JBL Tour PRO 3 Wireless Earbuds: More Features Than AirPods With Smart Charging Case
At $329, JBL’s Tour PRO 3 wireless earbuds combine dual drivers, adaptive noise cancellation, LDAC support, and a touchscreen Smart Charging Case to challenge Apple’s AirPods.
JBL Tour Pro 3 Wireless Earbuds Lifestyle in blue
JBL isn’t holding back with the new Tour PRO 3, its latest flagship true wireless noise cancelling earbuds that aim to outclass Apple’s AirPods Pro. Priced higher at $329, Tour PRO 3 ups the ante with dual drivers, JBL Spatial 360 audio with head tracking, and True Adaptive Noise Cancellation 2.0 to block out external noise while commuting or listening at home. Add in the brand’s Smart Charging Case loaded with real-time controls and metrics, and you’ve got one of the most feature-rich wireless earbuds JBL has ever built — a clear evolution from the Tour PRO 2 ($249) and Live TWS 3 Series that pushes portable listening into smarter, higher-fidelity territory.
JBL Tour PRO 3 Smart Charging Case
jbl-tour-pro-3-charging-case-black
The real showstopper of the JBL Tour PRO 3 is the Smart Charging Case — a clever piece of tech that does far more than just top off your earbuds. With a 1.57-inch LED touchscreen, the case lets you control your smartphone without ever pulling it out of your pocket. You can view text messages, answer calls, and manage playback or settings directly from the case, as long as it’s connected to your phone.
But JBL didn’t stop there. The Smart Charging Case also doubles as a wireless audio transmitter, letting you plug it into any USB or analog source — like an airplane seat jack or older laptop — for instant, high-quality audio through your earbuds. The direct case-to-earbud connection delivers lower latency and greater stability than standard Bluetooth, making it ideal for gaming, streaming, and flights where traditional wireless audio falls flat.
To top it off, users can personalize the touchscreen interface with custom wallpapers and display languages — 13 in total — adding a bit of flair to what might be the smartest earbud case on the market.
JBL Tour PRO 3 Earbuds Deliver Dual Drivers, Spatial 360 Audio, and Adaptive Noise Cancellation
JBL engineered the Tour PRO 3 earbuds to strike the right balance between high-end sound and long-wear comfort. Inside each earbud, a hybrid dual-driver setup — combining Balanced Armature and Dynamic drivers — delivers a mix of precision, punch, and detail across the frequency range. To make sure the fit matches the sound, JBL includes five sizes of silicone ear tips plus an extra set of foam tips, giving listeners the flexibility to find the perfect seal for comfort and optimal noise isolation during long sessions.
True Adaptive Noise Cancellation: JBL’s True Adaptive Noise Cancellation 2.0 is built to keep your audio experience consistent no matter where you are. The system monitors ambient noise more than 50,000 times per second, automatically adjusting to shifting environments while compensating for sound leakage. Whether you’re on a plane, in a crowded café, or walking through city streets, the Tour PRO 3 continuously fine-tunes its performance to maintain clarity and balance — without you lifting a finger.
Personalized Sound: The JBL Tour PRO 3 takes customization seriously with its updated Personi-fi 3.0 technology. Through the JBL Headphones app, listeners can run an Ear Canal Test to create a fully personalized sound profile based on their unique hearing characteristics. Using a combination of 12 EQ bands and 14 warble tones, JBL’s algorithm measures and compensates for differences in frequency perception — now doing so independently for each ear. The result is a sound signature tailored specifically to the listener, delivering the most accurate and individualized audio experience JBL has offered yet.
Auracast functionality. Easily share audio content with any Auracast-enabled device using the Auracast button on the Smart Charging Case display. Or join an existing broadcast by simply tapping in with the case and accompanying app.
JBL Spatial 360 with Head Tracking: The JBL Tour PRO 3 introduces Spatial 360 Audio with Head Tracking, bringing an immersive, cinema-like experience to any audio source. Whether you’re streaming a movie, gaming, or listening to music, this technology converts standard stereo sound into a multidimensional soundscape that moves naturally with your head position. The result is a more lifelike and engaging listening experience — one that feels anchored in real space, not just inside your ears.
jbl-tour-pro-3-earbuds-latte
Speaker Drivers: Each JBL Tour PRO 3 earbud features a hybrid dual-driver design that splits the workload for greater precision. The balanced armature driver handles the upper frequencies with added clarity and control, while the 10.2mm dynamic driver delivers clean, well-defined bass and natural-sounding vocals. Together, they provide a balanced and detailed presentation suited for a wide range of listening styles.
DAC: The JBL Tour PRO 3 employs a dedicated DAC for each driver, ensuring that every section of the frequency range — from 20Hz to 40kHz — is reproduced with precision. By assigning a digital-to-analog converter to each driver, JBL maintains cleaner signal separation and improved resolution across lows, mids, and highs, allowing listeners to hear subtle details and tonal balance more accurately.
Hi-Res Wireless Audio with LDAC: To further elevate audio quality, the JBL Tour PRO 3 supports Hi-Res certified LDAC wireless audio. This codec transmits up to three times more data than standard Bluetooth formats, preserving more of the original recording’s detail and dynamic range. The result is a higher-fidelity wireless listening experience that stays closer to true studio-quality sound.
Clear Phone Calling with JBL Crystal AI: The JBL Tour PRO 3 is equipped with six microphones and a hydrodynamic wind-resistant design to maintain voice clarity during calls. JBL’s Crystal AI algorithm actively filters background noise, adapting to both steady low-frequency sounds like traffic or subway rumble and unpredictable high-frequency noise from busy environments such as cafés.
To refine voice quality even further, the Tour PRO 3 adds a Smart Call Equalizer called Voice Call, which automatically adjusts sound levels, lowering overly loud voices and boosting quiet ones to keep conversations balanced and intelligible no matter where you are.
The JBL Tour PRO 3 introduces a brand-new audio platform developed for sonic excellence as it sets new standards in customization, performance, and convenience. I am particularly excited by the new generation Smart Charging Case because the new audio transmitter technology is unique as it unlocks so many potential scenarios for improving audio quality and enhancing the listening experience,” said Carsten Olesen, President of Consumer Audio at HARMAN.
Comparison
jbl-tour-pro-3-vs-pro-2
JBL ModelTour PRO 3 (2024)Tour PRO 2 (2023)
Product TypeWireless EarbudsWireless Earbuds
Price$329.95$249.95
Driver TypeDynamic Driver + 5.1 mm x 2.8 mm Balanced ArmatureDynamic Driver
Driver Size10.2 mm / 0.402” 10 mm / 0.394”
Frequency response: 20 Hz-40 kHz20 Hz – 20 kHz
Impedance32 ohm16 ohm
Sensitivity104 dB SPL@1 kHz100 dB SPL@1 kHz
Maximum SPL95 dB95 dB
Number of Microphones66
Microphone sensitivity-38 dBV/ Pa@1 kHz-38 dBV/ Pa@1 kHz
Voice Assistant integrationYesYes
Smart CaseYesYes
Smart Case LED Touchscreen Yes – 1.57 inchesYes – 1.45 inches
Bluetooth version (Earbud)5.35.3
Bluetooth version (Charging case):5.35.3
Bluetooth profile versionA2DP V1.4, AVRCP V1.6.2, HFP V1.8A2DP V1.3.2, AVRCP V1.6.2, HFP V1.7.2
Bluetooth transmitter frequency range2.4 GHz – 2.4835 GHz2.4 GHz – 2.4835 GHz
Bluetooth transmitter power (Earbud): <13 dBm (EIRP)<15 dBm (EIRP)
Bluetooth transmitter power (Charging case)<10 dBm (EIRP)Not Indicated
Bluetooth transmitter modulation (Earbud)GFSK, π/4 DQPSK, 8DPSKGFSK, π/4-DQPSK, 8-DPSK
Bluetooth transmitter modulation (Charging case)GFSKNot Indicated
Bluetooth Multi-Point ConnectionYesYes
Spatial SoundYesYes
True Adaptive Noise CancellingYesYes
Ambient AwareYesYes
Earbud battery typeLithium-ion battery (65 mAh/ 3.85 V)Lithium-ion battery (65 mAh/ 3.85 V)
Charging case battery typeLithium-ion battery ( 850 mAh/ 3.8 V)Lithium-ion battery ( 850 mAh/ 3.8 V)
Charging time2 hrs from empty2 hrs from empty
Wireless ChargingYesYes
Music playtime with BT on and ANC offUp to 11 hrsUp to 10 hrs
Music playtime with BT on and ANC onUp to 8 hrsUp to 8 hrs
Music playtime with BT on and True Adaptive ANC onUp to 7 hrsUp to 6 hrs
Talk time with ANC offUp to 5.5 hrsUp to 6 hrs
Talk time with ANC onUp to 5.2 hrsUp to 5.5 hrs
IP RatingIP55IPX5
Maximum operation temperature45 °C45 °C
Weight – Earbud5.6 g per pc (11.2 g combined) 0.01235 lbs per pc (0.02470 lbs combined)12.2 grams, 2.6 oz
Weight – Charging Case71.8 g/ 0.158 lbs73 g/ 0.158 lbs
ColorsBlack
Latte
Blue
Black
Champagne
What’s in the Box1 x JBL Tour Pro 3 earbuds
1 x Smart Charging Case
1x USB Type-C to Type-C cable
1x USB Type-C to Analog 3.5mm cable
1 x USB Type-C charging cable
1 x 5 sizes of eartips + 1 x set of foam tips
1 x Warranty / Warning
1 x QSG / Safety Sheet
1 x JBL Tour Pro 2 earbuds
 1 x Charging case
1 x 3 sizes of eartips
jbl-tour-pro-3-charging-case-blue
JBL Tour PRO 3 in special blue color coming November 2025.
The Bottom Line
The JBL Tour PRO 3 enters a crowded field of wireless earbuds, going up against major players like Apple’s AirPods and Sennheiser’s Momentum True Wireless 4. It’s priced a bit higher than Apple’s model, but the feature set helps justify it — dual drivers, True Adaptive Noise Cancellation 2.0, LDAC support, and a Smart Charging Case™ with a touchscreen interface that adds real utility instead of gimmicks.
For those who don’t need every feature, the more affordable JBL Live TWS 3 Series still includes the Smart Charging Case (with a smaller display) and offers a solid balance of performance and practicality. Both make it clear that JBL isn’t chasing trends — it’s quietly building credible alternatives in the wireless space.
Price & Availability
The JBL Tour PRO 3 is available in Black and Latte for $329 at Amazon and Crutchfield, along with a new special blue color coming November 2025.
Other JBL Options:
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle
Soundboks Mix delivers 72-watts Class D amplification, Bluetooth, and pro-level SKAA wireless with volume that goes to 11. Is it the right party speaker...
Shanling SM90 Music Streamer Angle Shanling SM90 Music Streamer Angle
Shanling SM90 adds HDMI ARC, dual AKM DACs, and Android streaming under $1,000, but can it stand out in a crowded streamer market?
JBL PartyBox On-the-go 2 Plus Portable Bluetooth Speaker at Beach JBL PartyBox On-the-go 2 Plus Portable Bluetooth Speaker at Beach
JBL PartyBox On The Go 2 Plus adds AI karaoke with real time vocal removal, EasySing mics, and Auracast. Is this the future of...
JBL’s L100 Classic 80 is the L100 Classic MKII in anniversary clothing—same drivers and tuning, new finish, limited to 800 pairs worldwide.
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Our favorite wireless noise cancelling earbuds of 2025 include Bose, Sony, Technics and Bowers & Wilkins.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
In-depth review of the Bowers & Wilkins true wireless noise cancelling earbuds covers everything you need to know.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
