Optoma UHZ36 4K Laser Projector Adds Filmmaker Mode, Pure Engine, and DuraCore Laser Technology
Does Optoma’s $1,299 UHZ36 deliver the right balance of brightness, gaming performance, and Filmmaker Mode upgrades or are key features missing for serious installs?
Optoma UHZ36 4K Laser Projector Lifestyle
Optoma has expanded its 4K laser lineup with the UHZ36, a $1,299 4K UHD projector aimed squarely at budget-conscious home entertainment buyers who want one box that can handle movies, TV, and gaming without demanding a blacked-out room. With 3,500 lumens of laser light output in a compact chassis, the UHZ36 is designed for flexible, lights-on viewing and everyday use. It builds on the platform established by Optoma’s UHZ35 (DuraCore laser) and UHD35x (lamp), but refines the formula for broader appeal rather than custom-install priorities.
4K Resolution via Pixel Shifting
DLP 4K Pixel Shifting
Like the UHZ35, UHD35x, and most value-oriented 4K UHD DLP projectors, the UHZ36 relies on a 0.47-inch 1080p DLP imaging chip (DMD — Digital Micromirror Device) from Texas Instruments. That chip contains roughly 2.1 million microscopic mirrors, far short of the 8.3 million pixels required for native 4K resolution. To bridge that gap, the UHZ36 uses high-speed pixel shifting, rapidly offsetting each pixel both vertically and horizontally at 240 Hz. The process happens so quickly that the full pixel grid is rendered within a single frame, allowing the projected image to meet UHD 4K classification standards once it hits the screen.
Optoma DuraCore Laser: 30,000 Hours of Use, No Brightness Drop
optoma-uhz36-4k-laser-projector-front
The UHZ36 continues Optoma’s shift away from traditional projector lamps in favor of a solid-state laser light source, eliminating the need for lamp replacements every 2,000 to 5,000 hours. Its laser engine is rated for up to 30,000 hours of use, significantly reducing long-term maintenance and ownership costs.
At the core of this design is Optoma’s DuraCore laser technology, which is engineered to maintain stable brightness and color performance across its entire lifespan, without the gradual light decay associated with lamp-based systems. There’s no warm-up delay, shutdown times are shorter, and the mercury-free laser light source makes the UHZ36 a more environmentally friendly option.
Reliability is further enhanced by an airtight optical engine with IP6X certification, preventing dust intrusion that can degrade image quality over time. The result is a compact 4K laser projector designed for consistent performance, lower maintenance, and long-term durability—without the usual projector headaches.
optoma-uhz36-remote
Gaming Support
As with the UHZ35 and UHD35x, the UHZ36 supports 4K at 60 Hz and 1080p at up to 240 Hz, making it well-suited for both console and PC gaming. Optoma also includes MEMC (Motion Estimation, Motion Compensation)processing to improve motion clarity for fast-moving content.
At 1080p/240 Hz, input lag drops to an impressive 4 ms, a clear win for competitive PC gamers who care about responsiveness. At 4K/60 Hz, input lag measures 16 ms, keeping the UHZ36 firmly in console-friendly territory. The combination of high refresh rates and low latency gives the UHZ36 the flexibility to handle everything from high-frame-rate PC titles to modern 4K gaming consoles without compromise.
optoma-uhz36-4k-laser-projector-rear
New features on the UHZ36
The UHZ36 adds several picture-focused upgrades aimed squarely at improving out-of-the-box image accuracy and motion handling.
Filmmaker Mode is now included, allowing viewers to disable artificial motion smoothing that leads to the dreaded “soap opera” effect. When engaged, the projector preserves the original film frame rate, color balance, and contrast, delivering a more cinematic presentation that aligns with the filmmaker’s intent rather than algorithmic guesswork.
Optoma also introduces its Pure Engine image processing platform, built around three core elements designed to fine-tune image performance:
  • PureDetail uses advanced algorithms to enhance fine textures such as hair, fabric, and skin detail without over-sharpening.
  • PureContrast improves dynamic range, delivering deeper blacks and brighter highlights for greater perceived depth.
  • PureMotion refines motion processing to produce smoother, more natural-looking action in fast-moving scenes.
Together, Filmmaker Mode and Pure Engine give the UHZ36 more control over image presentation, letting users choose between accuracy and enhancement rather than forcing one-size-fits-all processing.
Comparison
UHZ36
(2026)
UHZ35
(2024)
UHD35x
(2023)
Price$1,299$1,699$999
Projector Type1-Chip DLP1-Chip DLP1-Chip DLP
Throw TypeStandardStandardStandard
Display Resolution4K UHD (3840 x 2160) via pixel shifting4K UHD (3840 x 2160) via pixel shifting4K UHD (3840 x 2160) via pixel shifting
Brightness (White Light Output)3,500 ANSI lumens 3,500 ANSI lumens 3,600 ANSI lumens 
Contrast Ratio1,500,000:1500,000:11,000,000:1
Light SourceDuraCore laserDuraCore laser   Lamp 240w
Light Source HoursUp to 30,000 use hours (in Eco Mode)Up to 30,000 use hours (in Eco Mode)4000 (Bright)
15000 (Dynamic),
10000 (Eco)
Screen Size Range28 to 300 inches (diagonal 16×9 Aspect Ratio)26 to 300 inches (diagonal 16×9 Aspect Ratio)31 to 300 inches (diagonal 16×9 Aspect Ratio)
Projection Distance28 to 300 inches51.18 to 370.08 inches47.64 to 389.76 inches
Zoom Ratio (manual)1.31.61.1
Lens ShiftN/AN/AN/A
Keystone CorrectionHorizontal (±30 degrees)
Vertical (±30 degrees)
Horizontal (±40 degrees)
Vertical (±40 degrees)
Gaming SupportBuilt-in Enhanced Gaming Mode with 4ms response time in 1080p at 240Hz and 16.9ms response time in 4K at 60HzBuilt-in Enhanced Gaming Mode with 4ms response time in 1080p at 240Hz and 16.9ms response time in 4K at 60HzBuilt-in Enhanced Gaming Mode with 4.2ms response time in 1080p at 240Hz and 16ms response time in 4K at 60Hz
3D w/glassesYesYesYes
HDR SupportHDR10, HLGHDR10, HLGHDR10, HLG
Filmmaker ModeYesNoNo
Inputs1 x HDMI 2.0
1 x HDMI ARC
1 x HDMI 2.0,
1 x HDMI eARC
2 x HDMI 2.0
ARC Audio Format SupportDolby Digital 2.0
Dolby Digital 5.1
TrueHD 5.1
Dolby Digital 2.0
Dolby Digital 5.1
Not Indicated
Outputs1 x Audio out 3.5mm
1 x USB-A power 1.5A,
1 x Audio 3.5mm,
1 x USB-A (power 1.5A)
1 x Audio 3.5mm,
1 x S/PDIF
ControlWireless Remote
1 x RS232
1 x 12V trigger
Wireless Remote,
1 x RS232,
1 x RJ45 (compatible with AMX, Crestron RoomView, Extron IPLink)
Wireless Remote,
1 x RS232
Built-in Speaker1 x 15W speaker 1 x 15W speaker 1 x 10W speaker 
WiSA CertifiedNot IndicatedYes Not Indicated
Fan Noise (min/max)28 dB/33 dB28 dB/35 dB26 dB/28 dB
IP ratingIP6XIP6XNot Indicated
Dimensions (WxDxH)10.8 x 8.5 x 4.5 inches10.79 x 8.5 x 4.49 inches12.4 x 10.63 x 4.65 inhces
Weight7.8 lbs6.61 lbs8.77 lbs
Optional Wireless ModuleUHDCast ProUHDCast ProNot Indicated
The Bottom Line
The UHZ36 is a measured but deliberate step forward in Optoma’s 4K laser lineup. It keeps the proven performance foundation of the UHZ35 and UHD35x intact, while adding Filmmaker Mode and the new Pure Engine processing suite for viewers who care more about image accuracy and refined motion than installer-driven extras. Those upgrades meaningfully improve everyday movie and TV viewing, even if they don’t rewrite the spec sheet.
What the UHZ36 does not target is the custom-install crowd; WiSA certification and advanced control options are absent, and that’s not an accident. This projector is clearly aimed at value-focused home entertainment and gaming users who want bright, low-latency 4K laser performance with better picture tuning at a realistic price point. If you’re building a living-room or mixed-use setup and want strong image quality without paying for features you’ll never use, the UHZ36 might make a lot of sense.
Price & Availability
The Optoma UHZ36 is available for $1,299 at Amazon
Kaleidescape Terra Prime Movie Server
Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle
Soundboks Mix delivers 72-watts Class D amplification, Bluetooth, and pro-level SKAA wireless with volume that goes to 11. Is it the right party speaker...
Shanling SM90 Music Streamer Angle Shanling SM90 Music Streamer Angle
Shanling SM90 adds HDMI ARC, dual AKM DACs, and Android streaming under $1,000, but can it stand out in a crowded streamer market?
JBL PartyBox On-the-go 2 Plus Portable Bluetooth Speaker at Beach JBL PartyBox On-the-go 2 Plus Portable Bluetooth Speaker at Beach
JBL PartyBox On The Go 2 Plus adds AI karaoke with real time vocal removal, EasySing mics, and Auracast. Is this the future of...
Beats by Dre Powerbeats Pro 2 Nike Special Edition Wireless Earbuds Beats by Dre Powerbeats Pro 2 Nike Special Edition Wireless Earbuds
Beats and Nike team up for Powerbeats Pro 2 Special Edition with fitness features, bold design, and zero upgrades under the hood. Smart move...
BenQ’s W5850 targets serious home theater enthusiasts with laser brightness, factory calibration, and film-first features—but at a higher price and with notable omissions.
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
Projectors & Screens
Sony's VPL-VW6100ES BRAVIA Projector 8 offers stunning big screen home theater performance at a hefty price.
Compare every 2025 ultra-short throw (UST) 4K projector to decide which one is right for you.
LG CineBeam S is a compact 4K ultra short throw projector with RGB laser, smart streaming and Dolby Atmos for tight spaces.
With 5,000 ISO lumens, full DCI-P3 color, and support for screens up to 250 inches, the TITAN is built to handle almost any venue.
Priced from $1,699 to $2,999, XGIMI’s HORIZON 20 Series projectors offer high brightness, HDR and Harman/Kardon audio with Google TV.
