MOON is back at it out of Montreal, proving that 45 years of French-Canadian hi-fi chops aren’t just for show. The new MOON 371 Network Player/Amplifier kicks off the Compass Collection, MOON’s latest play in high-end audio, slotting just below the North Collection while quietly stealing some of its award-winning thunder.
Thanks to proprietary tech like the MHP power supply and MDCA distortion-cancelling amplifier, the 371 channels the North Collection’s pedigree without asking for the North-level price tag—which might be more than 4 season tickets for the Canadiens at the Bell Centre. Not inexpensive.
Stylish, smart, and built to last—with a 10-year warranty—this is MOON’s invitation to enter the world of uncompromising Canadian hi-fi… if you can handle the subtle snub that even their “entry-level” model is built to compete with anything below $10,000.
The 371 isn’t just borrowing a few ideas; it’s trickling down tech straight from MOON’s North Collection heavy hitters. The aforementioned MHP power supply and MDCA amplifier, previously reserved for the higher-end North Collection, now show up in the 371, giving it power and clarity that make you forget it’s technically “entry-level” Compass gear.
It’s like giving the little sibling the keys to the luxury car—the 371 inherits the sound DNA of MOON’s most celebrated models without asking for a North-level price tag—$6,500 USD or $8,800 Canadian Loonies—which is what Nick Suzuki makes playing one period for the Canadiens.
Pair that with control options—from the sleek CRM-4 remote to the full-color BRM-1 from the North Collection—and the 371 doesn’t just follow the North Collection, it flirts with it. Streamlined design, premium construction, and intuitive operation make it clear: MOON isn’t offering a watered-down experience here; the Compass Collection is a proper entry point into their high-end world, with just enough North Collection pedigree to make you smirk
MOON 371 Network Player/Amplifier: Streaming, Phono, and Bomb-Proof Build Quality
The MOON 371 is the Swiss Army knife of modern hi-fi—network player, amplifier, DAC, preamplifier, and phono stage, all packed into a single, handsome Canadian-made enclosure. As the entry point to MOON’s Compass Collection, it sets a bold benchmark for what a modern, versatile audio system should deliver.
Refined connectivity. MOON’s MiND 2 streaming platform gives you access to Tidal, Qobuz, Deezer, and Spotify, while also supporting Apple AirPlay, Roon Ready, Qobuz Connect, Spotify Connect, and TIDAL Connect. Bluetooth is on board too, so yes, you can finally stream that playlist from your phone without guilt.
Vinyl lovers, rejoice. The 371 sports a built-in MM/MC phono stage that channels the spirit of MOON’s award-winning phono gear, like the 810LP, delivering precise, detailed analog playback.
Trickle-down tech, eh? Borrowing from MOON’s flagship North Collection, the 371 integrates the MHP (MOON Hybrid Power supply) and MDCA (MOON Distortion Cancelling Amplifier). That means ultra-stable power, almost zero distortion, and shockingly linear, dynamic sound—basically giving Compass Collection owners a taste of North-level pedigree without mortgaging their cabin in the Laurentians.
The phono stage in the MOON 371 isn’t an afterthought—it delivers 40 dB of gain for MM cartridges and 60 dB for MC, making it flexible enough to handle everything from entry-level moving magnets to more demanding moving coils.
On the digital side, the integrated DAC is fully modern, capable of decoding hi-res files up to 32-bit/384 kHz PCM and DSD256, ensuring streaming and local playback sound as clean and dynamic as MOON’s analog pedigree demands. It’s basically old-school vinyl credibility meeting digital firepower, wrapped in one chassis.
Inputs & Outputs
The MOON 371 doesn’t just sound impressive—it plays well with everything you throw at it. Analog options include a phono RCA input with grounding post, a single RCA line-level input, and a balanced XLR input. Digital connectivity covers two SPDIF inputs, one TOSLINK optical input, HDMI ARC, and USB Type-C ports for both service and smartphone streaming. Networking is handled by two Ethernet ports, while output options include one RCA analog output and a robust pair of speaker binding posts.
Key Features & Specifications
Design & Features
- MDCA – MOON Distortion-Cancelling Amplifier
- MHP – MOON Hybrid Power supply
- MiND 2 – Streaming platform
- Phono Stage – Supports MM/MC cartridges
- MOONLink – For system integration
- Large Colour Screen – 17 cm display for settings and album art
- CRM-4 Remote Control – Aluminium, designed for Compass Collection
Audio Specifications
- Output Power (Stereo 8 Ω): 100 W
- Output Power (Stereo 4 Ω): 200 W
- Input Sensitivity: 0.3 V – 4 V
- Input Impedance: 9.5 kΩ
- Gain: 40 dB
- Frequency Response: 5 Hz – 100 kHz (+0/-3 dB)
- Total Harmonic Distortion + Noise (@ 1 W): 0.009%
- Total Harmonic Distortion + Noise (@ 100 W): 0.003%
- Intermodulation Distortion: 0.005%
- Signal-to-Noise Ratio: 108 dB
- Crosstalk: –108 dB
- Damping Factor: 425
Power Consumption
- Idle: 30 W
- Full Power Standby: 28 W
- Low Power Standby: 6 W
Physical Dimensions & Weight
- Width x Height x Depth: 16.9 × 3.5 × 15.2 in / 42.9 × 8.7 × 38.5 cm
- Shipping Weight: 20 lbs / 9 kg
The Bottom Line
The MOON 371 lands as a serious contender in the all-in-one category, blending North Collection trickle-down techlike the MHP power supply and MDCA distortion-cancelling amplifier with a full suite of modern features: MiND 2 streaming, 32-bit/384 kHz PCM and DSD256 DAC support, and a versatile phono stage with 40 dB MM and 60 dB MC gain.
Add in HDMI ARC, balanced and unbalanced analog inputs, robust digital connectivity, and MOON’s trademark Canadian build quality with a 10-year warranty, and you’re looking at a package that’s equal parts elegant and formidable.
At its asking price, the 371’s most obvious competition is heavyweights like the Naim Uniti Nova Power Edition—and based on what’s inside the Compass Collection’s debut, MOON looks more than ready for that fight.
Where to buy: $6,500 at Simaudio
Related Reading:
- Naim Uniti Nova Power Edition Review: A Heavyweight Streaming Amp That Leaves WiiM And Eversolo In The Dust?
- Bluesound’s New POWERNODE Has One Big Feature Other Streaming Amps Lack
- Cary Audio DMS-300A Streaming Amplifier: Because Clearly We Needed One More High-End Model For The Royal Rumble
- NAD M33 V2 & M23 V2 Crash High End Munich: Canadian Hi-Fi Invades, Apologizes, Then Sounds Better Anyway
David
October 1, 2025 at 3:23 pm
Hello Ian,
MDCA amp? I looked this up on Moon’s website but it’s all jargon and gobbledygook to me. It appears to be a high-current design as it doubles output into 4 ohms but is this a class D or AB or what?
David
Ian White
October 1, 2025 at 3:58 pm
David,
From Simaudio. “We’ve developed MDCA (Moon Distortion Cancelling Amplifier) technology, which fully aligns with our goal of achieving the highest level of sonic reproduction. Alongside it, the MHP (Moon Hybrid Power) supply combines the strengths of both traditional linear and modern switching designs—offering a more advanced solution than relying on a purely linear supply. If Class D amplification eventually surpasses what we have now, I might reconsider. But the purpose of MHP is to extract the best qualities from both linear and switch-mode topologies. The early stages use a switch-mode design, making it far less sensitive to AC mains fluctuations and line noise—significant advantages in real-world use. The second stage adds linear voltage regulation, which makes it a true hybrid. While this approach may be slightly less efficient than a pure Class D design, the result is cleaner DC output delivered to the audio circuitry, with none of the switching artifacts that can compromise sound quality.”
IW
Anton
October 2, 2025 at 6:33 pm
What the hell does that even mean? Sounds like a fancy long-winded answer from them that it’s sorta Class D, but we’re not willing to share the secret sauce and let consumers know how it really works. Does look well made. Not sure if I’d spend that kind of money on a network amplifier but NAD seems to be doing ok with their Master Series.
Ian White
October 3, 2025 at 4:16 pm
Anton,
It’s definitely not class A/B.
The weight should give it away. I had the MOON integrated amplifier here a few months ago for a listen and it weighed enough that I asked my son to help me move it.
Class A/B with a huge output transformer and bullet-proof chassis. One of the most impressive amplifiers I’ve seen or heard in many years.
IW
David
October 1, 2025 at 7:03 pm
Insert Bill the Cat illustration. “Ack! More goddledygook.”
Bill SpatialGuy
October 2, 2025 at 3:00 am
$6500 for a streaming player that doesn’t function to the highest levels of spatial audio? Pure lunacy.
Anton
October 2, 2025 at 6:34 pm
Not sure I get your point. Who cares if it does “spatial” audio. It’s not an AVR.
Chris Boylan
October 8, 2025 at 6:43 pm
I’m with ya, Bill. The Audio Network streamers (powered or otherwise) have been super slow to embrace multi-channel spatial audio like Dolby Atmos music or 360 Reality Audio. I had hoped when the companies like WiiM, Denon and Bluesound (and now Simaudio) started including an HDMI port on their streamers that it would mean support for Dolby Atmos music from TIDAL, Apple Music and Amazon Music, but nope. The HDMI/ARC or eARC ports on these streamers are mostly just to allow a powered (or unpowered) streamer to handle TV sound in two channel mode.
