New member Username: Macra12Post Number: 2 Registered: Mar-09 | I would like to know, is a dish network lnb linear, and circular? or only circular? |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4152 Registered: Oct-06 | D#N uses all Circular LNBFs on all satellites Only Sat 121W is linear No longer offered to new customers And slowly getting phased out |
Gold Member Username: PlymouthCanada Post Number: 8214 Registered: Jan-08 | macra12 -Standard DN LNB is circular Freq: 11250 -Special DN LNB for 118.8W is circular Freq: 10750/11250 -DN 121W LNB is Linear Freq: 10750 -Invacom QPH-031 LNB is Linear(10750)/Circular(11250) but can't get 118.8W I hope that help you. |
New member Username: Macra12Post Number: 3 Registered: Mar-09 | thanks Plymouth.. another question... as the diameter of the dish changes, does that also change the distance of the position of the LNB?, Im going to modify a dish if possible.. thanks for any advice |
Gold Member Username: PlymouthCanada Post Number: 8216 Registered: Jan-08 | macra12 That depends how is the curve, higher is the curve, near is the LNB, the focus point can vary with the manufacturer. The best is trying to get the best signal while using a satellite tracker. |
Bronze Member Username: Ferrarifire23Post Number: 34 Registered: Oct-06 | My arabic channels are not working? Are down for everyone right now? or whats going on? |
Gold Member Username: PlymouthCanada Post Number: 8218 Registered: Jan-08 | ferrari fire Read this thread: https://www.ecoustics.com/electronics/forum/home-video/557419.html |
