When Focal introduces a new speaker line, they usually make sure the world hears about it. The new Omada speakers arrived with a very different energy. However, according to Focal Naim America, the Omada speaker line is exclusive for ProSource members and dealers in the US and Amazon, Audio Advice, and Crutchfield are Authorized ProSource dealers. The introduction and launch of Omada represents a significant milestone in the history of Focal Naim America and its partnership with ProSource Member Dealers.
Focal Omada Speaker Lineup: Four New Models Positioned Between Vestia and Theva
Focal’s new Omada line launches with four models: the Omada N1 bookshelf at $1,398 per pair, the Omada N3 floorstander at $1,899 each, the Omada N4 floorstander at $2,299 each, and the Omada Center at $699. Based on pricing alone, the Omada family appears to slot between the Vestia and Theva series, giving Focal a new mid-tier option that fills the gap between entry-level home theater and their more ambitious hi-fi lines.
Core Features of the Focal Omada Speaker Line
The Omada series follows Focal’s long-running approach of bringing high-end tech down to more accessible price points. Like the Vestia and Theva lines, the new models feature the company’s TAM tweeter and Slatefiber cone—both technologies that debuted in far more expensive Focal loudspeakers. The goal is familiar: natural, detailed sound whether you’re building a two-channel setup or a full home theater system.
Design is another clear carryover. Every Omada model comes in a high-gloss black finish with a subtly curved front baffle, and the front panel adds a leather-like texture that gives the speakers a more refined look. The combination of finish, baffle shape, and front panel detail helps the Omada line blend into a wide range of rooms without calling too much attention to itself.
TAM Tweeter: Focal’s M-shaped dome TAM tweeter is engineered for clean, controlled treble with better dispersion and reduced distortion. Originally developed for Focal’s car audio lineup, it has since been refined for home use, giving the Omada series a proven high-frequency platform that slots neatly into Focal’s broader hi-fi ecosystem.
Slatefiber: The Omada series also benefits from Focal’s Slatefiber cone technology, first introduced in the Chora line back in 2019. Made from recycled carbon fibers, Slatefiber earned strong market feedback for its rigidity, damping, and overall balance. Focal has continued to refine the material since its debut, leading to higher performance and broader use across the catalog, including the Alpha Evo studio monitors and Slatefiber automotive kits.
Bass Reflex: To deliver stronger low-frequency extension and output, every Omada model uses a bass reflex design. The N1, N3, and N4 feature a front-firing port, while the Center speaker includes two smaller rear ports. In each case, the port works by directing the air pressure generated inside the cabinet into the listening space, effectively reinforcing bass response without demanding additional amplifier power. This approach allows the Omada series to produce fuller, more impactful low end while maintaining efficiency across the lineup.
Focal Omada Speaker Line Comparison
| Focal Omada Model | N°1 | N°3 | N°4 | Center Channel |
| Speaker Type | Bookshelf Speaker | Floorstanding Speaker | Floorstanding Speaker | Center Channel Speaker |
| Price | $1,398 (pair) | $1,899 (each) | $2,299 (each) | $699 (each) |
| Speaker Configuration | 2-way bass-reflex | 3-way bass-reflex | 3-way bass-reflex | 2-way bass-reflex |
| Speaker Drivers | 6 1/2″ (16.5cm) Slatefiber Midbass 1″ (25mm) Al/Mg inverted dome TAM tweeter | 3 x 6 1/2″ (16.5cm) Slatefiber Woofer 1 x 6 1/2″ (16.5cm) Slatefiber Midrange 1″ (25mm) Al/Mg inverted dome TAM tweeter | 2 x 8 1/4″ (21cm) Slatefiber woofer 1 x 6 1/2″ (16.5cm) Slatefiber Midrange 1″ (25mm) Al/Mg ‘M’-shaped inverted dome TAM tweeter | 2 x 6 1/2″ (16.5cm) Slatefiber Midbass 1″ (25mm) Al/Mg inverted dome TAM tweeter |
| Sensitivity (2.83V/1m) | 89.5dB | 92dB | 92dB | 91.5dB |
| Frequency response (+/-3dB) | 56Hz – 30kHz | 42Hz – 30kHz | 40Hz – 30kHz | 58Hz – 30kHz |
| Low frequency point (-6dB) | 48Hz | 35Hz | 34Hz | 50Hz |
| Nominal Impedance | 8 Ω | 8 Ω | 8 Ω | 8 Ω |
| Minimum impedance | 4.5 Ω | 2.9 Ω | 2.6 Ω | 3.6 Ω |
| Recommended Amplifier Power | 25 – 120W | 40 – 300W | 40 – 350W | 40 – 200W |
| Crossover frequency | 2,800Hz | 280Hz / 3,100Hz | 280Hz / 2,800Hz | 2,700Hz |
| Dimensions (WDH) | 8 5/8 x 10 1/4 x 15 1/4 in. 21.9 x 26 x 38.7 cm | 10 1/8 x 14 3/4 x 44 1/8 in. 25.6 x 37.5 x 112.2 cm | 12 x 16 7/8 x 44 3/8 in. 30.4 x 43 x 112.6 cm | 21 1/8 x 10 1/4 x 8 1/2 in. 53.7 x 25.9 x 21.6 cm |
| Net weight (with grille) | 15.4 lbs (7 kg) | 58.4 lbs (26.5 kg) | 69.45 lbs (31.5 kg | 22 lbs (10 kg) |
The Bottom Line
Focal’s reputation in the loudspeaker world is well established, and while the Utopia Evo series grabs the headlines, their mainstream lines—Vestia, Theva, and Aria Evo X—prove they know how to deliver real performance at real-world prices. The Omada series looks like another entry in that playbook. It’s a “just the essentials” approach built on proven Focal technologies like the TAM tweeter and Slatefiber cone, wrapped in a clean, modern design that won’t fight your room.
Focal slipped the Omada line into the market without the usual fanfare, which feels out of character for a brand that normally spotlights every new model. However, the answer is that this speaker line is a partnership between Focal Naim America and Prosource.
The Omada isn’t walking into an empty lane. KEF’s Q Meta series, Bowers & Wilkins’ 600 S3 line, and Q Acoustics’ 5000 series all offer strong performance at similar price points. Omada speaker line’s advantage here is its trickle-down tech and long-term brand equity. Omada looks like another solid mid-tier option in a very crowded class.
Price & Availability
- Omada N1 (Bookshelf Speaker) – $1,398/pair
- Omada N3 (Floorstanding Speaker) – $1,899/each
- Omada N4 (Floorstanding Speaker) – $2,299/each
- Omada Center (Center Channel Speaker) – $699/each
These speakers can be combined with the SUB 600P subwoofer for deeper and encompassing bass for $1,399 at Amazon. Meanwhile speaker stands for the N1 are available for $269/pair at Amazon.
Related Reading:
- Focal’s Aria Evo X Series Has Us Green With Envy
- Focal Launches Mu-so Hekla Dolby Atmos Home Cinema System: A New Era of Immersive Sound
- Focal’s $69K Diva Mezza Utopia Ditches Cables and Dares Audiophiles to Let Go of Their Separates
- Focal’s UTOPIA CINEMA LCR Speaker and Subwoofer Will Be a Popular Choice for Premium Home Theaters: ISE 2025
