Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 231 Registered: Jun-06 | I have VS Extreme and I just got the bin from Total, the 82 is working but the 91 isn't. Just wondering if these are the right settings: Sat : Nimiq 1,2 90.9 W LNB Power: ON LNB Type: Standard LNB Freq. : 11250 Tp Freq. : 11811 Diseqc: port 1 Legacy SW: none |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 233 Registered: Jun-06 | can anyone help please? |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 234 Registered: Jun-06 | Nalin? Fta tester? AV? ANYONE?!? |
Silver Member Username: DimwittPost Number: 270 Registered: Aug-06 | Tp Freq. : 11811 may be wrong. The first TP on 91w is 12224. |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 235 Registered: Jun-06 | i tried changing the tp to 12224 and 12239 but it changed right back to 11811 the next time i went into antenna settings |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 236 Registered: Jun-06 | bump |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 237 Registered: Jun-06 | Fta Tester your back! Can you help me out please?! |
Gold Member Username: Donnie1973Post Number: 2191 Registered: May-06 | whats the settings for 81? What kind of lnb do u have? Do u use a disecq switch? |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 238 Registered: Jun-06 | yes i have a standard lnb and i use 2 disecq switches |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1712 Registered: Sep-06 | go to viewsatuusa.com and get the satfile. Do a factory reset on your receiver. upload the satfile in receicver. go into antenna settings and adjust according to your set up. the do autp scan on all sat's you receive. Next time you update do it like in my guide in this thread https://www.ecoustics.com/electronics/forum/home-video/412456.html |
Gold Member Username: Donnie1973Post Number: 2192 Registered: May-06 | what r the settings for 82 that u have in ant settings? u posted 91, but not 82 |
Gold Member Username: Donnie1973Post Number: 2194 Registered: May-06 | r u saying 91 is not working at all with the old bin file, but 82 is fta? |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 240 Registered: Jun-06 | Sat : Nimiq 2, 82 LNB Power: ON LNB Type: Standard LNB Freq. : 11250 Tp Freq. : 12224 Diseqc: port 2 Legacy SW: none |
Gold Member Username: Donnie1973Post Number: 2197 Registered: May-06 | do u get signal on 91? do u have the channels on 91? Just no picture? |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 242 Registered: Jun-06 | yeah i have signal just no picture. I got the satinfo file too and there's been no difference except now the Tp freq. for Nimiq 1 is stuck on 12268 (its not moving to 12224 or anything else) |
Gold Member Username: Donnie1973Post Number: 2199 Registered: May-06 | ok, u should have listened to fta up there... u need the new bin file prolly. totalfta.c0m its on the front page. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1723 Registered: Sep-06 | Bud I bet he lost the transponders the channels will still be on the list or guide but the quality meter will read 0 if he lost the transponders. if he will go get the sat file or manually enter the missing transponders it will make the channels work. I saw this same thing today here at my customers house... unless he has another receiver on the same switch and it is keeping the lnb on the right and the transponder he wants is on the left or vis a versa saw that before too. |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 243 Registered: Jun-06 | how do i get the transponders? by loading the new bin...? how do i manually enter the missing transponders? I already have the new bin from Total |
Gold Member Username: Donnie1973Post Number: 2201 Registered: May-06 | yeah, and y would u have 2 disecq switches anyway? |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 244 Registered: Jun-06 | your asking the wrong guy, i didn't set up the dish. i had no idea about anything a year ago when the dish guy set it up for me. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1726 Registered: Sep-06 | you can NOT control 2 switches with a viewsat go over your set up from receiver to end everthing about your set up even what the receiver sits on it may help.. |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 245 Registered: Jun-06 | Sat : Nimiq 1,2 90.0 W LNB Power: ON LNB Type: Standard LNB Freq. : 11250 Tp Freq. : 12268 Diseqc: port 1 Legacy SW: none Sat : Nimiq 2, 82 W LNB Power: ON LNB Type: Standard LNB Freq. : 11250 Tp Freq. : 12224 Diseqc: port 2 Legacy SW: none |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 246 Registered: Jun-06 | when i loaded the VS bin from total again, there is still one TP in the channel search. How do i manually add transponders? |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1731 Registered: Sep-06 | you will be adding transponder for a few hours....or go get that satfile it is WAY faster |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1732 Registered: Sep-06 | munu, channel scan, go down read the screan it reads red buttion i think to add user transponder. you have to add frequency, polarity, cimble rate, 3/4 or whatever that is for each transponder...hit ok or back......FOR EACH TRANSPONDER their are oh about 400 for DN and BEV you lost some on all sat's so be ready to be their a long long time..oh and if you get one didget wrong it wont work......go get a new satfile it works and you will be done in about 5 min [link removed] |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 247 Registered: Jun-06 | thank you, wow that is so much easier! I thought you meant the new VS Bin rather than the satinfo file. I have all the tp's and it changed my nimiq 1 tp frequency to 12224. I have it on autoroll right now. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1734 Registered: Sep-06 | cool enjoy |
New member Username: JoeturnPost Number: 10 Registered: Apr-06 | Tester I think its something in the water!! The new files areless forgiving now ! My last one 436 on blindscan would scan both polaritys but would not load the Horrizontal ones to the screen,just vertical on 110.I got it to take both polarities by simply changing the local frequency to 10750!! However this newest 437 I had to do two scans one for horrizontal then a second for just the vertical on 91 or the stb would reboot before it loaded!! I guess it was overloaded with TPs????? |
Silver Member Username: Leafs_fan_4_evajammin wit Jamario MO..., Post Number: 248 Registered: Jun-06 | Fta Tester, I'm still missing some of the channels on 91. Any suggestions? |
