Platinum Member Username: NydasPost Number: 14104 Registered: Jun-06 | Essential kit 103 for conversion to 103 LZMA boot Kit. This is the new change recommended. Convert to PUFF_LZMA. There will not be any more PUFF PUFF_LZMA_207 BIN in separate file Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Bronze Member Username: AryanMississauga, Ontario Canada Post Number: 97 Registered: Nov-07 | nalin, if already converted to lzma and already have 206lzma on it, even then do v need to do all the steps or just rewrite the new 207lzma bin?? thanx |
Platinum Member Username: NydasPost Number: 14106 Registered: Jun-06 | It is recommended that you have boot 103 and not 102 although bot 102 will work | |
Bronze Member Username: AryanMississauga, Ontario Canada Post Number: 98 Registered: Nov-07 | i did it 103 boot the most recent u posted 2 days back then i think i just need to write new bin only right?? thanks |
Platinum Member Username: NydasPost Number: 14108 Registered: Jun-06 | Just load the 207 LZMA Bin. Did you notice the time on my and your posts? Their clock has gone haywire. |
Bronze Member Username: Abs_qurPost Number: 12 Registered: Aug-07 | I need help please, I had -PUFF-_boot Ver.1.0.1.bin loaded in my receiver, with the old Fwank7_PUFF_292.BIN So I try to update the latest boot -PUFF-boot_Ver.1.0.3.bin, and it keep running P U F F on the front and will not boot... What I can do to fix this...Thank you |
Platinum Member Username: NydasPost Number: 14113 Registered: Jun-06 | Does it say P.U.F.F. or P U F F ? The first is LZMA signature. if you have that, you are OK. Next using BL Updater Load the 207 LZMA_PUFF BIN. You will probably need to do user setup and antenna setup and a scan |
Bronze Member Username: Abs_qurPost Number: 14 Registered: Aug-07 | I did load Ukr_Jvvh-Team-PUFF_(Lzma)_v207.bin after that boot bin 64K, but it is not booting all they way...It keep flashing in a loop, like it say P U F F , then it gets stuck on F for a while and then same cycle starts again....and again, so it keep doing that but never boots....all the way... Thank you for your help Nalin... |
Silver Member Username: Jwl1Post Number: 358 Registered: May-06 | Jack--turn it off from the back, turn it on until you see the first "P" and upload the new bin. If you are not able to do that, then you need to start over with a prior working bin. |
Bronze Member Username: Abs_qurPost Number: 15 Registered: Aug-07 | I did reloaded new bin Ukr_Jvvh-Team-PUFF_(Lzma)_v207.bin when I see the first "P" and it loads the bin fine, but I think I messed up the boot PUFF-boot_Ver.1.0.3.bin and now it will not boot all they way.....????? | |
Bronze Member Username: KambamPost Number: 17 Registered: Apr-08 | I am getting Scrambled or bad channel. Do I have to scan the satellite after loading the boot -Ver1.0.3 & the 207 bin? | |
Bronze Member Username: Lubfr01Post Number: 66 Registered: Sep-07 | here we go again ... There is no simple answer and follow setup 1 2 3 and you are done.... I guess no one is sure as to what are the exact things to do and so we are in the limbo again... someone needs to test this first and get us all the steps...please |
Silver Member Username: JuanchoCANADA Xx Post Number: 467 Registered: Jun-08 | jack blor, the pufff on y off mean, you dident load correctly boot1.0.3. start again reload bin 205 fmu and redo the boot 1.03 and bin 207 LZMA |
Silver Member Username: JuanchoCANADA Xx Post Number: 468 Registered: Jun-08 | here you have the correct boot 1.0.3
Bronze Member Username: Lubfr01Post Number: 68 Registered: Sep-07 | Juan do you have 207 LZMA working on your FLU converted Pansat ? | |
New member Username: BqtootPost Number: 2 Registered: Aug-07 | Question on one of the steps: When using Ukronic's v.421 loader, what "file type" does one select at the bottom of the box, i.e., App file only, Channel data file, or boot file only? |
Silver Member Username: JuanchoCANADA Xx Post Number: 469 Registered: Jun-08 | other answer Stuck on F. This is happening because your crossing the compressed bins..and the need for the new bootfile.. -PUFF-boot_Ver1.0.2 is for use with Ukr_Jvvh-Team-PUFF_(Lzma)_V206 NOT Ukr_Jvvh-Team-PUFF_V206. I put out the bootfile as a slight headsup b/c at the rate the bins are growing -PUFF-Ver.1.0.1 won't be much more use for long. And to 'roll' back to puff you'd have to load the -PUFF-boot_Ver.1.0.1 back into your box then load in a PUFF type bin NOT Lzma.. |
Bronze Member Username: Abs_qurPost Number: 18 Registered: Aug-07 | Juan: You are right, it seems that PUFF-boot_Ver.1.0.3.bin did not load properly for some reason, and it keeps displaying P U F F and then gets stuck on the last F second time and same process keep repeating.... What files in order I have to reload please ? |
Silver Member Username: JuanchoCANADA Xx Post Number: 470 Registered: Jun-08 | jack blor; you have to load the bin that your receiver had before, only you know, 205 o fmu or if your receiver had the 1.0.1 do it with the 205 bin femu. then use my posted boot, because that boot said on system inf. boot ver 1.0.3 and last file 207 LZMA |
Bronze Member Username: Abs_qurPost Number: 19 Registered: Aug-07 | Thank you so very very much Juan Ramirezone: I did exactly what you told be except I used the one I had Tronics_PUFF_v201_FEMU_RollPuffFix.bin then PUFF-boot_Ver.1.0.3.bin and finally Ukr_Jvvh-Team-PUFF_(Lzma)_v207.bin, SO I am back in business... Thanks a lot again indeed...:-) |
Platinum Member Username: NydasPost Number: 14115 Registered: Jun-06 | Jack blor: 1. kindly let us knoe if it is doing P U F F or P.U.F.F.. 2. You do not mix Tronic bin and the fwank7 bin now fwank7 and UKR are interchangeble. 3. You must follow the sequence 3 a. Install the 103 BIN using the Ukronic's Box updater .421. This MUST be done with the receiver showing "ON". 3. b. When COMPLETED, either showing P.U.F.F. or "ON", you must load the 207 LZMA BIN using Ukronic's .420 or BL updater 1.4. and 207 LZMA BIN. This must be done using rhw techniue of clicking "Write" as soon as P appears. 4. YOU HAVE NOT FINISHED YET. You may need to do User set up, and antenna setup and blind scan. Or your previous scan become active or you use a recently saved channel master channel list. There are uncertainties here except for a blind scan. REMEMBER THAT P U F F is the signature of the old PUFF boot and P.U.F.F P.U.F.F. is the signature of LZMA PUFF. If you are seeing th eold PUFF signature then install the PUFF 205 or PUFF 206 and see that it comes to ON before converting to LZMA BOOT. |
Platinum Member Username: NydasPost Number: 14116 Registered: Jun-06 | If you already have the old PUFF, the full kit of LZMA essentials and the BIN are posted right at the top of this thread. | |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 309 Registered: Jun-06 | Nalin after loading boot 103 and LZMA 207 I am getting ARYOW INDUS AAG MUSIK and few other chanells as scrambled where as bofore they were all ok with boot file 102. Can you please suggest somthing. Thanks | |
Platinum Member Username: NydasPost Number: 14122 Registered: Jun-06 | Delete all channels form the sat and rescan. Look at 610x channel numbers. Then rename | |
Platinum Member Username: NydasPost Number: 14123 Registered: Jun-06 | Look aT channel names TV 6XXX 7XXX | |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 310 Registered: Jun-06 | No. ARYOW and others are again scanned but show as scrambled. And there is no 610 channel scanned. | |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 311 Registered: Jun-06 | I checked again in 7XXX and 8XXXX no ARYOW etc. in there. | |
Bronze Member Username: Abs_qurPost Number: 20 Registered: Aug-07 | Nalin: I think it was P U F F before now after loaded 103 boot bin then lzma 207, now it says P.U.F.F. Let me know f you need more info...Thanks to all again.... |
Silver Member Username: BorinickPost Number: 505 Registered: Mar-07 | hey i heard that the ftabins has regular puff bin that works fine with out this problem the new bin has cause. It's danspuff207 | |
Platinum Member Username: NydasPost Number: 14124 Registered: Jun-06 | Jack: If you are stopping on F. after the 103 load, switch off at back and get ready to write the LZMA_207 BIN using BL updater 1.4. Turn on receiver and as son as P appears click on write to write the BIN. Now if you had a channel list already there, you might be OK to view TV, otherwise do a user setup and then either load a recent list or do antenna setup and scan again. |
Platinum Member Username: NydasPost Number: 14125 Registered: Jun-06 | Do not use danspuff207. It does not say LZMA in the name and the regular PUFF is history now because of memory shortage. There are three others to choose from - Fwnak7, UKR and NIKK. |
Platinum Member Username: NydasPost Number: 14133 Registered: Jun-06 | Tamara: I was testing a conversion receiver and I could not get the channels you are searching. I will let you know if and when I come across a solution. |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 313 Registered: Jun-06 | Thank You Nalin. | |
Bronze Member Username: ElvirmPost Number: 79 Registered: Sep-07 | I did everything right, but now missing some important ch. (NBATV, FSC and more). Other channels working fine. Need help Nalin. | |
Bronze Member Username: JjariPost Number: 25 Registered: Oct-07 | hi all I could't Install the 103 BIN using the Ukronic's Box updater .421 ... ? I tried when i saw "P" but i can't see the progress of the download .. HELP PLZ jj |
Platinum Member Username: NydasPost Number: 14153 Registered: Jun-06 | jjar jjari Installing "103 BIN using the Ukronic's Box updater .421 ... ? I tried when i saw "P"..." You always install the BOOT files like 103 when the receiver is in in "ON" position. Please read the instructions carefully. |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 314 Registered: Jun-06 | Any words on Missing Pakistani channels Nalin? and thanks, | |
Platinum Member Username: NydasPost Number: 14155 Registered: Jun-06 | I just checked on a CW800a on Anik F3. Channels which were there before and are MISSING NOW are: AAGTV ARY WORLD ARY MIZICA QTV INDUS MUSIC INDUS VISION That is 6 MISSING out of 44 Indian/pakistani/Bagladeshi channels on ANIK F3 I will check later on Echo 3 and try again on a 2500/2700 conversion, although this was the case yesterday when I tried on a conversion. Right now it is time for ZEETV and "SA RE G A MA PA" FINALE |
Bronze Member Username: ElvirmPost Number: 80 Registered: Sep-07 | Nalin, do you know anything about NBA TV, FSC ect. | |
Platinum Member Username: NydasPost Number: 14161 Registered: Jun-06 | Receiver - CW800s. NBA TV is there as 560 and 402 on TP 12224V, Echo 10/11. They are showing Euroleague basketball. FSC used to be there, but I am not seeing it on my latest scan. What is the problem? |
Bronze Member Username: ElvirmPost Number: 81 Registered: Sep-07 | I scanned, I think Echo 7/Ku, and I don't have NBA TV and FSC. I had them before. | |
Platinum Member Username: NydasPost Number: 14169 Registered: Jun-06 | NBA TV s on Echo 10/11 at 110W. | |
Gold Member Username: PlymouthCanada Post Number: 7183 Registered: Jan-08 | Fox Soccer is up on Echo 10,11 # 149 Tp 12370 20000 V 5/6 v5666 a5667 p5666 |
Bronze Member Username: Melissa666Post Number: 13 Registered: May-06 | Help please! I did everything as per the instructions - converted the box to LZMA (1.0.3 version), even we were watching TV with 206 bin 2 days ago. Now with the 207 file - I am getting only Scrambled or bad channel. Did a Blind scan - same thing. Reloaded 1.0.3 again, and the 207 bin (I tried all of them) - the same. The only channels I can see are HOME and DISH. The others are black screen and after few minutes - Scrambled. Anybody to help? |
Platinum Member Username: NydasPost Number: 14172 Registered: Jun-06 | 1. System reset, reload LZMA_207 AND SCAN. 2. System reset, 1.1.1 and PUFF_206 and scan. (Not LZMA_206). Then 103 and 207 and if necessary scan. 3. If nothing works, B60 boot, then PUFF 640K 253 Boot/BIN, then 103, 207 etc. Hope you succeed. Do tell us what happens and what works. |
Bronze Member Username: Melissa666Post Number: 14 Registered: May-06 | I did system reset (factory settings), Antenna Setup and SCAN. Everything is working now! Thanks Nalin! You're the best! |
Bronze Member Username: ElvirmPost Number: 82 Registered: Sep-07 | Thanks for information, but problem is I don't have signal on TP12370. I had these channels before LZMA v207, and this is first time than I don't have these channel. I don't know why I have this situation. | |
Bronze Member Username: KillzalotBristol Post Number: 12 Registered: Sep-07 | Hey Jack, How did you get out of the PUFF loop ? I'm stuck there now. |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 315 Registered: Jun-06 | Nalin I'll wait for your final check. Thanks. By the way what has happened to them have they been moved to another star? | |
Bronze Member Username: KillzalotBristol Post Number: 13 Registered: Sep-07 | Night rider lights only now ??? So much for the fights tonight. | |
Platinum Member Username: NydasPost Number: 14179 Registered: Jun-06 | Night rider lights are NOT a sign of catastrophe. Don't expect people to be able to help you without all details. |
Bronze Member Username: KillzalotBristol Post Number: 14 Registered: Sep-07 | Very true Nalin...I got the factory bin loaded now. I will report back as soon as I have recooped. | |
Bronze Member Username: KillzalotBristol Post Number: 15 Registered: Sep-07 | ok ...don't wanna screw up again. I am back to 2500a factory bin. What next ? Please advise. | |
Bronze Member Username: KillzalotBristol Post Number: 16 Registered: Sep-07 | Should I start a new thread for this? | |
New member Username: GeeksqaudPost Number: 5 Registered: Feb-08 | Back in March 2008 we were told LZMA replaced PUFF, then LZMA disappeared. Nearly fried my STB switching back to PUFF. Now we are being told to switch to LZMA again? Maybe I'll wait a couple weeks... Same story back then "There will not be any more PUFF" |
Bronze Member Username: KillzalotBristol Post Number: 17 Registered: Sep-07 | Restored with factory bin at first sign of night rider lights. Followed updating instructions and everything is up and running now. | |
Platinum Member Username: NydasPost Number: 14186 Registered: Jun-06 | Killz: Start a new thread, but give details of your box and the current status and what you tried. | |
Bronze Member Username: Rockman169Canada Post Number: 53 Registered: Nov-06 | stuck on f after loading v205 femu file . now cant get to on to load 103 lzma boot file . try loading older pull files and still stop on f . | |
Bronze Member Username: Rockman169Canada Post Number: 54 Registered: Nov-06 | puff file sorry . now do i have to load the 101puff boot file again to get it to reboot and where could i find that thanks | |
Platinum Member Username: NydasPost Number: 14192 Registered: Jun-06 | See my long post at https://www.ecoustics.com/electronics/forum/home-video/546784.html |
Bronze Member Username: Rockman169Canada Post Number: 55 Registered: Nov-06 | thanks nalin all is fine |
