FiiO isn’t slowing down — at this point, you half-expect them to announce a toaster with dual R2R ladders and LDAC support. Barely two weeks after dropping the FT13 closed-back headphones, the B15 R2R DAC, and the new Air Link Bluetooth transmitter, the company’s affordable Jade Audio brand is back with two more headphones aimed squarely at first-time hi-fi converts, and a new Bluetooth receiver under the FiiO branding.
Leading the charge is the Jade Audio JT7, an open-back planar magnetic headphone designed to drag newcomers into high-fidelity territory without wrecking their bank accounts. It’s joined by the Jade Audio JT3, a dynamic headphone built for the same mission. And rounding out the trio is the FiiO BR15 — a desktop Bluetooth receiver built around a 24-bit R2R DAC array, pushing wireless audio far closer to the real thing than most people assume possible at this price.
Together, the JT7, JT3, and BR15 cement FiiO’s ongoing strategy: relentless releases, premium engineering, and pricing that makes the rest of the industry look like they’re charging admission to a private club.
Jade Audio JT7: The Most Affordable Planar Magnetic Headphone
The Jade Audio JT7 is a straightforward statement from FiiO: planar magnetic headphones don’t need luxury-tier pricing to deliver real performance. Designed entirely in-house, the JT7 uses a large 95 × 86 mm planar driver and a fully symmetrical push-pull magnetic system built from high-density magnets. The result is low distortion, clean transient response, and a wider, more natural soundstage than you’d expect at $119.99 at Amazon.
FiiO also brings its F.E.S. (FiiO Elastic System) diaphragm embossing to the mix. This structural tweak increases elastic amplitude, giving the JT7 more convincing low-frequency weight while keeping the speed and clarity that define planar drivers.
At 318 grams, the JT7 stays lightweight and practical. It folds for easier transport, includes both 3.5 mm single-ended and 4.4 mm balanced cables, and offers replaceable earpads plus a removable Velcro headband cushion for long-term durability. With a frequency range of 7Hz–40kHz, 92dB/mW sensitivity, and an 18-ohm load, it’s easy to drive and pairs naturally with FiiO’s M21 player.
The JT7 isn’t dressed up to be something it’s not — it’s simply FiiO’s most accessible planar to date, aimed squarely at listeners stepping into higher-fidelity territory without overspending.
Jade Audio JT3: An Open-Back Dynamic Headphone at a Landmark Price
The Jade Audio JT3 sits under the JT7 but goes after a different corner of the market — the entry-level open-back space dominated by Grado Labs, Skullcandy, Audio-Technica, and Sennheiser. With the JT3 priced at $69.99 at Amazon, FiiO is making it clear they want a seat at that table.
The JT3 uses a 50 mm dynamic driver with a PEK + PU composite diaphragm and a high-tension CCAW voice coil, giving it solid low-end punch, focused mids, and clean upper-range extension. A brass damping ring helps keep distortion in check and improves micro-detail clarity. The headphone is rated at 97dB/mW sensitivity with an 80-ohm impedance and covers a 10Hz–40kHz range. Dual 3.5 mm TRS connectors keep cable swaps simple.
FiiO keeps the focus on acoustic design rather than extras, maintaining their philosophy of putting the budget into the components that affect sound. The result is an open-back dynamic headphone built to deliver honest, straightforward performance at an accessible price point.
At 330 grams, the JT3 remains lightweight, with velvet earpads and aluminium-magnesium alloy grilles for comfort and durability. It pairs naturally with FiiO’s JM21 player for everyday listening.
FiiO BR15: A Next-Gen Bluetooth Receiver Built for Real Hi-Fi Systems
The FiiO BR15 is aimed at listeners who want wireless convenience without giving up fidelity. It’s a compact desktop receiver, but the feature set reads more like a full decoding hub for a hi-fi system, headphone amp, or active speakers. Priced at 199.99 USD and arriving in December 2025, the BR15 is positioned as a serious upgrade for anyone trying to modernize an existing setup.
At the center of the design is Qualcomm’s QCC5181 Bluetooth 5.4 platform with support for both aptX Lossless and LDAC — the two formats that matter if you care about preserving actual detail over the air. The BR15 goes a step further by using a fully differential 24-bit R2R DAC built from precision resistor arrays, giving the unit a more natural, analog-leaning tonal balance than typical chip-based decoders.
Connectivity is straightforward: Bluetooth, USB inputs on the front and back, and SPDIF, all feeding dual RCA outputs and an XLR balanced output for systems that need it. It pairs cleanly with powered speakers like FiiO’s own SP5 or any traditional amplifier chain. A 10-band PEQ, accessible through the FiiO Control app on laptop or phone, makes system-level tuning easy without adding extra boxes.
The BR15 includes its own internal power supply and comes with a remote, making it a low-clutter way to add modern wireless decoding to speakers or full-size hi-fi gear.
The Bottom Line
FiiO’s latest trio shows a company that refuses to sit still, even as tariffs and rising manufacturing costs make affordability harder to deliver. The Jade Audio JT7 breaks new ground as the world’s most affordable planar magnetic headphone, pairing a large in-house driver with a genuinely lightweight, foldable design at $119.99 — something no major competitor is offering at this price. The JT3 targets the crowded entry-level dynamic market and goes straight at Grado Labs, Skullcandy, Audio-Technica, and Sennheiser with a wide-open soundstage and a clean, no-frills acoustic design for $69.99. And the BR15 pushes wireless audio further than most budget Bluetooth receivers dare, thanks to aptX Lossless, LDAC, and a true 24-bit R2R DAC at $199.99, all while keeping system integration simple.
Not every FiiO release is a walk-off homer, but in 2025 they’re batting around .750 — a number the rest of the industry would kill for. These three products underline why: focused engineering, sensible pricing, and a willingness to challenge established brands by offering more for less. In a market getting squeezed from every direction, FiiO’s value-first strategy still lands where it counts for everyday listeners.
For more information: fiio.com/jt3 | fiio.com/jt7
Where to buy:
- FiiO JT3 (open-back) Dynamic Headphones – $69.99 at Amazon
- FiiO JT7 (open-back) Planar Magnetic Headphones – $119.99 at Amazon
- FiiO BR15 Bluetooth Receiver – $199 (coming December 2025)
Related Reading:
- FiiO Launches FT13 Wooden Headphones, B15 R2R DAC, And Air Link Wireless Hub: Premium Sound For The Desktop And On-The-Go
- FiiO K13 R2R DAC: A Balanced Headphone Amp And Hi-Res Desktop Audio Hub With Enough Power For Planar Headphones
- FiiO QX13 Carbon Fiber DAC Debuts Ahead Of CanJam London 2025: High-Res Audio Goes Pocket-Sized
- FiiO M27 Flagship DAP: 5W Balanced Amp, AptX Lossless, And Dragonwing AI—Pocket Power That Could Actually Scare IBasso And Astell&Kern
