AUER Acoustics Brings Versura Speakers to America: German Tankwood Cabinets Hit the US High-End Scene
AUER Acoustics brings its very expensive VERSURA speakers to the US, featuring tankwood cabinets, refined design, and high-end engineering aimed at serious audiophiles.
AUER VERSURA V2 Speakers Front Lifestyle
AUER Acoustics is ready to make its American push. The Bavaria-based loudspeaker maker is bringing its VERSURA line to the US, previewing the system at Musical Artisans of Chicago December 12-13, 2025 during an exclusive, appointment-only showcase for dealers and early adopters.
The series already turned heads at AXPONA 2025, but this marks the first proper stateside introduction, complete with those famously dense tankwood cabinets that Germany seems to reserve for things meant to survive a century or two.
AUER VERSURA Speakers
auer-versura-speakers-v4
AUER VERSURA V4
The VERSURA line leans hard into AUER Acoustics’ obsession with materials and engineering. Every model is built from tankwood, a hyper-dense, pressure-treated hardwood normally used in applications where failure simply isn’t an option. Here, it becomes the backbone of a loudspeaker cabinet with unusually low resonance, giving the drivers a rock-solid platform to do their work.
Add in state-of-the-art components, silver internal wiring, and carefully voiced crossover networks, and you get a family of speakers designed for maximum transparency without sacrificing musicality or elegance.
AUER’s four-model lineup covers everything from a compact standmount to a full-blown 4-way tower:
  • V4 — 4-way floorstander built for scale, dynamics, and flagship performance
  • V2 — 3-way floorstander aimed at rooms that can’t accommodate the V4 but still demand authority
  • V1 — 3-way standmount that brings the AUER design ethos into a more manageable footprint
  • V0 — 2-way bookshelf/standmount for listeners who want refinement and neutrality in a compact form
Here’s a closer look at what each model brings to the table.
Why AUER Uses Tankwood for VERSURA Speakers — And Why It Matters for Sound Quality
auer-versura-speaker-manufacture
AUER’s use of tankwood in the VERSURA line isn’t a gimmick — it’s the core of the design. Tankwood is a highly compressed natural wood that’s manufactured under extreme pressure, creating a material far denser and more inert than traditional MDF or plywood. AUER claims this density gives their cabinets an almost ideal mix of internal damping and rigidity, which helps suppress unwanted vibrations and lets the drivers operate with far greater precision. In practice, that means faster transients, clearer midrange detail and bass that stops and starts exactly when it should.
This isn’t the first time tankwood — often referred to in engineering circles as Panzerholz — has been used in high-performance audio. Its combination of stiffness and natural damping has made it popular for turntable plinths, anti-vibration platforms and even some boutique speaker designs. The material’s ability to kill resonance without sounding overdamped is the reason hobbyists and manufacturers treat it like a secret weapon.
By building the entire VERSURA enclosure from tankwood, AUER is essentially giving its drivers a non-resonant, ultra-stable platform. The cabinet isn’t contributing its own voice; it’s getting out of the way. That’s the engineering logic behind AUER’s promise of improved clarity, better-controlled bass and more explosive dynamic behavior — the kind of performance ceiling you can only reach when the box holding the drivers stops behaving like a box.
Closed-Box Design: Tighter Control, Cleaner Bass
auer-versura-v2
AUER VERSURA V2
In addition to tankwood, AUER ACOUSTICS favors the closed box cabinets, which have some distinct advantages. Unlike the resonators used in vented loudspeakers, sealed enclosures will enable the VERSURA to retain more bass precision and control.
Deep Bass, Smart Engineering, and Design That Actually Fits Your Home
AUER Acoustics clearly put serious effort into low-frequency performance across the entire VERSURA lineup. The flagship V4 digs all the way down to 20 Hz — true full-range territory — while the compact V0 still reaches an impressive 35 Hz, a range many standmounts and even some floorstanders can’t touch. That low-end reach comes from a combination of tightly controlled drivers, the dense tankwood cabinets, and power handling up to 200 watts, giving each model enough headroom to perform confidently in rooms big and small.
auer-versura-woofer
And while the engineering takes center stage, AUER doesn’t ignore the fact that these speakers need to live somewhere other than a lab. The VERSURA line is intentionally understated, with clean lines and elegant proportions designed to blend into real homes rather than dominate them. Buyers can choose from 10 standard finishes — matte, glossy, or natural wood — and AUER even offers custom colors and finishes for those who want something more personal.
auer-versura-speakers-v1-v0
AUER VERSURA V1 (left) & V0 (right)
Comparison
Versura V4Versura V2Versura V1Versura V0
Speaker TypeFloorstanding Floorstanding StandmountBookshelf / Standmount
Price (Pair)€44,038 €39,524€19,949€13,615
Working principle4-way closed box3-way closed box3-way closed box2-way closed box
Sensitivity (dB @ 2.83V/1m)90 dB89 dB88 dB88 dB
Max. power rating200 W200 W200 W200 W
Recommended minimum amp power20 W20 W20 W20 W
Nominal impedance (Ohm)8888
Impedance minimum (Ohm)6666
Lower cut-off frequency (Hz @ +/- 3 dB)20 Hz30 Hz33 Hz35 Hz
Upper cut-off frequency (kHz @ +/- 3 dB)40 kHz40 kHz40 kHz40 kHz
Tweeter (Beryllium)1 1/3″ (34 mm)1 1/3″ (34 mm)1 1/3″ (34 mm)1 1/3″ (34 mm)
Midrange speaker5″ (12 cm)5″ (12 cm)5″ (12 cm)
Bass-midrange driver7″ (18 cm)2 x 7″ (18 cm)7″ (18 cm)7″ (18 cm)
Woofer12″ (32 cm)
ConnectionsBi-Wiring optionalBi-Wiring optionalBi-Wiring optionalBi-Wiring optional
Weight 226 lbs.
102.6 kg
173 lbs.
78.4 kg
70 lbs
31.7 kg
49.2 lbs
22.3 kg
Weight with standN/AN/A103.6 lbs
47 kg
84.4 lbs
38.3 kg
Dimensions (HWD)46 8/9″ x 8 2/3″ x 18 1/9″
119.1 x 22 x 46 cm
46 8/9″ x 8 2/3″ x 13 3/4″
119.1 x 22 x 35 cm
21.5″ x 8 2/3″ x 13 3/4″
54.7 x 22 x 35 cm
16.5″ x 8.5″ x 13 3/4″
41.7 x 22 x 35 cm
StandN/AN/AOptionalOptional
ColorsDeep Black
Slate Grey Neo
Chalk
Lugano Blue
Indian Red
Pure Orange
Shade Green
Metallic
Traffic White
Walnut
Oak Wood
Deep Black
Slate Grey Neo
Chalk
Lugano Blue
Indian Red
Pure Orange
Shade Green
Metallic
Traffic White
Walnut
Oak Wood
Deep Black
Slate Grey Neo
Chalk
Lugano Blue
Indian Red
Pure Orange
Shade Green
Metallic
Traffic White
Walnut
Oak Wood
Deep Black
Slate Grey Neo
Chalk
Lugano Blue
Indian Red
Pure Orange
Shade Green
Metallic
Traffic White
Walnut
Oak Wood
auer-versura-v2-speakers-pair
AUER VERSURA V2
The Bottom Line
AUER Acoustics is the latest European brand to test America’s appetite for expensive, boutique loudspeakers, and on paper the VERSURA line checks every “serious hi-fi” box — novel cabinet materials, meticulous engineering, elegant craftsmanship and the kind of finish options that make interior designers break into applause. The look straddles contemporary and traditional in a way that feels intentional rather than trend-chasing.
But the truth is simple: until we actually hear them, we can’t tell you where they land against heavy hitters like Focal, Sonus Faber, KEF and the rest of the established high-end field. AUER is making big performance claims and charging accordingly. If the VERSURA line delivers what the engineering suggests, the price might make sense. If not, it’s another beautiful European import hoping its tankwood mystique justifies the bill — and that’s a very big bill.
Price & Availability
According to a price sheet provided by AUER, here is how their VERURA line shakes out in Euros (US pricing should be forthcoming). Prices are listed per pair, but may vary depending on finish and add-ons (such as stands, capacitor, bi-amp/bi-wire cable, and diamant tweeter).
  • V4 Floorstanding 4-Way Speaker: €44,038
  • V2 Floorstanding 3-Way Speaker: €39,524
  • V1 Standmount 3-Way Speaker: €19,949
  • V0 Bookshelf/Standmount 2-Way Speaker: €13,615
Musical Artisans of Chicago appears to be their lead US dealer/distributor.
For more information: auer-acoustics.com
Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front
For about a 10% price premium, customers in the EU and APAC can purchase the Bowers & Wilkins 707 Prestige Edition bookshelf speaker in...
2026 ARCAM Radia AVA 2026 ARCAM Radia AVA
ARCAM’s new Radia home theater lineup adds Dirac Live ART, higher channel counts, and new audio video amps and processors, priced from $4,500 to...
Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026 Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026
Theory Professional previews the SR-221.3 at ISE 2026, an extreme-output full-range loudspeaker. Pricing isn’t final, but it won’t be cheap.
JBL Synthesis SCL In-room Loudspeakers 2026 JBL Synthesis SCL In-room Loudspeakers 2026
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
Arcam RADIA Series Loudspeakers 2026 Models Arcam RADIA Series Loudspeakers 2026 Models
ARCAM debuts the Radia Series loudspeakers at ISE 2026, returning to speakers with a premium-priced lineup for music and home cinema.
Shanling ONIX Zenith XMT20 Streaming Music Bridge Shanling ONIX Zenith XMT20 Streaming Music Bridge
ONIX’s XMT20 streamer transport pairs a new Linux platform with Roon Ready, TIDAL and Qobuz Connect, plus high-end digital outputs and CD ripping support.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our top floorstanding loudspeakers for 2025 come from Magnepan, Q Acoustics, KLH, Audiovector, and ATC—five brands delivering standout engineering, scale, and true high-end performance.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Focal quietly drops the $699–$2,299 Omada speakers between Vestia and Theva, packing TAM tweeters and Slatefiber cones in a non-typical rollout but with good...
JBL unveils its new flagship 4369 Studio Monitors at the Tokyo International Audio Show for audiophiles and studios alike. Available Q1 2026, price TBA.
Audiovector Trapeze Ri speakers offer warm, bass-forward sound, precise top end, and natural midrange. Rock-solid Danish design meets high-end performance, requiring a powerful amp...
Polk Audio have been quite aggressive with their Reserve and Legend Series speakers, and news has dropped on a brand new lineup called the...
Perlisten A-Series loudspeakers are designed for stereo or home theater. Choose between two towers, a stand-mount and on-wall surround.
