JBL PartyBox On-The-Go 2 Plus Launches as Portable Party Speaker with Wireless Mic, Bigger Sound, and All-Day Battery
JBL PartyBox On The Go 2 Plus adds AI karaoke with real time vocal removal, EasySing mics, and Auracast. Is this the future of party speakers?
JBL PartyBox On-the-go 2 Plus Portable Bluetooth Speaker at Beach
JBL is doubling down on portable party speakers with a clear focus on karaoke, expanding its PartyBox lineup with the new PartyBox On-The-Go 2 Plus alongside the EasySing microphone ecosystem. At the center of the launch is AI-powered EasySing technology, which uses on-device processing to separate vocals from music in real time—allowing users to reduce or remove the original singer without relying on cloud services or pre-processed tracks.
The system goes beyond simple vocal stripping. JBL integrates pitch support, Voice Boost for high-frequency clarity, and built-in effects like reverb, echo, and noise suppression to create a more controlled and customizable performance. Paired with the new EasySing microphones, the platform is designed to turn any song into an instant karaoke track while keeping latency low and setup straightforward—no apps, subscriptions, or external processing required.
As music continues to evolve, so does the way people experience it together,” said Carsten Olesen, President of Consumer Audio at HARMAN. “At JBL, we’re harnessing advanced AI technologies like real-time vocal separation and intelligent vocal enhancement to transform passive listening into shared, interactive moments. By integrating AI directly into our products, we’re creating new ways for people to connect and celebrate.”
JBL PartyBox On-the-Go 2 Plus
jbl-partybox-on-the-go-2-plus-black
Designed to elevate both parties and karaoke nights, the JBL PartyBox On-The-Go 2 Plus combines JBL’s signature sound and dynamic lightshow with its new EasySing AI technology. Using the JBL One app, users can adjust sound and lighting settings, while the system brings vocals forward in real time to instantly transform any track into a performance-ready experience.
Portability gets a practical upgrade with a redesigned central handle for better weight balance, along with a wider, thicker shoulder strap that makes it easier to carry between locations.
Under the hood, the speaker delivers up to 100 watts of power, driven by dual silk-dome tweeters and a 5.25-inch woofer for solid bass and clear, detailed highs. Battery life is rated at up to 15 hours, and the inclusion of a replaceable battery means it’s built for extended sessions without cutting the party short.
For even more party flexibility, the PartyBox On-The-Go 2 Plus is also Auracast compatible for easy multi-speaker pairing with JBL Auracast-enabled speakers
Comparison
jbl-partybox-compare
JBL ModelPartyBox On-The- Go 2 Plus (2026)PartyBox On-The- Go 2 (2026)PartyBox On-The- Go (2020)
Product TypeParty SpeakerParty SpeakerParty Speaker
Price $419.95$419.95$249.95
Output Power100 W RMS 100 W RMS 100 W RMS
Speaker Drivers1 x 5.25-inch (135 mm) woofer
2 x 0.75 inch (20 mm) Dome tweeters
1 x 5.25in (133mm) woofer
2 x 1.75in (44mm) tweeters
Frequency Response40 Hz – 20 kHz (-6 dB)40 Hz – 20 kHz (-6 dB)50Hz – 20KHz (-6 dB)
Signal-to-Noise Ratio> 80dB> 80dB> 80dB
Bluetooth/USB Input-9dBFS-9dBFS-9dBFS
USB Playback Formats Supported (Disable for EMEA region)MP3, .WAV, FLAC MP3, .WAV, FLAC MP3, .WAV, WMA
USB File FormatFAT16, FAT32FAT16, FAT32FAT16, FAT32
Bluetooth Version5.45.44.2
Bluetooth® Profile A2DP V1.4, AVRCP V1.6 (SW), TMAP1.0, PBP1.0A2DP V1.4, AVRCP V1.6 (SW), TMAP1.0, PBP1.0A2DP 1.3, AVRCP 1.6
Bluetooth AuracastYesYesNo
Bluetooth® Transmitter Frequency Range2.4 GHz – 2.4835 GHz2.4 GHz – 2.4835 GHz2.4 GHz – 2.48 GHz
Bluetooth® Transmitter Power≤ 16 dBm (EIRP)≤ 16 dBm (EIRP)10dBm (EIRP)
Bluetooth® Transmitter ModulationGFSK, π/4 DQPSK, 8DPSKGFSK, π/4 DQPSK, 8DPSKGFSK, π/4 DQPSK, 8DPSK
2.4G Wireless Transmitter Frequency range2404 – 2478 MHz2404 – 2478 MHzNot Indicated
2.4G Wireless Transmitter Power< 10 dBm (EIRP)≤ 8.5 dBm (EIRP)Not Indicated
2.4G Wireless ModulationGFSKGFSK, π/4 DQPSK, 8DPSKNot Indicated
Aux-In370 mV RMS (3.5mm connector)370 mV RMS (3.5mm connector)(3.5mm connector)
Mic-In20 mV RMS20 mV RMSYes – voltage not indicated
Battery Battery Type: Li-ion 34 Wh (7.2 V / 4722 mAh)
Battery Charge Time: < 3.5 hours (Speaker off mode)
Music Play Time: up to 15 hours (varies by volume level and xaudio content)
Fast Charging: 10 minutes provides up to  80 minutes of playtime
Battery type: Lithium-ion 18Wh (7.2V @ 2500mAh)
Battery charge time: <3.5hrs
Music  play time: <6 hrs
USB Charge Out11 V / 2 A (Max) (Speaker off mode)USB charge out: 11V / 2A (Max) (Speaker off mode)Not Indicated
Power Input 100 – 240 V ~50/60 Hz100 – 240 V ~50/60 Hz100 – 240 V ~50/60 Hz
Power Cable TypeAC power cable (type varies by region)AC power cable (type varies by region)AC power cable (type varies by region)
AC Cable Length2.0m / 6.6 ft2.0m / 6.6 ft2.0m / 6.6 ft
IPX RatingIPX4IPX4IPX4
Dimensions (WHD)501 x 258 x 221 mm
19.72 x 10.16 x 8.70 inches
501 x 258 x 221 mm
489 x 244.5 x 224 mm
19.3 x 9.6 x 8.8 inches
Weight6.45 kg / 14.22 lbs6.36 kg / 14.02 lbs6.5 kg / 14.3 lbs
Wireless MicrophoneEASYSING with AI vocal removal included
Frequency response: 50 Hz – 15 kHz (-6 dB)
Transmitter transmitting power: < 8.5 dBm (EIRP)
2.4G wireless transmitter frequency range: 2404 – 2478 MHz
Distance between transmitter and receiver: ≤ 30 m
Microphone playtime: up to 10 hours
Rechargeable battery: 240mAh 3.7V Li-ion battery
Carrier frequency: 2404~2478MHz
Receiver Max Output Level: <1VRMS
JBL Standard Mic Included
Frequency Response: 50Hz – 15kHz(-6dB)
Signal-to-Noise: >59dBA
Transmitter transmitting power: <8.5dBm (EIRP)
2.4G wireless transmitter frequency range: 2404 – 2478MHz
Distance between transmitter and receiver: ≤30m
Frequency response: 65Hz – 15kHz
Signal-to-noise (S/N) ratio: >60dBA
Transmitter transmitting power: <10mW
Microphone battery play time: <10hrs
Distance between transmitter and receiver: >10m
Wireless Microphone Dimensions (WHD):46.5mm x  225mm x 43mm
1.83’’ x 8.86’’ x 1.69’’
Not IndicatedNot Indicated
Wireless Microphone Weight197g / 0.434lbs MicNot IndicatedNot Indicated
What’s in the Box1 x JBL PartyBox On-The-Go-2 Plus
1 x Quick-start guide
1 x Safety Instruction and Warranty Card
1 x wireless microphone (EASYSING)
1 x microphone holder
AC power cord – quantity and plug type vary by regions
1 x shoulder strap
1 x shoulder strap
JBL EasySing Mics & JBL EasySing Mic Mini
jbl-easysing-mics-package
Pro Tip: Images and full specifications for the JBL EasySing Mic Mini were not available at the time of publication.
Expanding the EasySing ecosystem, JBL is also introducing the EasySing Mics and the EasySing Mic Mini. These AI-powered microphones integrate real-time vocal separation and enhancement into a compact, performance-ready design.
Built for flexibility, they offer users greater control over vocals with improved clarity and processing, making them a natural extension of the PartyBox experience for karaoke sessions, parties, and casual performances.
The JBL EasySing Mics provide real-time, AI-powered vocal removal from any track while maintaining clear, balanced audio. Users can adjust the level of original vocals to 25%, 50%, or fully removed, while JBL’s EasySing algorithm enhances live vocals with Voice Boost for improved high-frequency clarity, along with natural reverb, echo, and noise suppression.
The JBL EasySing Mic Mini takes a more compact approach, offering a pocket-sized solution for singing and content creation. It includes Voice Boost for high-pitch support and AI-based noise suppression to reduce background interference, making it suitable for a wider range of environments.
Setup is intentionally simple. There are no apps or complicated pairing steps—just plug the included USB-C dongle into a compatible JBL speaker and start using the microphones immediately. It’s a straightforward, wireless approach that keeps the focus on performance rather than setup.
Portability is also a priority. A compact carrying bag makes it easy to store in a pocket or small bag, while the microphone design includes a ring handle for a secure grip and a magnetic clip for hands-free use.
Each set includes two microphones, offering up to 10 hours of battery life on average and a 30-meter wireless range for duets and group performances. A USB-C dongle is also provided for seamless plug-and-play. EQ customization is provided by the JBL One App
JBL EasySing Mics are compatible with JBL PartyBox On-the-Go 2, JBL PartyBox Encore 2, JBL PartyBox Encore Essential 2, JBL PartyBox Club 120, JBL PartyBox Stage 320, JBL PartyBox 520, and JBL PartyBox 720
JBL EasySing Mic Mini is compatible with JBL Go 5, JBL Grip, JBL Flip 7, JBL Charge 6, JBL Xtreme 5, JBL Boombox 4, and all JBL PartyBox models through Aux. (Aux cable not included.)
JBL EasySing Mic Specifications
jbl-easysing-mics-pair
JBL Model EasySing Mic
Product TypeWireless Microphone
Price (comes as a pair)$199
Dynamic Range98 dBA @ 1 kHz
Signal -to -Noise 59 dBA
THD  (Total Harmonic Distortion)< 1% @ 94 dB SPL, 100 Hz – 10 kHz
Microphone Head 16 mm ECM
Transmitting Power< 10 dBm
Carrier frequency 2404 – 2478 MHz
Encryption AES – 128
Frequency / Channel selection Adaptive channel selection
Frequency response: 50 Hz – 15 kHz50 Hz – 15 kHz
Battery Specifications Microphone rechargeable battery: 240 mAh, 3.7 V Li-ion polymer battery
Microphone battery charge time: < 3.5 hours in off mode
Playtime: Up to 10 hours
Dimensions (WHD)Microphone: 45.5 x 224.5 x 42.7 mm / 1.79” x 8.84” x 1.68”
Dongle: 24 x 45.4 x 15.6 mm / 0.95” x 1.79” x 0.61”
WeightMicrophone: 195 g / 0.43 lbs
Dongle 12 g / 0.026 lbs
What’s in the Box2 x Microphone
1 x AI Dongle
2 x Microphone Holder
1 x USB to USB-C Adaptor
1 x QSG (Quick Start Guide)
1 x Safety Sheet
jbl-partybox-on-the-go-2-plus-top
jbl-partybox-on-the-go-2-plus-back
The Bottom Line
JBL knows exactly where this category is heading and isn’t standing still. The PartyBox On-The-Go 2 Plus leans hard into AI-driven karaoke with EasySing, combining real-time vocal removal, onboard vocal processing, and Auracast support into a portable speaker that’s built as much for participation as it is for playback. That’s the hook—this isn’t just background music anymore, it’s the main event. The addition of dedicated EasySing microphones pushes JBL further into a more complete ecosystem that feels purpose-built for social listening and performance.
What’s missing? This isn’t an audiophile product and doesn’t pretend to be. You won’t find high-resolution streaming features, advanced codec support, or the kind of system integration that serious hi-fi buyers expect. And if you don’t care about karaoke or AI vocal tricks, the standard PartyBox On-The-Go 2 might make more sense—and cost less—since it sticks to the basics with a traditional wireless mic.
Who is this for? Anyone who wants to turn a backyard, beach day, or living room into a low-effort karaoke setup without messing around with apps, subscriptions, or complicated gear. If your idea of a good night involves a microphone, questionable song choices, and zero patience for setup, JBL just made your life easier.
jbl-partybox-on-the-go-2-plus-white
Price & Availability
  • JBL PartyBox On-The-Go 2 Plus comes with one EasySing Mic and is available for pre-sale for $419.95 on JBL.com with a sale date of April 12, 2026.
  • JBL PartyBox On-The-Go 2 (without EasySing Mic and AI) – $419 at Amazon
  • JBL EasySing Mics$199 at Amazon
  • JBL EasySing Mic Mini will be available for pre-sale beginning April 12, 2026, at JBL.com for $179.95 with an on-sale date of May 10, 2026.
JBL PartyBox On The Go 2 Plus adds AI karaoke with real time vocal removal, EasySing mics, and Auracast. Is this the future of...
Beats by Dre Powerbeats Pro 2 Nike Special Edition Wireless Earbuds Beats by Dre Powerbeats Pro 2 Nike Special Edition Wireless Earbuds
Beats and Nike team up for Powerbeats Pro 2 Special Edition with fitness features, bold design, and zero upgrades under the hood. Smart move...
Fosi Audio S3 Music Streamer Front Angle Silver with Orange Knob Fosi Audio S3 Music Streamer Front Angle Silver with Orange Knob
Can the $259 Fosi Audio S3 streamer DAC and preamp challenge WiiM and Bluesound with balanced outputs and HDMI eARC despite missing key features?
LAiV Crescendo Verse DAC headphone amplifier lifestyle with headphones and IEMs LAiV Crescendo Verse DAC headphone amplifier lifestyle with headphones and IEMs
2026 Samsung QN70H and QN80H Neo QLED 4K TVs 2026 Samsung QN70H and QN80H Neo QLED 4K TVs
Samsung M80H and M70H Mini-LED 4K TVs Angle Samsung M80H and M70H Mini-LED 4K TVs Angle
At $799, the Marshall Bromley 450 packs 360-degree sound, 40+ hour battery, and mic inputs in a 27 pound portable party speaker box.
JBL Boombox 4 and PartyBox 720 are the perfect portable party speakers for 2025 with booming bass, waterproof designs and epic lightshows.
Ikarao's Shell S1, Break X1, and Break X2 combine wireless and wired music streaming with touchscreens, light effects, and karaoke features for the ultimate...
TCL’s TP200K and TP300K party speakers bring solid specs and features to challenge Sony and JBL—perfect for any gathering, from Bar Mitzvahs to dog...
Tronsmart Halo 300 crashes the 2025 party speaker scene. How does it stack up against Sony’s ULT Tower 9 and JBL's PartyBox Series?
JBL's Summit Series audiophile loudspeakers, the Makalu, Pumori, and Ama, honor 80 years of acoustic precision and emotional power.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Lots of power, bridgeable configuration options, and rack-compatible sizes add flexibility to any custom home theater setup.
