Echostar3, Nimiq and Indian channels problems
Username: Advfta
On VS 2000 Ultra
Echostar 3 and Nimiq settings are:
Satellite EchoStar 3 61.5 W Nimiq 1, 3 91.0W
LNB Power ON ON
LNB Type Standard Standard
LNB Frequency 11250 11250
22KHz Off Off
TP Frequency 12297 12224
DisEqC 1.0 Port 3 Port 2
Motor Off Off
Legacy SW None None
When I scan for Echostar3, I only get B*V channels and no Indian channels? could someone please help me.
Also, I am missing CBC and CTV newsnetwork channels. I have deleted all the channels and scanned a coupple of time but am having problem as explained above. Please help
Username: Plymouth
Post Number: 4459
Switch the port and rescan
Username: Advfta
Tried all ports and scanned (auto and blind scan, still not getting any DN channels.
Username: Kirankumar
NO Bashing
Post Number: 2975
do you have a dish pointing at 61.5?
post your dish and switch set up here so we can help
Username: Mucho
Post Number: 779
ad v, try
A) Factory Setting
B) Blind Scan
Username: Plymouth
Post Number: 4474
Yesturday i lost many Tp on Dn and it come back whis this solution:
Go in Menu
System information
Code Menu
Select Nagra
Down arrow then select 00 01 00,01 01 00 and 01 06 00 and delete those 3 dish provider with "F3" on remote and load latest bin file, save and exit, wait that the autoroll found keys and all Tp come back.
You will need to rescan your satellite
Username: Tapeman
New York City in-HD, NY
Post Number: 3606
DANGER
Please disregard 13 year old White hawk comments
This egyptian kid likes to play
He does not belong to this forum
"ad v, DO NOT TRY
A) Factory Setting
B) Blind Scan
Consider yorself warned about all his childish games
Real solution from King:
Yo have a bad D-switch or wrong setup/wiring
I would by-pass D-switch
By temp run a F/F coupler connecting 61.5 LNB straight to receiver
Yo'll now get 61.5 if yo haven't change settings
Keep in mind to change TP freq to obtain signal if necessary
Username: Kiruba
Post Number: 20
for E3set
LNB Power ON ON
22KHz Off Off
TP Frequency 12326
DisEqC 1.0 none
Motor Off Off
Legacy SW None None
only 60channels for the DN i dont see the667and 576missing from the list
Username: Tapeman
Post Number: 3608
Missing channels is one thing and scanning to get different satellite is another
I see many people reporting missing channels due to migration to another satellite like 118.7 or it could be dropped out or possible due to ECM etc.
I sent yo a reply cuz yor initial post is yo scan D#N and yo get B#V
As far as why yo can't get 2 channels on 61.5 I strongly belive they migrated to another satellite like 118.7
Maybe Plymouth or Nalin can be familiar with those 2 channels
Username: Advfta
I have Dishnetwork and BEV dishes.
Echostar is pointing to 61.5W
Nothing has been changed w.r.t to switch or settings.
Everything was working fine until 1st Oct and since then am not getting any Indian channels.
Username: Advfta
Thank you all for your responses. But the problems still remains.
Plymouth and kirubaaaaaaaaaaa, I tried both your suggestions and am still am unable to get the channels. I am baffled now.
King Tapeman, It is just not 2 channels that I am not getting on DN, it is all the channels on it. Also, I am not getting some channels CBC, CTV news network etc. on the B3V also.
Any other suggestions.
Username: Plymouth
Post Number: 4490
A-D-V where you take the bin file?
Username: Doreenakadj
Ontario Canada
Post Number: 2088
hubby just rewired all Sat's and switches and we can't get DN now at all. Nimiq is only working now .... Not sure if its the rewiring or if DN is down tho
Username: Plymouth
Post Number: 4492
Up on Vs Ultra
Username: Tj07
Post Number: 26
I am not getting Indian Channels too.
Username: Fredp
THOSE CHANNAL YOU CAN GET THEM ON THE SAT 118
CHANNAL NUMBERS
795 SUN TV ( INDIA )=610 AT THE SAT 61.5
796 KTV ( INDIA ) = 667 AT THE SAT 61.5
Username: Advfta
Post Number: 7
Plymouth, I took the bin file from totalfta or from thetotalfta
I haven't touched any wiring or switches and getting no DN channels at all.
Username: Plymouth
Post Number: 4507
go in Channel scan and delete Echo 3 with garbage can save and exit and do a blind scan on 61.5W
Here is the good setting for Echo 3
LNB Type: standard
LNB Freq: 11250
Tp freq is not important
Choose the good port if you have many LNBs.
do it exactly like i mentionned and reply with the result.
Thank
Can you changed your name because Ecoustic block this word.
