Aequo Audio Launches ADAMANTIS and ENSIUM Speakers with Revolutionary Nanotech Enclosures at High End Munich 2025
Discover Aequo Audio’s Adamantis and Ensium high-end loudspeakers with nanotech enclosures and analog ARPEC room correction.
Aequo Audio Ensium and Adamantis Loudspeakers White
Aequo Audio isn’t playing by the old rules. The Dutch manufacturer is bringing two new loudspeaker models to High End Munich 2025—ADAMANTIS and ENSIUM—and both arrive wrapped in a technology that’s about as subtle as a lightsaber in a library. Built using a proprietary nanotech material that converts cabinet vibration into heat, Aequo’s new enclosure design targets resonances across the entire audible and ultrasonic range—from 1 Hz to 100,000 Hz. That’s a full-spectrum assault on distortion.
Both the ADAMANTIS (a passive 3-way) and the ENSIUM (a 500W bass-assisted 3-way with full analog room and placement correction) share Aequo’s new nanotech enclosure, but it’s the shape that hits first—hard. These aren’t polite boxes designed to disappear into your living room. Think: New Order Stormtroopers on a strict Jenny Craig plan crossed with the Imperial Royal Guard, standing at attention in the Emperor’s throne room. Finished in a deep, almost menacing gloss that practically hisses “wear gloves or suffer,” they don’t try to hide. They loom.
ensium-adamantis-loudspeakers-with-text
Aequo’s design is guided by a “form follows function” philosophy, and the Nano material’s castability opens the door to complex 3D geometry that most speaker makers wouldn’t even attempt. Each speaker weighs in north of 100 kg (220 lbs), yet manages to pack an impressively large internal volume within a relatively compact footprint. Heavy? Absolutely. But every gram earns its keep.
We begin with a perfect, time-aligned acoustic shape and refine from there without compromise,” says Ivo Sparidaens, Aequo’s founder and chief technologist. That refinement includes Aequo’s latest driver and crossover designs, with results that claim ultra-low baffle diffraction and exceptional linearity in phase, distortion, and dynamics. The goal? A speaker that vanishes sonically—even if it looks like it could interrogate a rebel spy.
Why Nanotech?
Aequo Audio’s use of nanotechnology isn’t just marketing gloss—it’s the foundation of a radical shift in loudspeaker design. At the heart of their new enclosure is a proprietary Nano material engineered to convert mechanical vibration directly into heat.
Unlike traditional cabinet materials—wood composites, aluminum, or even carbon fiber—this nanotech compound has a near-zero sonic imprint. That means it doesn’t ring, resonate, or color the sound, no matter what frequency is pushed through it.
Measured performance confirms it: the material delivers 10 times more damping than aluminum, effectively silencing internal resonances from 1 Hz all the way to 100,000 Hz—well beyond the limits of human hearing and most standard audio measurements. This isn’t about minor improvements in cabinet rigidity; it’s a full-spectrum blackout of resonance.
The result? Drivers are allowed to perform in near-perfect conditions, free from the smear and time-domain distortion that typical enclosures introduce. That clarity translates into something more than just technical accuracy—it enhances the loudspeaker’s ability to communicate emotion and realism. It’s not just about hearing more. It’s about feeling more. And definitely spending more.
ensium-adamantis-deep-carmine-red
ADAMANTIS and ENSIUM: A Love Story
The Adamantis is Aequo’s take on the classic passive 3-way floorstander—but don’t mistake it for old-school. This isn’t a throwback. It’s a modernized, precision-built tank of a speaker that leans into everything that makes passive designs great, and then systematically eliminates the weak spots. It’s unshakable, brutally refined, and hits way above its weight.
Call it a high-end rock with a PhD. You want purity, presence, and performance without the gimmicks? Adamantis delivers it—and then some. It doesn’t just punch above its class; it rewrites the class system.
The Ensium, on the other hand, is the one that steps out of line—and gets promoted for it. It’s more sensitive than its sibling (90dB at 8 ohms), but don’t let that stat fool you.
This is the bold one. The one with the secret weapon: ARPEC™—that’s Analogue Room size and Placement Extension Control for those keeping score. No DSP, no software updates, no digital meddling. Just pure analog voodoo that lets you place the speaker almost anywhere and still get pinpoint imaging and full-range slam.
ARPEC doesn’t care if your room’s perfect—it makes the speaker fit the space, not the other way around. It’s the kind of tech that makes you wonder why no one else figured this out before. Maybe they didn’t have the guts.
ARPEC might sound like some new kind of Imperial Walker but it’s actually something unique to their range of loudspeakers. How does it work exactly?
ensium-adamantis-loudspeaker-black
ARPEC is Aequo’s fully analog solution to one of the biggest problems in high-end audio: bass that misbehaves depending on your room or where you place your speakers. Instead of using digital signal processing (DSP), ARPEC works with the incoming full-range signal and adds extra current—real power—only to the bass region. Think of it like giving your low end a powerful analog boost, while keeping the signal path 100% pure and untouched by digital filters.
The result? You get the tight, deep, and fast bass you’d expect from a massive sealed-box speaker with giant woofers—but without needing a perfectly treated room or giant footprint.
Tuning it is simple. Each speaker has two smooth-turning dials on the back:
  • One adjusts for room size, from XXS to XXL
  • The other sets for placement, from tight in a corner to fully free-standing
No menus, no remotes, no software—just turn the dials and dial in perfect bass. ARPEC keeps time and phase completely intact, so everything sounds natural and locked-in, even in tricky rooms. It’s high-end performance with zero hassle.
Comparison
ADAMANTISENSIUM
MSRP (per pair)$37,900$44,900
SIZE (h x d x w)116 x 52 x 42 cm116 x 52 x 42 cm
POWER500W on-board amplifier and
ARPEC™ system
WEIGHT (per speaker)100 kg100 kg
SENSITIVITY88dB at 4-ohms nominal90dB at 8-ohms nominal
FREQUENCY RANGE (-3 dB in-room response)20 Hz – 45 kHz16 Hz – 45 kHz
NOMINAL IMPEDANCE4 ohms8 ohms
MINIMUM IMPEDANCE3 ohms6 ohms
DYNAMIC OUTPUTFull range linearity maintained stereo output SPL >116 dB @500WMax full range linear SPL depending ARPEC settings typically >116 dB
ensium-side-top-close-up-white
The System
The ENSIUM will be shown in both gloss white and red finishes, and yes, they look every bit as commanding as they sound. Whether you prefer the pristine elegance of white or the menacing glow of red—think royal guard on full alert—these loudspeakers are visual statements as much as acoustic ones. And they carry the firepower to back it up: $44,900 USD for a pair.
But Aequo isn’t coming to Munich alone—they’re rolling deep with a full-stack reference system that tips the scales at $330,320 USD. Highlights include the VPI Avenger Direct turntable ($40,000), a beast of New Jersey analog engineering finished in high-gloss black to match the imperial theme; the Taiko Audio Extreme Server ($30,000); Playback Designs MPT-8 transport and MPD-8 DAC ($46,000 combined); and WestminsterLab electronics handling preamp and mono block duties.
All of it wired up with $100,000 worth of AudioQuest cabling and Aequo’s own Ferroguard power cables for the speakers.
Joining Aequo for the ride is industry veteran Walter Schofield of Nexus Audio, who’ll be spinning records and giving live walkthroughs of the system throughout the show.
If you’re looking for true next-gen loudspeaker design—with the presence of a Star Destroyer and the precision to match—Atrium 4.2, Room F.204 is where your ears need to be.
For more information: aequoaudio.com
2 Comments
2 Comments
  1. Anton Epstein
    May 7, 2025 at 6:23 pm
    Like if Estelon and the Royal Guard conceived a child and it had poor posture.
    The prices on these speakers.
    • Ian White
      May 7, 2025 at 6:29 pm
      Anton,
      I thought Epstein didn’t have any kids. The $$$$ trend can’t last. There will always be a small percentage of the population who can afford these speakers and that’s great. Let these brands create something great that 100 people buy. At $40,000/pair — that’s enough to sustain a brand for a year. Maybe. Also understand that they have more affordable speakers that keep the lights on. I suspect that these probably sound as they look. Nuff said.
      IW
QUAD ESL 2912X Electrostatic Speaker System at AXPONA 2026
Quad ESL 2912X electrostatic speakers at AXPONA 2026 from MoFi Distribution prove big panels can deliver clarity, scale, and real emotional connection without excess.
Amphion Stereo System AXPONA 2026 Amphion Stereo System AXPONA 2026
Amphion Argon7LX arrives at AXPONA 2026 with Finnish precision, clean power, and zero drama. No hype, just sound that quietly outperforms.
ATC EL50 Anniversary Active Speakers at AXPONA 2026 ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Geshelli TORC DAC at AXPONA 2026 Geshelli TORC DAC at AXPONA 2026
Geshelli's TORC DAC makes its case at AXPONA 2026 with a modular design, swappable DAC boards, and a real upgrade path that will not...
2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood 2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood
Dynaudio Legend bookshelf speakers hit AXPONA 2026 with Esotar 3 tweeter, real bass, and Danish build that proves the internet got this one wrong.
2026 Grado Phono Cartridges 2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Paradigm Premier Series v2 arrives at AXPONA 2026 with six new models, upgraded driver technology, and pricing aimed at affordable high performance.
Loudspeakers
Fyne Audio is now offering bold custom colors to UK buyers. Have Scottish speakers decided beige is no longer brave enough?
Is ATC’s EL50 Anniversary the most compelling fully active 3-way tower under £50K for serious listeners seeking studio grade precision at home?
Børresen M8 Gold Signature is a $1,150,000 loudspeaker built in Denmark. Engineering breakthrough or high-end excess for the ultra wealthy?
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Arendal Sound unveils the 1610 loudspeaker series bringing flagship inspired design and three way performance to a more accessible price point without cutting corners.
ARCAM debuts the Radia Series loudspeakers at ISE 2026, returning to speakers with a premium-priced lineup for music and home cinema.
