HumminGuru EZ Vinyl Record Washer Takes Aim at SpinClean — A More Expensive, More Polished Challenge to the Budget Cleaning King
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
HumminGuru EZ Record Washer Package
For decades, the Spin-Clean has owned the affordable, manual record-cleaning lane—simple tubs, rotating brushes, and a price point that made it the default first stop for anyone getting serious about vinyl. That dominance hasn’t gone unchallenged, but it’s rarely been threatened in a meaningful way. Now HumminGuru, best known for making ultrasonic record cleaning less intimidating (and less mortgage-inducing), is stepping directly into Spin-Clean territory with the new EZ Vinyl Record Washer—a more refined, more expensive take on the old-school, hands-on approach that record collectors know all too well.
humminguru-ez-vinyl-record-insert
humminguru-ez-clamp-angle
The HumminGuru EZ Vinyl Record Washer is exactly what it sounds like: a manual cleaning system designed to remove grime without turning record maintenance into a chore—or a science experiment. It’s built to handle 7-inch, 10-inch, and 12-inch vinyl with minimal fuss, focusing on ease of use and repeatable results rather than gimmicks. This is a hands-on cleaner for people who actually play their records and don’t want to overthink the process every time an LP comes off the shelf.
At the center of the EZ is HumminGuru’s patented clamp with an integrated handle, and it’s the most thoughtful part of the design. The clamp protects the label, keeps oils from your fingers off the playing surface, and allows the record to rotate smoothly with one hand—no awkward gripping, no fingerprints, no accidental edge dents. It’s a small but meaningful upgrade over traditional manual washers, and one that feels aimed squarely at collectors who clean a lot of records and are tired of handling compromises.
humminguru-ez-clamp
To keep things effective without getting aggressive, the HumminGuru EZ Vinyl Record Washer uses ultra-soft goat-hair brushes—a sensible choice for anyone who flinches at the idea of stiff bristles anywhere near their records. Used with cleaning fluid, the brushes are designed to loosen and lift everyday contaminants like dust, grime, greasy fingerprints, and skin oils without digging into the grooves or scuffing the surface.
It’s a deliberately gentle approach, and that’s the point. This isn’t about scrubbing your records like a dirty frying pan; it’s about controlled contact that cleans consistently while minimizing wear. For collectors with a lot of older pressings—or newer audiophile releases they’d like to keep pristine—the brush setup feels more considered than the typical “good enough” solutions that have dominated the affordable end of the market for years.
humminguru-ez-brush
The HumminGuru EZ Vinyl Record Washer also addresses the less glamorous part of record cleaning: the aftermath. A spill-free drain system keeps cleanup tidy instead of turning your listening room into a slip hazard, while the integrated drying rack holds up to eight records and neatly stows underneath when not in use—no separate plastic contraption to lose or crack.
protective lid keeps dust out of the basin between sessions, which sounds obvious until you realize how many cleaners skip that detail. Visually, the EZ leans modern rather than utilitarian—smooth curves, clean lines, and a design that won’t look out of place next to a carefully curated vinyl setup. It’s functional first, but there’s no denying HumminGuru wants this to feel like an upgrade, not just another tub you hide in a closet.
Elegant Design, Built for Effortless Use
The HumminGuru EZ Vinyl Record Washer is laid out with obvious intent—everything has a purpose, and nothing feels tacked on. From setup to cleanup, the workflow is straightforward, which matters when you’re cleaning multiple records and don’t want to wrestle with plastic parts or awkward angles.
Smooth, Spill-Free Draining: Dual water outlets are positioned at an optimal pouring angle, allowing the basin to empty cleanly without splashing or dripping all over your work surface. It’s a small engineering detail that makes a big difference in everyday use.
Drying Rack & Storage: The included drying rack holds up to eight records for air-drying and stores neatly underneath the washer when not in use. No tools, no disassembly, and no separate storage problem to solve later.
Protective Lid: When the EZ isn’t in use, the supplied lid keeps dust out of the basin so it’s ready to go the next time you clean—no rinse-before-you-rinse ritual required.
7-Inch Adapter: The EZ also accommodates 7-inch 45rpm records with a standard 38mm center hole. Just place the adapter on the clamp base before securing the record, and you’re good to go. It’s a practical inclusion that acknowledges most collections don’t stop at 12-inch LPs.
For complete step-by-step details on using the  Humming EZ Vinyl Record Washer, refer to the Official Product Page, or watch the following promo video;
HumminGuru positions the EZ Vinyl Record Washer as the ideal first step before moving on to its ultrasonic record cleaner, and the logic checks out. The EZ is meant to handle the obvious stuff first—surface dust, fingerprints, and general grime—so the ultrasonic stage isn’t wasting time or energy on debris that’s easily removed by hand.
Used as a two-step process, the approach makes practical sense: pre-wash with the EZ to strip away surface contaminants, then let ultrasonic cleaning dig deep into the grooves where embedded dust and residue live. It’s not a miracle cure, but it’s a methodical workflow that plays to the strengths of both tools—and for collectors already invested in ultrasonic cleaning, it’s an efficient way to get more consistent results without unnecessary wear or drama.
humminguru-drying-rack
The Bottom Line
Manual record cleaning still works—and it’s still where most vinyl listeners realistically land—but it comes with limits. The Spin-Clean ($79.99 at Amazon) has dominated this space for decades precisely because it’s simple, affordable, and effective enough for the masses. The HumminGuru EZ Vinyl Record Washer could become a genuine competitor—but only if it lands under $250. Above that, it stops being an “easy recommendation” and starts wandering into “why didn’t I just buy ultrasonic?” territory.
HumminGuru’s messaging about the EZ being a “pre-wash” for its ultrasonic cleaner muddies the waters a bit. Yes, a two-step process can yield better results—but implying that the EZ needs a second, much more expensive machine undercuts the whole “easy and affordable” pitch. Based on what’s been shown so far, the EZ should absolutely be capable of cleaning records on its own. Anything else feels like upsell gravity doing what upsell gravity always does.
Here’s the reality check: manual machines clean records, but they don’t perform miracles. They won’t excavate decades of embedded filth the way ultrasonic systems can—but they will dramatically reduce surface noise, protect your cartridge, and extend the life of your records if you actually use them. Casual listeners will still stop at a carbon-fiber brush and a spray bottle, and that’s fine—until it isn’t. Dirty records sound worse, chew through stylus life, and let hair, dust, smoke residue, and general household crud permanently bond with the grooves.
Not cleaning your records is bad practice. Whether the EZ becomes the next Spin-Clean depends almost entirely on pricing. Keep it sane, keep it simple, and HumminGuru might have a real hit on its hands. Push it too high, and it becomes another “nice idea” that vinyl people admire… and then ignore.
Price & Availability
The HumminGuru EZ Vinyl Record Washer will be released on January 5th, 2026, and will be available from HumminGuru. The price is forthcoming.
The HumminGuru Ultrasonic Vinyl Record Cleaner is $398 at HumminGuru, where it’s currently a better deal than at Amazon.
Kanto Audio Tuk Grand Lifestyle
Kanto debuts TUK Grand and updates TUK, YU6, and YU4 at AXPONA 2026. Can affordable speakers stand out in a high-priced show?
LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV. LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV.
LG’s Micro RGB evo TVs aim to boost brightness and color beyond OLED, but can they justify a premium over models like the G6...
2026 LG W6 Wallpaper TV Lifestyle Angle 2026 LG W6 Wallpaper TV Lifestyle Angle
LG’s 2026 OLED evo W6 Wallpaper TVs bring ultra thin design, Zero Connect, and 165Hz support in either 77-inch or 83-inch screen sizes.
Sennheiser HD 480 Pro Headphones in the Studio Sennheiser HD 480 Pro Headphones in the Studio
Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle
Klipsch and OJAS debut the kO-R2 at Milan Design Week 2026. Limited to 600 pairs total, with global availability expected in June.
Head(amame) Pro Headphones Head(amame) Pro Headphones
Head(amame) Pro debuts at AXPONA 2026 with 40mm glass diaphragm drivers, 3D printed modular design, 280g weight, and user-tunable acoustics.
Can the $749 Okki Nokki ONE built in the Netherlands set a new standard for quieter and more reliable record cleaning machines?
A skeptical, experience-driven take on hi-fi accessories that actually work—QED, Advance Paris, IsoAcoustics, IsoTek, iFi, ddHiFi—minus the snake oil.
Clearaudio’s Mini Toolkit provides precision tools for perfect turntable setup, cartridge alignment, and vinyl care for the best possible sound.
We tested three inexpensive ways to clean vinyl records from GrooveWasher, Spin Clean and Turntable Lab to keep your LPs sounding pristine.
Originally designed for the BBC, the Keith Monks ReduxTwo offers professional grade record cleaning with zero recontamination.
Turntable Lab's Peter Hahn has some great suggestions for vinyl listeners looking to enhance their listening experience.
The Record Doctor X now cleans both sides of the record at the same time and it's $400 less than the VPI HW16.5.
