Bang & Olufsen Unveils Beosound Premiere: A “Budget” Soundbar That’s Still More Luxe Than Your Living Room
Bang & Olufsen’s Beosound Premiere brings Dolby Atmos and Wide Stage tech to a smaller, $5800 “budget” soundbar—luxury sound for anyone who still has money left after rent.
Bang & Olufsen Premiere Soundbar Angle Lifestyle
Bang & Olufsen doesn’t do boring—or cheap. The Danish design house is back with another sculptural showpiece, the Beosound Premiere Soundbar, a sleeker, more refined follow-up to the Beosound Theatre that delivers much of the same engineering firepower at roughly half the price. Featuring Dolby Atmos and B&O’s new Wide Stage Technology for an expanded, more immersive sound field, the Premiere blends cinematic performance with gallery-worthy aesthetics. Just don’t get any ideas about “shrinking” your own soundbar design—some companies are a little touchy about that.
According to Kristian Teär, CEO of Bang & Olufsen, the new model “transcends the conventional soundbar; it’s a sculptural masterpiece and a bold expression of acoustic artistry. Sculpted from our signature aluminium, it embodies Bang & Olufsen’s century-long heritage of pioneering audio innovation in harmony with timeless design. This is not merely a product; it is a curated experience… transforming sound into an emotional encounter and the soundbar into a piece of art.”
beosound-premiere-black
The Design: Turning the Soundbar into Sculptural Art
The body of the Beosound Premiere is sculpted from pure aluminum, crafted through a close collaboration between Bang & Olufsen’s in-house design team and the precision engineers at Factory 5 in Struer, Denmark. The speaker drivers are intentionally showcased rather than hidden, reflecting B&O’s long-standing philosophy of designing from the inside out—and from the outside in.
The seamless aluminum chassis is pearl-blasted to achieve a matte satin finish, while the structure itself relies on precise alignment of extruded aluminum and cut end caps to maintain a slim, architectural profile. Despite its compact appearance, the frame accommodates ten speaker drivers with exacting precision.
At the center sits an up-firing tweeter—a subtle but distinctive design feature. Its surface includes 1,925 laser-cut perforations, a deliberate nod to the year Bang & Olufsen was founded and a quiet tribute to a century of Danish craftsmanship and engineering discipline.
beosound-premiere-black-top-angle
The Spatial Sound Twist: Wide Stage Technology Redefines Dolby Atmos
The Beosound Premiere is designed to deliver high-fidelity spatial sound that elevates home cinema and music immersion well beyond the typical soundbar experience. It uses ten custom-engineered drivers, including an up-firing center driver that adds vertical dimension and depth, allowing sound to unfold naturally around the listener. The result is precise dialogue, detailed imaging, and surprisingly powerful bass that fills the room without distortion.
At the core of this performance is Bang & Olufsen’s new Wide Stage Technology, a proprietary signal-processing system developed specifically for the Beosound Premiere. It creates the illusion of added external speakers by expanding the soundstage both horizontally and vertically—making the soundbar’s physical limits disappear. All ten drivers work in sync to generate a spacious, room-filling presentation that feels cinematic yet controlled.
The soundbar also adapts to its environment using onboard acoustic analysis to optimize playback for the room. For users building a larger system, Beolink Surround enables the integration of additional Bang & Olufsen speakers. With a fully integrated Dolby Atmos 7.1.4 decoder, the Beosound Premiere scales seamlessly into a full surround setup, offering an even deeper and more immersive listening experience.
LED Light Show: Dynamic Illumination Meets Bang & Olufsen Craftsmanship
No, the Beosound Premiere isn’t a party speaker, but it does feature a subtle, interactive design element that adds a touch of personality. Inside the soundbar, 90 responsive LEDs create a soft, ambient glow that shifts as you adjust settings or change modes. The illumination isn’t just decorative—it’s meant to establish a tactile connection between the listener and the product, reinforcing the idea that sound and design should respond to human interaction, not just fill a room.
Beocare
The Beosound Premiere is built for long-term ownership—something you’d expect given its nearly $6,000 price tag. Bang & Olufsen supports that investment with ongoing firmware updates tied to its Cradle to Cradle Certified Bronze sustainability designation, ensuring the product evolves over time. Buyers who register through Beocare also receive a five-year warranty, extending peace of mind and reinforcing B&O’s commitment to longevity over planned obsolescence.
There’s Just One More Thing…
beosound-premiere-haute-edition-front
 Beosound Premiere Haute Edition
To celebrate the launch of the Beosound Premiere, Bang & Olufsen’s Atelier team has created a special Haute Edition, limited to just 25 pieces worldwide. This version highlights the soundbar’s sculptural form with a precision-milled pattern that radiates outward from the central slot, wrapping the entire chassis in flowing grooves that mimic the movement of sound waves. The pattern catches light and invites touch, giving the soundbar a dynamic sense of motion and energy—turning an already striking design into something truly kinetic.
According to Bang & Olufsen, the pattern is achieved through a meticulous 17-hour milling process, where a spinning blade carves delicate grooves into raw aluminum, creating a visual echo of the soundbar’s expansive acoustic performance. The result is a seamless fusion of art and engineering—a soundbar that looks as intricate as it sounds.
beosound-premiere-haute-edition-top
Each unit in this limited series is individually engraved and numbered (1 of 25), accompanied by a limited-edition Beoremote One presented in a handcrafted wooden box, along with a certificate of authenticity—a final reminder that in the world of Bang & Olufsen, sound and sculpture have always been one and the same.
Bang & Olufsen Beosound Premiere Haute Edition Remote Control
Comparison
Pro Tip: The image below is not to scale – the Premiere (Left) is approximately 37 inches wide and the Theatre (Right)  is approximately 48 inches wide.
beosound-premiere-vs-theatre
Beosound Premiere (2025)Besound Theatre (2022)
Product TypeSoundbarSoundbar
Price$5,800$13,600
Cabinet TypeClosedClosed
Number of Channels 7 Channels
Left, Centre, Right front-firing
Left & Right side-firing (adjustable width)
Left & Right up-firing (adjustable width & height)
11 (physical and virtual)
Internal Speakers
Left, Centre, Right  Left and Right side-firing
Left and Right up-firing
Virtual Speakers
Left and Right Surround
Left and Right Front Height
Speaker Configuration4 x 4×3” Racetrack drivers
2 x 2” full range (front firing)
2 x 2” full range (side firing)
1 x 1.5” full range (up firing)
1 x 0.8” tweeter
2 x 6.5” woofer custom-made
1 x 5.25” midrange + 1 x 1” tweeter for custom-made coaxial centre speaker
2 x 3” midrange
4 x 2.5” full range
2 x 1” tweeter
Amplification4 x 70-watt amplifiers for woofers
1 x 50-watt amplifier for tweeter
5 x 50 watts amplifiers for left/right/up firing/side firing full ranges
2 x 100-watt amplifiers for bass outputs
10 x 60 watts amplifiers for center channel, left/right/upfiring/side firing outputs
Advanced Sound FeaturesIntegrated 7.1.4 Dolby Atmos decoding and custom-tuned post-processing with proprietary True Image up- / up-/downmixing algorithm.
Wide Stage technology
Advanced Bass Management System
Adaptive Bass Linearization (ABL)
Thermal protection
Integrated 7.1.4 Dolby Atmos decoding and custom-tuned post-processing with proprietary True Image up-/downmixing algorithm.
Thermal protection
Active Room CompensationYesYes – Roomsense
Automated speaker setup with external microphone: ·
Speaker level and distance
Speaker role ·
Speaker position
compensation from 30 – 10.000Hz ·
Room resonance compensation from 30 – 200H
Frequency Response32 Hz – 23,000 Hz28 Hz – 23,000 Hz
Maximum SPL (Sound Pressure Level) @ 1mFull Range: 102 dB
Bass: 86 dB
Full Range:  112 dB
Bass: 94 dB
Audio Support via HDMIDolby Digital TrueHD
Dolby Digital Plus 7.1 (including DD5.1)
Dolby Atmos, Dolby MAT
PCM 7.1 multichannel
MPEG-2 AAC
MPEG-4 HE-AAC
MPEG-2 AAC
MPEG-4 HE-AAC
Wired Connectivity1 x HDMI eARC with passthrough 4K 120FPS / 8K 60FPS / 40Gbit with CEC input
Analog audio in via USB-C (3.5 mm passive jack adaptor required. B&O partno. 6271374)
Ethernet switch with 3 x 1 Gbit ports. One port is assigned to the TV
3 x HDMI input with CEC input
Analog audio in via USB-C (3.5 mm passive jack adaptor required. B&O partno. 6271374 )
Ethernet switch with 4 x 1Gbit ports.
One port assigned for LG OLED TV connection for integrated control via Beoremote One
Wireless ConnectivityDual band WLAN 2.4 / 5GHz IEEE 802.11 b/g/a/n/ac/ax
Bluetooth 5.4 (BLE and EDR)
Bluetooth Codecs: Android (SBC), iOS: (SBC and AAC
Standard built-in, WiSA compliant.
Connect up to eight Beolab loudspeakers wirelessly in addition to the wired loudspeakers.
Bluetooth 5.1 (BLE and EDR)
Bluetooth Codecs: Android (SBC), iOS: (SBC and AAC)
Integrated Music ServicesBang & Olufsen Radio TIDAL Deezer (incl. Deezer HiFi)Bang & Olufsen Radio TIDAL Deezer (incl. Deezer HiFi)
Voice AssistantVia an external Google Assistant deviceVia an external Google Assistant device
Remote ControlIntegrated system control, including LG OLED TV
Beoremote One BT
Bang & Olufsen App for music streaming
Beoremote Halo for music streaming
Beoremote One BT
Streaming Services Via AppApple AirPlay
Bluetooth audio streaming
HomeMedia
Spotify Connect
TIDAL Connect
Deezer Connect
QPlay 2.0
Apple AirPlay
HomeMedia
Google Cast
Spotify Connect
TIDAL Connect
Deezer Connect
QPlay2.0
Beolink SurroundEnjoy a true surround sound experience by connecting additional speakers to your setup through wired or wireless connectionsEnjoy a true surround sound experience by connecting additional speakers to your setup through wired or wireless connections
Multiroom AudioApple AirPlay multiroom
Beolink Multiroom incl join of TV / HDMI input sound (not in sync) and analog line-in
Google Cast groups
External Speaker Outputs4 x Digital Power Link8 x Wireless Powerlink
8 x Powerlink
Power ConsumptionTypical: 80 WTypical: 120 W
Dimensions WHD (With Stand)93.2 x 17.2 x 1 cm
36.69 x 6.77 x 0.39 inches
122.2 x 19.7 x 15.7 cm
48.11 x 7.76 x 6.18 inches
Dimensions WHD (Without Stand)93.2 x 16 x 1 cm
36.69 x 6.3  x 0.39 inches
122.2 x 18.9 x 15.7 cm
48.11 x 7.44 x 6.18 inches
Weight 8.5 Kg / 18.75 lbs18 Kg / 39..70 lbs
In The BoxBeosound Premiere
HDMI cable
LAN cable
Mains cable
Soundbar universal stand (combined wall & table solution)
Soundbar wall plate
Installation guide
Important guide
Drilling template for wall mounting of soundbar
Torx screw driver
Screws for bracket/ stand
A tool for removing the speaker cover
USB-C to AUX Adapter
Polishing clot
Beosound Theatre including 55” or 65” or 77” Side Wings ·
HDMI cable ·
LAN cable ·
 Mains cable ·
Soundbar wall bracket (for installing as a “stand-alone” soundbar) ·
Soundbar table stand (for installing as a “stand-alone” soundbar) ·
Decoration covers
Installation guide ·
Microphone for automated RoomSense setup
beosound-premiere-aluminum-gold-tone-black
The Bottom Line
The Beosound Premiere may be the “affordable” option in Bang & Olufsen’s soundbar lineup, but let’s be honest—$5,800 is still rarefied air for most living rooms. Yet, it earns its price tag with precision engineering, a smaller and more flexible form factor, and the debut of Wide Stage Technology, B&O’s latest take on immersive spatial audio.
Compared to the flagship Beosound Theatre, the Premiere delivers most of the same firepower, just in a more compact design that better fits sub-40-inch installations—while the Theatre still pairs best with oversized Bang & Olufsen OLED TVs.
In this ultra-premium category, B&O faces competition from heavyweights like Steinway Lyngdorf’s Model S ($17,000) and Canvas Hi-Fi (starting at $5,000)—though the latter is currently tied up in a legal tangle with Bang & Olufsen. So yes, the Beosound Premiere costs a small fortune, but it’s still the most accessible way to own a piece of B&O’s century-long fusion of design, innovation, and spatial sound artistry—lawsuits and all.
Pricing & Availability
Beosound Premiere is available for pre-order now for $5,800 at Bang & Olufsen (£3,900/€4,900) in natural aluminum with an expected delivery date of December 3, 2025. New colors will rollout in the follow months thereafter, while interchangeable covers add to the price.
  • Color Options:  Natural Aluminium (Dec 2025), Gold Tone (Feb 2026), and Black Anthracite (Mar 2026). The soundbar comes with a versatile stand that enables both wall-mounting and tabletop placement.
  • Covers: Optional interchangeable fabric covers in grey melange ($325) as well as wooden covers in oak and dark oak ($1,650)
The Beosound Premiere Haute Edition is priced at $15,700 is available in selected Bang & Olufsen stores as long as supplies last.
If you prefer, the original Beosound Theatre Soundbar starts at $13,600 and is available online and through Bang & Olufsen stores.
FiiO Darkside Pro Linear Power Supply
Can a $159 linear power supply fix weak wall adapters and unlock better sound from your DAC or amp? FiiO thinks the DARKSIDE PRO...
Netflix Stranger Things Complete Series July 2026 Netflix Stranger Things Complete Series July 2026
Movies
Stranger Things Complete Series on Blu-ray and 4K UHD arrives this July in four collector box sets, but which edition should you buy?
Schiit Lyr 5 Forkbeard Headphone Amplifier and Preamp Silver Angle Schiit Lyr 5 Forkbeard Headphone Amplifier and Preamp Silver Angle
Schiit's Lyr 5 Headphone Amplifier at $799 combines tube and MOSFET gain with up to 6W output and Forkbeard control but skips balanced inputs...
Technics x Aimé Leon Dore SL-1200M7ALD Turntable Technics x Aimé Leon Dore SL-1200M7ALD Turntable
Technics x Aimé Leon Dore SL-1200M7ALD lands at $2100. Just hype or a smart play on vinyl’s billion dollar comeback?
Marshall Bromley 450 Party Speaker Lifestyle Marshall Bromley 450 Party Speaker Lifestyle
At $799, the Marshall Bromley 450 packs 360-degree sound, 40+ hour battery, and mic inputs in a 27 pound portable party speaker box.
Michi X430 Integrated Amplifier Michi X430 Integrated Amplifier
At $4,999, the Michi Prestige X430 integrated stereo amplifier features 210 watts per channel, HDMI ARC and a new ESS DAC.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Head Units
Pioneer brings Dolby Atmos to Apple CarPlay with its SPHERA in-dash receiver, opening immersive in-car audio to existing vehicles without factory systems.
TCL is putting Samsung, LG, and Hisense on notice with its featured packed TCL QM6K Series QD-MiniLED TVs (50 to 98 inches).
Your ticket to watching movies on a Kaleidescape 4K movie server just got a $1,000 cheaper, but are the trade-offs worth the discount?
At $12,000 for the combo, the new Marantz home theater separates include a 13.4-channel AV preamp and 12-channel amplifier.
Streaming movie and TV shows is getting very complicated, and you may not always get what you think you're paying for.
The Denon AVR-A1H and A10H AVRs have everything you could possibly need for a high-end home theater setup, but which top-of-the-line model is right...
Explore the Denon S-Series AVR 2025 lineup: Budget-friendly home theater receivers, features, and performance for every setup.
$1,500 Beo Grace earbuds from Bang & Olufsen push luxury, style, and audio performance but don’t forget the optional $400 leather pouch.
