Hi! I just purchased my first HT system (Samsung HT-DB600) and I had a question about the video inputs/outputs on its receiver. On this particular unit, it has component video coming in and component video going out. I would like to use component video with my Xbox and with the DVD player built into the receiver, but my TV has only 1 set of component video plugs. *So here's the question!* Can I hook my Xbox into my receiver and hook my receiver up to my TV and switch between Xbox video signal and DVD player video signal? Thanks in advance for any advice/comments given.
Derek
Component Video IN. That's a new one. I say try it. It should work.
Yes, you can use the reciever to switch comp. video between your Xbox and DVD.
