Klipsch KO-R1 Limited Edition: OJAS Hosts ‘Exclusive’ Listening Sessions at RubenBenjamin Studio in Munich – Leb das Leben, bevor es dich überholt!
Join renowned audio designer Devon Turnbull for exclusive listening sessions featuring the Klipsch kO-R1 Limited Edition loudspeakers at RubenBenjamin Studio in Munich on May 16-17.
Ojas in High End Munich 2025
At the last High End Munich Show, one of the best Hi-Fi demos might just happen to be offsite, because why limit yourself to the usual six-figure stereo systems crammed into windowless booths? This could be your chance to experience something a bit more, dare we say, genuine—like Munich’s vibrant nightlife and culture. Forget the typical show floor chaos and let your ears (and liver) enjoy something truly memorable. Who knows? You might even find that the city’s beer gardens offer better acoustics than some of those “ultra-high-end” setups.
Devon Turnbull, the mastermind behind OJAS, is hosting exclusive listening sessions with the Klipsch kO-R1 Limited Edition loudspeakers at RubenBenjamin Studio in Munich on May 16 and 17. From 2:00 PM to 6:00 PM each day, you’ll get a rare chance to hear Turnbull’s signature sound philosophy in a setup designed to let the speakers shine.
Das ist wie ein Bratwurst ohne Senf – es mag funktionieren, aber es fehlt einfach etwas Wichtiges.”
And that, my friends, is exactly how this unique speaker might hit you—less about chasing measurements and more about hitting you right in the feels. While the show floor is full of $200,000 speakers made from indestructible nanotech and stones harder than your last relationship, this little gem isn’t here to impress the measurement crowd. It’s here to remind you that sometimes, the best things in life aren’t built to withstand a lab test—they’re built to make you feel something real.
And let’s just say, I owe some of that perspective to being raised in a house where German, Yiddish, and Polish weren’t just languages—they were a crash course in authenticity and finding the heart in the details.
klipsch-ojas-ko-r1-spiral-red-oak-loudspeaker
Klipsch + Ojas kO-R1 Limited Edition Loudspeaker (spiral red oak)
Klipsch kO-R1 Limited Edition – For Audiophile Royalty (Or German Aristocrats, Really)
Yeah, we all did a double-take when we saw the price, but let’s be real—Klipsch and Devon Turnbull will have no problem moving every single pair of these. Klipsch has teamed up with Turnbull, the mastermind behind OJAS, and the result is the debut of the kO-R1 horn-loaded loudspeaker. It’s the perfect blend of minimalist design and bespoke craftsmanship, all wrapped up in the horn tech Klipsch has been perfecting for the last 75 years.
The kO-R1 pulls inspiration from the Klipsch Heresy, but with a sleek, modern twist. It’s got a multicell design and an enclosure crafted from butt-joined Baltic birch plywood—fancy, right? Then there’s the exposed biradial horn made of sand-cast aluminum.
Oh, and don’t forget the adjustable horn mount, anodized aluminum binding posts, and anti-vibration rubber feet. To really make you feel special, it even comes with a five-step high-frequency gain attenuator for precise sound tuning and a laser-engraved metal ID plate because, well, exclusivity.
Each limited edition kO-R1 comes with the Klipsch K-12 speaker stand to ensure optimal height and presentation. Choose between two finishes: Spiral Red Oak or Pewter Grey.
klipsch-ojas-ko-r1-pewter-gray-loudspeaker
Klipsch + Ojas kO-R1 Limited Edition Loudspeaker (pewter gray)
Specifications
  • Speaker Configuration: 2-way, Bookshelf/Stand Mounted
  • Frequency Response: 51 Hz – 20kHz (+/- 3dB), 40 Hz – 21kHz  (-10dB)
  • Power Handling: 200W  (28.3V)  40 Hz – 10kHz
  • Max SPL Continuous Output: 117db  40 Hz – 10kHz
  • Sensitivity: 97.5 db @ 2.83V
  • Crossover Point: 970 Hz
  • Horizontal Coverage Pattern: 90 degrees, +/- 30 degress, 600Hz to 15kHz
  • Vertical Coverage Pattern: 60 degrees, +/- 30 degress, 2kHz to 15kHz
  • Nominal Impedance:  8 ohms (4.40-ohm min. @ 133 Hz)
  • Transducers: K-28-E 12” Woofer; K-706 HF Driver
  • Enclosure: Slotted Vent (bass reflex) system
  • Enclosure Material: 13-ply Grade A Baltic Birch Plywood
  • Connection Terminals: 5-way binding posts
  • Dimensions (WHD): 16.5″ (42cm)  x 28.125″ ( 71.4cm) x 13.0″ (33cm)
  • Net Weight: 52 lbs. (23.6 kg)
  • Shipping Weight: 59 lbs. (26 kg)
Where to Find It
Join us at RubenBenjamin Studio, located at Falkenstraße 7A, 81541 München, for this exclusive event. The listening sessions will take place on May 16 and 17, 2025, from 2:00 PM to 6:00 PM. And don’t miss the Suntory Highball Social Hour on May 17, from 5:00 PM to 6:00 PM—because what’s a great sound experience without a drink in hand?
Space is limited, so get there early if you don’t want to miss out.
Price & Availability
Limited to a smaller number, the Klipsch + Ojas kO-R1 loudspeakers are available for $8,498/pair from the Ojas store and at select authorized Klipsch retailers, such as Commonwave and IQ Home Entertainment.
Bonus: The kO-R1 comes with a hardbound book that chronicles the journey of inspiration, research, ideation, design, and manufacturing behind the creation of the loudspeaker.
6 Comments
6 Comments
  1. Anton
    May 13, 2025 at 8:06 pm
    The price for those is ridiculous. Paying for the name.
    • Ian White
      May 14, 2025 at 1:09 am
      Not as ridiculous as some of the brands charging $50,000 to $200,000 for some of their speakers. I’m pretty sure these will sell out much faster and not suck.
      IW
  2. ORT
    May 14, 2025 at 2:30 am
    These things are Fugly ENC. Emperor’s New Crap. A turd is a turd regardless of whether it costs $200,000 a pair or $8,498 a pair. These speakers will be covered in flies in no time.
    Mayhap Klipsch and Nothing can join farces to form “Klipschithing”?
    As for the Poopsie Generation learning to earn and appreciate the normal things in life? I doubt it. They are morally bankrupt lemmings waiting for the latest SINFLUENCER (my own excellent portmanteau!) to lead them off yet another cliff into sloblivian.
    These Brundleflies are more concerned with creating gnu genders to ASSign to themselves than they are creating a family. They live to be bitter not better and their pitiful raison d’etre is to be continuously BROFFENDED by normal folk. Personally I look forward to them being spirited away by midget clowns that live in porta-potties…I call this a variation on the them of the CRAPture. That’s were we all awaken to the sound of the Woke being flushed away.
    Yeah. It is talent on loan from God.
    I have owned multiple Klipsch speakers for many years. Not anymore and it has nothing to do with this aberration. But not buying any more does.
    This KO-R1 looks like something Picasso sharted on a canvas. Fugly.
    The ORTacle at Helfi
    • Ian White
      May 14, 2025 at 2:34 am
      ORT,
      “This KO-R1 looks like something Picasso sharted on a canvas. Fugly.”
      I am going to go out on a limb and suggest that Klipsch might not use that in their advertising. Just a hunch on my part.
      Having not heard them…I don’t know if they’re good or not. I do think the price is weird. And I can think of other speakers for $3,000 less that I know are superior.
      IW
  3. ORT
    May 14, 2025 at 9:56 am
    Ian – I know beauty when I see it. When I hear it. And these things by Klipsch are far from beautiful. They are just weird and while I recall 40 some years ago being told to “close your eyes” when auditioning speakers at a mid-80s audio store, I just couldn’t do it as it seemed silly to me.
    Focal makes some beautiful speakers. And headphones.
    Klipsch makes nice, “purposeful” speakers but this pair of eyesores were made on purpose to be listened to with your eyes and your soul shut down tight.
    “With a name like KO-R1, it just has to be okie-dokie.”
    With that name and those looks it could be in a Star Wars spinoff as a Droid named KO-R1 paired with a hybrid Droid/Gungan, C-PNAJar. Yeah…How wude! Meesah know that wassa reeeel reacharound, huh?
    Back to pushing the rock up the hill. Messa soooo tired…
    ORTiwan Hooboobee
    • Ian White
      May 14, 2025 at 9:58 am
      ORTiwan,
      “Back to pushing the rock up the hill. Messa soooo tired…”
      Don’t tell anyone where I buried the Gungan. The name of the speaker is rather forgettable.
      IW
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Klipsch’s mid-range Dolby Atmos soundbar system delivers impressive performance at an affordable price
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
Daily Deals
Why bother with under-performing soundbar-based surround sound systems when you can pick up this separates-based complete home theater for under $1,200?
Podcasts
On this live stream podcast, the eCoustics team discusses the very best of what we saw and heard at CES 2026 in Las Vegas.
Loudspeakers
No specs or pricing yet, but Klipsch concept products at CES 2026 signal a strategic shift fittingly timed with the legendary speaker maker’s 80th...
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
Loudspeakers
Klipsch marks 80 years with a year-long series of anniversary events, new products, and limited editions celebrating a legacy built on physics, horn-loaded innovation,...
