Apple iPhone 17 Lineup Explained: iPhone 17, Air, Pro, and Pro Max — Which New iPhone Is Best for You in 2025?
Apple surprises with new ultra-thin iPhone Air to accompany iPhone 17, 17 Pro, and 17 Pro Max models for 2025.
2025 Apple iPhone 17 Air Pro Max
Apple has unveiled its 2025 iPhone lineup, introducing four new models: the iPhone 17, the all-new ultra-thin iPhone 17 Air, the iPhone 17 Pro, and the iPhone 17 Pro Max. Prices begin at $799 for the iPhone 17 and range up to $1,199 for the Pro Max, each with 256GB of storage, with a $200 premium to upgrade to 512GB. Alongside the new smartphones, Apple also launched the AirPods Pro 3, designed with advanced features—like live translation, fitness tracking, and enhanced ANC—that integrate most seamlessly with the iPhone 17 series.
iPhone 17 Air Debuts as Apple’s Biggest Redesign Since iPhone X
apple-iphone-air-hero
iphone-air-colors-rear
iPhone Air
All four iPhone 17 models are faster than the iPhone 16 series, with improved front and rear cameras and longer battery life across the board. But the real headline is the brand-new iPhone 17 Air. Sitting in the middle of the lineup with a 6.5-inch display and a $999 price tag, the Air prioritizes thinness and lightness over extra hardware. It borrows some “Pro” DNA, including the powerful new A19 Pro chipset, but trims back on camera features with a single rear lens—meaning no dedicated macro shots or ultra-wide (0.5x) capabilities.
Even so, the iPhone 17 Air represents Apple’s boldest design shift since the iPhone X, signaling a new direction for the lineup.
iPhone 17 Pro & Pro Max Deliver Record Speed and Battery Life
iphone-17-pro-colors
iPhone 17 Pro (and 17 Pro Max) colors
The iPhone 17 Pro and Pro Max are once again Apple’s performance flagships, combining the fastest processors with the longest battery life ever in an iPhone. The Pro delivers up to 33 hours of runtime, while the 6.9-inch Pro Max pushes that to 39 hours thanks to the extra room for a larger battery. Aside from size and endurance, the two models are identical—your choice really comes down to whether you want something easier to pocket or the biggest possible screen.
One of the most interesting upgrades across the entire 2025 lineup is a new square imaging sensor that lets you shoot landscape even while holding the phone in portrait mode. It’s not something Apple can easily backport to older devices without cutting resolution, so this one looks exclusive to the iPhone 17 series. All models also gain the ability to record with the front and rear cameras at the same time, opening up new options for vloggers and creators.
Apple also refreshed its color lineup. The Pro and Pro Max get two exclusive finishes—deep blue and cosmic orange—on top of the standard silver. The iPhone 17 comes in lighter shades Apple is calling sage (green), mist blue, and lavender. The new iPhone 17 Air stands apart with its own palette: space black, cloud white, light gold, and sky blue.
iphone-17-colors
iPhone 17
apple-iphone-air-colors-flat
iPhone Air
So which iPhone should you buy in 2025? With four models across three screen sizes, four storage tiers, and a dozen color choices, the decision is trickier than ever. That’s where our comparison chart below comes in—it’ll help you cut through the noise and pick the right one. Or checkout Apple’s Can’t Decide Guide on YouTube.
Comparison
ModeliPhone 17iPhone AiriPhone 17 ProiPhone 17 Pro Max
MSRP$799$999$1,099$1,199
Display6.3”6.5″6.3″6.9″
Storage256GB, 512GB256GB, 512GB, 1TB256GB, 512GB, 1TB256GB, 512GB, 1TB, 2TB
DesignAluminum frameTitanium, thinnest ever (5.6mm)Aluminum unibodyAluminum unibody with larger battery
Thickness7.95 mm5.64 mm8.75 mm8.75 mm
ChipsetA19A19 ProA19 ProA19 Pro
GPU5-core5-core6-core6-core
Front Camera18MP Center Stage18MP Center Stage18MP Center Stage18MP Center Stage
Rear Camera(s)48MP Dual Fusion camera system (Main, Ultra Wide)48MP Fusion camera system (Main)48MP Pro Fusion (Main, Ultra Wide, Telephoto)48MP Pro Fusion (Main, Ultra Wide, Telephoto)
Optical Zoom.5x, 1x, 2x1x, 2x.5x, 1x, 2x, 4x, 8x.5x, 1x, 2x, 4x, 8x
Macro PhotographyYesYesYes
Spatial photosYesYesYes
Optical image stabilization1st gen1st gen2nd gen2nd gen
Cinematic modeYesYesYes
ProRAW / ProRes RAWYesYes
Dolby Vision4K at 60 fps4K at 60 fps4K at 120 fps4K at 120 fps
Battery Life30 hours27 hours33 hours39 hours
USB-CUSB 2.0USB 2.0USB 3.0USB 3.0
LiDAR ScannerYesYes
Vapor CoolingYesYes
Durability (front)Ceramic Shield 2Ceramic Shield 2Ceramic Shield 2Ceramic Shield 2
Durability (back)Ceramic ShieldCeramic ShieldCeramic Shield
Rated IP68YesYesYesYes
Bluetooth 6YesYesYesYes
Wi-Fi 7YesYesYesYes
Weight6.24 ounces (177 grams)5.82 ounces (165 grams) 7.27 ounces (206 grams) 8.22 ounces (233 grams)
Main ColorsLavender, Sage, Mist Blue, White, BlackSpace Black, Cloud White, Light Gold, Sky BlueDeep Blue, Cosmic Orange, SilverDeep Blue, Cosmic Orange, Silver
The Bottom Line
Apple’s 2025 iPhone lineup is all about refinement and one bold new move. Every model gets faster performance, longer battery life, and upgraded cameras, but the differences come down to priorities. The iPhone 17 keeps things simple and affordable, while the new iPhone 17 Air makes thinness and design the story—though at the cost of camera flexibility.
The Pro and Pro Max remain the power players with the best displays, battery life, and performance. Add in a new square imaging sensor that changes how you shoot video, dual-camera recording, and a fresh set of colors, and this year’s lineup feels like the biggest shake-up since the iPhone X.
Price & Availability
All new 2025 iPhones can be pre-ordered beginning at 5am PDT on Friday, September 12th with availability beginning Friday, September 19, 2025 in more than 63 countries, followed by another 22 countries a week later.
Denon Home 200, 400 and 600 Wireless Speakers White Lifestyle
Denon brings Dolby Atmos music support to its HEOS whole home music platform with this trio of wireless speakers.
Andrew Jones Introduces New Speaker and Company Jones and Cerreta Andrew Jones Introduces New Speaker and Company Jones and Cerreta
Andrew Jones to debut Jones and Cerreta at AXPONA 2026 with MoFi Distribution but what is this field coil concentric floorstander and how much...
Børresen Center3 Front Angle Lifestyle Børresen Center3 Front Angle Lifestyle
Center Speakers
Børresen’s $7,000 Center3 brings flagship tech to home theater but is it the missing piece for X Series owners or still overkill?
FiiO Darkside Pro Linear Power Supply FiiO Darkside Pro Linear Power Supply
Can a $159 linear power supply fix weak wall adapters and unlock better sound from your DAC or amp? FiiO thinks the DARKSIDE PRO...
Netflix Stranger Things Complete Series July 2026 Netflix Stranger Things Complete Series July 2026
Movies
Stranger Things Complete Series on Blu-ray and 4K UHD arrives this July in four collector box sets, but which edition should you buy?
Schiit Lyr 5 Forkbeard Headphone Amplifier and Preamp Silver Angle Schiit Lyr 5 Forkbeard Headphone Amplifier and Preamp Silver Angle
Schiit's Lyr 5 Headphone Amplifier at $799 combines tube and MOSFET gain with up to 6W output and Forkbeard control but skips balanced inputs...
At $549, Apple’s AirPods Max 2 wireless headphones improve noise cancellation and spatial audio with new H2 chip, while adding Live Translation and Conversational...
European customers of the streaming service are reporting that movies and shows that used to be available in Dolby Vision dynamic HDR are now...
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
I stream, you stream, here are our choices for the best video streaming devices of 2025.
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Cyber Monday 2025 delivers huge savings on Audioengine, Denon, SVS, Samsung and more. The best home audio and TV discounts of the year are...
At $3,499, the Hisense PX3-PRO might be one of the best new UST projectors of 2024.
