Gold Member Username: Saqeeb9000Post Number: 3854 Registered: Oct-07 | hi can any one tell me if star choice 36 inch dish can be used to catch 118.7 with special lnb? is it possible? |
Gold Member Username: The_codersPost Number: 1410 Registered: Jan-08 | will work fine but you cant use the SC linear lnb's for 118.7 |
Gold Member Username: Saqeeb9000Post Number: 3856 Registered: Oct-07 | thanks coder but i have special lnb that is used for 118.7 so i wanna know if i can use with star choice dish. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3531 Registered: Oct-06 | Sada There is no encryption bin for DC-II star*choice Yo can get the signal with a 30" dish and a linear LNB But yo won't the channels without a bin |
Gold Member Username: Saqeeb9000Post Number: 3857 Registered: Oct-07 | king i mean it says star choice dish and its about 36 inch.. i have special lnb the one u recommended , i wanna get 118.7 so can i use the "special lnb" to make it work with star choice dish (front part only ) let me know if its possible and thanks |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3532 Registered: Oct-06 | My bad I didn't see 118.7 All along I thought yo always had 118.7 |
Gold Member Username: Saqeeb9000Post Number: 3858 Registered: Oct-07 | so yes or no |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3534 Registered: Oct-06 | Sada 28" dish or above will work fine Yo can even get few TPs with Star*choice LNBs Give it a try befor yo change LNBs Yor existing LNB might get 118.7 |
Gold Member Username: Saqeeb9000Post Number: 3859 Registered: Oct-07 | thanks |
Platinum Member Username: NydasPost Number: 11726 Registered: Jun-06 | sada: Look at my write 0n on 118.7 today. https://www.ecoustics.com/electronics/forum/home-video/516462.html |
Gold Member Username: Saqeeb9000Post Number: 3861 Registered: Oct-07 | it helps a lot .. thank you very much |
