Silver Member Username: ImauserPost Number: 150 Registered: Oct-07 | I have Pansat converted receiver using LZMA_209. I did Advanced scan one by one. AAG, ARY, QTV and Music all are on 12661Mhz. But I don't get all these 4 channels at the same time. When I scan for QTV, I loose ARY. When I scan for ARY, I loose QTV. Can anybody guide me how do I get all 4 channels at the same time... THanks |
Gold Member Username: PlymouthCanada Post Number: 8207 Registered: Jan-08 | FM read this thread: https://www.ecoustics.com/electronics/forum/home-video/557419.html |
Silver Member Username: ImauserPost Number: 152 Registered: Oct-07 | It seems noone is trying to help me out |
Silver Member Username: SaadiaaPost Number: 118 Registered: Nov-07 | I was having the same problem u know what u do scan one channel at a time add to a fav list then scan then add .. It worked like that for me ., what is the freq for agg tv.. And ary digital ..can u tell the aud and vid values ... |
Silver Member Username: ImauserPost Number: 153 Registered: Oct-07 | Aag: v4898, a4899, p4898 Ary: v6434, a6435, p6434 |
Silver Member Username: ImauserPost Number: 154 Registered: Oct-07 | Plymouth! thanks for helping me out. I read the whole thread but I didn't get the solution. Would it be nice if you give me the solution without reading the whole thread. Thanks |
Silver Member Username: SaadiaaPost Number: 119 Registered: Nov-07 | Fm to get all channels scan them one by one add one by one to a fav list ..that way u will get all channels altogether .. I just did it that way ... |
Silver Member Username: ImauserPost Number: 155 Registered: Oct-07 | Thanks Saadia |
Silver Member Username: ZunnaPost Number: 297 Registered: Jun-06 | i have done the same thing and i'm not getting all of them .. sadia after putting the pid and everything do i scan the channel? |
Silver Member Username: ZunnaPost Number: 299 Registered: Jun-06 | wat should i do |
