CD Players
dCS Varèse Music System Expands with Reference-Grade CD/SACD Transport for Ultimate Disc Playback
Only for Varèse owners: dCS’s new Transport delivers reference-level CD and SACD playback with ultra-low vibration and ACTUS bit-perfect transmission.
dCS Varese CD/SACD Transport Angle
The dCS Varèse Music System just got an upgrade—but don’t get too excited unless you already own one (or plan on dropping serious coin soon). dCS has introduced a dedicated CD/SACD Transport designed exclusively for the Varèse, giving listeners the option to experience reference-level sound from their silver discs. After six years of obsessive development, the Varèse remains dCS’s most ambitious creation yet, and this new transport keeps the focus firmly on ultimate audio performance and immersive playback—provided you’re already in the Varèse club.
The MSRP is GBP £35,000 or USD $39,950—not a typo. And before we get into the whole Varèse Music System thing, it’s worth reminding everyone that dCS isn’t some upstart chasing audiophile dollars—it’s one of the benchmark brands for reference-quality digital playback and headphone listening. Our own eCoustics Headphone Editor, Will Jennings, took the plunge two years back, and let’s just say he hasn’t filed a single complaint since.
dCS Varèse System: $320,000 of Reference-Level Audio—and You’d Better Love Every Detail
dcs-varese-stack
The dCS Varèse Music System isn’t just a product—it’s a full-on reference-level ecosystem. Pricing reflects the ambition: the Varèse Core System, which includes the Core, User Interface, Remote Control, and a 1.5m ACTUS cable, comes in at $116,500. Add the Varèse Mono DAC pair with dual ACTUS cables for $110,250, the Master Clock at $39,950, and the dedicated CD/SACD Transport at $39,950, and you’re deep in six-figure territory before you even touch the $14,200 I/O Module.
Each component is designed to work seamlessly together, delivering the kind of sound only a Varèse setup can provide—so plan accordingly if you’re serious about chasing reference-level digital playback.
Before we even get to the shiny new CD/SACD Transport, let’s take a moment to appreciate just what the Varèse Music System actually is—and why it costs as much as a small cottage on the coast of Nova Scotia. The Varèse isn’t a single box you toss on a rack; it’s a full ecosystem designed to push digital playback into reference-level territory.
dCS Varèse Music System Front and Back
dCS Varèse Music System without Transport
At its core, literally, is the Varèse Core, the brains behind the operation. It handles all hi-res audio formats, streaming services, and any processing the system needs before passing signals off to the dual Mono DACs, one for each channel—which convert digital to analog with precision most mere mortals won’t notice until they’ve spent years chasing it.
The User Interface hooks into the dCS Mosaic ACTUS app on iOS or Android, giving you control and navigation via touchscreen or the included Bluetooth LE remote.
And if you’re obsessive about timing—and if you own a Varèse, you probably are—the optional Master Clock keeps everything locked in, reducing jitter and drift with dCS’s patented Tomix protocols, ensuring the music has focus, presence, and image that feels alive rather than just “there.”
The Varèse suite also introduces some serious tech cred:
  • dCS Tomix: The new clocking tech that keeps everything ultra-precise.
  • ACTUS: The bespoke interface that carries audio, control, and timing signals seamlessly between components.
  • Differential Ring DAC: An all-new evolution of dCS’s signature Ring DAC, the biggest change in a generation, promising more detail, clarity, and nuance.
Physically, the system is built like a small tank. The Core is 33 kg (73 lbs), each Mono DAC is almost 19 kg (41 lbs), the Master Clock is 15.7 kg (34.7 lbs), and the User Interface weighs 14.6 kg (32 lbs). Each component is carefully dimensioned for proper airflow and ACTUS cable routing—because, yes, setup requires planning, and no, you won’t just shove it on a standard shelf.
Connectivity and format support is exhaustive: Ethernet streaming, USB Type A for mass storage, USB Type B for high-res PCM and DSD, AES/EBU, S/PDIF, Word Clock outputs, and support for sample rates from 44.1kHz up to 384kHz PCM and DSD up to 512. Residual noise sits better than 118 dB, spurious responses better than –115 dB—basically, this is the audio equivalent of wearing a bulletproof suit while sipping single-malt scotch.
All of which brings us to the big question: you’ve got the Varèse Core, the dual Mono DACs, the Master Clock, the User Interface—but how do you feed it the kind of silver-disc perfection that makes the system truly shine? That’s where the dedicated Varèse CD/SACD Transport comes in…
True Reference-Level Sound: dCS Varèse CD/SACD Transport
dcs-varese-cd-sacd-transport-angle-closed
dCS has been building CD and SACD transports for over two decades, and the engineering obsession shows in every detail of the new Varèse Transport. From the ground up, the design is about reducing anything that gets in the way of pure sound: noise, vibration, and distortion are all treated as enemies. Every mechanical and electronic choice is scrutinized—from the stability of the drive mechanism to the precision of the chassis construction—and everything that powers the transport is fed with ultra-clean voltages to ensure consistent performance.
Software and hardware have evolved in lockstep with mechanical improvements, meaning the Varèse Transport isn’t just a disc player; it’s a platform engineered to extract every ounce of musical information from CDs and SACDs with maximum fidelity.
dcs-varese-cd-sacd-tray-open
The Varèse Transport continues dCS’s transport development, offering lower noise and vibration than previous models through a redesigned chassis and the ACTUS interface. It plays Redbook CDs in 44.1 kS/s and SACDs in native DSD, with a single ACTUS cable handling bit-perfect audio, asynchronous timing, and control signals between the Transport and Varèse Core.
The Transport automatically syncs to a master clock via ACTUS—either the Varèse Clock, if present, or the Core—eliminating the need to adjust sync settings manually. Playback can be managed through the Varèse User Interface, remote, or Mosaic ACTUS app, providing flexible control.
Mechanically, the top, sides, and front of the chassis are machined from a single billet of aluminium, with constrained-layer damping between base and dress plates to reduce vibration. Mechanism mounts are also milled from solid aluminium without joins or fixings. The drive mechanism is derived from the Vivaldi II and Rossini Transports, but mounted in a new way to reduce noise and physical vibrations further.
dcs-varese-transport-front
dcs-varese-transport-rear
The Bottom Line
The dCS Varèse CD/SACD Transport is a precision-engineered component designed for the Varèse ecosystem, delivering reference-level playback for CDs and SACDs with minimal noise and vibration. The ACTUS interface simplifies setup and ensures bit-perfect transmission, while the machined-aluminium chassis and remounted mechanism reduce mechanical interference.
The pros are obvious: it integrates seamlessly with the Varèse Core, gives multiple ways to control playback, handles Redbook and DSD natively, and benefits from improved mechanical and electrical stability. The cons? It only works with the Varèse system, and at $39,950, it’s not for casual listeners. If you’re already invested in Varèse—or planning to be—this Transport maximizes the system’s potential; if not, it’s essentially a very expensive paperweight.
For more information: dcsaudio.com
Emotiva BasX TA2+ Integrated Amplifier
Can Emotiva’s BasX TA2+ revive the stereo receiver? With 135W power, HDMI ARC, balanced inputs, and phono support, it targets modern 2 channel systems.
Lyngdorf SB-75 Passive Soundbar Lifestyle Angle Lyngdorf SB-75 Passive Soundbar Lifestyle Angle
What makes Lyngdorf's $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Sonos Era 100 SL and Sono Play Wireless Speakers 2026 Sonos Era 100 SL and Sono Play Wireless Speakers 2026
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these...
Woman wearing ASUS ROG Cetra Open Gaming Wireless Earbuds Woman wearing ASUS ROG Cetra Open Gaming Wireless Earbuds
ASUS launches the ROG Cetra Open Wireless gaming earbuds with cross platform support for PC, Mac, PlayStation, Switch, iOS, and Android. Are open earbuds...
STAX SR-009S Headphones STAX SR-009S Headphones
STAX unveils the SR-009D, the latest evolution of its legendary SR-009 electrostatic headphone platform. Can the new flagship raise the bar again?
ABYSS Diana TC Signature Audiophile Headphones ABYSS Diana TC Signature Audiophile Headphones
Can the $4,995 ABYSS Diana TC Signature really compete with Audeze and Meze? We listened at CanJam NYC 2026 on a $30K Woo Audio...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
CD Players
Mission completes its 778 Series with the 778CDT CD transport, a practical, affordable addition that reflects the quiet return of CD playback in modern...
CD Players
Shanling’s $999 CT90 CD transport targets modern CD collectors with digital-only outputs and Bluetooth, but skips SACD, analog outs, and compact rack-friendly design.
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
CD Players
TEAC's Reference 500 Series PD-507T CD Transport is engineered for audiophiles pairing external DACs with a growing CD resurgence.
CD Players
At $359, the Shanling CD80 II combines hi-res CD / media playback, dual headphone amps, and Bluetooth for modern or vintage hi-fi setups.
CD Players
Onkyo's new Icon C-30 CD player brings audiophile tech at a surprising price. Discover why physical CDs still matters at Audio Advice Live 2025...
At $15,500 the dCS Lina DAC X combines hi-res digital music streaming, proprietary Ring DAC tech, and a build quality that justifies its top-shelf...
CD Players
The Shanling CR60 provides CD playback and ripping capability for a very reasonable $299, but it requires an external DAC.
