Ultraview sat made mistake
Username: Transformer105
I have the new code on a USB so I am not worried about that. However the problem is, while I was playing around with the satelite (yes i will learn from my mistake) i pressed factory default and clicked yes, and all the channels got erased and no guides whatsoever. And I tried putting the code a million times but the channels still didnt show up, and it just says "no channels"...can some one please help me on this! thanks!
Username: Extremex
Post Number: 49
Setup your sat settings and then do an autoscan.
Username: Razzorwyre
Post Number: 46
Hello aaa
you will need set you your satellites again and rescan for channels
how would i set my sat settings? is there any specific way?
Post Number: 47
you will need to go into your antenna settings
then depending on your LNB type you will need
to add the LNB, port and switch info for each satellite.
Username: Ke5aqn
Post Number: 1836
your settings have to match your set up...if you have a motor , or use 4 dishes whatever......
please read this guide it will help you to fix your receiver..https://www.ecoustics.com/electronics/forum/home-video/412799.html
hmm ok i will try what you are saying. thanks...it sounds confusing but lets see
Post Number: 48
TFT.. i am interested in this motor set up. What would I need other than the motor. I currently use the DN double lnb i believe its the legacy with swith 42.
hmmm this is werid, i got some channels to work cuz i played around with the atenna scan and channel scan...but is there any faster way to get all the channels?
Username: Jagr1234
Post Number: 105
use channel master
