Help with Captivworks 600s Premium
Username: Dawood1022
Post Number: 11
I down loaded the wrong file for CW600s when I have the premium box. It would not turn on, rather it gives me flashing two's (2 2).
Any idea how to reset it or fix it?
Thank you
Username: Dimwitt
Post Number: 860
Put the premium in boot mode (turn on from back while pressing front power button) and load the factory bin.
Post Number: 12
Thank you Tooter,
Should I do that while its plugged to the TV?
Post Number: 13
Tooter,
Where can I find the Factory bin?
Username: Dimwitt
Post Number: 861
load it like you normaly would, just have it in boot mode -
captiveworks.com
www.captiveworks.com/software/CW600PV1.09_Reocrder_2_20_07.bin
Post Number: 14
Tooter,
You are great. Thank you so much. I'm back in business!!!!
