Solution for recover all TP and channels
Username: Plymouth
Post Number: 4574
-Load any old bin files May 2008
-Blind scan all satellites for get new Tp
Delete channels or satellite(Viewsat)
Do settings on each satellites and autoscan it
load latest file and enjoy
Username: Doreenakadj
Ontario Canada
Post Number: 2146
thanks Plymouth
but I thought that the coders would take that into consideration when coding the bins wouldn't they? if not they should
Ontario Canada
Post Number: 2147
btw.. once you do a factory reset all sats , tps and channels are gone. I would suggest saving all channel lists and reload it when getting a new file. That way you wont need to do the steps all over again like Plymouth offers here.
Username: Plymouth
Post Number: 4577
Doreen
The satellite setting is now in Keys and you must scan with old bin.
Tested and work fine
Username: Plymouth
Post Number: 4579
Here is another solution
neil
Username: Frobi
Post Number: 234
Posted on Thursday, October 09, 2008 - 09:48 am: Edit Post
Thanks Plymouth.
Did factory default, loaded older bin (17/12/07), rescanned, got all channels, reloaded latest bin, unabled patch and works great.
Username: Cartier1
Post Number: 2100
PLYMOUTH THANX . BUT IS THIS SOLUTION FOR THE QUALITY THAT DROPED TO ZERO, OR IT;S CORRECTING MISSING CHANNLES. ????
I HOPE IT CORRECTS THE QUALITY ISSUE.
Username: Plymouth
Post Number: 4589
Cartier
Example: before 68 channels and after 160 channels and all work
I found that the settings are inside the provider keys.
I tied to deleted provider in key menu but it not work, then i tried a old bin and autoscan and all channels come, then i install latest bin and all channels come up.
It work for both provider
Username: Plymouth
Post Number: 4590
Neil try a factory default and load old file and autoscan then load latest file and it work too.
The secret is, scan with old file
Username: Mohamad_obama
Terhan, Iran Iran
Post Number: 28
ply mouth you stated you only watched true fta, why do you need a bin?
Username: Plymouth
Post Number: 4596
I says factory file VIEWSAT_ULTRA_V0143.PGM not work fine, i use this one VIEWSAT_ULTRA_V0132.PGM
AND IT WORK FINE
Username: Bazzoon
Post Number: 29
What is so special about bins from May 2008?
Username: Plymouth
Post Number: 4679
baz zoon
You can try another bin file, the problem come from one of the 2 or 3 latest bin files, probably corrupted.
Username: Cartier1
Post Number: 2115
still dont get a signal
Username: Dimwitt
Post Number: 953
C/P
Plymouth
Username: Plymouth
Post Number: 4574
Do the Hokey Pokey
Username: Plymouth
Post Number: 4750
Cartier
I post a answer for you on this thread:
https://www.ecoustics.com/electronics/forum/home-video/519896.html
