Question regarding Captive Works 700S
Username: Piccalo
Post Number: 130
Hi guys,
Quick question; which bin do I use for Captive Works 700S?
I would appreciate the reply.
Thanks
Username: Nydas
Post Number: 7035
Try Bins version 1.39, 1.38 or 1.37
After today's ECM, all receivers are working well on BINs of 21-26 Dec., 2007, and the latest BINs are not working.
Username: Piccalo
Post Number: 131
hi Nalin, thank you very much....one more question; would you know the website where I can get from?
Thanks again for the reply.
Username: Nydas
Post Number: 7038
CaptiveWorks BINs
[link removed]
[link removed]
There are probably a dozen other sites too.
Username: Brucester
Post Number: 989
good work nalin nyda keep up the good work
Username: Piccalo
Post Number: 132
Thank you very much Nalin Nyda appreciate the reply and help.
Cheers.
Username: Nydas
Post Number: 7041
Bruce 1: Could you please look at
https://www.ecoustics.com/electronics/forum/home-video/433414.html
Username: Piccalo
Post Number: 133
hi Nalin I got the bin and uploaded to the receiver and did a factory reset and scanned for all the channels. It scanned about 300 channels but the problem is its saying "scrambled channel"....did I do something wrong or is there any setup that I am missing?
Username: Brucester
Post Number: 994
inable the patch f1 000 on the remote
Username: Piccalo
Post Number: 135
love you man....thanks for the help....its working now....appreciate the elp
Username: Brucester
Post Number: 998
you are walcome any time if you need my help you can find me here or at crazyfta dot com
Username: Piccalo
Post Number: 138
hi...my CW 700S was working today morning; after I switched off the power on the remote, its saying "scrambled channel"......I tried switching off the receiver from the back and still no luck.
I was wondering of anyone know what I am doing wrong.
Thanks for the help.
Username: Brucester
Post Number: 1004
most of bev is down go to vu2 for about five min then try tv land.ca 637ch
Username: Piccalo
Post Number: 139
hi Bruce, I am using DN....is DN down by anychance?
Username: Brucester
Post Number: 1008
no what bin do you have did you try the new bin from 01-10-08 can you try it it might be working on both because cw came out with bins for the cw600p and cw600s so the bin from yesterday i think will work try and let me no thanks
Username: Piccalo
Post Number: 140
noluck bruce...still the same issue.
Username: Brucester
Post Number: 1015
are you sure you have bin 145 for the cw700 with the date 01-10-08 i when to other sites and all say bin is working good is the patch in abbled if it is diabbiled it will not roll and if you are on sat 110w put it on ch 195 and for 119 CNN and this will help it roll faster and sume boxes tack longer then others to roll cheack to mack sure you have bin 145 go to the ch i told you and let it site for like 10 or 20 min or hit page down on remot then hit red button this will let you chang the keys by hand go to crazyfta dot com and get the new keys to put in the numbers us the numbers on the remote and for letters use to pick use ch up and down to lock it hit OK on the remote if all this dos not work check you setting and let me no thanks
