Pansat 2700a help
Username: Jalaj69
Post Number: 173
n e one have problem with "no signal" on international channels?
Some one please help?
...sometimes it comes on it most of the time "no signal".....used both 268 and 269 bin!!
Username: Dude123
Post Number: 2343
268 is working good for me, no problems at all. Try the hardboot and then set default key let it autoroll see if that helps.
Username: Jalaj69
Post Number: 174
tried everything! setting it to Fac setting and let it autoroll...no luck..
Username: Similarevil
Post Number: 11
try this, restore it to factory flash, then start over...sometimes data gets corrupted during the factory default operation....and make sure you cut on autoroll in the units menu...
Username: Pulpfiktion
Post Number: 309
THERE IS NO ROOM HERE FOR OLD MEN WHO
KNOW NOTHING AND POST ONLY
B*S ..... B*S...... B*S
