Cary Audio DMS-300A Streaming Amplifier: Because Clearly We Needed One More High-End Model for the Royal Rumble
At $5,995, Cary Audio enters the crowded streaming amp arena with the DMS-300A, a Class A/B heavyweight packed with hi-res support, tons of inputs, but no room correction.
Cary Audio DMS-300A Streaming Amplifier Silver with Remote Control
Streaming amplifiers are the audio world’s new black turtleneck—every brand’s got one, and if they don’t, they’re scrambling to design one before the playlist ends. What started as a niche solution for space-starved apartments and cable-hating millennials has ballooned into a full-blown arms race.
You’ve got budget options from WiiM, NAD, Eversolo, and Marantz slinging some very capable boxes under $1,000. Move up the chain and you’re staring down serious contenders like Naim’s Uniti line, Cambridge Audio’s Evo series, and Hegel’s smartly engineered all-in-ones. And that’s before you wander into the upper tiers where things get serious—and pricey.
Enter Cary Audio, a brand that rarely dips a toe in the stream without giving it some old-school American thunder. Their new DMS-300A streaming integrated amplifier throws its hat into this very crowded ring, aiming not just to compete but to stand out with a Class A/B design that still promises all the digital bells and whistles. Hand-built in the U.S. with 75 watts per channel into 8 ohms and streaming support baked in, this isn’t a half-hearted attempt to ride the wave—it’s Cary’s declaration that they’re ready to bring the heat in a category quickly reaching critical mass.
Cary Audio DMS-300A Streaming Integrated Amplifier
cary-audio-dms-300a-black-front
Cary Audio didn’t just slap a streaming module onto an amp and call it a day—the DMS-300A is built to compete in the heavyweight division of hi-fi. On the streaming side, it’s armed to the teeth: it can handle PCM files up to a ridiculous 32-bit/768kHz and native DSD512. That’s more resolution than most people need, but hey, it’s 2025—go big or go home.
It supports Qobuz Connect, TIDAL Connect, Spotify Connect, AirPlay, and Bluetooth with aptX for the lossy crowd. You’ve also got UPnP and DLNA support, so pulling music off a NAS or local server is a breeze, assuming you still remember your network password.
Roon Ready? Of course it is. It would be malpractice for a $6K+ amp in this category not to be.
Physical connections are generous: coax and optical digital outputs and inputs, three USB-A ports for local storage (or maybe your collection of old DACs you can’t quit), and three line-level analog inputs. There’s even a 3.5mm stereo jack, which feels a bit retro in the best way. On the front, you’ll find an SD card slot because somewhere out there, a Cary loyalist still loads music like it’s 2011.
No headphone amplifier, though—so if you’re looking for late-night sessions without waking the dog or your upstairs neighbor, you’ll need an external solution. The DMS-300A does come with its own control app for both Android and iOS, though—thankfully—so you won’t have to control this thing with a rotary dial and Morse code.
cary-audio-dms-300a-silver-rear
Cary Audio DMS-300A Features & Specifications
  • Amplifier Type: Streaming Integrated Amplifier (Class A/B)
  • Power Output:
    • 75W x2 @ 8Ω
    • 125W x2 @ 4Ω
  • Amplifier Design: Power MOSFET, Class A/B
  • Dimensions: 3.75″ (H) x 17.25″ (W) x 12.5″ (D)
  • Weight: 26 lbs
  • Power Consumption: 255W
  • Frequency Response: 10Hz – 50kHz (±0.1dB)
  • Total Harmonic Distortion (THD): 0.0004% (1kHz)
  • Signal-to-Noise Ratio: >100dB (A-weighted)
  • Dynamic Range: 117dB
  • Channel Separation: 106dB
  • Preamp Output Level: 3.0V RMS
  • Analog Inputs
    • 3 x RCA (Main-In, Line 1, Line 2)
    • 1 x 3.5mm Stereo Jack
  • Analog Outputs: 1 x RCA Subwoofer Out
  • Digital Inputs
    • 3 x USB-A
    • 1 x SD Card (front panel)
    • 1 x Optical (Toslink)
    • 1 x Coaxial
    • Bluetooth aptX (Input)
  • Digital Outputs
    • 1 x Coaxial
  • Streaming Services:
    • Qobuz Connect
    • TIDAL Connect
    • Spotify Connect
    • Apple AirPlay
    • Bluetooth (Qualcomm aptX)
  • Roon Ready Certified
  • Network Protocols: DLNA, UPnP
  • App Control: Available for iOS and Android
  • Wi-Fi: 802.11 b/g/n
  • Ethernet: Yes
  • PCM Resolution: Up to 32-bit / 768kHz
  • DSD Support: DSD64, 128, 256, 512
cary-audio-dms-300a-silver-angle-left
The Bottom Line
The Cary Audio DMS-300A enters a crowded arena already stacked with smart, mature contenders like Hegel, Naim, PS Audio, Cambridge, Marantz, and Lyngdorf—brands that have spent years refining the all-in-one streaming amp formula. Cary’s approach is refreshingly traditional: Class A/B power instead of Class D, a solid array of analog and digital I/O (no HDMI ARC, but enough for serious setups), and an old-school visual aesthetic free of touchscreen gimmicks that most of us can’t read without squinting like we’re decoding ancient runes.
There’s no phono stage, no room correction, and it comes in at a premium price—meaning it’s clearly not chasing entry-level users. But for those who want American-built hi-fi with real heft, familiar usability, and a clean signal path, the DMS-300A has appeal. Just know that at this price point, you’re standing in the ring with some of the industry’s most battle-tested heavyweights—and they’ve all had more rounds to work out the kinks.
Where to buy: $5,995 at Cary Direct
3 Comments
3 Comments
  1. Anton
    August 7, 2025 at 7:29 pm
    I didn’t even know that Cary Audio was still in business. They made some really nice tube power amplifiers in the 1990s. Good to see them still alive and kicking.
    Sorta like VanAlstine. Sadly he passed away I think. Hopefully the family keeps that one going.
    • Ian White
      August 7, 2025 at 8:14 pm
      Cary is very much in business (obviously) and still making some great amplification.
      I think I remember the amplifier you mentioned from the 1990s. Was it a silver/gold 300B or 845 triode power amplifier?
      IW
    • Ian White
      August 7, 2025 at 8:29 pm
      I forgot to respond to the Van Alstine comment. Frank passed away in January and the company continues to design and offer new components.
      Interesting man. Met him twice at shows. Respected engineer and not a marketing guy.
      IW
clearaudio N2 MM Phono Cartridge Connected to Black Tonearm
Clearaudio N2 MM cartridge uses a carbon fibre PETG body, 8.5g weight and $290 price to challenge Audio-Technica, Grado, Ortofon and Sumiko.
JBL PartyBox 330 and 130 Party Speakers Lifestyle JBL PartyBox 330 and 130 Party Speakers Lifestyle
JBL PartyBox 330 and 130 add upgraded drivers, Auracast, mic and guitar inputs, fast charging, and party-ready power from $449.95.
2026 Fluance RT87 Dual Plinth Turntable in Walnut 2026 Fluance RT87 Dual Plinth Turntable in Walnut
Fluance RT87 flagship turntable adds dual-plinth isolation, a 22mm acrylic platter, and AT-VM95ML or 2M Blue cartridge options.
2026 Technics Fritz Hansen Limited Edition SL-40CBT Turntable 2026 Technics Fritz Hansen Limited Edition SL-40CBT Turntable
Technics gives the SL-40CBT Bluetooth turntable a limited Fritz Hansen makeover, proving Danish design still knows how to shame a living room.
Wharfedale Elysian R Series Loudspeakers in Grey Wharfedale Elysian R Series Loudspeakers in Grey
Wharfedale Elysian R Series debuts with upgraded AMT tweeters, revised drivers, SLPP bass loading, and flagship performance from $5,995.
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Father's Day 2026 4K UHD Blu-ray Disc Movies
Cambridge Audio Evo 300 delivers 300Wpc, Hypex NCOREx power, StreamMagic Gen 4, HDMI eARC, MM phono, and big Evo ambition.
Marantz's Model M1 packs 100W, HEOS, HDMI eARC, and Dirac Live into a compact streaming amp for only $1,000.
Our favorite streaming amplifiers of 2025 for audiophiles include models from WiiM, Marantz, Ruark, Naim and Aavik.
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
With upgraded DirectDigital amplification, Bluesound's new POWERNODE is a 2 or 3-channel streaming amplifier with support for a center channel speaker and even a...
WiiM takes the popular form factor of its Ultra streamer and adds a 100 watt per channel power amp. Just add speakers.
Check out the Marantz M1 streaming amplifier, Quad's retro Integrated Amp, Ruark's stereo console and Schiit's sold out headphone amp.
Naim Uniti Nova PE delivers powerful 150W per channel streaming with class D amp tech, hi-res support, and multi-room features.
