Geo News
Username: Sindhiguy
Post Number: 36
I Really don't know that the problem is or everyone is having the same problem. But all of my channels are working except Geo News. Any Suggestions or Anything ?
Username: Plymouth
Post Number: 4608
Humayun
Do a autoscan with a old bin file then load latest file
It work on Viewsat and Captiveworks.
Username: Nydas
Post Number: 12241
Geonews seems to have disappeared from Echo 3. It was channel 902 and now is not shown on Lyngsat list.
This is part of the gradual shift to 118W.
You are better off getting set with a 33" Dish and a special 118 LNB and start using that instead of 61.5.
Of course you should try blind scan first. If you see a channel which says TV 905 then that is your channel.
Username: Nydas
Post Number: 12243
Mistake - TV 902 channel.
I have checked that Echo 3 does NOT have Geo News no, but I am not able to test a rescan tonight.
Username: Nydas
Post Number: 12244
ON Echo 3, I tested 12603(v) TP and all of them have disappeared from that TP, i.e ZCINE ZEETV, B4U Movie, Melody Arabia, etc.
I may retest tomorrow with a new scan, but you should try a Blind scan to see if you can find these channels.
Please post to tell me if the other channels are working.
Username: Plymouth
Post Number: 4609
Nalin
Geonews is there and up, i confirm
ZEECINE, ZEETV US,B4U, all up but Melody Arabia autoroll and after delete the sat and autoscan it comeback.
