Ariza 700,750,800and700sFills
Username: Lookekhoshshans_1356
Tehran, Tehran Iran
Post Number: 124
Ariza Fills
[link removed]
https://www.ecoustics.com/electronics/forum/home-video/466796.html
Tehran, Tehran Iran
Post Number: 125
Do you need the 700 Setup Instructions?
[link removed]
Tehran, Tehran Iran
Post Number: 126
Ariza 700/750 How To Guide found here [link removed]
loader found here [link removed]
files found here [link removed]
get the keys here
[link removed]
get a key grabbing program here
[link removed]
Entering Keys Manually For Ariza. found here [link removed]
Tehran, Tehran Iran
Post Number: 128
FTA View
[link removed] (all receivers)
Data Viewing Sequences
[link removed] ( Conaxsat and all receivers)
FTA Bins
[link removed] (C00LSAT and All receivers)
FTA For All
[link removed]
Cut and Paste these into your browser:
REMOVE the * in links below: These are the larger sites,and therefore Ecoustics has blocked their names and active links..
[link removed]
[link removed]
[link removed]
or get Keymaster 4.0 here free and NO registration is required...
[link removed]
Best TV Guide site
www.sharpc.com
Relevant Product Info
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 112
hi all
my Ariza cannot get PPV is there any fix yet?
thank you
Username: Tehrani
Iran, Tehran Iran
Post Number: 121
hi
My Ariza can not get PPV
Do you have new fill?
thanks
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 113
Do you have New Key?
Username: Ustaad_hc
Post Number: 582
file is not out yet.
Tehran, Tehran Iran
Post Number: 129
Last Updated :April/07/2008
Ariza 700,
Turn on the receiver.
Press Menu on the remote
Select Parental Control
Enter i2004 as the pin
Go down to Key Menu
Leave the first option ON and change the rest OFF
Press Exit just once
Go down to Nagravision2 , press OK
Press down arrow to select Key Number 00
Press Down arrow to highlight Key Data
Enter new Key Data for Key No: 00
Key data 95 AF 68 2B 92 2E D4 77
39 3B 59 17 F5 34 46 77
Press OK button on remote to store and save the changes
then go to Key Number again and by pressing right button just once
change it to 01
Enter new Key Data for Key No: 01
Key data 6A 8D 64 D3 77 B5 B4 B4
B8 81 93 19 84 7D 80 F8
Press OK button on remote to store and save the changes.
Now press EXIT until you see the picture. (Exit completely out of the menu)
Enjoy
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 114
hi HC
Your Ariza is working now?
My Ariza doesnot work
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 115
Nalin Nyda , LK and lookekhoshshans are very help ful
If new fix come out, They will be tell us
Thanks a lot for them
Username: Ustaad_hc
Post Number: 584
No Ariza doesn't work right now.
Username: Aysa
Toronto, On Canada
Post Number: 36
Mingo is busy and he is the only one who makes fixes for arizas...
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 116
The new keys doesnot work
do you have new keys?
What should we do?
i donot have PPV
please help us
thanks
Username: Ustaad_hc
Post Number: 585
any luck for ariza guys..
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 117
What should we do?
i donot have PPV
please help us and give a new key
thanks
Username: Bluebee
Post Number: 77
Its not keys issue. We need a new bin. So far no new bin available.
Username: Bluebee
Post Number: 78
Mingo's Advice
Since Mingo is moving to the UK and has stated it will be more difficalt for him to supply bins but will still do his best to do so. It now up to us to deside to stick it out with the Ariza stb or move on to something else. Here is a quote from Mingo.
C/p from Mingo plus his link.
Best advice I can give is buy the cheapest box you can afford. Dont invest to much money. In Europe Things have been down for some time and soon It could happen here as well. We all know B is doing a card swap. It will be DTV all over again. So dont over spend. You can buy a CNX mini for 139.99 or less Great prices on hard ware now. Captive works for as low as 70.00 you cant go wrong. If you think It wont happen I want my DTV back! SKY in the UK also uses NDS so that would be sweet.
MINGO><OGNIM
http://www.ftatalkDOTcom/showpost.php?...1&postcount=22
Here are some STB prices in Canadian funds. Don't over pay if you buy a new STB. And don't buy a clone. Keep in mind that bev is doing a card swap.
CNX Mini $120.00 with switch and USB
Sonicview sv 4000 $129.99 USB port
Captive Works 600 prem $49.00 (found this one on Sale was $84.00)
Captive Works 700s $114.99 with USB port
Captive Works 800 $129.99 USB port
Viewsat Ultra $139.99 USB port
Viewsat Pro $169.00 USB port.
Now these prices were easy to find on the internet for the southern Ontario region. You may find them lower or higher as these were the average prices I found. You'll pay more for Authorized Dealers but most of all read up on detecting a clone before buying any model. Even Authorized Dealers can rip you off so be a smart shopper.
For those that want to stay with the Ariza I'll say this. AS long as someone supplies bins for the Ariza STB I'll do my best in helping to keep them going.
All the best to you Mingo and thanks for your past support and continuing support on the Ariza STB. The STB choices you made have great support and I'm sure members will be happy with them.
I'm not a dealer in STB's so please don't ask to buy one from me.
Username: Tehrani
Iran, Tehran Iran
Post Number: 122
good news ! there's hope if you're willing to test.
________________________________________
it's been confirmed elsewhere that ariza 700 can be succesfully converted to pansat 2700. i have all the instructions and files but i can't do any testing due to my lnb soaked in water. It apparently had cracked and i didn't notice it till now. this is not a rumor. I would post the files but i think only administrators can do that. these files are 1 day old so i'm confident they're up to date.
here's the actual post:
Ariza 700 To Pansat 2700 Jtag Conversion
Ok folks here is the conversion for the ariza 700 to pansat 2700...
Now it is a USE AT OWN RISK and also DO NOT PM ME WITH QUESTIONS there will be a feedback thread started for that....To start you will need the files provided in thread... Also if you not good with jtag do not try ..
YOU WILL NEED A JTAG AND ALSO A NULL CABLE TO LOAD FILES
Step 1 Read the instructions provided with jtag info.....( a must)
Step 2 when done with jtagging do not turn off machine unhook jtag
Step 3 open up gt rom loader 27.02 and load pansat 2700 factory bin..
Step 4 load the B75_m fileNow when machine done loading it will reboot do not turn off let it show 8"s goin across then stops on last 8 for roughly 30 sec..
now turn off from back and set up loader...When loader ready turn on from back and at first sign of light hit fix on loader..Do this process for all files...
Step 5 open up BL 1.3 loader and load jvvh 209 file
Step 6 load jvvh 209 file
Step 7 load on the jvvh 211 file
Step 8 load the jvvh 217 file
Step 9 load the jvvh 220 ( the whole time using the BL 1.3 loader)
Step 9 Do blind scans of sats.What u will notice is that your display shows 8's on it dont worry about it at this point just enjoy and watch t.v........And yes your ariza remote will work on this conversion......
REMEMBER READ AND FOLLOW ALL INSTRUCTIONS
These are new and reported to be working well. Use at your own risk.
File Type: zip 2700_Jtag_Repair_Kit_by_(rougesat).zip (690.3 KB, 7 views)
[link removed]
Username: Ustaad_hc
Post Number: 588
look like ariza 700 is the piece of junk now because no fix......
Username: Partner500
visit http://www.earthhourblog.blogspot.com
for more info on this!
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 118
Does some have the new ariza 700 files thanks
Username: Bluebee
Post Number: 79
Alime,
There are no new Ariza files yet.
Username: Dimwitt
Post Number: 604
Ariza 700 can be converted to vortex 2700 via JTAG
www.dsstester DOT com/details.php?file=3678
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 119
It is work?
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 120
dsstester dot.com/details.php?file=3678 - did not match any
Username: Dimwitt
Post Number: 605
Space on both sides of DOT needs to be removed
Tehran, Tehran Iran
Post Number: 130
C/P
Step 10 Do blind scans of sats.What u will notice is that your display shows 8's on it dont worry about it at this point just enjoy and watch t.v........And yes your ariza remote will work on this conversion......
Thanks goes to RBBB and the others at geeks
USE AT YOUR OWN RISK!!!
Username: Ustaad_hc
Post Number: 594
lookekhoshshas
your ariza is working after jtag?
Tehran, Tehran Iran
Post Number: 131
I bought Pansat 2700A.
I saw this writing at the sit then i copy that.
i donot know
thanks
Username: Ustaad_hc
Post Number: 595
thanks,,,,,,,,,,,,
Tehran, Tehran Iran
Post Number: 132
If friend, Mingo not give support to Ariza for a long time
Read This:
C/p From MINGO
Quote:
Hi guys / gals just so you guys know I am soon to be a dad So I will be busy with my new baby. Also I Will be moving to the UK because of a great opertunity for me. I am giving a heads up to everyone here. As always I will do my best to help out the comunity. I see many people working on many soulutions and was very suprized that people here at fta talk got ariza xtreame working again. were there is a will there is a way. I will be taking my ariza to the UK wonder what I will see there. I am sure some one will step up to the plate. Thanks again for everthing every one.
MINGO><OGNIM
Username: Ustaad_hc
Post Number: 596
text/htmlUpload
Simple JTAG for Dummies.html (8.9 k)
Username: Ustaad_hc
Post Number: 597
Simple JTAG
Ok here it is.
A very simple JTAG interface that works!
I like most people was not born reading schematics and figured there was a easier way to do this JTAG stuff.
I am sure a lot of other people came up with the following.
The kudos' for this collection go to the original authors, who ever they are.
Parts
I bought a 5 pack of 100 OHM 1/2 watt resistors from Radio Shack (wattage does not matter, 1/8 through 1/2 are fine). Also I scrounged up a 25D(parallel) connector. I also used a six inch piece of Cat5 cable I had laying around (keep it under 12" and you should be fine).
Connections to D25
1. I soldered one wire to pins 18-25 on the D25 connector. Really all I did was spread solder across those pins and then soldered the wire to it.
2. Soldered a 100 OHM resistor to each the following pins on the D25 connector. Pins 2, 3, 4, 5, and 13.
3. I then soldered a wire from the Cat5 cable to the other end of each resistor.
4. I unplugged the IRD and unhooked all the cables to it.
5. Then I flipped it over and soldered the wires from the other end of the Cat 5 cable, parallel or serial ribbon cable can also be used as seen below.
Connection to Ariza 7xx IRD
------------ Front-------------
X X X X X X X X X X
X X X X 2 3 4 13 X 5
Numbers are the pin numbers on the DB-25 connector.
Use a board mounting screw hole "the tinned solder patch under the screw" is enough for a good ground.
Try to keep its length less than 6-8 inches if you can.
This view is from the front right of the Ariza looking from above the card slot if equipped and behind
Solder the wires directly to the correct jTag pads on the board as shown above.
Tehran, Tehran Iran
Post Number: 133
[link removed]
JTAG Guide
Introduction
After reading this simple, easy to follow guide, and following all the instructions exactly, you will be able to extract your receiver's box keys and dump your TSOP. The box key is useful when using camless solutions such as emulation or when using the Atmega. Dumping your TSOP is a good idea because there is always the possibility of an ECM that targets your TSOP. Almost anyone with experience will tell you it is a good idea to dump your TSOP. This guide will assume you have some basic knowledge and know how to download files off the internet and unzip them. Please note I take no resposiblity for any damage you may cause as well as any laws you may be breaking. Please read the disclaimer on the home page. This guide is for eductaional purposes only. Enjoy.
Difficulty Level
The difficulty level of this project is 7 on a scale of 1 to 10. It will require that you solder wires to the bottom of your receiver and you must have at least a little bit of experiece with soldering in smaller areas. This project should take you 45 minutes if all goes well.
What's Needed
• Jkeys 1.33
o download it from here
• Bell Expressvu or Dish Network IRD
o must have JTAG port on bottom
o The following models have JTAG: 2700, 2800, 3700, 3800, 3900, 4700, 4900, DP301 (3100), PVR501 (5100), 6000 plus DRD420, 440, 480
• Computer:
o must have available printer port
• 5 100Ohm Resistors
o I've heard that 1/8 to 1/2 Watt will work, I know 1/4 Watt works
• Soldering Iron
o 25 Watts or so
• Wire
o Cat 5 works best, but regular copper wire works too
o you wont need too much wire. You will need 6 pieces that are 6 inches or so
• Solder
o any 60/40 solder
• DB 25 Connector
o you will want a male connector because your computer's printer port in female
Building the JTAG
The first thing you're going to do is make the simple JTAG reader. First, solder the 5 100 Ohm resitors to pins 2, 3, 4, 5 and 13 . Now, take your 5 pieces of 6 inch wire and solder one each to each end of the 5 resistors. You may not get proper results if your wire is longer than 6 inches. Now would be a good time to inspect all your solder joints and make sure that you didn't leave a solder spike across any of the pins. Now, you must make a connection for ground. This is done by taking the last wire you have and soldering it to pins 18-25 of the DB 25.
Hooking up the JTAG
Once you have the JTAG reader built, you now want to solder it to your IRD. First of all, you should pre solder your wires. Just add a little bid of solder to the end of each wire. ***Please note that if you aren't careful when soldering your JTAG to your IRD, you can mess something up. Please note that I take no responsibility for whatever may happen. Many people say that you shouldn't solder at all to those pads on the bottom of your IRD. I have done this on 4 different IRDs and never had a problem, but that doesn't mean you wont. BE CAREFUL AND DON'T CROSS ANY WIRES. You've been warned!*** Ok, once you've pre soldered your wires, you now have to figure out where you are going to solder your wires to on the bottom of your IRD. Make sure your IRD is unplugged when soldering to it. Please use these diagrams as a reference:
2700,2800,3700,3800,3900,4700 & 4900 IRDs
3100 IRD
5100 IRD
6000 IRD (Not sure if this is correct!)
Please note where the front and back of the IRD is.
Make sure that you have good connections to the proper pads. DON'T HOLD THE SOLDERING IRON ON THE PADS TOO LONG. I don't even like to touch the IRD pads. What I do is hold the soldering iron to the wire and let the heat melt the solder that is on the wire when I pre soldered it. Inspect all your joints and make sure that there are no crosses and that your JTAG wires aren't touching each other.
Getting your Boxkey
You now want to download Jkeys and unzip it to a folder of your choice. Connect your JTAG to your computer's printer port and plug in your IRD. DO NOT TURN THE IRD ON. Just plug it in. When you start Jkeys, your box keys should be there. If you don't see your Boxkey and IRD number, make sure that all your connections are good and no wires are crossing. ONCE YOU HAVE YOUR BOX KEY, WRITE IT DOWN IN A SAFE PLACE! YOU DON'T WANT TO LOSE THIS! . It might be a good idea now to save your TSOP in case of an ECM. No one would argue that it is a bad idea to have a back up of your TSOP on your computer. Read the next section for information on backing up your TSOP.
Backing up your TSOP
Once you have got your box key, you should dump (make a back up) of your TSOP. Doing this is not to difficult with JKeys. All you have to do is look at the chart below, and then enter the values into JKeys. Different IRDs have different TSOPs, so that means they have different start addresses and sizes. To dump your TSOP, find your IRD in the chart below, then enter the values for youR IRD into JKeys. Then press "Save Mem". Note that the 3100 and 5100 have two TSOPs, so you must save both
Username: Ustaad_hc
Post Number: 598
if you wanna made jtag your self its look like seem to be me little hard because if you missed any single wire or wire touch each other your stb going to dead.
I order jtag wire from ebay. its only $10.00 US which is worth.
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 121
Hi there,
Who knows where I can find the most updated bin file for Ariza 700? Since Apr 4, there is no updated bine file anymore.
Thanks!
Tehran, Tehran Iran
Post Number: 134
i thing There appears to be no more new files for the Ariza`s
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1925
Go to dsstesterDOTcom and select in left side "Ariza" i found one there
I dont know if it good
Username: Plymouth
Post Number: 1926
Sorry this is 2008-04-04
Username: Ustaad_hc
Post Number: 600
No new bin out after April 04,2008.
old bin doesn't work either. i think you have to do jtag and convert Ariza 700 to pansat 2700.
some people did that and running very good.
Username: Lklives
Post Number: 15428
Heres how to convert the Ariza 700 to a Vortex 2700 (2700 clone)..NO JTAG needed..
Username: Lklives
Post Number: 15429
Ariza 700 to Vortex 2700
All instructions, files and loader needed included..
use at own risk..
[link removed]
Tehran, Tehran Iran
Post Number: 135
I do not know if this works or not. I have NOT TESTED it, so I cannot answer questions on it.
[link removed]
USE AT OWN RISK
Tehran, Tehran Iran
Post Number: 136
hey guys
Ariza is working on bin 328 with the new number.with bid of freez
good luck
[link removed]
Username: Ustaad_hc
Post Number: 612
thats tru guys ariza is working with Bin 328e.
Username: Aysa
Toronto, On Canada
Post Number: 41
it is working yippie i guess ariza has a little luck left
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 122
299 - iftikhan alam - BEV + DN
300 - newtecradio - DN
301 - kenjite - BEV + DN
302 - sarniametz - BEV + DN
303 - magmorg - BEV + DN
304 - (bellz33 - BEV) (gustokopa - BEV + DN)
306 - the big indian - BEV
307 - dpig69 - BEV
308 - iamcaper - BEV
309 - FTANewf - BEV
310 - outforsat - DN
311 - fantasmal - BEV
312 - 9606jma49 - BEV + DN
313 - miskelly - DN
314 - cye71 - BEV
315 - (yorgos - BEV) (vishy - DN) (donofnb - BEV)
317 - pendingman - BEV
318 - nguyensamdoan - BEV
319 - ilbtr - DN
320 - dawber - BEV + DN
321 - johnjon100 - BEV + DN
322 - bluedog1301 - BEV + DN
323 - JMLR - BEV + DN
324 - (dcmre - DN) (johnjon100 -BEV)
325 - kamdyn - BEV + DN
326 - yiannis - BEV + DN
Username: Pdee333
Post Number: 38
lookekhoshshans, we did the Ariza Jtag Conversion to Pansat. It took a little while, as am new at this, but it worked eventually. There is no more channel guide. and the front of the Ariza shows 8888 all the time.. but at least i didn't have to toss the Ariza's into the dust bin.
Thanks for the help again..
Thanks for the encouragement..
Username: Ustaad_hc
Post Number: 613
good for you.
Tehran, Tehran Iran
Post Number: 137
ARIZA 700 TO PANSAT2700 use at own risk
jvvh file for clone Pansat 2700
[link removed]
Tehran, Tehran Iran
Post Number: 138
good luck
[link removed]
Username: Way2smart
Www.Desifta.com
Post Number: 1562
[link removed] for new ariza bins
Tehran, Tehran Iran
Post Number: 139
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released..also Nalin and her troublemaking aliases are NOT allowed at these sites..
Some of these specialize in particular FTA receivers as noted next to their links...
If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community now...
Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information .
So again I highly recommend using ANY of these sites BELOW!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby!
FTA View
FTA Bins
FTA For All
[link removed]
[link removed]
[link removed]
[link removed]
[link removed]
Best TV Guide site
[link removed] - VIEWSATS and ?Sonicview
[link removed] - C00LSATS
[link removed] - CaptiveWorks.
[link removed] - Ariza and Pansat Conversions
[link removed] - Nfusion
Username: Gregraf
Post Number: 396
Good info all the way from Iran
Username: Nydas
Post Number: 10396
The Coders Gold Member
Username: The_coders
Post Number: 1070 Registered: Jan-08
Posted on Sunday, April 27, 2008 - 10:57 pm:
I recommend U all stay away from DssCommunity.con site...they have no files nor educational purposes...its a site of 95% troublemakers who are using the nicks of some real respected DSS personnel.... their sole intent is to character assasinate the well known respected members of the Dss community and to KILL FTA...its also been rumored that these "troublemakers" are actually employees of Dishnet and Bev...the site and its admins allow this type of bashing and use of other people's nicks, so thats self explanatory regarding the intentions of this "DssCommunity" site...I don't believe it to be safe there or of any FTA value..
DssCommunity allows posting of live links too...so every scammer in the world is posting there many times a day...Mostly these are Pay sites, with fine print selling memberships to public files, and scamming all the newbies who don't know any better... satscams has identified many of these scam sites posting at DssCommunity..use the sponsors posted at Reputable sites not live links from a site like DssCommunity...I highly recommend U stay away from DssCommunity..
__________________
Post Number: 1080
__________________
Username: Nydas
Post Number: 10397
Always go to "home site of your receiver" first. The sites in BOLD offer direct downloads without registration.
Tehran, Tehran Iran
Post Number: 141
https://www.ecoustics.com/electronics/forum/home-video/461836.html
Username: Nydas
Post Number: 10399
The above was posted by a fake person - an imposter. his ID is as follows. As you can see, he is a new member
Nalin Nyda
Username: Nydss
Username: Gregraf
Post Number: 397
I knew you were a crackhead Nalin You LOSER
Post Number: 1085
LK is well known as a newbie, wannabee, moron and scammer. I cant imagine that she has any any goal in life beyond sitting in her grandma's basement and dising people that are better than her. Other than being a source of idiotic rumors, I doubt that anyone here is bothered by anything she posts since only a few of our members believe anything she says.
Username: Gregraf
Post Number: 404
Nalin Nyda is well known as a newbie, wannabee, moron and scammer. I cant imagine that she has any any goal in life beyond sitting in her grandma's basement and dising people that are better than her. Other than being a source of idiotic rumors, I doubt that anyone here is bothered by anything she posts since only a few of our members believe anything she says.
Post Number: 1086
greg raf is well known as a newbie, wannabee, moron and scammer. I cant imagine that she has any any goal in life beyond sitting in her grandma's basement and dising people that are better than her. Other than being a source of idiotic rumors, I doubt that anyone here is bothered by anything she posts since only a few of our members believe anything she says.
Tehran, Tehran Iran
Post Number: 142
Nalin Nyda
Username: Nydas
is help ful he/she helped alot of peoples many and many times
Isaw
thanks
Tehran, Tehran Iran
Post Number: 143
Nalin Nyda was helping me many time when I bought Ariza700.
thanks a lot Nalin Nyda for help
thanks a lot
Tehran, Tehran Iran
Post Number: 144
New ECM Alert - May 1, 2008
Maybe good news for testing:
New data has been detected in the stream for both BEV 0907 and DN 0106.
This means that a new hit should be taking place at any moment.
The good news is that we have lots of older bins designed to work with 0106 and 0907, so we should have lots of opportunity to do some testing.
Hopefully they will procede with the new ECM's on 0907 and 0106, giving Ariza owners a good chance to find a fix.
I strongly advise that you manually input latest keys first from "keyz as they already had new keys for 0907 and 0106 this morning. Always check for keys there first before checking here.
If I learn anything new on this, I will post it as fast as possible.
Here's the link for the Data Base information section.
[link removed]
The first bins to be tried are those that were specifically designed for 0907 and 0106.
If it helps further...the ECM has been identified as a MECM60 -EMM Type 9F. Try to start with older bins containing some or all of these calls.
[link removed]
Ariza Bins- Data Base and Reports
After giving this much thought, I think that the best way to keep the bin reporting area organized is to establish a central reference post which will reflect all the different reports.
As each member adds their report to this thread, I will try to keep updating this post. This way members won't have to search through all the different posts which will follow. If any member has additional suggestions how to improve this reporting area...please PM me. Please keep this thread for reporting only...thanks.
Notes:
I have researched as much information as possible going back over hundreds of postings to try and compile this information.
I am certain that there will be errors in the bin reports but at least it gives us a starting point. If you have corrections to offer or additional information on bins, please post them in this thread as reports only...NO COMMENTS or DISCUSSIONS.
DN: You will see that I show both provider ID's. The reason..in effect they are still operating on both 0101 and 0106, but the majority of channels do required a new bin and key entry would only be effective on the small number of channels left operating on 0101.
(P) indicates a problematic bin.
(U) indicates unknown information.
Your input reports will be very helpful to this thread as all members information can be constantly added to help develop this data base. I apologize for the poor layout but the website's Word processing ability is limited in what can be done.
Additonal Testing Information
'Ariza Bins and ECM History'
Buteo401 has posted an information file from his tracking records for DN and BEV along with other useful information which may help you with tracking.
Here is a link to the file.
[link removed]
The file is downloadable and will give you a good idea of how a 'Real Tester' like Buteo has been keeping records for tracking purposes.
Important: Before posting any information, please look through the thread to see if the information you wish to post is already there. There is no point in posting repeat information.
Satellites and Channels for Bin Testing:
When testing bins it is very important that you tune to channels that will give you optimum opportunity for activation. The following satellite list contains the channels you should tune to whenever you are putting in a new bin or testing an old one.
BEV
Satellite Channels
82----------781 - 782
91----------218 - 280
DN
61.5--------607 - 615 - 620
110 --------119 - 309 - 499
119 --------200 - 303 - 333
121 --------733 - 737 - 766
129 --------(7041-2-3-4) - 7047 -7932
148 --------607 - 615 - 778
There are some other channels as well on most satellites but this list should be sufficient to assist you quickly. If any member has anything to add to this information or needs something corrected, please notify me...thanks.
Locating Older Bin Files:
Scroll down past the Main Forums Discussion area and you will come to the Files area. Ariza Files are the first at the top of the list. Select Ariza Files. This will open the complete list to all Ariza Bin Files. If the file you are trying to locate is an older file, scroll down to Display Options on the bottom left. The box is usually set for a 2 month period. In order to go back further, select the drop down box and it will give you a number of time periods to select from to find older files. All files shown in this Data Base can be found there.
Here the link to the Ariza Files Section:
[link removed]
Latest Keys:
Always check Keys Section here first at FTAtalk. But I recommend that you also check for verification at xxx.tvkeyz.com (replace xxx with www). The information at this site is updated rapidly.
Guide to Bin List:
Anything printed in bold will be an old bin which reactivated after a hit and/or the actual ECM that turned off the bin listed above it.
The bin that follows is the correcting bin to the ECM.
Test Channels for DN satellites:
Please use the channels listed above for the satellites you are testing.
DN Keys only active against 0101 Provider ID Channels.
Bin and Date Autoroll Y/N Manual Key Y/N Provider ID
299 09-12-07-----Y-----------Y---------0101
300 11-15-07-----N-----------Y---------0101 + 0106
301 11-23-07-----N-----------Y---------0101 + 0106
302 12-02-07-----N-----------Y---------0101 + 0106
303 12-05-07-----N-----------Y---------0101 + 0106
MECM 9F & Map 22-Freezing/Loss
304 12-08-07-----N-----------Y---------0101 + 0106
MECM 9F & Map 22 & Timing
306 12-14-07-----N-----------Y---------0101 + 0106
307 12-17-07-----N-----------Y---------0101 + 0106
308 12-22-07-----N-----------Y---------0101 + 0106
309 01-02-08-----N-----------Y---------0101 + 0106
310 01-08-08-----N-----------Y---------0101 + 0106 (P)
MECM 9F
311 01-16-08-----N-----------Y---------0101 + 0106
New Dynamic Code + Keys
312V2 01-18-08---N-----------Y---------0101 + 0106
313 01-21-08-----N-----------Y---------0101 + 0106
314 01-22-08-----N-----------Y---------0101 + 0106
(Bin 299 Reactivated) Map 9F EMM MECM 60
315 01-28-08-----N-----------Y---------0101 + 0106
MECM 60 Map 4E + Timers
317 02-02-08-----N-----------Y---------0101 + 0106
MECM 40 Map 29 New Timing (not confirmed)
318 02-04-08-----N-----------Y---------0101 + 0106
MECM 60 4 Maps calls + New Timers
319 02-11-08-----N-----------N---------0106
320 02-17-08-----N-----------N---------0106
MECM 9F & Map 22-Freezing/Loss-BIN 304 Recovery
-BIN 306 Recovery-BIN 308 Recovery
321 02-20-08-----N-----------N---------0106
322 02-22-08-----N-----------N---------0106
323 02-28-08-----Y-----------N---------0106
322 also working well
324 03-08-08-----Y-----------Y---------0106 + 0101
NO ECM-325 bin for BEV problem only
325 03-14-08-----Y-----------Y---------0106 + 0101
NO ECM-Bin 326 to fix BEV only
326 02-22-08-----Y-----------Y---------0106 + 0101
New Type ECM on DN 0101-Keys not working
327 03-30-08-----Y-----------Y---------0101
Map 2 ECM-Pic 3 Minutes off-3 Minutes on
328 04-04-08-----Y-----------Y---------0101
BEV
Procedures for testing a bin
1. Always make certain you load the correct bin that matches your receiver.
2. Input the latest keys for 0901 Provider ID.
3. Load Bin from Data Base that was used with A/R and manual key entry on 0901. Recommended - bin 309.
4. Tune your receiver to channel 218.
5. If getting 'Scrambled or Bad Channel' message, go to Parental Control menu, hit Default Key twice and then exit back to picture.
6. Make certain that you now have 'Updating Data' message.
7. If you don't, then go to EMU and make certain that autoroll is set to ON. Then exit and see if this has activated the Updating Data message.
8. If still not showing this message, go back to EMU and set Key Code to ON and exit again.
9. Try variations of A/R ON and OFF and Key Code ON and OFF.
10. If 'Data Updating' message is on screen, allow it to reach 1000%.
11. If nothing has worked, then do a hard reboot from the back of the receiver.
12. Always remember to keep your receiver tuned to channel 218 while testing.
13. If all of the above has not worked, then move on to testing the 0907 bins.
The above information applies to testing on BEV 91.
I need further information to post here for the channel selected for testing on BEV 82. (Could someone advise)
309 Recommended first bin to try after a hit.
299 09-12-07-----Y-----------Y---------0901
Rev 248 + MECM 40
300 11-16-07-----N-----------Y---------0901 + 0907
301 11-23-07-----N-----------Y---------0901 + 0907
302 12-02-07-----N-----------N---------0907
303 12-05-07-----N-----------N---------0907
Map F9 + Map 22
304 12-07-07-----N-----------N---------0907
306 12-14-07-----Y-----------Y---------0901
307 12-17-07-----N-----------N---------0907
308 12-22-07-----Y-----------Y---------0901
309 01-02-08-----Y-----------Y---------0901
310 01-08-08-----N-----------Y---------0907 (P)
MECM 40 & 60
311 01-16-08-----Y-----------Y---------0901
312 01-18-08-----N-----------N---------0907
313 01-21-08-----N-----------N---------0907
314 01-22-08-----N-----------N---------0907
(Bin 306 Reactivated) Map 9F EMM2
315 01-28-08-----N-----------N---------0907
317 02-02-08-----Y-----------Y---------0901
318 02-04-08-----N-----------N---------0907
Bin 309 Reactivated - Aurtorolled.
319 02-11-08-----Y-----------Y---------0901
320 02-17-08-----N-----------Y---------0901
321 02-20-08-----N-----------Y---------0901
MECM 60 Full 0907-First, Then part 0907+0901
322 02-22-08-----N-----------Y---------0901 + 0907
323 02-28-08-----Y-----------N---------0907
324 03-08-08-----Y-----------Y---------0907 + 0901
New ECM-Older bins working from 0901 e.g. 306, 317
325 03-14-08-----Y-----------Y---------0901
New ECM on BEV-315 reactivates (0907)
326 03-22-08-----N-----------N---------0907
New ECM-Keys not working on 0901
327 03-30-08-----Y-----------Y---------0901
Map 2 ECM-New Type-3 minutes ON-3 minutes OFF
328 04-04-08-----Y-----------Y---------0901
[link removed]
Username: Wakenbake
Post Number: 385
WOW... Thats ugly wallpaper
Tehran, Tehran Iran
Post Number: 145
Go down to Key Menu
change it to 01
Enjoy
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 124
01 :
key 0 02 BA 6B 74 E5 8E 8F 63 EE BC 1B F1 3D 60 CC 94 New
Key 1 8E 8D BC FB A2 8D 3D 70 F8 58 A0 37 E8 07 0F 62
D!SH 0101 - Last Update: 05/02/08 02:59 PM
00: 02 BA 6B 74 E5 8E 8F 63 EE BC 1B F1 3D 60 CC 94
01: 4F C1 6C 53 93 15 D3 11 B0 E9 F5 15 35 52 86 04
hi I did all of the keys but i can not get 91.
could some one help what should i do?
thanks
Username: Ariza700
Markham, On Canada
Post Number: 50
Folks,
Is Ariza 700 working for DN ? if yes than which file and from where I can download it ??
Thanks for your help....
Username: Ustaad_hc
Post Number: 615
Ariza is dead since 2 weeks. no Bin for ariza. & no Keys for ariza 700.
Username: Dimwitt
Post Number: 651
www.dsstesterDOTcom/details.php?file=3678
new vortex file is still needed
Username: Ustaad_hc
Post Number: 616
I guess if you wanna Jtag so convert to Pansat 2700. Because pansat file comes out so fast.
