Username: Mati Post Number: 6 Registered: Apr-08
Thursday, May 22, 2008 - 14:24 GMT Dear All, Who can help me with software the above mention Modem. I will thank you in advance for your cooperation. Reagards.
Username: Plymouth Quebec city,
Quebec
Post Number: 2472 Registered: Jan-08
Thursday, May 22, 2008 - 17:56 GMT What you want to know?
Username: Mati Post Number: 7 Registered: Apr-08
Friday, May 23, 2008 - 11:55 GMT Dear Plymouth, I need the software and driver of this modem. Also I need the username and password, so I can connect to Internet. Thank in advance for your cooperation. Regards.
Quebec
Post Number: 2481 Registered: Jan-08
Friday, May 23, 2008 - 12:36 GMT yugene Albert I found the manual http://www.tstt3g.co.tt/AXW-D800_T1900_User_Manual_eng.pdf The username and password is funished by the internet provider, If you want to connected on internet, normally this modem needed to be accepted by provider, if you want just use it as rooter you dont need software. Connect it and assigned Ip for each computer. What you want to do with this Modem-rooter?
Quebec
Post Number: 2482 Registered: Jan-08
Friday, May 23, 2008 - 12:53 GMT If you want acces in the Modem open internet and put 192.168.0.1 on username and password just "enter" on these 2 If that not work look under or back panel if you see a "reset" and push it and now you can access. Good luck
Quebec
Post Number: 2483 Registered: Jan-08
Friday, May 23, 2008 - 12:56 GMT If you want install the driver just to connect USB port on Win2000, XP or Vista(sh1t)it supposed to install by itself
Username: Mati Post Number: 8 Registered: Apr-08
Friday, May 23, 2008 - 18:31 GMT Dear Plymouth, Thanks for the information and I will contact you if I get through Regards.
Quebec
Post Number: 2485 Registered: Jan-08
Friday, May 23, 2008 - 19:05 GMT You are WELCOME my friend
