Austrian Audio Arranger: New Open-Back Dynamic Headphones Bridge Hi-X and Composer Series
Austrian Audio’s Arranger open-back headphones combine a new 44mm DLC driver, low 25Ω impedance, and foldable metal design. A serious mid-tier reference option?
Austrian Audio The Arranger Headphones Lifestyle
Austrian Audio continues to flesh out the middle of its headphone lineup with the Arranger, a new open-back, wired dynamic model designed to sit squarely between the affordable Hi-X series and the company’s flagship The Composer. As January winds down and CanJam’s global tour kicks off with its new Dubai show, the timing feels deliberate. The personal audio market is accelerating, and manufacturers are clearly paying attention to emerging regions where serious listening is no longer a niche hobby.
The Arranger enters one of the most competitive price bands in the category, going head-to-head with established players from Sennheiser, Grado Labs, Dan Clark Audio, Meze, and Audeze in the roughly $1,000 to $1,200 segment. At its core is a newly developed 44mm dynamic driver using a diamond-like carbon–coated diaphragm and Austrian Audio’s proprietary ring magnet system, aimed at delivering fast transients, low distortion, and controlled bass without drifting into artificial “hi-fi” excess.
And yes, as the industry heads to the Gulf to put these products in front of a new audience, one can only hope geopolitics doesn’t get in the way of progress. The last thing this hobby needs is another shooting war interrupting what should be a golden moment for high-end headphones in the Middle East.
austrian-audio-arranger-headphones-angle
Austrian Audio: The Vienna Engineering Team Behind AKG’s Modern Legacy
Austrian Audio exists because AKG Vienna was shut down, and a lot of very serious engineers weren’t ready to retire, relocate, or watch decades of know-how get scattered to the wind.
When Harman closed the historic AKG facilities in Vienna, a core group of former AKG staff did what engineers tend to do when management makes a somewhat controversial long-term decision: they built something better. In 2017, 22 veterans from AKG’s management, acoustics, electronics, mechanical design, RF/wireless, and software teams founded Austrian Audio with a simple goal, preserve the Vienna engineering tradition and prove that high-performance audio design does not have to be outsourced or diluted.
The result is a company that may be young on paper, but old where it actually matters. Between them, the team carries more than three centuries of cumulative engineering experience, rooted in a city that has been serious about music since Mozart was still annoying his landlords.
Austrian Audio designs and builds professional microphones, headphones, and supporting electronics in Vienna, including the OC818 and OC18 condenser microphones that use the company’s own handcrafted CKR12 ceramic capsules. This isn’t “heritage” as a marketing bullet point. It is a deliberate response to what was lost when AKG left Austria, and a reminder that real audio engineering still has a home in Vienna, even if the bean counters tried to move it somewhere cheaper.
Austrian Audio Arranger: A New Open-Back Reference
The Arranger is Austrian Audio’s latest open-back, over-ear dynamic headphone, positioned deliberately between the company’s Hi-X series and its flagship Composer. It is designed as a reference-oriented model that balances high-end engineering with practical usability, rather than chasing extreme specifications or fragile luxury.
At its core is a newly developed 44 mm high-excursion dynamic driver, designed in-house, using a diamond-like carbon (DLC) coated diaphragm and Austrian Audio’s proprietary ring magnet system. The stated design goals are fast transient response, low distortion, and controlled low-frequency extension, rather than exaggerated bass or artificially widened staging. On paper, the Arranger is specified to reach from 5 Hz to 30 kHz, with a sensitivity of 110 dB/V and a low 25-ohm impedance, making it easier to drive than many traditional open-back reference designs.
The Arranger uses an open-back acoustic structure intended to support a natural, spacious presentation without isolating the listener from their environment. This is a headphone built primarily for critical listening at home or in the studio, not for commuting or noise isolation. The design emphasis is on stability and durability, with a predominantly metal construction and a foldable frame that is still uncommon at this price level.
austrian-audio-arranger-pads
Comfort is addressed through soft suede leatherette ear pads and a moderate overall weight of 320 grams (without cable), which should place it in a manageable category for longer sessions, assuming the clamping force is sensibly tuned. The detachable cable uses a symmetrical 4-pin connector and supports unbalanced TRS as well as optional balanced Pentaconn and 5-pin XLR terminations.
Connectivity is straightforward: a 3 m detachable cable terminated in 3.5 mm TRS is included, along with a 6.3 mm adapter. Input power handling is rated at 155 mW, and total harmonic distortion is specified at under 0.1% at 1 kHz.
austrian-audio-arranger-headphones-front
The Bottom Line
The Austrian Audio Arranger is an open-back dynamic headphone designed to sit between entry-level “pro” models and true flagship designs. What makes it stand out on paper is the combination of a newly developed DLC-coated 44 mm driver, low 25-ohm impedance, and a foldable, predominantly metal chassis, features that are not common together in this price category.
These are likely to suit listeners who want a neutral, technically capable open-back headphone that is easy to drive, practical to own, and suitable for both home listening and studio use. If you are considering alternatives from Sennheiser, Meze, Dan Clark Audio, Audeze, or Grado in the $1,000–$1,200 range, the Arranger is positioned as a more utilitarian, engineering-first option rather than a luxury statement piece.
For more information: austrian.audio/product/the-arranger/
MSRP: $1,099
Fosi Audio S3 Music Streamer Front Angle Silver with Orange Knob
Can the $259 Fosi Audio S3 streamer DAC and preamp challenge WiiM and Bluesound with balanced outputs and HDMI eARC despite missing key features?
LAiV Crescendo Verse DAC headphone amplifier lifestyle with headphones and IEMs LAiV Crescendo Verse DAC headphone amplifier lifestyle with headphones and IEMs
2026 Samsung QN70H and QN80H Neo QLED 4K TVs 2026 Samsung QN70H and QN80H Neo QLED 4K TVs
Samsung M80H and M70H Mini-LED 4K TVs Angle Samsung M80H and M70H Mini-LED 4K TVs Angle
Bravia 3, II TV with BRAVIA Home Theater Bar 9 and 2 BRAVIA Theater Sub 9s. Bravia 3, II TV with BRAVIA Home Theater Bar 9 and 2 BRAVIA Theater Sub 9s.
Sony just launched two new soundbars, new rear speakers and three new subwoofers plus the ability to add a second powered sub to their...
Sony BRAVIA 3, Mark II Sony BRAVIA 3, Mark II
Sony is bringing its renowned XR video processor for TVs to a much more affordable price point.
Grado Classic Series launches with 7 updated headphones from $125. What’s new, what’s not, and who these are really for.
Can Axel Grell move the soundstage outside your head? The Grell OAE2 debuted at CanJam NYC 2026 and the listening experience was…unexpected.
Are wired headphones making a comeback? Grado’s Signature S550 debut at CanJam NYC 2026 suggests the cable never really went away.
Can the Audeze CRBN2 finally give electrostatic headphones real bass and soul? Listening impressions from CanJam NYC 2026.
Are HiFiMAN’s Arya WiFi and HE1000 WiFi planar headphones the future of wireless audiophile listening, or just very expensive experiments?
Can HiFiMAN’s HE1000 WiFi and Arya WiFi bring true high resolution audio to wireless planar open-back headphones? We’ll find out at CanJam NYC 2026.
Can the $3,500 Audio-Technica ATH-ADX7000 deliver electrostatic-like speed and space without an energizer? We listened at CanJam NYC 2026.
