UST Turf War Brewing: AWOL Lines Up Aetherion Pro and Max Against Hisense Ahead of CES 2026
AWOL debuts its Aetherion Pro and Max UST projectors at CES 2026, taking aim at Hisense’s L9Q with big-screen scale, PixelLock tech, and gaming-focused features.
AWOL Aetherion UST Projector Front
At CES 2026, AWOL Vision is planting a very deliberate flag in ultra-short-throw territory with the debut of its new Aetherion Series UST projectors, led by the Aetherion Pro and Aetherion Max. This is AWOL’s most ambitious play to date, built around what the company is positioning as the world’s sharpest 4K triple-laser UST platform.
That claim puts the Aetherion line squarely in the crosshairs of Hisense, whose L9Q currently sits as the undisputed top dog in its UST arsenal—now reinforced by the recently announced PX4‑PRO, unveiled just before Christmas. Whether AWOL can truly disrupt that hierarchy remains to be seen, but the opening salvo is clear: this is no longer a one-brand race at the top of the UST food chain.
PixelLock Optics: Faster, Bigger, Sharper
Built around proprietary PixelLock technology, a newly developed precision optical engine, and a stack of under-the-hood refinements, the Aetherion lineup is engineered to push performance where UST projectors usually start making excuses. The focus here is unapologetically practical: faster pixel response for gaming, large-scale image stability for big screens, and sharper on-screen detail that actually holds together at seating distances people really use.
AWOL is framing this as a projector platform equally comfortable handling cinematic content, high-motion sports, and latency-sensitive gaming—and on paper, at least, it reads like a direct attempt to reset expectations for what a flagship UST system should deliver in 2026.
awol-aetherion-ust-projector-home-theater
Maintaining 4K Precision at Large Screen Sizes
The Aetherion Max and Aetherion Pro are designed to maintain 4K UHD image fidelity (via pixel shifting) on screen sizes up to 200 inches, with PixelLock playing a central role in how that consistency is achieved. The system is intended to ensure that each pixel in a 4K image remains fused, synchronized, and accurately positioned on the screen, helping reduce color fringing, misalignment, and image softening as screen sizes increase.
Ultra short throw projectors are especially susceptible to pixel drift and color separation due to their extreme projection angles and complex optical paths. PixelLock was developed specifically to address those challenges.
It functions as an integrated optical, mechanical, and digital alignment system, compensating for lens tolerances, temperature-related expansion, minor geometric shifts inherent to UST projection, reflective path inconsistencies, and DLP sequencing artifacts. The aim is not marketing drama, but stability—keeping image alignment consistent as operating conditions change.
From Andy Zhao, Founder & CEO of AWOL Vision“Aetherion is the culmination of everything we’ve learned in pushing UST boundaries. It’s engineered to outperform on every axis—speed for gamers, scale for home-theater and sports enthusiasts, and sharpness that aims to set a new bar for 4K UST projection. Whether in the living room, man cave, or backyard, with Aetherion, you can see the difference down to the pixel.”
awol-aetherion-ust-projector-side
AWOL Aetherion (side) with USB 3.0 input
Core elements of PixelLock are focused on maintaining optical consistency rather than chasing marketing theatrics. Congruent pixel alignment is designed to minimize color fringing, even as image size increases into very large screen territory.
An industry-first diamond-like carbon (DLC)–coated lens system is used to improve light transmittance—rated at up to 99.97%—while reducing parasitic reflections by approximately 30%.
The Sapphire-Series optical lens assembly combines a high refractive index with a hardened surface to help control aberrations and improve long-term durability. AWOL also employs its thinnest terminal imaging lens to date, engineered to promote more uniform light distribution and reduced dispersion across the image.
Rounding out the optical package is a motorized dust-seal lens cover, intended to protect the lens assembly and preserve image clarity over extended use.
AWOL claims that the Aetherion projector line is designed to deliver one of the sharpest 4K UST images currently available, whether used straight out of the box or dialed in by home-theater enthusiasts. The company points to its advanced optical engine as the foundation for that performance, emphasizing image clarity with minimal setup requirements.
awol-aetherion-ust-projector-rear-left
This approach is reinforced by PixelLock technology and a supporting set of contrast and color refinements intended to improve consistency, detail resolution, and overall image stability across a wide range of viewing conditions, including:
  • EBL (Enhanced Black Level): 6,000:1 Native Contrast Ratio and 60,000:1 Enhanced Black Level support deep blacks.
  • EBL Shadow Refinement: This utilizes a 7-level IRIS system, shaping brightness and optimizing shadow detail scene-by-scene
  • Zero light-leakage Optical Design – The supports cleaner blacks and purer highlights
  • Bright Images – With 3,300 ISO Lumens (Aetherion Max) and 2,600 ISO lumens (Aetherion Pro) light output, these projectors can be used in a variety of room environments, including rooms with some ambient light.
  • Anti-RBE Technology – This reduces discarding rainbow artifacts caused by the use of DLP imaging chips. The rainbow effect is reduced by 99.99%.
  • HDR: The Atherion projector line is compatible with Dolby Vision and HDR10+ with Dynamic Tone Mapping (DTM),. IMAX Enhanced and  Filmmaker Mode are also supported.
Taken together, these innovations are intended to deliver accurate visuals with consistent color reproduction, smooth tonal transitions, and stable clarity across the entire image.
Audio with ThunderBeat
On the audio side, the Aetherion projectors can also operate as a built-in center-channel speaker when paired with a compatible home audio system, such as the AWOL Vision ThunderBeat, allowing dialogue and center-channel information to be routed directly through the projector.
awol-aetherion-ust-projector-rear-inputs
Gaming Performance: Low Latency, Large-Scale Immersion, No Hand-Waving
In addition to home theater video and audio duties, the Aetherion line is designed to support responsive performance for gaming and fast-moving content. AWOL positions the platform around reduced latency, higher refresh rates, and motion handling intended to keep pace with modern consoles and PCs, relying on a combination of updated hardware and motion control processing rather than aggressive post-processing tricks. Key gaming-related features include:
  • 1ms-class input latency at 240Hz – Intended to support faster controller response for competitive and high-frame-rate gaming scenarios.
  • Variable Refresh Rate (VRR) – Designed to reduce tearing and stutter during gameplay and high-motion sports content by synchronizing refresh rates.
  • Auto Low Latency Mode (ALLM) – Automatically switches the projector into its lowest-latency configuration when a compatible gaming source is detected.
  • Dolby Vision Gaming – Supported on both the Aetherion Max and Aetherion Pro, enabling HDR gaming with dynamic metadata for improved highlight control, shadow detail, and color consistency where supported.
awol-aetherion-ust-projector-angle-right
AWOL Aetherion
Hisense L9Q UST Projector at 2025 Showdown
Hisense L9Q
Comparison
Brand/ModelAWOL Aetherion Pro AWOL Aetherion MaxHisense L9Q
Product TypeUSTUSTUST
Price$3,499$4,499$5,999
SOC Chipset PlatformFlagship 4K UHD SoC MT9655 with 8GB RAM /128G EMMC memoryFlagship 4K UHD SoC MT9655 with 8GB RAM /128G EMMC memoryNot Indicated
Projection Screen Size80″-200”80″-200”80″-200″
Imaging Chip0.47-inch DMD with TI New Display Controller DLPC84450.47-inch DMD with TI New Display Controller DLPC84450.47″ DMD
Light SourceRGB Triple LaserRGB Triple LaserRGB Triple Laser
Laser Life25,000+ Hours25,000+ Hours25,000+ Hours
Resolution (via Pixel Shift)4K UHD4K UHD4K UHD
Brightness2600 ISO Lumens3300 ISO Lumens5000 ANSI Lumen
Contrast Ratio6000:16000:15000:1
Throw Ratio0.2:10.2:10.18:1
Refresh Rate4K @ 60Hz
1080p 120/240Hz
4K @ 60Hz
1080p 120/240Hz
60Hz
VRR (Variable Refresh Rate)YesYes
ALLM (Auto Low Latency Mode)YesYesYes
Input Lag1 ms1 msNot Indicated
Color Space110% REC.2020110% REC.2020110% BT.2020
Color ValidationNot IndicatedNot IndicatedPantone colors, Pantone SkinToneValidated
HDR SupportHDR10+
Dolby Vision
Dolby Vision Gaming
HDR10
HLG
HDR10+
Dolby Vision
Dolby Vision Gaming
HDR10
HLG
HDR10+
Dolby Vision
HDR10
HLG
IMAX EnhancedYesYesYes
Dynamic Tone MappingYesYesYes
Filmmaker ModeYesYesYes
3D-Viewing ReadyYes – Active Glasses RequiredYes – Active Glasses RequiredYes – Active Glasses Required
Smart TV PlatformGoogle TV (Google Certified)Google TV (Google Certified)Google TV (Google Certified)
App StoreGoogle Play StoreGoogle Play StoreGoogle Play Store
Major Streaming ServicesNetflix
Disney+
HBO MAX
Hulu
Prime Video
SHOWTIME
Pandora
Sling TV
YouTube
Netflix
Disney+
HBO MAX
Hulu
Prime Video
SHOWTIME
Pandora
Sling TV
YouTube
Netflix
Disney+
HBO MAX
Hulu
Prime Video
SHOWTIME
Pandora
Sling TV
YouTube
Voice AssistantGoogle AssistantGoogle AssistantGoogle Assistant
Works WithHey Google
Amazon Alexa
Google Home
Apple Homekit
Hey Google
Amazon Alexa
Google Home
Apple Homekit
Hey Google
Amazon Alexa
Screen Mirroring/CastingChromecast
Airplay2
Miracast
Chromecast
Airplay2
Miracast
Chromecast
Airplay2
Wireless ConnectivityWiFi 7
Bluetooth 5.4
WiFi 7
Bluetooth 5.4
Wifi 6e
Bluetooth
Wired Connectivity3 x HDMI 2.1
1 x Display Port
1 x USB 3.0
1 x USB 2.0
1 x Ethernet (LAN)
1 x Digital Optical Audio Output
1 x Analog Audio Input
1 x RS232
3 x HDMI 2.1
1 x Display Port
1 x USB 3.0
1 x USB 2.0
1 xEthernet (LAN):
1 x RS232
2x HDMI 2.1 (ALLM)
2x HDMI 2.0
HDMI ARC, CEC:
1 x (eARC on HDMI port 3)
:1 x USB 3.0
1 x USB 2.0
1 x USB 3.0 Type-C
1 x Ethernet (LAN)
1 x RF Antenna (Tumer – NTSC /ATSC /Clear QAM)
1 xDigital Optical Audio Output
1 x Analog Audio Output
Speaker System1 x full-range driver
1 x high-frequency driver
13 speakers
Audio Output Power25W – full-range driver
20W high-frequency driver
116W
Surround Sound Format SupportDolby TrueHD
Dolby Atmos
DTS:X
Dolby TrueHD
Dolby Atmos
DTS:X
Dolby Atmos
DTS:X
Sound CalibrationLocal Speaker By RemoteLocal Speaker By RemoteDevialet
Other FeaturesRGB Music LED
Atmosphere Lamp
Lens Iris
Motorized Lens Cover
RGB Music LED Atmosphere Lamp
AI Super Resolution
upscaling
Auto Screen Fit
Noise Reduction
Parental Controls
Closed Caption
Sleep Timer
Eye Safety
MEMC
Remote Finder
Control OptionsAI voice control (4 directional mics)AI voice control (4 directional mics)Wireless Remote
Control4
TRI
URC
Power Supply FeaturesPower Supply: AC 120V, 60Hz
Standby Consumption: <0.5W
Power Consumption: 180W
Power Consumption: 350W
Console Dimensions22.13 x 12.73 x 6.49 inches
562 x 323 x 139.5 mm
24.6” x 12.5” x 6.5” inches
624 x 317 x 166 mm
Console Weight8.75 kg/9.75 lbs8.75 kg/9.75 lbs12.9kg / 28.4 lbs
Package ContentsAetherion Pro
Remote Controller
User Manual
Cleaning Cloth
Power Cord
AV Input Cable
Type-C to Type-C Cable
USB-A to Micro
USB Cable for Upgrade
Battery
Aetherion Max
Remote Controller
User Manual
Cleaning Cloth
Power Cord
AV Input Cable
USB-A to Micro
Battery
L9Q UST
Voice remote with backlight
QSG in box (Manual online)
Power Cable
Cleaning Kit
awol-aetherion-ust-projector-top-angle
AWOL Aetherion
The Bottom Line
AWOL Vision is making a very intentional move upmarket with the Aetherion Pro and Max, and the timing is no accident. The company is clearly taking aim at the current benchmark in the category, the Hisense L9Q, which recently walked away with multiple wins at a major 2025 UST Projector Showdown and remains the reference point for brightness, color accuracy, and overall balance in the segment. PixelLock alignment, large-screen stability up to 200 inches, and a noticeably stronger gaming feature set—especially low input lag and Dolby Vision Gaming—give AWOL a credible counterpunch rather than a marketing swing.
The L9Q still holds advantages that matter to traditional home-theater buyers, including higher published brightness figures, Pantone color validation, and built-in TV tuner support, all of which reinforce its status as the safest “TV replacement” UST on the market today. Where the Aetherion line differentiates itself is scale, gaming performance, and flexibility.
For users targeting 132- to 200-inch screens, a properly paired UST projector and ALR screen remains far more affordable—and vastly more practical—than any television at that size. That makes the Aetherion Pro and Max a smart fit for enthusiasts who value cinematic scale and responsive gameplay over incremental gains in lumen numbers. CES 2026 will show whether AWOL has simply closed the gap—or forced Hisense to respond.
awol-aetherion-ust-projector-angle-left
Price & Availability
  • AWOL Aetherion Max – $4,499
  • AWOL Aetherion Pro – $3,499
Both projectors are expected to be available in March 2026. Early-bird pricing, limited-run perks, and Kickstarter-only bundles will go live in late January 2026. For more information, please visit www.awolvision.com
2026 ARCAM Radia AVA
ARCAM’s new Radia home theater lineup adds Dirac Live ART, higher channel counts, and new audio video amps and processors, priced from $4,500 to...
Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026 Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026
Theory Professional previews the SR-221.3 at ISE 2026, an extreme-output full-range loudspeaker. Pricing isn’t final, but it won’t be cheap.
JBL Synthesis SCL In-room Loudspeakers 2026 JBL Synthesis SCL In-room Loudspeakers 2026
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
Arcam RADIA Series Loudspeakers 2026 Models Arcam RADIA Series Loudspeakers 2026 Models
ARCAM debuts the Radia Series loudspeakers at ISE 2026, returning to speakers with a premium-priced lineup for music and home cinema.
Shanling ONIX Zenith XMT20 Streaming Music Bridge Shanling ONIX Zenith XMT20 Streaming Music Bridge
ONIX’s XMT20 streamer transport pairs a new Linux platform with Roon Ready, TIDAL and Qobuz Connect, plus high-end digital outputs and CD ripping support.
Roksan Caspian 4G Streaming Pre-Amplifier (Top) and Power Amplifier (Bottom) Roksan Caspian 4G Streaming Pre-Amplifier (Top) and Power Amplifier (Bottom)
Can Roksan’s $4,500 Caspian 4G Streaming Preamp and $3,750 Power Amp compete with NAD and Naim in this price class?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
LG came on strong at CES 2026 with a new suite of OLED TVs featuring stunning design and impressive video performance.
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
Podcasts
On this live stream podcast, the eCoustics team discusses the very best of what we saw and heard at CES 2026 in Las Vegas.
LG revives its iconic Wallpaper TV with the OLED evo W6 in 77- or 83-inch screen sizes that are only 9mm thick.
Cambridge Audio unveils its L/R Active Speaker Series at CES 2026—bold design, serious power, StreamMagic streaming, and a clear shot at KEF’s LS dominance.
CES 2026 reveals a turning point for movies: IMAX hits record highs, home screens get massive, and Netflix–Paramount reshape the future of theaters.
EarFun unveils Air Pro 4+, Clip 2, and Wave Pro X at CES 2026 with hybrid ANC, Bluetooth 6.0, lossless audio, AI translation, and...
