Pansat 2500 Conversion
Username: Snissar
Post Number: 38
hey guys i wanted convert my pansat 2500 to 2700
i started to transfer the file jvvh_208_2500to2700.bin to my reciver and then it didnt show b75 and i turned it off it doesnt turn back on
whats the problem
somewhere else i read if i u original pansat 2500a, install 293T or 294T Bin first which i didnt know before
any one know whats the problem now..:-(
Username: Snissar
Post Number: 39
If using an original pansat 2500a, install 293T or 294T Bin first
Any of above whether converted or not converted.
i didnt know it^ and now it doesnt turn on
Username: Saqeeb9000
Post Number: 1321
they are already so many threads here for this reciever..
Username: Snissar
Post Number: 40
but everyone has simple problems that alters the reciver
Username: Nydas
Post Number: 6875
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
http://public.box.net/2500_full_kit
Username: Snissar
Post Number: 42
i know nalin
but i did something wrong
i think i was supposed to load 294 bin to my reciever first but i loaded the jvvh_208_2500to2700 bin.
so its now not turning on
do i need jtag which i dont have any idea about ?
Username: Rtap
FL
Post Number: 1570
sns you have to jtag your receiver to bring it back to life.
Username: Nydas
Post Number: 6882
sns: If there is light, reverse it by using the revert kit included in a subdirectory of the full_kit8. Then start again. You are supposte to install 294T not 294 before starting the conversion.
Username: Snissar
Post Number: 43
what if there is no light on display
Username: Nydas
Post Number: 6885
Then you need to jtag.
You can use the full jtag file supplied by Chancy with the CS232 or CS233T and it is there in the full_kit8.
You will need the jtag cables compatible with your original receiver.
