Castle Loudspeakers is back—and this time, they brought reinforcements. The storied British brand, known for its meticulous craftsmanship and warm, natural sound since 1973, has officially joined forces with MoFi Distribution. If you’re familiar with MoFi, you already know the drill: they don’t just deal in gear, they deal in legends. Wharfedale, Leak, Quad, Audiolab—brands with serious heritage and cult-like followings. Now Castle joins the fold, armed with the new Windsor Series—the Duke and the Earl—two handcrafted bookshelf loudspeakers built in the UK with zero flash and all substance.
And no, there’s no relation to Frank Castle, but these speakers still pack the kind of precision and impact that would make the Punisher proud.
Built Like a Castle, Because It Is
This isn’t some offshore reissue with a “Made in Britain” sticker slapped on. These are built where British hi-fi was born. Every Windsor loudspeaker is a product of real craftsmanship, not marketing fluff.
Real-Wood Veneers. Not Vinyl. Not Faux Anything.
Every cabinet is wrapped in actual wood veneer—because that’s what you do when you give a damn about how something looks and sounds. These things are built to age like good whisky, not wear out like IKEA flat-pack.
Custom Stands? Of Course
Because throwing one of these on a wobbly side table is like parking a Bentley on cinder blocks. Each Windsor model comes with its own bespoke stand, engineered to lock in imaging and stability. No guesswork. No compromise.
British Design, Modern Engineering—Zero Apology
They look like they’ve been around since the Thatcher years, but under the hood, it’s all 21st-century refinement. Castle didn’t reboot for nostalgia—they came back to show how heritage and performance can still matter in a world overrun with smart speakers and bad taste.
Windsor Duke: No-Nonsense Nobility
The Windsor Duke doesn’t need a flashy spec sheet or some over-polished marketing campaign—it’s a proper bookshelf monitor built to perform and built to last. Under the hood, it’s rocking an 8” woofer and a custom 28mm textile dome tweeter, both engineered from scratch to work together like they’ve been on tour for years.
Castle didn’t phone in the details here. These drivers use cast alloy components, woven polypropylene cones, and glass-fiber voice coils—real parts, real engineering, no off-the-shelf compromises. It’s all designed to keep that classic Castle character intact while pushing the performance into modern territory.
And yeah, the cabinet lives up to the name. Book-matched real wood veneers, hand-selected from the same sources Castle’s been using for decades. Each pair is finished by a small crew that treats them like heirloom furniture, not mass-produced speaker boxes. No shortcuts. No two pairs are alike.
The Windsor Duke is for listeners who want honesty, not hype.
A Royal Weave
Instead of using molded plastic cones, Castle takes a more refined path. Thin strips of polypropylene are woven into a fabric-like material, pressed into shape, and cut to size. It’s a more complex process—but one that pays off.
This woven design creates variable rigidity across the cone, helping to suppress unwanted resonances and deliver a flatter, more accurate frequency response. The 200mm cones are finished with low-hysteresis rubber surrounds that resist aging, ensuring performance that lasts.
Regal Magnetics
The Windsor Series doesn’t mess around when it comes to midrange clarity. Each driver’s motor structure includes an aluminum compensation ring, which keeps impedance variation in check during operation. The payoff? Lower harmonic and intermodulation distortion, and a more open, natural-sounding midrange.
A Voice Coil of the Upper Class
Instead of aluminum—which invites unwanted eddy currents—Castle uses glass fiber voice coils bonded with high-temp resin. It’s just as stiff, but far cleaner when it comes to preserving signal integrity. These drivers are engineered to sound refined without smoothing over the truth.
Built Like a Castle
While drive unit tech has evolved, the best cabinet design principles haven’t changed much since the BBC laid the groundwork decades ago. Castle leans into that legacy with modern precision.
The Windsor Series cabinets use dual-layer MDF panels bonded with a flexible acoustic glue that damps midrange resonance without adding bulk. Strategic point-to-point bracing locks down low-frequency rigidity while keeping unwanted vibrations from spreading.
After extensive testing, Castle fine-tuned this construction to match their custom drivers perfectly—resulting in a quiet, controlled cabinet that lets the music do the talking. Simple idea, complex execution.
The Final Crossover
The basic topology of both models is a 4th order LKR (Linkwitz-Riley) crossover that allows the best integration of the purpose-designed drive units. The aim was to get a flat response with an easy load for amplifiers and a low distortion measurement.
Developed using a combination of advanced computer modelling and many hours of listening tests, the core aims were to achieve a flat response, an easy load for amplifiers and a low distortion measurement.
All critical inductors in the crossover design are of the ‘air core’ type – this means there are no metal cores present in the circuit, preventing hysteresis or distortion through the network. The main inductor resistance is compensated in the mid/bass driver’s magnet system, so there is no disadvantage from the slightly higher resistance of this air coil.
Windsor Earl…Duke, Duke, Duke of Earl
The Windsor Earl takes the same approach as the Windsor Duke, combining precision engineering with the timeless craftsmanship that Castle Acoustics is known for. Equipped with a 6” woven Polypropylene woofer and a 28mm textile dome tweeter, this two-way bookshelf speaker delivers a smooth, balanced sound that brings out the nuances of your favorite tracks.
The woofer is custom-designed using woven Polypropylene for improved rigidity, resulting in a cleaner, more accurate bass response. Meanwhile, the textile dome tweeter, with its high-performance voice coil, ensures a detailed and clear treble, avoiding the harshness that some speakers bring to the table. Together, they create a dynamic, full-range sound that’s ideal for everything from delicate acoustics to punchy rock tunes.
Just like the Windsor Duke, the Windsor Earl is handcrafted in the UK, using real wood veneers that are as much about function as they are about form—optimizing the speaker’s acoustic performance while providing a sleek, high-quality finish. And to make sure every note lands perfectly, each speaker is paired with a custom matching stand, designed to enhance stability and imaging.
Castle’s commitment to craftsmanship doesn’t stop at the aesthetics—the Windsor Earl is built to provide you with a natural, detailed listening experience, elevating every piece of music you play.
Comparison
| Windsor Earl (smaller) | Windsor Duke (bigger) | |
| Speaker Type | Two-way stand mount | Two-way stand mount |
| Enclosure Type | Bass reflex with rear port | Bass reflex with rear port |
| Tweeter | 28mm (1-inch) microfibre dome | 28mm (1-Iinch) microfibre dome |
| Mid/Bass Driver | 165mm (6.5-inches) woven polypropylene cone | 200mm (8-inches) woven polypropylene cone |
| Sensitivity (2.83V @ 1m) | 89dB | 90dB |
| Impedance | 8 ohms nominal; 4.3 ohms minimum | 8 ohms nominal; 4.2 ohms minimum |
| Recommended Amp Power | 25-100W | 30-150W |
| Frequency Response | 58Hz-22kHz | 52Hz-22kHz |
| Bass Extension (-6dB) | 45Hz | 39Hz |
| Crossover Frequency | 2.2kHz | 2.1kHz |
| Cabinet Volume (Liters) | 15.8L | 26L |
| Cabinet Dimensions (HWD-mm) | 430 x 240 x 260mm | 470 x 280 x 310mm |
| Cabinet Dimensions (HWD-inches) | 16.9 x 9.4 x 10.2 inches | 18.5 x 11 x 12.2 inches |
| Weight (kg) | Not provided | Not provided |
| Weight (lbs) | Not provided | Not provided |
Windsor Stands
Let’s cut to the chase. If you want your Castle Windsor loudspeakers to perform at their best—and not embarrass yourself with a wobbly, unstable setup—these custom-engineered Windsor stands are your answer. Crafted in the UK from high-carbon British steel, every detail of these stands has been designed for ultimate resonance control and stability. Weighted plates, internal damping, and stainless-steel spikes keep everything in place like it should be—no drama.
Each stand, tailored to either the Duke or Earl models, ensures perfect height and positioning for optimal sound. And yes, floor protectors and spike seat options come standard, because we know you like your floors as much as you like your sound.
Earl Stands Dimensions:
980 (on plinth) x 240 x 296 mm
Duke Stands Dimensions:
1020 (on plinth) x 280 x 346 mm
Now go ahead, indulge in perfection—or don’t. Your call.
The Bottom Line
The Castle Windsor Duke and Windsor Earl aren’t just loudspeakers; they’re a quiet rebellion against the soulless, cookie-cutter designs cluttering today’s market. Handcrafted in the UK with real wood veneers, these speakers bring back that tactile, tangible feel that’s long gone in an age of mass production. Precision engineering, custom stands, and a design that screams “we’ve been doing this right since 1973″—these are built to last and sound like they mean it.
Now, let’s get real for a second. It’ll be interesting to see how these stack up against Wharfedale’s Heritage series, a line that’s been delivering its own vintage goodness for years. Castle’s new lineup? Definitely promising, but it’s going to take more than a polished veneer and a few clever tweaks to knock the established players off their perch.
And honestly, these have more than a hint of the Spendor Classic series about them. They’ve got that “I’m timeless, deal with it” vibe. The sound, the craftsmanship, the overall “we know what we’re doing here” attitude—if there’s a competition brewing, it’s only going to get interesting. These speakers could easily have that same level of enduring appeal, if not more.
So, if you’re sitting there, ignoring the raw potential of speakers like these, well… you might as well be living in the past with the rest of them. At least give these a shot before you toss your money into something less, well, honest.
For more information: castle-hifi.co.uk
Related Reading
Mike Cornell
May 1, 2025 at 12:56 pm
You stole my line, Ian! When these were first announced, all I could think of was Duke, Duke, Duke, Duke of Earl…..! I have owned some Castles ( Knight 5 transmission lines) and will attest to their smoothness, neutrality and cabinet work (even though mine were from IAG’s Chinese facility). Going to have to pour myself a pint now! Cheers!
Ian White
May 1, 2025 at 1:32 pm
Mike,
I remember seeing Castle at some dealers in Toronto but never had the opportunity to listen to them. I’m curious how these differ from the Wharfedale Heritage Series in terms of sonics. I only like the Super Denton and the smaller model here has me intrigued as an option if it’s better. These will not be cheap.
IW
Anton Heimsworth
May 1, 2025 at 3:42 pm
I’m actually very intrigued about the smaller one and love the woodwork.
Any chance they make an active version of these in the near future? Powered by Audiolab or Leak?
ORT
May 2, 2025 at 4:58 pm
As someone who this week downsized from a 9.2 fAtmos(!) setup to a 2.1 system, these speakers intrigue me. I borrowed a pair of Matin-Logan bookshelf speakers from my son along with a nondescript subwoofer I own that works just fine for now…
A Denon Home Amp (HEOS!!), Marantz CD60 and turntable with SpinBase by Andover Audio. That’s it! That’s all! That’s life!
Atmos is great but I appear to be in the twilight of my time here and need to downsize for the sake of my loved ones. But that does not mean I cannot hear my life’s soundtrack and these British speakers would be a welcome addition to my room as would several of Wharfedale’s offerings.
Life happens, especially if your listening.
The ORTacle at Helfi
