Ikarao Launches Trio of Karaoke Smart Speakers with Touchscreens
Ikarao’s Shell S1, Break X1, and Break X2 combine wireless and wired music streaming with touchscreens, light effects, and karaoke features for the ultimate party experience.
Ikarao Smart Karaoke Speakers Group
Founded in 2021, UK-based Ikarao built its name on rugged party speakers, and now they’re back for 2025 with something a little more refined—but still aimed at the fun crowd. The new lineup includes the Break X1 ($699), Break X2 ($449), and Shell S1 ($349) portable smart speakers. Each model is designed for flexible use around the house or on the move. And yes, it’s another trio of wireless speakers in an already overcrowded space—but Ikarao’s trying to break through the noise with some interesting twists.
Ikarao isn’t exactly new to the portable smart speaker game. In 2024, they dropped the Shell S2 ($339) and Shell S3 ($219)—both designed with outdoor vibes and portability in mind.
Break X1, X2, and Shell S1: Key Features and Smart Speaker Specs Unpacked
Here’s what Ikarao is packing into the Break X1, X2, and Shell S1 smart speakers — because in 2025, apparently your party speaker needs a touchscreen, LED light show, and a karaoke career:
  • Built-in Full HD 1080p touchscreen with 180° rotation — swipe, tap, and tilt like you mean it.
  • Android 13 OS with Wi-Fi + Bluetooth 5.3 for streaming straight from your phone or tablet.
  • HDMI output so you can beam lyrics or apps to your TV or projector — instant living room concert.
  • Dual wireless supercardioid mics with smart auto-charging — yes, your duet is now cordless.
  • Up to 10 hours of battery life from the built-in rechargeable battery — long enough to outlast the party.
  • Bass-boosted stereo and 2.2 channel audio systems for bigger, bolder sound.
  • Adjustable LED lights and a sleek steel grill design — part speaker, part light show.
  • MicroSD support (X1, X2) and USB storage (S1) for offline music or karaoke libraries.
  • 6-month free Karafun subscription with access to over 59,000 tracks — or just YouTube your way through the night.
Ikarao Shell S1: Smart, Stylish, and Built for Portable Karaoke Fun
ikarao-shell-s1
Ikarao Shell S1
The Shell S1 is the smallest of the new Ikarao lineup, but don’t let the compact size fool you—it still delivers a robust 280W of power and an immersive user experience via a 10.1” Full HD touchscreen. Running Android 13, the Shell S1 gives users direct access to YouTube, Karafun, and other popular streaming apps over Wi-Fi, while Bluetooth 5.3 support allows seamless pairing with smartphones and tablets. Designed for smaller rooms and intimate gatherings, the Shell S1 is ideal for solo sessions, karaoke duets, or casual background music anywhere you take it.
Break X2 Portable Smart Speaker – Bigger Screen, Bigger Sound
ikarao-break-x2
Ikarao Break X2
The Break X2 builds on the Shell S1’s feature set with a 10.1” rotatable touchscreen and an upgraded 300W audio output. It also adds a dedicated guitar input, making it a more versatile option for musicians and performers. With stronger sound and broader connectivity, the X2 is ideal for medium-sized gatherings, whether it’s a backyard party, small venue performance, or an open mic night at your local bar.
Break X1 Portable Smart Speaker – Flagship Power and Performance
ikarao-break-x1
Ikarao Break X1
Topping the lineup, the Break X1 is the flagship model featuring a massive 13.3” touchscreen that rotates 180°, pumping out a serious 460W of audio power. It comes equipped with two wireless microphones that recharge themselves smartly—perfect for full-throttle parties, karaoke nights, restaurants, and outdoor events where you need sound that commands attention.
IKARAO Smart Portable Speakers Comparison
Ikaro ModelShell S1Break X2Break X1
Product TypeSmart Multimedia Speaker with KaraokeSmart Multimedia Speaker with KaraokeSmart Multimedia Speaker with Karaoke
Price$349.99$449.99$699.99
Speaker System2.2 speaker system with Bass booster2.2 speaker system with Bass booster2.2 speaker system with Bass booster
Woofer Size3.5″ × 24.0″ × 26.5 inch × 1
Tweeter1″ x 21.2″ x 22.6″ x 2
Bass Reflex TypeInverter TubeBass Reflex TubeBass Reflex Port
Frequency range48Hz – 18kHz48Hz – 20kHz45Hz – 20kHz (-10dB)
Signal-to-noise ratio≥85dBA (Rated power)≥85dBA (Rated power)≥85dBA (Rated power)
Speaker SPLWoofer: 86dB
Tweeter: 87dB
Woofer: 84dB
Tweeter: 88dB
Woofer: 89dB
Tweeter: 93dB
Maximum SPL 104dB105dB107dB
Recommended usage space15 – 80 m²
(150 – 800 ft²)
15 – 100 m²
(150 – 1000 ft²)
15 – 200 m²
(150 – 2000 ft²)
RMS Power15W ×2 (Woofer) + 10W ×2 (Tweeter)25W ×2 (Woofer) + 10W ×2 (Tweeter)80W (Woofer) + 10W ×2 (Tweeter)
Peak Power280W300W460W
Distortion≤1%≤1%≤1%
Standby power≤0.5W≤0.5W≤0.5W
Input overload≤1V≤1V≤1V
Noise Floor (A-weighted)≤500μV≤500μV≤500μV
Touchscreen 10.1 Inches10.1 Inches13.3 inhces
Wireless Mic SystemYes – 2 micsYes – 2 micsYes – 2 mics
Microphone Settings 8-mode Equalizer
Volume
Echo
8-mode Equalizer
Volume
Echo
8-mode Equalizer
Volume
Echo
Blueooth Yes  – ver 5.3Yes  – ver 5.3Yes  – ver 5.3
TWS PairingYesYesYes
Physical Connections AUX input, Additional micinput, USB-C, and HDMIAUX, guitar, HDMI (for connecting to a larger screen), mic, USB, Micro SD, and line-out.AUX, guitar, HDMI (for connecting to a larger screen), mic, USB, Micro SD, and line-out.
Karafun App Yes – Free for 6 months Yes – Free for 6 months Yes – Free for 6 months
LED Lighting EffectsYesYesYes
Integrated BatteryRechargeable battery lasts up to 8 hours (lights and screen off) and charges via USB-CRechargeable battery lasts up to 8 hours (lights and screen off) and charges via USB-CRechargeable battery lasts up to 10 hours (lights and screen off) and charges via USB-C
Dimensions (DWH)6.8 x 13.8 x 6.6 inches8.3 x 11.8 x 10.6 inches23.5 x 15 x 13.5 inches
Weight 11.68 lbs13.2 lbs32 lbs
Included AccessoriesUSB cable
Carrying strap
2 Wireless microphones
USB cable
Carrying strap
AC cable
Carrying strap
ikarao-shell-s1-carry
Ikarao Shell S1
The Bottom Line
Ikarao might not be a household name yet, but their Smart Multimedia Speakers with Karaoke are built for those who want to keep the party going—whether at home or on the move. Bluetooth and Wi-Fi streaming cover your everyday music needs, while karaoke mode, complete with wireless mics and colorful light effects, takes things up a notch.
The rotatable touchscreens and HDMI connectivity make it easy to display lyrics on big screens—ideal for larger crowds. Portability gets a nod, but don’t expect to toss the Break X1 in the back of a car without some effort; at 32 pounds and no obvious wheels or handles, it’s more “portable-ish” than truly grab-and-go.
Still, for summer cookouts, school events, and winter holiday bashes, Ikarao’s lineup is worth a hard look if you want to bring the noise.
For more information: https://ikarao.com
ikarao-smart-karaoke-speakers-2025-group
Top row: Break X2, Break X1 / Bottom row: Bottom row: Shell S2, Shell S1, Shell S3
Price & Availability
Previously released models:
3 Comments
3 Comments
  1. David
    July 24, 2025 at 3:48 pm
    I find these very appealing and quite innovative from a design and function perspective. I think the younger generations would just eat these up.
    • Ian White
      July 24, 2025 at 7:23 pm
      David,
      They are definitely different. I give them points for trying.
      IW
  2. ORT
    July 24, 2025 at 9:47 pm
    I need one of these if only to channel the great Slim Whitman whose voice saved the Earth when Mars Attacked!
    Slim ORTman
Epson Lifestudio Grand Plus UST Projector
The new Epson Lifestudio Grand Plus LS970 UST Projector is bright enough to light up a huge screen just inches from the wall and...
Denon Home 200, 400 and 600 Wireless Speakers White Lifestyle Denon Home 200, 400 and 600 Wireless Speakers White Lifestyle
Denon brings Dolby Atmos music support to its HEOS whole home music platform with this trio of wireless speakers.
Andrew Jones Introduces New Speaker and Company Jones and Cerreta Andrew Jones Introduces New Speaker and Company Jones and Cerreta
Andrew Jones to debut Jones and Cerreta at AXPONA 2026 with MoFi Distribution but what is this field coil concentric floorstander and how much...
Børresen Center3 Front Angle Lifestyle Børresen Center3 Front Angle Lifestyle
Center Speakers
Børresen’s $7,000 Center3 brings flagship tech to home theater but is it the missing piece for X Series owners or still overkill?
FiiO Darkside Pro Linear Power Supply FiiO Darkside Pro Linear Power Supply
Can a $159 linear power supply fix weak wall adapters and unlock better sound from your DAC or amp? FiiO thinks the DARKSIDE PRO...
Netflix Stranger Things Complete Series July 2026 Netflix Stranger Things Complete Series July 2026
Movies
Stranger Things Complete Series on Blu-ray and 4K UHD arrives this July in four collector box sets, but which edition should you buy?
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
Our favorite wireless speakers of 2025 include models from Audioengine, Denon, Devialet, Edifier, Q Acoustics and Ruark.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Discover the FiiO K15 DAC Headphone Amp: A powerful, affordable desktop solution offering balanced audio, Wi-Fi, and Bluetooth, all for $549. Compare with top...
Dutch & Dutch’s new 6c wireless speaker brings compact design, BACCH3D audio, RoomMatching, and high-end engineering to a smaller, more flexible footprint.
