Need factory bin for pansat 2500
Username: Irky
Post Number: 18
please ..... i need new factory bin for pasnsat 2500a
thank you...
Username: Ke5aqn
Post Number: 956
Support for any new bin's for the 2500's is over. At Future the home forum for pansat it say's NEVER in the files section. I just spent 10 min looking for the factory bin for you with no luck..r ...one sugestion in the forum to a user with same question was to trash it and get a newer receiver...a good idea
vewsat plat light is $130 shipped all over the nett cheap for all it can receive for ya...
Username: Irky
Post Number: 19
how i can updeate my 2500 in 2700 pansat
Username: Ke5aqn
Post Number: 958
you cant.....the only way I ever found that was that comment to throw it away and buy a newer receiver..
sorry so long to respond I had to reload this laptop it was running stupid..
Username: Crazy_greek
Post Number: 1347
irky
You can download the factory bin
for the Pansat 2500a here, the home of Pansat.
http://www.pansatusa.com/download.htm
Username: Sitsat
Post Number: 136
Yes irky, you can convert your pansat 2500A to a clone 2700a.
There are numerous threads here with detail instructions on how to successfully convert a pansat 2500A to a 2700A. Please go through the posts and read.
Username: Nydas
Post Number: 5303
Except for the future-fta site, the Pansat 2500 factory BIN is available at a lot of sites.
However, it would be prudent at this stage to convert to Pansat 2700.
