Bronze Member Username: Sunshine123Post Number: 39 Registered: Mar-08 | Has there been a bin sent out for fixing the remote control issue. As in when you slect a channel on the guide selection and the channel does not change it stays on the same channel you started from. Thanks All |
Gold Member Username: KirankumarNO Bashing Post Number: 2792 Registered: Oct-07 | i haven't heard of any remote control issues press SAT on remote and make sure "all satellites" is selected |
Bronze Member Username: Sunshine123Post Number: 40 Registered: Mar-08 | Hey African Thanks but, tried that and still no working ... Here is the problem as best as I can explain. Select guide then find channel you want by searching guide. Select OK on channel you want Hit exit on remote your new channel would show up but on mines it goes back to the channel that you started with from the beging one you selected guide from the first time Thank you for anyone that can help |
Silver Member Username: DimwittPost Number: 702 Registered: Aug-06 | exit from epg , enter channel number. |
Silver Member Username: DimwittPost Number: 703 Registered: Aug-06 | www.myspace.com/downset |
Bronze Member Username: Sunshine123Post Number: 41 Registered: Mar-08 | Tooter, Not sure by what you mean ? Could you explain please. Thanks |
Silver Member Username: MetallicaPost Number: 721 Registered: Jan-08 | Leaf it happen to me too..it's the bin not your remote problem.. when you selected guide go to the channel you want press OK twice it might help if you press OK one time somtime it go back to the previous channel.. |
Bronze Member Username: Sunshine123Post Number: 42 Registered: Mar-08 | Thanks Metallica, I will give it shot Thank you |
Silver Member Username: Mdl97Post Number: 186 Registered: Jan-06 | metallica is right.same thing was happening to me.just hit select twice and all shall be o.k. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2440 Registered: Jan-08 | Guide is a new improvement: Now you need to press OK 2 times for have channel If you exit or repress on guide, you return to last channel. Whit this improvement you can see others channels and return on channel without recall. Read this thread for understand https://www.ecoustics.com/electronics/forum/home-video/480645.html |
Bronze Member Username: Sunshine123Post Number: 43 Registered: Mar-08 | Plymouth ramiro gonzo METALLICA African Tooter Once again thank you ALL for your help Thank Goodness for the Internet Leaf |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2476 Registered: Jan-08 | Leaf you are WELCOME |
New member Username: Hotrod3_652000Dallas, Tx Usa Post Number: 5 Registered: Jan-07 | i need help with veiwsat 2000 i just bought |
Gold Member Username: The_codersPost Number: 1264 Registered: Jan-08 | dannie get your viewsat plat bin here : [link removed] |
Bronze Member Username: PalmettololaPost Number: 16 Registered: Dec-07 | Yeah, leaf, mine is doing the same thing. AGGREVATING!!!! |
