another novelty deck—it’s a fully functional audiophile-grade T1 BT wrapped in Schulz-style nostalgia. With a legit Ortofon OM 10 cartridge, aluminum tonearm, thick glass platter, built-in phono stage, and Bluetooth streaming, it’s got the specs to back up the comic strip charm. This isn’t just for fans of Snoopy and Schroeder—it’s for anyone who wants real hi-fi with a side of childhood memories.
Sure, Lucy might still yank the football away, but at least your records will spin flawlessly while she does it.
Where to buy: €599 at Pro-Ject Audio
4 Comments
4 Comments
  1. Anton
    July 16, 2025 at 9:11 pm
    I have seen some of the other artist series models in record stores, and they apparently sell rather well. The Metallica and AC/DC models are actually quite expensive.
    • Ian White
      July 16, 2025 at 9:17 pm
      We reviewed the Sgt. Pepper model and the reviewer loved it so much that she bought it.
      I’ve seen the Metallica table up close and it’s not using cheap components. Platter is high quality.
      The AC/DC table is definitely different.
      Charlie Brown records sell out very quickly these days. One of the most popular RSD releases every year.
  2. ORT
    July 20, 2025 at 7:51 pm
    Hail and well meet to all!
    I am thee definite Pro-Ject Enthusiast having 4 of their tables, 3 of which are Beatles Editions (Sgt.Peppers Drum Kit, Beatles ’64 and Beatles Singles ‘tables!). Since I am something of a (minor) Supreme Peanuts Enthusiast, I contacted Heinz Lichtenegger via email and he said these are not yet available in America, even to such as I…He kindly told me that maybe they could arraign to send one directly to me but I politely declined (a true Herculean effort on my part (believe me!) and told him I would wait and save until they are here in The U! S! A! I also thanked him for his kindness. Heinz is a friend and a gentleman.
    I want one just because it’s Peanuts Stuff by Pro-Ject. So freakin’ COOOOOOOOOOOL!!
    I also want a few motorbikes and to visit Australia and the United Kingdom. I’ll be lucky to get the Peanuts ‘table!
    The ORTacle at Helfi
    • Ian White
      July 21, 2025 at 12:32 pm
      ORT,
      This table will be a hit.
      For nostalgia reasons alone.
      IW
Sony True RGB TV compared to BRAVIA 9 Mini LED TV.
2026 Samsung Music Studio 7 Wireless Speakers Lifestyle 2026 Samsung Music Studio 7 Wireless Speakers Lifestyle
Samsung's Music Studio 7 and 5 Wi-Fi speakers debut with bold design, multi-room flexibility, and Atmos support, but can they challenge Sonos and Bluesound?
2026 Samsung HW-S990H Soundbar Lifestyle 2026 Samsung HW-S990H Soundbar Lifestyle
Samsung’s 2026 Q-Series soundbars build on Wireless Dolby Atmos, Q Symphony, and SpaceFit with options from full surround systems to all in one designs....
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Craft Recordings brings Vince Guaraldi and Bola Sete’s From All Sides back on 180g vinyl with RTI pressing, offering clean sound as original copies...
Vince Guaraldi’s final Peanuts recordings arrive on eco friendly bio vinyl for It’s Arbor Day Charlie Brown with rare tracks and real environmental impact.
At $899, the Technics SL-40CBT Bluetooth Direct Drive Turntable features aptX Adaptive, built-in MM phono stage and three finishes.
Technics ends the SL-1200/1210G run with two Grand Class Master Edition turntables in black or silver with even better performance and fancy gold accents.
Pro-Ject unveils the Debut Reference 10 and names a new U.S. distributor. With pricing updates and tariff shifts looming, what changes for buyers?
Craft Recordings’ Original Jazz Classics series kicks off 2026 with AAA reissues of From All Sides, Alone in San Francisco, and Full House on...
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Lexus is pushing its first full-electric SUV with Miles Davis on classic vinyl and a gorgeous turntable from VPI, and we're fully on board.
